查看: 543|回复: 4
[Allegro16.6][20层]altera(EP3SL150F1152+SAMTEC_QSHDP120CUSTOM+网口)pcb文件
发表于 2019-12-16 16:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
' y# w5 c, `) X4 j( U* K8 w[allegro16.6][20层]altera(EP3SL150F1152+SAMTEC_QSHDP120CUSTOM+网口)pcb文件) b2 ]( u( ?0 `# x  \% w# Z; t
文件描述:
4 e  G! h7 @5 Y' N  G1 y
1. 软件版本:Allegro16.6
2. 层数:20层# \- ~9 x0 h5 B& R' R" {4 S
3. 用到的主要芯片:EP3SL150F1152+SAMTEC_QSHDP120CUSTOM+网口
4. PCB尺寸:8*6.75  mm
5 a& {4 Q3 ~: L* q: d4 S
作品截图如下:
7 S1 f: D/ M) h, S0 m
顶层截图:
, J* E/ Y. c5 j9 j" |
底层截图:
  w5 P" V$ X& x& z6 r: I( @4 E2 ]6 z
+ n& K8 {" v- n) m! j* [' E0 A
5 ^' O* C, E- |7 G1 g5 J
全层截图:
1 t1 N" [/ J2 i
4 S5 [/ b" h: F
叠层信息:
6 G$ l$ L# p+ U
8 x4 r- t' |8 Z  ^  y
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP_0402_0.1UF0.1uFDISCRETE112C1;  C2;  C11;  C129;  C130;  C132;  C133;  C134;  C135;  C137;  C138;  C139;  C140;  C143;  C144;  C145;  C146;  C147;  C150;  C151;  C152;  C153;  C154;  C155;  C157;  C158;  C159;  C160;  C161;  C162;  C163;  C164;  C165;  C171;  C174;  C176;  C179;  C182;  C186;  C187;  C188;  C194;  C195;  C196;  C197;  C199;  C202;  C206;  C207;  C209;  C210;  C217;  C218;  C219;  C223;  C226;  C229;  C231;  C232;  C233;  C235;  C236;  C238;  C239;  C240;  C247;  C249;  C254;  C255;  C256;  C257;  C258;  C261;  C265;  C267;  C268;  C276;  C277;  C282;  C292;  C293;  C294;  C295;  C296;  C299;  C300;  C301;  C303;  C307;  C310;  C311;  C312;  C313;  C314;  C315;  C316;  C317;  C370;  C372;  C373;  C375;  C376;  C377;  C381;  C384;  C385;  C387;  C388;  C390;  C392;  C393;  C402
402CAP_0402_1UF1uFDISCRETE19C6;  C7;  C8;  C9;  C10;  C44;  C61;  C67;  C82;  C269;  C273;  C283;  C284;  C285;  C286;  C287;  C288;  C291;  C302
402CAP_0402_0.01UF0.01uFDISCRETE28C15;  C113;  C115;  C117;  C128;  C131;  C136;  C175;  C181;  C184;  C185;  C201;  C225;  C228;  C230;  C234;  C237;  C264;  C272;  C274;  C278;  C279;  C337;  C338;  C374;  C380;  C386;  C391
402CAP_0402_7.0PF7.0pFIC3C87;  C88;  C89
402CAP_0402_DNIDNIIC2C93;  C213
402CAP_0402_1000PF1000pFDISCRETE4C106;  C109;  C110;  C111
402CAP_0402_1NF1nFIC1C108
402CAP_0402_47NF47nFDISCRETE3C112;  C114;  C116
402CAP_0402_12PF12pFIC2C142;  C170
402CAP_NP_0402_0.1UF0.1uFIC5C148;  C156;  C166;  C167;  C383
402CAP_0402_33NF33nFDISCRETE1C172
402CAP_0402_4.7NF4.7nFDISCRETE10C177;  C178;  C180;  C211;  C215;  C222;  C227;  C266;  C379;  C389
402CAP_0402_100PF100pFDISCRETE4C200;  C403;  C404;  C405
402CAPACITOR_NP_1_0402_0.1UF0.1uFIC2C214;  C216
