返回列表 发新帖
楼主: pmp_mcu
allegro 求救
16#
发表于 2014-2-27 00:41 | 只看该作者
我也遇到相同问题
17#
发表于 2018-5-3 11:13 | 只看该作者
最后怎么解决的啊?
18#
发表于 2020-4-1 16:17 | 只看该作者
我今天是在改env的情况下出现了类似的情况。就是将个人的env从home路径下复制,拷贝到安装目录下的pcb text文件下。不知是误删了还是覆盖了pcb text文件下的这个文档(文档内容复制一部分在下面) 然后找同事要下pcb text文件下的原始文档放回原处,然后个人env放回home路径。最后终于PCB editor能打开了。(看到pcb重新能打开,久违的,能重新呼吸的感觉)希望这个能对大家有帮助。8 X- P( C. x, w
' p  c( o! x& g( A" S#
4 a/ ?8 {& j1 Q2 s( G5 ^) z# ALLEGRO GLOBAL Environment file
) p5 ~9 M- P5 z#
% K& d: D; c1 N' D# V9 H2 R/ H9 h# N* i, x% u& G; ?( j( `- \
# The following variables are set by the software if not preset by user:
9 _* h! \, O! h3 q/ X/ J#     CDS_SITE, ALLEGRO_SITE, TELENV, ALLEGRO_INSTALL_DIR,
; M& o5 m  {/ n. j2 x#     ALLEGRO_INSTALL_TOOLS, ALLEGRO_INSTALL_ROOT, ALLEGRO_TYPE,# |+ T  ^( I, s* }) W
#     __UNIX (if UNIX), _PROGRAM, HOME( g& ^. Z# S, r
1 L0 j6 w/ O! Q4 E% A/ M! M# You may set the Operating System variable:
3 j4 l2 B' A# E6 j#        ALLEGRO_PCBENV <alternative directory>
3 }, a5 |9 n9 }5 k: s; [# to overwrite the default of the user's pcbenv directory. This variable4 V& @" ]( A. I" f
# must be set at the OS level and has no effect if set in an Allegro env file.
- i+ \. A4 r. m& m7 s# The directory given must exist. If no directory is found the system will0 l( I" w* w- v
# fallback to its default location." q' C* }7 H  Y7 N+ h; _3 R7 M2 v
% X. I" n+ i) i  k. G" U7 b# The following variables are preset at startup, direct settings in env8 m( [  T; _2 Y  e" G0 v
# files will be overridden3 ]4 F% i" k5 l: I% `* [2 ?4 \
#        LOCALENV:  seeded based upon <HOME>/pcbenv (or if set ALLEGRO_PCBENV)
1 O- r7 b9 p- V. ]# @" }  k) Q- }8 Z#        LOCALPATH: seeded based upon . LOCALENV, ALLEGRO_SITE, GLOBALPATH! q+ e6 f5 m9 l" y
# Variable names are case insensitive
& }0 d0 E( ~) J0 {2 r* x+ T# r
8 f2 F% q) N: B  o8 L#--------------------------------------------------------------------
/ P8 B2 R, ~8 m- M" C9 _; r# System Variables
1 y% Q+ O, U3 j  ?1 U4 O: ]set GLOBAL = $ALLEGRO_INSTALL_DIR/text
) a6 N" u4 [6 N, H: ?8 t( ^
; `) _8 t. y, q+ h5 V# change from LIBPATH because it conflicts with IBM's shared library. O6 B7 X! d6 g  h; H2 O7 b3 Q6 L
# environment variable
& X: ^. m* ~0 C* [; A) N+ B6 \) a! Qset ALIBPATH = $ALLEGRO_INSTALL_DIR/pcb_lib4 d6 K! H# h# M! Y2 q
- @! L. v8 K# n7 o
set COMPLIBPATH = $ALLEGRO_INSTALL_DIR/allegrolib
$ h6 F, v% c3 U, z
& i9 @8 x! |3 n! y3 Xset GLOBALPATH = . $GLOBAL1 k9 Y6 ]4 P: P% }$ y2 J# v  A
9 g: f8 e& p+ I
# Allegro Data Services Variable
2 z# _5 m' k) y) y4 U6 mset ADSPATH = $GLOBALPATH
4 m- s5 T  V/ g  C" |
+ G4 n- m1 ^" k) k3 x. ?# Present for compatiblity with older versions of Allegro.; [' Y) O! O8 |" X& C1 \
ifnvar ALLEGRO_SITE "set ALLEGRO_SITE ."
' q# p( ~# V" L1 r! Zifnvar CDSPLAT "set CDSPLAT "
  x: F/ h( o" V$ o* pifnvar ALLEGRO_INSTALL_DLL "set ALLEGRO_INSTALL_DLL "8 {4 }5 I, ^6 Z& D) z3 _, Z
; ^/ v: E, q- U* }: Y0 q3 i& ]& C#--------------------------------------------------------------------1 O5 ^+ i" F' i! k1 ]1 p
# Configuration variables (Don't change)
; Z7 o1 b( t1 Q6 aset BMPPATH = . $ALLEGRO_SITE/icons $GLOBAL/icons
7 Z# s0 V/ O& \0 @; E+ ?......
; Z/ f8 ~# U. O  [4 Q( D! r7 T......3 i; Y5 M9 x& \/ d4 d4 h$ k; C
2 l# }( p/ a3 g* H6 Y) q
GMT+8, 2025-9-16 21:33 , Processed in 0.125000 second(s), 19 queries , Gzip On.
