[ allegro16.3][4层]MI无线模块(MW300)(88MW302+W25Q32FVZPIG)原理图和pcb文件
# z. J# D r2 {- Q文件描述: # j6 g% G. g' |- H+ W E: B
1. 作品用途:MI无线模块(MW300) 2. 软件版本:allegro16.3 3. 层数:4层 4. 用到的主要芯片:88MW302+W25Q32FVZPIG 5. PCB尺寸:28.981*15.646 mm 0 m% c6 A5 L7 O6 e
作品截图如下: ( F1 h/ T! Q2 B% M0 z$ |
顶层截图: B( K3 ]4 _+ i% l
底层截图:
- G' z7 l% x" E+ I
$ Z p G' x' S* `* Q全层截图:
$ z6 F- h5 `" n5 ?: p L9 S0 f
& S, o Z- W5 Z. ?BOM: Bill of Material Report (Condensed) | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | C0402S0 | CAP_NP_C0402S0_10UF 6.3V X5R | 10uF 6.3V X5R | IC | 3 | C1; C2; C11 | C0402S0 | CAP_NP_C0402S0_1.0UF | 1.0uF | IC | 2 | C3; C4 | C0402S0 | CAP_NP_C0402S0_0.01UF | 0.01uF | IC | 7 | C8; C21; C22; C23; C24; C25; C26 | C0402S0 | CAP_NP_C0402S0_0.1UF | 0.1uF | IC | 11 | C9; C10; C12; C13; C14; C15; C16; C17; C27; C28; C29 | C0402S0 | CAP_NP_C0402S0_2.2UF | 2.2uF | IC | 3 | C18; C19; C20 | C0402S0 | CAP_NP_C0402S0_10PF RF | 10pF RF | IC | 3 | C34; C35; C36 | C0402S0 | CAP_NP_C0402S0_NC_10PF RF | NC_10pF RF | IC | 1 | C37 | CN-8030-6S0 | MM8430_1_CN-8030-6S0_MM8030-261 | MM8030-2610 | IC | 1 | J1006 | IC_WBOND_WSON8_ZP | IC_WBOND_SPI_FLASH_DQIO_WSON8_0 | W25Q32FVZPIG | IC | 1 | U3 | L0402 | INDUCTOR_L0402_22NH | 22nH | IC | 1 | L3 | L0805 | INDUCTOR_L0805_2.2UH+/- 20% | 2.2uH+/- 20% | IC | 1 | L1 | MODULE_50_SQ_21X37-5 | MODULE_10_MODULE_50_SQ_21X37-5_ | MODULE | IC | 1 | U6 | MRVL_QFN88LP40_10X10_NXU | 88MW302_QFN88L_0_MRVL_QFN88LP40 | 88MW302QFN88 | IC | 1 | U1 | R0402S0 | RES_R0402S0_6.04K 1% | 6.04k 1% | IC | 1 | R1 | R0402S0 | RES_R0402S0_51K | 51K | IC | 4 | R4; R5; R6; R7 | RF_TDK_BPF_LGA3_1_6X0_8 | RF_DEA162450BT-1298A1_RF_TDK_BP | DEA162450BT-1298A1 | IC | 1 | FL1 | SDIO_ANT_SINGLE_INVERT_SOUTH | ON-BOARD ANT_0_SDIO_ANT_SINGLE_ | PCB Micro-strip Patch Antenna | IC | 1 | ANT2 | XTAL_TXC_SMD_1-6X1-2MM | XTAL_TXC_SMD_0.2MM_XTAL_TXC_SMD | 38.4MHz +/-10ppm | IC | 1 | Y2 |
& [! b' a. N( z5 |附件: 原理图和pcb文件如下: " ?$ _* }1 Z: w