402CAP_0402_33PF33pFIC28C344;  C345;  C346;  C347;  C348;  C349;  C350;  C351;  C352;  C353;  C354;  C355;  C356;  C357;  C358;  C359;  C360;  C361;  C362;  C363;  C364;  C365;  C366;  C367;  C368;  C369;  C371;  C378
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1IC9L2;  L4;  L5;  L6;  L7;  L9;  L11;  L16;  L17
402BEAD_FERRITE_SM_0402_DNIDNIIC4L3;  L10;  L12;  L15
402RESISTOR_0402_00DISCRETE5R1;  R7;  R74;  R146;  R160
402RESISTOR_0402_DNIDNIIC11R2;  R8;  R18;  R19;  R20;  R55;  R91;  R137;  R139;  R140;  R142
402RESISTOR_0402_10.0K10.0KDISCRETE35R3;  R4;  R9;  R45;  R66;  R69;  R83;  R84;  R85;  R86;  R87;  R88;  R99;  R112;  R113;  R114;  R115;  R122;  R132;  R134;  R154;  R159;  R162;  R164;  R165;  R184;  R185;  R188;  R189;  R190;  R191;  R193;  R223;  R224;  R245
402RESISTOR_0402_20.0K20.0KIC3R5;  R6;  R72
402RESISTOR_0402_4.7K4.7KDISCRETE15R10;  R11;  R13;  R14;  R25;  R32;  R36;  R37;  R39;  R40;  R44;  R138;  R161;  R201;  R204
402RESISTOR_0402_22K22KIC1R12
402RESISTOR_0402_100, 1%100, 1%DISCRETE6R15;  R141;  R153;  R206;  R221;  R243
402RESISTOR_0402_2727IC3R16;  R17;  R89
402RESISTOR_0402_1.00K1.00kDISCRETE24R21;  R30;  R33;  R35;  R42;  R71;  R90;  R93;  R94;  R95;  R96;  R126;  R136;  R148;  R171;  R172;  R174;  R176;  R177;  R202;  R229;  R230;  R239;  R240
402RESISTOR_0402_1.30K1.30KIC1R22
402RESISTOR_0402_3.57K3.57KIC1R23
402RESISTOR_0402_100K100KDISCRETE8R24;  R31;  R38;  R43;  R65;  R77;  R79;  R81
402RESISTOR_7_0402_249249IC1R27
402RESISTOR_7_0402_301301IC1R28
402RESISTOR_0402_1.78K1.78KIC1R29
402RESISTOR_0402_5.23K5.23KIC2R34;  R41
402RESISTOR_0402_220220DISCRETE24R46;  R47;  R48;  R49;  R50;  R51;  R52;  R53;  R54;  R56;  R57;  R58;  R59;  R60;  R61;  R62;  R63;  R64;  R167;  R170;  R175;  R179;  R212;  R213
402RESISTOR_0402_6.81K6.81KIC1R67
402RESISTOR_0402_2.2K2.2KDISCRETE5R68;  R100;  R111;  R120;  R133
402RESISTOR_0402_3.24K3.24KIC1R70
402RESISTOR_0402_4.99K4.99KDISCRETE2R73;  R200
402RESISTOR_0402_13.3K13.3KDISCRETE1R75
402RESISTOR_0402_30.1K30.1KDISCRETE1R76
402RESISTOR_0402_787K787KDISCRETE3R78;  R80;  R82
402RESISTOR_0402_56.256.2DISCRETE18R92;  R104;  R110;  R187;  R199;  R203;  R225;  R231;  R232;  R233;  R234;  R235;  R236;  R237;  R238;  R241;  R242;  R244
402RESISTOR_0402_10K10KDISCRETE15R97;  R101;  R102;  R103;  R105;  R106;  R107;  R116;  R117;  R118;  R119;  R123;  R124;  R125;  R128
402RES_SMD_0_0402_10.0K10.0KIC3R108;  R109;  R144
