查看: 1137|回复: 0
[求助]请问如何用skill重播script?axlShell("replay xxx.scr")会有问题
    2022-5-6 15:29
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2017-7-11 18:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    在command窗口可以用replay xxx.scr重播
    skill可以用
    但用这个指令,经常会出现E-Can't found window;form.xxx这种问题
    比如我需要Export dxf,录制的scr如下
    scriptmode +c
    version 15.51
    setwindow pcb
    dxf out
    setwindow form.dxf_out
    FORM dxf_out dxffile top
    FORM dxf_out layercnvfile TOP_1
    FORM dxf_out edit
    setwindow form.dxfOutMapping
    FORM dxfOutMapping selectall YES
    FORM dxfOutMapping newlayer
    fillin "top"
    FORM dxfOutMapping map
    FORM dxfOutMapping done
    FORM dxf_out exportsymbols NO
    FORM dxf_out drillinfo NO
    FORM dxf_out nomultisegpoly NO
    FORM dxf_out monochrome YES
    FORM dxf_out execute
    FORM dxf_out close
    setwindow pcb
    反馈如下:
    Script version: 15.51
    E- Can't find window; form.dxf_out
    E- Command not found: FORM dxf_out dxffile top
    E- Command not found: FORM dxf_out layercnvfile TOP_1
    E- Command not found: FORM dxf_out edit
    E- Can't find window; form.dxfOutMapping
    E- Command not found: FORM dxfOutMapping selectall YES
    E- Command not found: FORM dxfOutMapping newlayer
    E- Command not found: fillin top
    E- Command not found: FORM dxfOutMapping map
    E- Command not found: FORM dxfOutMapping done
    E- Command not found: FORM dxf_out exportsymbols NO
    E- Command not found: FORM dxf_out drillinfo NO
    E- Command not found: FORM dxf_out nomultisegpoly NO
    E- Command not found: FORM dxf_out monochrome YES
    E- Command not found: FORM dxf_out execute
    E- Command not found: FORM dxf_out close
    用replay xxx.scr就不会有这个问题;用axlShell("replay xxx.scr")就出现了
    在注册功能 axlCmdRegister("cmd" 'cmd) 的时候需要加上?cmdType 'general
    即axlCmdRegister("cmd" 'cmd ?cmdType 'general)
    好像是没出现上面的问题了
    GMT+8, 2025-11-3 04:51 , Processed in 0.156250 second(s), 24 queries , Gzip On.
