TA的每日心情 | 擦汗 2021-7-6 15:07 |
签到天数: 3 天 [LV.2]偶尔看看I
本帖最后由 Snowy 于 2010-11-18 12:01 编辑 * F7 K" `' |$ \3 A5 E9 _
; j& e% p5 j# Q' O5 D6 ?
这里给大家一个方法,可以用于整板换线宽的另一个方法:0 n: f3 c3 T3 N: q8 e4 K
步骤如下:
& i+ e; i( o) V5 U) i8 v& w1 .File->export->sub-drawing 或者在命令栏里输入clpcopy 回车.8 \. u7 m2 @+ ]! k: M. u
2 .在find里只选择cline
o1 `8 Y0 s1 d {3 .将板上的线(可以不管是否是你所想要换的线宽)都框进来.(也可以用temp group多次选择,选好了要记得complete哈)) ^! v8 ^3 @4 [ v% y, V
4 .在命令栏里输入x 0 0 然后会让你输入文件名,例如命名standard
) C$ a% a; |9 J5 .在所存的目录下的standard.clp 用编辑器打开" ]3 ~, l+ ~) w2 `0 z0 P9 t7 C
例如您将看到如下文:(这里是以16.2的为例)1 U+ a0 p. Z/ ~& t
; Allegro sub-drawing file# d1 V& i) K" }. b
; Created by Allegro PCB Design GXL; version= 16.2 s007
) L3 @& Q% o5 y; W# i5 q0 F8 a/ y0 W7 e8 a2 u/ ]& ^) J R6 j
_clp_lay_drw = axlDesignType(nil)
" O3 |1 B/ H7 @+ I1 o_clp_sym = nil
" y% A& C# ?0 x# h_clp_pbuf = nil6 n' T( O# R( `3 Z9 Z
_clp_cinfo = make_clp_coord_info()
: y& s2 `; B0 n- f( N% ^1 U_clp_cinfo->f_rotation = 0.0
; n: h7 d, o8 q9 e a% U_clp_cinfo->l_origin = '(0.0 0.0)7 \8 ]- ]3 m1 c0 v- D
_clp_text_orient = make_axlTextOrientation()
: X- L2 V N) j, B, U0 H* g0 a_clp_pin_text = make_axlPinText()
! O. Z9 m. g% G_clp_cinfo->t_from_units = "mils"
; W5 r9 h- n* i_clp_cinfo->t_to_units = car(axlDBGetDesignUnits())
* L( o8 g+ d$ {6 y: R& G# C_clp_cinfo->preserve_shape_net = nil' P! _* H! T3 ]
_clp_cinfo->preserve_via_net = nil
5 c z, v/ h/ }_clp_cinfo->snapToObject = nil% a9 p) ~- a; h5 c/ V
_clp_group_info = make_clp_group_info()7 H' W0 _# T& c: [* ^8 U
_clp_cinfo->group_info = _clp_group_info+ ^) k/ X, m5 i; O; @
_clp_accuracy =24 J( \2 G- g$ t) t
_clpCheckAccuracy(_clp_accuracy _clp_cinfo->t_from_units _clp_cinfo->t_to_units)
- C+ n' g2 g @# S* C(putprop _clp_cinfo (list (_clpAdjustPt -154.77:-5330 _clp_cinfo)
! |+ @; t6 `9 x4 e: R+ R (_clpAdjustPt 3793:-197.25 _clp_cinfo)) 'l_extents)6 i0 a8 o( c9 ?