402RESISTOR_0402_470470IC1R121
402RESISTOR_0402_1.5K1.5KIC1R127
402R_0402_56.256.2IC6R129;  R130;  R145;  R147;  R150;  R151
402RESISTOR_0402_80.6K80.6KIC1R131
402RESISTOR_7_0402_10.0K10.0KIC3R143;  R149;  R152
402RESISTOR_0402_49.949.9DISCRETE21R155;  R156;  R157;  R158;  R168;  R169;  R180;  R181;  R182;  R183;  R192;  R194;  R195;  R197;  R198;  R205;  R207;  R208;  R209;  R210;  R211
402R_0402_10.0K10.0KIC2R219;  R220
402RESISTOR_0402_71.5K71.5KIC2R226;  R227
603CAP_0603_1.0UF1.0uFDISCRETE4C3;  C4;  C192;  C245
603CAP_0603_0.22UF0.22uFIC2C5;  C104
603CAP_0603_36PF36pFIC2C141;  C169
603CAP_0603_DNIDNIIC2C190;  C191
603CAP_0603_1UF1uFDISCRETE3C259;  C262;  C395
805CAP_0805_10UF10uFDISCRETE40C12;  C27;  C36;  C37;  C50;  C51;  C53;  C56;  C57;  C58;  C76;  C77;  C81;  C168;  C183;  C193;  C198;  C208;  C212;  C220;  C224;  C241;  C246;  C248;  C252;  C253;  C260;  C263;  C270;  C289;  C340;  C341;  C342;  C394;  C396;  C397;  C398;  C399;  C400;  C401
805CAP_0805_4.7UF4.7uFDISCRETE7C18;  C91;  C92;  C101;  C127;  C173;  C271
805CAP_0805_1.0UF1.0uFIC1C204
1206CAP_1206_100UF100uFDISCRETE6C94;  C95;  C96;  C97;  C98;  C99
1210CAP_1210_10UF10uFDISCRETE14C100;  C105;  C119;  C120;  C122;  C123;  C125;  C126;  C189;  C203;  C205;  C221;  C343;  C382
2512RESISTOR_2512_100100IC1R98
3216CAP_SMD_POL_3216_10UF10uFDISCRETE1C13
6032PPCAP_6032P_100UF100ufIC21C14;  C19;  C22;  C23;  C24;  C25;  C35;  C40;  C43;  C45;  C64;  C65;  C68;  C72;  C73;  C74;  C75;  C83;  C84;  C85;  C86
6032PCAP_SMD_POL_6032P_10UF10uFDISCRETE1C149
7260PCAP_7260_100UF100uFIC1C90
7343PCAP_SMD_POL_7343P_470UF470uFDISCRETE4C78;  C102;  C103;  C107
BB165ACY7C1313V18_0_BB165A_CY7C1263V1CY7C1263V18-375BZXCIC1U15
BCC9688E1111_BCC96_88E111188E1111IC1U25
CAP_PACK_4_1206CAP_ARRAY_0_CAP_PACK_4_1206_0.10.1uf x 4DISCRETE16CN1;  CN2;  CN3;  CN4;  CN5;  CN6;  CN7;  CN8;  CN9;  CN10;  CN11;  CN12;  CN13;  CN14;  CN15;  CN16
CAP_SMD_8MMPCAP_CAP_SMD_8MM_150U150uIC3C118;  C121;  C124
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051IO1J23
DDR2_60_SPECMT47H32M8BP_DDR2_60_SPEC_MT47H3MT47H32M8BPIC2U17;  U20
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026IC4U21;  U23;  U24;  U26
DIMM240DDRII_DIMM_DIMM240_DDR2_DIMMDDR2_DIMMIC1J19
DIPSWITCH16SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8IC2SW2;  SW5
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1IC1SW1
DO-214AB_RECTRONDIODE_DO-214AB_RECTRON_FM540FM540IC1D28
EG2201ASW SLIDE-DPDT_EG2201A_EG2201AEG2201AIC1SW4
