查看: 292|回复: 0
[allegro15.6][16层]ML605 FPGA开发板(6VLX240TFF1156+DDR3_SO-DIMM+网口+USB)p...
发表于 2019-12-20 15:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro15.6][16层]ML605  FPGA开发板(6VLX240TFF1156+DDR3_SO-DIMM+网口+USB)pcb文件
8 |5 N! P8 c( g: u3 ?
; e9 j1 r" `3 T7 a
文件描述:
& O! H  P! D& ]0 {
1. 作品用途:ML605  FPGA开发板
2. 软件版本:allegro15.6
3. 层数:16层
4. 用到的主要芯片:6VLX240TFF1156+DDR3_SO-DIMM+网口+USB
5. PCB尺寸:10.5*5.323 mm
( P% d% Z! v) u7 _3 \1 B
作品截图如下:
" o1 s- [3 L  [, e8 X" k( F
顶层截图:
/ v0 E; O9 u) i2 R5 M0 P9 @# R$ o& ?
底层截图:
* E9 ~9 v1 D, }
9 R9 z6 [# o. E( c! Q2 F- t7 e+ \; n
全层截图:
7 o# n, |. f3 q7 Z( C$ d
6 U9 o( [# p' ?: T
叠层阻抗信息:
0 C- M  b' \- G3 Z
/ y8 D+ t, M9 ^5 P/ K/ R
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
5MMX3_2MMECS-3525_5MMX3_2MM32.000MHZIC1U28
5X3_2MM12MHZ_5X3_2MM12_000MHZIC1X1
6VLX240TFF11566VLX240TFF11566VLX240TFF1156IC1U1
20-VQFNUCD7230RGWR_20-VQFNUCD7230RGWRIC2U35; U36
32K10K-400SMA_32K10K-40032K10K-400E3IC10J26; J27; J28; J29; J30; J31; J55; J56; J57; J58
4020_1UF_04020.1UFDISCRETE141C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C364; C365; C370; C371; C372; C373; C378; C379; C380; C381; C382; C383; C390; C391; C392; C393; C394; C395; C396; C397; C398; C399; C420; C422; C423; C424; C425; C426; C427
4020_01UF_04020.01UFIC30C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C172; C175; C178; C179; C180; C181; C182; C374; C375; C384; C385; C386; C387; C388; C389
4021UF_04021UFIC13C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C195; C198; C199
4020_22UF_04020.22UFIC25C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226
4020_068UF_04020.068UFIC5C250; C251; C253; C254; C411
4021000PF_04021000PFIC1C256
4024700PF_0402DNPIC1C314
402820PF_0402820PFIC7C315; C316; C318; C319; C327; C328; C409
4026800PF_04026800PFIC3C321; C322; C410
40211PF_040211PFIC2C330; C331
40222PF_040222PFIC12C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343
40233PF_040233PFIC5C344; C345; C346; C347; C348
402270PF_0402270PFIC2C349; C350
40233_2K_040233.2KIC1R2
40227_4_040227.4IC18R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R19; R20; R21
4024_7K_04024.7KIC76R22; R23; R24; R25; R26; R27; R28; R29; R30; R33; R34; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R53; R54; R55; R56; R58; R59; R60; R61; R66; R67; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R342; R343; R344; R345; R401; R402; R403; R404; R405; R406
402510_0402510IC7R51; R52; R57; R62; R63; R64; R65
402NS_0402DNPIC21R68; R122; R127; R128; R129; R130; R131; R132; R134; R135; R136; R137; R138; R139; R162; R163; R305; R347; R410; R411; R412
40236_5K_040236.5KIC1R99
40247_5_040247.5IC15R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114
4024_22K_04024.22KIC4R117; R119; R390; R397
4020_04020IC9R133; R304; R312; R413; R414; R415; R416; R417; R418
40210_040210IC1R140
40220_5K_040220.5KIC1R141
