[ allegro16.3][4层]IMX122 高清Sensor板(IMX122LQJ-C+SN74CB3T3306+AP1513)pcb文件
/ ?: H' \4 o( b0 {文件描述: 9 L+ c" a) |( W- ^4 ~) h2 {: F
1. 作品用途:IMX122 高清Sensor板 2. 软件版本:allegro16.3 3. 层数:4层 4. 用到的主要芯片:IMX122LQJ-C+SN74CB3T3306+AP1513 5. PCB尺寸:38*38 mm
; R c* u2 r+ h/ r作品截图如下: 9 s7 \5 S1 }" f: l$ c
顶层截图: . B( r' @! S5 S7 s8 z$ d8 u: o `
底层截图:
9 J p/ }! c h# r2 g; Y2 P
; @0 m- i& k& ?9 F6 L9 D; j) |" J# Z- J8 S全层截图:
7 k# L- W) O6 D. B* L
* s; T+ Z& h6 r+ r+ d: ABOM: Bill of Material Report (Condensed) | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | C236D118 | TP_9_C236D118_MOUNTING_HOLE | MOUNTING_HOLE | IC | 1 | HK1 | C236D118 | TP_10_C236D118_MOUNTING_HOLE | MOUNTING_HOLE | IC | 1 | HK2 | C236D118 | TP_11_C236D118_MOUNTING_HOLE | MOUNTING_HOLE | IC | 1 | HK3 | C236D118 | TP_12_C236D118_MOUNTING_HOLE | MOUNTING_HOLE | IC | 1 | HK4 | C0402 | X5R,10U,6_0.3V,20%,0402_C0402_1 | 10uF | IC | 2 | C175; C371 | C0402 | X7R,0_0.1UF,16V,0402_C0402_0.1U | 0.1uF,16V | IC | 2 | C176; C370 | C0402 | X5R,1UF,6_0.3V,0402_C0402_1UF,6 | 1uF,6.3V | IC | 2 | C368; C614 | C0402 | X7R,1NF,50V,0402,10%_0_C0402_1N | 1nF,50V | IC | 1 | C617 | C0402 | X5R,2.2UF,6_3.3V,0603_C0402_1UF | 1uF,6.3V | IC | 1 | CK1 | C0402 | Y5V,0_3.1UF,16V,0402_C0402_0.1U | 0.1uF,16V | IC | 29 | CK2; CK3; CK5; CK7; CK9; CK11; CK13; CK15; CK17; CK19; CK21; CK23; CK25; CK27; CK29; CK31; CK33; CK35; CK37; CK39; CK41; CK44; CK45; CK46; CK62; CK67; CK83; CK88; CK89 | C0402 | X5R,2.2UF,6_4.3V,0603_C0402_1UF | 1uF,6.3V | IC | 21 | CK4; CK6; CK10; CK12; CK14; CK16; CK18; CK20; CK22; CK24; CK26; CK28; CK30; CK32; CK34; CK36; CK38; CK40; CK42; CK43; CK59 | C0402 | X5R,2.2UF,6_6.3V,0603_C0402_1UF | 1uF,6.3V | IC | 1 | CK8 | C0402 | Y5V,0_5.1UF,16V,0402_C0402_0.1U | 0.1uF | IC | 1 | CK50 | C0402 | Y5V,0_4.1UF,16V,0402_C0402_0.1U | 0.1uF | IC | 1 | CK52 | C0402 | Y5V,0_0.22UF,10V,0402_C0402_0.2 | 0.22uF,10V | IC | 1 | CK60 | C0402 | NPO,15PF,50V,0402_1_C0402_15PF, | 15pF,50V | IC | 1 | CK63 | C0603 | X5R,0_0.47UF,16V,0603_C0603_0.4 | 0.47uF,16V | IC | 1 | C367 | C0603 | X5R,10UF,6_6.3V,0805_C0603_10UF | 10uF | IC | 1 | CK49 | C0603 | X5R,10UF,6_4.3V,0805_C0603_10UF | 10uF | IC | 1 | CK51 | C0603 | X5R,10UF,6_3.3V,0805_C0603_10UF | 10uF | IC | 1 | CK61 | C0603 | X5R,2.2UF,6_5.3V,0603_C0603_2.2 | 2.2uF,6.3V | IC | 2 | CK64; CK66 | C0603 | X5R,2.2UF,6_4.3V,0603_C0603_XX2 | xx2.2uF,6.3V | IC | 1 | CK87 | C1210 | X7R,1UF,100V,1210_1_C1210_100UF | 100uF 6.3V | IC | 4 | CK47; CK55; CK56; CK58 | C1210 | X7R,1UF,100V,1210_1_C1210_470UF | 470uF 6.3V | IC | 3 | CK48; CK57; CK65 | CONDIP1X2_125 | WAFER,MALE,1X2X1.25MM,180D_COND | Wafer 1x2_125 | IC | 1 | J7 | CONDIP1X4_125 | WAFER,MALE,1X4X1.25MM,180D_COND | Wafer 1x4_125 | IC | 1 | J26 | CONDIP1X6_125 | WAFER,MALE,1X4X1_0.25MM,180D_CO | Wafer 1x6_125 | IC | 1 | J27 | CON_0_5MM_40P | SN74CB3T3306_1_CON_0_5MM_40P_CO | CON_0_5MM_40P | IC | 1 | J9 | L0402 | TMP_215121_L0402_GB100505V320TW | GB100505V320TW | IC | 2 | L20; L21 | L0603 | TMP_215057_L0603_0 OHM | 0 ohm | IC | 3 | L68; L69; L70 | L0603 | TMP_0_L0603_MLB-160808-0010P-N1 | MLB-160808-0010P-N1 | IC | 4 | LK1; LK2; LK6; LK7 | L0805 | TMP_1_L0805_MLB-201209-0300P-N2 | MLB-201209-0300P-N2 | IC | 1 | LK8 | R0402 | 220,5%,0402,1/16W_0_R0402_220 | 220 | IC | 2 | R274; R275 | R0402 | 120K,5%,0402,1/16W_0_R0402_120K | 120K | IC | 1 | R276 | R0402 | 120K,5%,0402,1/16W_0_R0402_10K | 10K | IC | 6 | R277; R278; R279; R280; R281; R282 | R0402 | 120K,5%,0402,1/16W_0_R0402_47K | 47K | IC | 1 | R283 | R0402 | 120K,5%,0402,1/16W_0_R0402_100K | 100K | IC | 1 | R284 | R0402 | 120K,5%,0402,1/16W_0_R0402_100R | 100R | IC | 1 | R285 | R0402 | 10K,5%,0402,1/16W_3_R0402_10K | 10K | IC | 1 | RK8 | R0402 | 30,5%,0402,1/16W_1_R0402_30 | 30 | IC | 1 | RK9 | R0402 | 10K,5%,0402,1/16W_4_R0402_XX10K | xx10K | IC | 1 | RK33 | R0402 | 0,5%,0402,1/16W_0_R0402_0 | 0 | IC | 1 | RK34 | R0603 | 2_0.2K,5%,0603,1/10W_R0603_2.2K | 2.2K | IC | 2 | RK1; RK2 | R0603 | 0,5%,0603,1/10W_0_R0603_0 | 0 | IC | 1 | RK35 | R0603 | 1K,5%,0603,1/10W_0_R0603_1K | 1K | IC | 2 | RK36; RK39 | R0603 | 15K,5%,0603,1/10W_0_R0603_18K | 18K | IC | 1 | RK37 | R0603 | 15K,5%,0603,1/10W_0_R0603_15K | 15K | IC | 1 | RK38 | SENSOR-IMX122LQJ-C | IMX122LQJ-C_SENSOR-IMX122LQJ-C_ | IMX122LQJ-C | IC | 1 | UK1 | SON8-2X2P0_5 | AP1513_SON8-2X2P0_5_AP1513 | AP1513 | IC | 1 | U33 | SOT23-5 | CAT7106_5_SOT23-5_FP6146-27S5G | FP6146-27S5G | IC | 1 | UK2 | SOT23-5 | CAT7106_5_SOT23-5_FP6146-18S5G | FP6146-18S5G | IC | 1 | UK3 | SOT23-5 | CAT7106_5_SOT23-5_FP6146-12S5G | FP6146-12S5G | IC | 1 | UK4 | SOT23-5 | CAT7106_5_SOT23-5_RT9193-33 | RT9193-33 | IC | 1 | UK5 | SOT23-6 | AP1511A_1_SOT23-6_FP5502 | FP5502 | IC | 1 | U11 | SOT-23 | 2N1069_SOT-23_NPN9013 | NPN9013 | IC | 1 | Q3 | SOT-23-3 | N DGS_0_SOT-23-3_AP2306N | AP2306N | IC | 2 | Q1; Q2 | TANT_A | TAN,22UF,6_1.3V,A CASE_TANT_A_2 | 22uF,6.3V | IC | 1 | CK84 | XTAL_X32 | OSC,27M,50PPM,SMD 5X3_0.2_XTAL_ | OSC,37.125M,1V8 | IC | 1 | XK1 |
附件: PCB文件如下: |
( J3 h, j) O- G4 t7 {) H; E |
