楼主: partime
最新补丁来了,福利来了,high起来!SPB16.6.079!!!!
34#
发表于 2016-10-21 09:07 | 只看该作者
太快了呀, 感谢!5 m" J* b" a# ^" C
38#
发表于 2016-10-21 09:55 | 只看该作者
dddddddddddddddddddddd; Y) ^+ Y4 s+ h# A1 @, q% Z
    郁闷
    2023-9-28 15:01
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    40#
    发表于 2016-10-21 10:25 | 只看该作者
    DATE: 09-23-2016   HOTFIX VERSION: 078+ W4 h  X1 v  L6 |
    9 U9 y1 m. U* U9 g2 J7 PCCRID   PRODUCT        PRODUCTLEVEL2   TITLE
    ' r' ?  F$ I# g, a5 i/ o===================================================================================================================================
    ' C, q5 R, ~' k7 r" e5 {$ A6 P& O1607016 ADW            TDA              TDO crashes after LRM update during check-in hierarchy
    ) g4 A' x( U! m! |1607954 ALLEGRO_EDITOR SHAPE            Dynamic Shape not updating correctly
    8 A3 [9 K3 D5 w- g6 b1607956 ALLEGRO_EDITOR OTHER            Unable to generate the model index file from the command line using the mkdeviceindex utility8 j  |! U: k- |2 U+ K6 [9 M& W
    1611446 ALLEGRO_EDITOR SHAPE            Inconsistent break in shape when creating voids in a design in  16.6 Hotfix 698 |* u9 [: L# C! d
    1618173 ADW            SRM              SRM Does not automatically run when a brd is opened from EDM Flow Manager 17.2 ISR3$ T% h; j) r' @# G) L/ S
    1618832 ADW            SRM              ADW SRM marks parts as updated even when they are not updated9 k% \6 G) ~, j6 w
    1623113 ASI_SI         GUI              Aggressor waveforms are not displayed in the Waveform viewer after running a crosstalk simulation3 R" Z: Y7 q+ k  a$ p/ C
    1623231 CONCEPT_HDL    CORE             Unable to make the Attributes form part of the standard display in DE-HDL
    ( v2 W2 r8 }' z) {1625610 ALLEGRO_EDITOR SHAPE            Modifying a shape boundary leads to other shapes losing their voids. Z* X: z3 ?5 X" Z8 U
    1631792 SCM            OTHER            The NC net has re-attached itself to another net, RIGHT_LEFT_N, in the design! c" J! x3 R, B2 |
    1632223 ADW            LRM              Crash seen in CReviUtils::loadPPTOptions during check in hierarchy
    5 E; s7 p8 p$ C9 t5 a4 _1632504 CONCEPT_HDL    CORE             DE-HDL core dumps during Save Hierarchy on Linux! z; S1 F8 p! k; z1 ]
    1632844 F2B            DESIGNVARI       Part is simultaneously defined as Pref and DNI in Variant Editor with no error- w+ Z8 j4 C  l- C0 n' `3 v
    1633454 ADW            TDA              TDO crashes if DAO throws an exception
    , Q9 S5 ^2 _# \3 B2 `* G. }' K1633647 ALLEGRO_EDITOR MANUFACT         Variant issue: Create Assembly Drawing command is not creating filled shapes in the attached design
    郁闷
    2023-9-28 15:01
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    41#
    发表于 2016-10-21 10:26 | 只看该作者
    能给个更新目录吗
    2024-2-9 15:00
  • 签到天数: 191 天
    [LV.7]常住居民III
    43#
    发表于 2016-10-21 10:50 来自手机 | 只看该作者
    看看有哪些新功能    学习学习
    7 K1 Q" x: s! T  }& l; G
    GMT+8, 2025-9-16 05:15 , Processed in 0.125000 second(s), 18 queries , Gzip On.