4021_80K_04021.80KIC1R142
4021_60K_04021.60KIC1R144
40215_040215IC4R148; R149; R150; R151
4022_43K_04022.43KIC6R152; R153; R154; R155; R156; R157
4026_81K_04026.81KIC2R158; R159
4022_15K_04022.15KIC1R160
4024_75K_04024.75KIC18R161; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R358; R359; R360; R361; R362; R363; R364
40249_9_040249.9IC14R164; R165; R166; R167; R168; R169; R348; R349; R350; R351; R354; R355; R356; R357
40251K_040251KIC2R172; R173
40227_4K_040227.4KIC3R174; R271; R272
40210_0_040210IC4R175; R176; R179; R180
40233_0_040233IC2R197; R198
4021K_04021KIC1R201
40249_9K_040249.9KIC2R203; R204
40275_0_040275IC3R205; R206; R207
402100_0402100DISCRETE28R213; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R235; R236; R237; R238; R239; R240; R408; R409
40233_040233IC1R214
402200_0402200IC2R241; R378
4022_0K_04022.0KIC8R242; R243; R244; R299; R300; R301; R379; R380
40210_0K_040210.0KIC30R245; R246; R247; R248; R249; R250; R251; R252; R254; R255; R256; R257; R258; R259; R260; R262; R263; R264; R265; R266; R267; R268; R269; R367; R368; R369; R381; R382; R383; R407
40210K_040210KIC18R273; R275; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R289; R290; R291
402140_0402140IC3R292; R293; R294
40220K_040220KIC4R295; R296; R297; R298
402100K_0402100KIC1R302
402100K_0402100KIC1R303
4021_00K_04021.00KIC20R306; R311; R317; R318; R322; R323; R324; R325; R330; R331; R370; R371; R372; R373; R374; R375; R376; R396; R399; R400
4022_21K_04022.21KIC2R320; R328
4021_3K_04021.3KIC1R329
402360_0402360IC1R332
402270_0402270IC1R333
402470_0402470IC1R334
4021_0M_04021.0MIC1R335
4024_99K_04024.99KIC1R336
402215_0402215IC2R337; R338
4021_21K_04021.21KIC3R339; R340; R341
402100_0402100DISCRETE1R366
402150_0402150IC6R384; R385; R386; R387; R388; R389
402787_0402787IC1R392
402330_0402330IC1R419
603100PF_0603100PFIC2C140; C141
6031UF_06031UFIC1C143
6030_1UF_06030.1UFIC12C173; C176; C304; C305; C306; C307; C308; C309; C310; C311; C312; C421
6034_7UF_06034.7UFIC9C200; C351; C352; C353; C354; C355; C356; C357; C358
6030_22UF_06030.22UFIC4C257; C258; C259; C260
6031000PF_06031000PFIC5C267; C268; C269; C270; C271
6032700PF_06032700PFIC2C325; C326
6031800PF_06031800PFIC1C329
6030_47UF_06030.47UFIC1C362
603FERRITE-220_0603FERRITE-220IC21F4; F5; F6; F7; F8; F9; F10; F12; F13; F14; F15; F18; F1009; F1029; F1030; F1032; F1033; F1111; F1112; F1113; F1114
6031_0_06031IC4R193; R194; R195; R196
6032_2_06032.2IC2R199; R200
60324K_060324KIC1R377
0603-A447X4_0603X447IC2RP2; RP3
0603_SHORT0603_SHORTIC11Z1; Z2; Z3; Z4; Z5; Z6; Z7; Z8; Z9; Z10; Z11
6121UF_06121UFIC1C313
8052_2UF_08052.2UFIC21C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139
80510UF_080510UFIC17C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C376; C377
80510UF_080510UFIC5C243; C244; C245; C246; C247
80522UF_080522UFIC6C261; C262; C263; C264; C265; C266