F54K1B3216B2E_F54_K1B3216B2EK1B3216B2EIC2U4;  U10
F64_10X13PC28FXXXP30B85_F64_10X13_PC48F4PC48F4400P0VB00IC1U9
F256EPM2210GF256_F256_(S1+S2),(S3+SEPM2210_F256FBGAIC1U5
F1152S3_F1152_HOST_SWAP_EPSL150F1152EP3SL150F1152IC1U22
FH12X_18S_0P5SHFPC_FFC_18PIN_FH12X_18S_0P5SH_DDNIIC1J24
FH12X_30S_0P5SHFPC_FFC_30PIN_FH12X_30S_0P5SH_FFPC_FFC_30PINIC1J4
HDR2X1_2MM1X2_HDR2X1_2MM_HDR2X1HDR2x1IC1J6
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2IC3J2;  J3;  J13
HDR2X1_100MILCON2_HDR2X1_100MIL_DNIDNIIC2J7;  J11
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7IC1J22
HDR3X1_100MILCON3_0_HDR3X1_100MIL_TSW-103-07TSW-103-07-L-SIC3J10;  J12;  J20
HDR3X2_100MILCON6A_HDR3X2_100MIL_TSW-103-07-TSW-103-07-L-DIC1J9
HDR4X1_100MIL1X4_HDR4X1_100MIL_HDR4X1HDR4X1IC1J1
IHLP2525INDUCTOR_IHLP2525_10UH10uHIC3L8;  L13;  L14
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1DISCRETE1L1
KEYSTONE_BT1_1060BATTERY_0_KEYSTONE_BT1_1060_BATBatteryIC1BT1
LGA118LTM4601_LGA118_LTM4601LTM4601IC3U32;  U33;  U34
LQFP-32FT245BL_LQFP-32_FT245BLFT245BLIC1U11
LQFP-48ADG726_0_LQFP-48_ADG725ADG725IC1U19
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDIC25D1;  D2;  D3;  D6;  D7;  D8;  D9;  D10;  D11;  D12;  D14;  D15;  D17;  D20;  D21;  D22;  D23;  D24;  D25;  D26;  D27;  D32;  D33;  D35;  D36
LUMEX_LED1206LED_LUMEX_LED1206_RED_LEDRed_LEDIC2D13;  D34
LUMEX_LED1206LED_LUMEX_LED1206_BLUE_LEDBlue_LedIC1D16
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021IC1J15
MSOP8LM4990MM_MSOP8_LM4990LM4990IC1U1
MSOP8LM95235_MSOP8_DNIDNIIC1U16
MSOP10LTC2402_MSOP10_LTC2402LTC2402IC1U18
PSOP-DGQ10TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQIC3U36;  U37;  U38
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchIC7S1;  S2;  S3;  S4;  S5;  S6;  S7
QFN56CY7C680_56QFN_QFN56_CY7C68013A-CY7C68013A-56LFXCIC1U12
QUAD_7SEGQUAD_7_SEG_DSPLY_7_QUAD_7SEG_QUQUAD_7SEG_M2212RIIC2U27;  U28
RAPC712CONN_JACK_PWR_RAPC712_RAPC712XRAPC712XIC1J21
RES_PACK_8RES_PACK_8_RES_PACK_8_10K10KDISCRETE2RN1;  RN2
RES_PACK_8RES_PACK_8_RES_PACK_8_5656DISCRETE15RN3;  RN4;  RN5;  RN6;  RN7;  RN8;  RN9;  RN10;  RN11;  RN12;  RN13;  RN14;  RN15;  RN16;  RN17
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EIO1J14
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01IO2J8;  J18
SM55-OSCOSC_ALT_SM55-OSC_125MHZ125MHzIC2Y1;  Y5
SM55-OSCOSC_ALT_SM55-OSC_24MHZ24MHzIC1Y4
SM55-OSCOSC_ALT_SM55-OSC_50MHZ50MHzIC1Y6
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1IO2J16;  J17