(putprop _clp_cinfo (_clpAdjustPt '(0.0 0.0) _clp_cinfo) 'l_zeropt)! {% s9 j0 j# N- u' L h, K# i8 f
(unless (_clpSelectRotOrg _clp_cinfo)4 _% C8 R% g- R! D2 A
(error "CANCEL"))
* @0 H; h* O- u_clp_clip_prop_value = _clpGetClipPropValue(). O1 K: F3 l( t) S- P1 c
, o, y- A) U3 b- M" L3 R K0 M8 f_clp_path = (_clpPathStart (list (_clpAdjustPt 3065:-2505 _clp_cinfo))
. E \: X+ k9 r (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units _clp_cinfo->t_to_units))$ X, N! z, J. C3 j
_clp_path = (_clpPathLine _clp_path (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units7 d( ~* H& R$ b7 v' p0 D' e
_clp_cinfo->t_to_units) (_clpAdjustPt 3065:-2535 _clp_cinfo))( b3 D" K. @/ }7 G7 z
_clp_path = (_clpPathLine _clp_path (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units# p! \6 v+ z; ^# k$ u7 S6 d! J6 j
_clp_cinfo->t_to_units) (_clpAdjustPt 3050:-2550 _clp_cinfo))
+ U5 d Y& v0 |8 P) E. b3 y_clpPl = list(
4 u' w; T. A% x: R* R* H0 l list("CLIP_DRAWING" _clp_clip_prop_value))
. h! ~7 N9 W5 Y_clp_dbid = _clpDBCreatePath(_clp_path "ETCH/BOTTOM" nil _clp_sym _clpPl)
/ ~6 a0 Z0 K8 ^$ p) c" ~2 A_clpPl = nil
* Z2 N; T) ]' v# e- E) F+ J& I( r: K) l# `7 g1 @
_clp_path = (_clpPathStart (list (_clpAdjustPt 3041.03:-2489.92 _clp_cinfo))
5 \7 p& Q: b! z6 W' {8 p- l (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units _clp_cinfo->t_to_units))( u# h7 h$ O4 ]0 e6 X# R- x! w+ v& ^" o
_clp_path = (_clpPathLine _clp_path (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units; c0 H' M1 @6 p0 O' U) X# F
_clp_cinfo->t_to_units) (_clpAdjustPt 3041.03:-2541.03 _clp_cinfo))
; r. x/ o- d; {7 \, r_clp_path = (_clpPathLine _clp_path (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units' k. y4 g+ `( y3 b* U
_clp_cinfo->t_to_units) (_clpAdjustPt 3050:-2550 _clp_cinfo)); i1 t$ m3 _2 n& s c# Z. x) C( Z
_clpPl = list(
9 f- [& v6 N7 S8 Q# v' d '(CLIP_DRAWING "CLIP_42")) _; j8 k# l8 ~/ V: D' o* Y
8 N5 O, H6 L- Y; L# D9 S% \$ E_clp_dbid = _clpDBCreatePath(_clp_path "ETCH/TOP" nil _clp_sym _clpPl)
0 B' B& ?7 ?# j. w9 {_clpPl = nil
+ x, ? ?1 a% i) O& I+ N* r! p. Z- ]( k
_clp_path = (_clpPathStart (list (_clpAdjustPt 2883.55:-2489.92 _clp_cinfo))
8 k# v1 j; `( W0 k7 x) g& W (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units _clp_cinfo->t_to_units))
4 u9 \1 K2 m9 p% g! f! P0 O7 a_clp_path = (_clpPathLine _clp_path (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units
6 @0 t1 r! o* K& y& U' @- v _clp_cinfo->t_to_units) (_clpAdjustPt 2883.55:-2541.45 _clp_cinfo))
; {! k) M* C! m. ]2 D_clp_path = (_clpPathLine _clp_path (_clpMKSConvert 5.500000 _clp_cinfo->t_from_units" D% G1 z) R S) N4 i9 n
_clp_cinfo->t_to_units) (_clpAdjustPt 2875:-2550 _clp_cinfo))3 Q' s. {& v* d* l! v/ T3 Y) e
_clpPl = list(
) e" p% d& H7 c% [ list("CLIP_DRAWING" _clp_clip_prop_value))' V4 p4 L* x3 a( K# j
_clp_dbid = _clpDBCreatePath(_clp_path "ETCH/TOP" nil _clp_sym _clpPl)9 |+ F" ]& i9 ~! B& b
_clpPl = nil; I& E+ |2 P3 q) w
# v* x- `9 e5 e8 O& L- c9 l7 U0 V: {2 \
6 .关键的地方来了:在编辑器里去找你所想要换的线宽那个值,比如想要把5.5换成6.5# ^% K7 c! E4 V8 e7 y; l
您就可以把这个值找出来"clpMKSConvert 5.500000"然后全部替换成"clpMKSConvert 6.500000"
- s! e1 H5 X. m' d0 U7 .保存.
# K# ^! D1 \3 P% s. L8 .把刚刚的那些导出去的线删掉.0 e k2 D7 `& T
9 .把保存后的standard.clp再导回来.即可.# g c) J$ C9 @8 C5 n5 M
其它版本的这串字符有可能不一样,但是方法是一样的." B8 K! H" d4 a( }$ C
对于你如果想换一小段的,这个方法是不行的.它会把一样的线宽给全换了,当然这种情况不多的话还是直接用change seges会方便很多的.
/ n4 \- d' w/ H3 N e2 m8 | E3 @
: p1 A) k; {8 o7 b( ~% a: g7 H# Z, M! A" ]# p/ i