805NS_0805DNPIC1C320
805HZ0805E601R-10_0805HZ0805E601R-10IC2F2; F3
80582NH_080582NHIC6L1; L2; L3; L4; L5; L6
80510_080510IC1R202
0805-A40_1UF_08050.1UFIC15CP1; CP2; CP3; CP4; CP5; CP6; CP7; CP8; CP9; CP10; CP11; CP12; CP13; CP14; CP17
0805_A40_01UF_08050.01UFIC2CP15; CP16
12064_7UF_12064.7UFIC2C248; C249
120610UF_120610UFIC1C363
12061UF_12061UFIC4C414; C415; C416; C417
12061M_12061MIC1R1
121010UF_121010UFIC2C117; C118
121022UF_121022UFIC11C144; C145; C147; C148; C149; C150; C151; C152; C153; C154; C400
2512_SMTRES_CUR_SENSE_2512_SMT0.005RIC2R395; R398
3352W2K_POT-3352W0-2KIC1R270
3637_SMTRES_CUR_SENSE_3637_SMT0.005RIC2R208; R365
3637_SMTRES_CUR_SENSE_3637_SMT0.001RIC1R346
1108800SK_DIP8_4110880IC1X5
1367073-1SFP-1367073-1SFP_CONN_CASEIC1P4
ABLSXTAL-SMD_ABLS25.000MHZDISCRETE1X3
ASP_134486_01ASP_134486_01ASP_134486_01IC1J64
ASP_134603_01ASP_134603_01ASP_134603_01IC1J63
CAPAE4301UF_ELECT_B1UFIC2C412; C413
CAP_F330UF_5_3MMX5_3MM330UFIC6C277; C278; C280; C281; C282; C405
CONN_USB_BUSB_MINI_BIC3J20; J21; J22
CON_MOL_5569_6P39-30-1060_JACK_500X54039-30-1060IC1J60
CON_TYCO_350211350211-1_ATX_JACK_1000X375350211-1IC1J25
DCU_R-PDSO-G8SN74LVC2G08DCU_DCU_R-PDSO-G8SN74LVC2G08DCUIC3U12; U13; U86
DDR3_SO-DIMMDDR3_SO-DIMMIC1J1
DPAK5TL1963_DPAK5TL1963AKTTRIC1U8
DPAK_369_51MJD200_TO-252MJD200IC1Q1
EGP_R-PDSS-T12PTD08A020W_EGP_R-PDSS-T12PTD08A020WIC2U42; U43
EGS_R-PDSS-T12PTD08A010W_EGS_R-PDSS-T12PTD08A010WIC3U20; U21; U91
EXBE-1608RP4_7K_EXBE-16084.7KIC4RP4; RP5; RP7; RP8
FANHDR3FANHDR3IC2J33; J59
FBGA64XCF128X_FBGA64XCF128X-FTG64CIC1U27
FMC_15FMC_15DNPIC4J43; J44; J47; J48
HC-49220007224MHZIC1Y1
HDR-1X1CON1H-1X1IC5J15; J16; J51; J52; J53
HDR-1X2HRD_1X2H-1X2IC7J37; J38; J39; J40; J65; J68; J69
HDR-1X3HRD_1X3H-1X3IC6J17; J18; J19; J54; J66; J67
HDR-1X4HRD_1X4DNPIC2J6; J7
HDR-1X5HRD_1X5DNPIC1J36
HDR-2X3HDR_2X3H-2X3IC1J42
HDR_1X2HDR_1X2IC7J8; J9; J10; J11; J12; J13; J14
HDR_2X6H-2X6_HDR-6X2H-2X6IC1J35
HDR_2X7HEADER_7X2_LCDSSW-107-01-T-DIC1J41
HDR_BOX_2X5HDR-2X5-SHR_HDR-2X5-SHRHDR_BOX_2X5IC1J3
IND300X3002_2UH_IND_CT_DR74-2R22.2UHIC2L7; L8
KUSBX-SLAS1N-BUSB_A_KUSBX-SLAS1N-BUSB_A_VERT_THIC1J5
KVIX-DA29S-N-WDVI_KVIX-DA29S-N-WDVI_CONNIC1P3
LED-0603LED-GRN-SMT_LED_0603LED-GRN-SMTIC15DS1; DS9; DS10; DS11; DS12; DS13; DS14; DS15; DS16; DS17; DS18; DS19; DS20; DS21; DS22
LED-0603LED-GRN-SMT_LED_0603LED-GRN-SMTIC2DS2; DS32
LED-0603LED-RED-SMT_LED_0603LED-RED-SMTIC2DS30; DS31
LED-1206LED-GRN-SMT_LED_1206LED-GRN-SMTIC4DS25; DS27; DS28; DS29
LED_GRN_SMALL_DUAL_STACKLED_GRN_SMALL_DUAL_STACKLED_GRN_SMALL_DUAL_STACKIC3DS33; DS34; DS35
MH_125_250HOLE_MH_125_250MH_125_250IC5MH1; MH2; MH3; MH4; MH6
MINIMELF1N4148_MINIMELF1N4148IC1D16
ML621S_F9DEML621S_F9DEBATTERY_ML621SIC1B1
MSOP-8INA333_MSOP-8INA333IC4U74; U76; U93; U94
N7E50-7516PG-20N7E50-7516PG-20_CF-50PINN7E50-7516PG-20IC1U73
OSC_EG2121CA_6PEG2121CA200MHZIC1U11
