最近在做有关FPGA的仿真,在ISE中约束管脚和电平后,生成IBIS模型,可是仿真时出问题,拓扑结构能够提取出来,但是仿真时提示"cycle.msm does not exist"tlsim里面内容如下:
0 {' ], t4 S6 Y**** Tlsim command line ****
( T* i" R" ^! `7 _, {+ U1 a8 q tlsim -e 2.000000e+001 -r 0.200000 -o waveforms.sim -dl delay.dl -dst distortion.dst -log tlsim.log -ocycle cycle.msm main.spc$ L) A6 @# Y: M) J: x2 g8 R
5 ^' `- D/ }! E) v- C) ]
# V7 L0 W, c& w: ]+ B* B Failed To Compile SubCircuit xUHF==RECEIVER_icn_ckt 1 UHF==RECEIVER_icn_ckt
) V: Z, } E4 s% }+ n7 D# q* K* M; y) g+ |% }
3 j8 O0 _4 z4 x
*********************************************************. ]; Y" a! G {+ n/ g* f8 h: Q5 R8 s
% }1 v$ ]+ H5 Y4 u! r/ Y F*********************************************************. E- E. x( i) u* p% t% L
ABORT:The Circuit is Empty * q0 o0 n: p+ B) l& L. F& |
, F' m. }* D) a( t+ `% w2 z* K2 j
- V8 d# ^9 J' r* @; x/ a6 v
$ Q3 W! t% a; v- b2 L8 ~: u0 {, U在audit所仿真的网络时,有错误:
8 s- e" {* k* o, x2 g* g p: JERROR >> Pin(s) with conflict between PINUSE property
8 ?1 p& m" r0 f9 B B and signal_model parameter in IbisDevice pin map :
' u" l- {- B7 p. T% y! D Pin Component Pin Use Signal Model Design& n0 f- s9 c' B
i8 C! H9 ?! b/ c! Y- n/ O B4 U11 NC SPARTAN6_PINASSIGN_LVDS_33_TB_25 UHF==RECEIVER7 X1 w8 {$ D* p, e; t2 R @5 q
& E/ V& B% V5 X; M& O. _; G
2 M4 j' Z' k& W) Q, R. O; d请各位大侠帮忙!!!多谢!!! Z. s9 }6 U7 i/ d1 P
5 C2 d; G1 G. E' ~: @, | |