SMB403A_03ZENERDIODE_SMB403A_03_20V ZENER20V ZenerDISCRETE3D29;  D30;  D31
SMCZC2800E/SOT_SMC_B530C-13B530C-13IC1D18
SO8AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-BIC1U6
SO824XX128_SO8_QUSB2CP1QUSB2CP1IC1U7
SO8TPS271_SO8_DNIDNIIC1U13
SOD-123DIODE_SOD-123_1N6263-W1N6263-WIC2D4;  D5
SOD-123ZC2800E/SOT_SOD-123_MMSD914MMSD914IC1D19
SOD-123ZENERDIODE_SOD-123_40V SCHOTTKY40V SchottkyIC1D37
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NIC2Q1;  Q2
SOT23-5AD8531_SOT23-5_DNIDNIIC1U14
SOT23-5LT1761_SOT23-5_LT1761LT1761IC2U29;  U31
SOT23-5LT1931_SOT23-5_LT1931LT1931IC1U35
SOT23-DBVSN65220DBV_SOT23-DBV_SN65220DBVSN65220DBVIC1U8
SSOP16NTS3A5018_0_SSOP16N_TS3A5018TS3A5018IC2U2;  U3
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HCB1694HCB16WTIC1SW3
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HAB1694HAB16WTIC1SW6
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFIC10TP1;  TP2;  TP3;  TP4;  TP5;  TP6;  TP7;  TP8;  TP9;  TP10
TSSOP16-EPADLT1374_TSSOP16-EPAD_LT1374LT1374IC1U30
USB2_0-RAUSB_CON_USB2_0-RA_USB CONUSB CONIO1J5
WSL2010RESISTOR_WSL2010_.0090.009IC15R26;  R135;  R163;  R166;  R173;  R178;  R186;  R196;  R214;  R215;  R216;  R217;  R218;  R222;  R228
X2Y_0603CAP_X2Y_X2Y_0603_10NF10nFIC12C16;  C33;  C41;  C42;  C52;  C55;  C60;  C66;  C79;  C319;  C329;  C333
X2Y_0603CAP_X2Y_X2Y_0603_47NF47nFIC16C20;  C30;  C46;  C54;  C80;  C242;  C244;  C251;  C290;  C297;  C298;  C309;  C318;  C320;  C328;  C334
X2Y_0603CAP_X2Y_X2Y_0603_22NF22nFIC15C26;  C31;  C34;  C47;  C48;  C59;  C63;  C70;  C250;  C275;  C281;  C324;  C325;  C330;  C332
X2Y_0603CAP_X2Y_X2Y_0603_100NF100nFIC4C29;  C71;  C321;  C339
X2Y_0603CAP_X2Y_X2Y_0603_4.7NF4.7nFIC6C32;  C38;  C39;  C322;  C323;  C331
X2Y_0805CAP_X2Y_X2Y_0805_180NF180nFIC7C243;  C280;  C305;  C308;  C326;  C335;  C336
X2Y_1206CAP_X2Y_X2Y_1206_220NF220nFIC5C17;  C21;  C62;  C304;  C306
X2Y_1206CAP_X2Y_X2Y_1206_470NF470nFIC1C327
X2Y_1210CAP_X2Y_X2Y_1210_1UF1uFIC3C28;  C49;  C69
XTAL_HC49CRYSTAL_XTAL_HC49_24.000 MHZ24.000 MHZDISCRETE1Y2
XTAL_HC49CRYSTAL_XTAL_HC49_6.000 MHZ6.000 MHZDISCRETE1Y3
XTAL_PACK_DXTAL_XTAL_PACK_D_25MHZ25MHzIC1X1
3 s7 E( L+ O: y8 \9 f8 S- v3 s
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
+ O9 O/ z8 L0 v) t+ z" Y4 c  u5 d6 `( V
. A5 a# M" M+ @8 {! G  p. c. R
    2020-8-10 15:48
  • 签到天数: 104 天
    [LV.6]常住居民II
    发表于 2019-12-17 09:37 | 只看该作者
    看看
    GMT+8, 2025-7-19 03:44 , Processed in 0.140625 second(s), 27 queries , Gzip On.