OSC_SI500D_6PSI500DDNPIC1U89
PCIE_8LANE_EDGEPCIE_8LANE_EDGEPCI_E-FINGER-8XIC1P1
PFC_S-PQFP-G80UCD9240PFC_QFP50P14X14-80UCD9240PFCIC2U24; U25
PQFP50P1720X2320-128RM88E1111_PQFP128RM88E1111IC1U80
QFN50P500X500_28CP2103GM_MLP-28CP2103GMIC1U34
QFP50P1200X1200-64CH7301C_LQFP64CH7301C-TFIC1U38
RJ45_HFJ11-1G01ERJ45_HFJ11-1G01ERJ45IC1P2
SC70-6INA213IC1U85
SDMX-4-XSWDIP_SW-12_SDMX-4-XSDMX-4-XIC1S1
SDMX-6-XSWDIP_SW-12_SDMX-6-XSDMX-6-XIC1S2
SDMX-8-XSWDIP_SW-16_SDMX-8-XSDMX-8-XIC1SW1
SIPTML_8008H-1X8_SIPTML_8008H-1X8IC1J62
SIT8102_5X7SIT810247MHZIC1X4
SMA_3P_MOLEX_73251185CON_SMA_SCREW_ONDNPIC2J45; J46
SO-8DUAL-FET-8PINVALIC2Q3; Q4
SO-81310333IC1U39
SOD123MBR0520LT1G_SOD123MBR0520LT1GIC4D10; D11; D12; D13
SOD-123BZX84C4V7_SOT23BZT52C5V1-TPIC2D14; D15
SON-10TPS51100_SON-10TPS51200DRCTIC1U17
SOP127P500X600-8MIC2025-2B_SOP8MIC2025IC1U16
SOT23-3REF3012AIDBZT_SOT23-3REF3012AIDBZTIC1U23
SOT23-5TPS73633_SOT23-5TPS73633DBVTIC1U15
SOT23-51310447IC1U40
SOT23-5TS321I_SOT-23-5TS321IDBVRIC1U41
SOT23-6SN74LVC1G18_SOT23-6SN74LVC1G18IC1U10
SOT23_LUMEX1700020IC1DS23
SOT143SP0503BAHT_SOT143SP0503BAHTIC1X6
SOT223-4SOT223_SOT223-4NDT3055LIC1Q24
SOT223-6TL1963A_18DCQR_SOT223-6IC1U79
SOT-23BAV40-04_SOT23BAS40-04IC9D1; D2; D3; D4; D5; D6; D7; D8; D9
SOT-23NDS331N_SOT23NDS331NIC18Q2; Q5; Q6; Q9; Q10; Q11; Q15; Q16; Q17; Q18; Q19; Q20; Q21; Q22; Q23; Q25; Q26; Q27
SOT-23FET-3PINIC1Q14
SOT-23-6TPS3808G25DBVT_SOT-23-6TPS3808G25DBVTIC1U7
SOT_89FCX491A_SOT_89FCX491AIC2Q12; Q13
SW_450_5001201M2S3ABE2_SLIDE_2POS1201M2S3ABE2IC1SW2
TANT-A15500613.3UFIC1C142
TANT-B330UF_TANT_B33UFIC1C201
TANT-B47UF_TANT_B47UFIC21C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C293; C294; C295; C296; C297; C298; C299; C301; C302; C303; C407
TANT-C3_3UF_TANT_C3.3UFIC1C227
TANT-C150UF_TANT_C150UFIC1C255
TANT-D330UF_TANT_D330UFIC7C272; C274; C275; C276; C403; C418; C419
TANT-V330UF_TANT_V330UFIC3C359; C360; C361
THTL3301EF100QGPUSHBUTTON_4TL3301EF100QGIC8SW3; SW4; SW5; SW6; SW7; SW8; SW9; SW10
TQFP50P1600X1600-100CY7C67300-TQFP100CYP_USB_HOSTIC1U81
TQFP1001310404IC1U26
TQFP144XCCACE-TQ144I_TQFP144XCCACE-TQ144IIC1U19
TSM_107_01_L_DVTSM_107_01_L_DVDNPIC1J24
TSOC_61310353IC1U18
TSOP50P2000X1400-56JS28F256P30_TSOP50P2000X140056JS28F256P30IC1U4
TSSOP65P640X300-8M24128-BWDW6TPM24128-BWDW6TPIC1U5
TSSOP65P640X300-8M24C08-WDW6TPM24C08-WDW6TPIC1U6
TSSOP65P640X300-8ICS844021I_TSSOP8ICS844021IIC1U82
TSSOP-16CD74HC4051_TSSOP-16CD74HC4051IC2U2; U3
TSSOP-16ICS854104_TSSOP16ICS854104IC3U14; U83; U84
TSSOP-20ICS874001_TSSOP20ICS874001IC1U9
TSSOP-20ST2378EST2378EIC5U29; U30; U31; U32; U33
TSSOP-20SN74LV541APWRIC1U88
VQFP1001310301IC1U22
WSL2010-20_006_WSL2010-20.006IC2R115; R116
XTAL_MA506XTAL_MA50625.00MHZIC1X2
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
8 _2 _1 l8 h3 L% }# `& C0 d9 `
GMT+8, 2025-7-10 14:31 , Processed in 0.140625 second(s), 28 queries , Gzip On.
