作品名:[AD 9][2层] 可以用来熟悉和学习布局布线的板子(AT89S51+78XX+74HC00)原理图和PCB源文件
' c7 o& z1 k* H7 Q文件描述 1. 作品用途:可以用来熟悉和学习布局布线的板子 2. 软件版本:AD 9 3. 层数:2层板 4. 用到的主要芯片:AT89S51+78XX+74HC00 5. PCB尺寸:138.5mm*112.5mm 4 X* u- F( u2 m
作品截图如下: 全层截图: * u0 z8 ]6 b% b' r) ~% f: X
叠层信息截图如下: . O6 f( o4 K2 `1 s) u
BOM: Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | NPN1 | BG1, BG2 | TO-92C | 2 | PNP1 | BG3 | TO-92C | 1 | BRIDGE2 | BRIDGE1 | RS108 | 1 | 30 | C1, C2 | RAD0.1 | 2 | 1000UF | CB3 | RB.2/.4 | 1 | 470UF | CB4, CB44 | RB.2/.4 | 2 | 10U | CB77 | RB.1/.2 | 1 | LED | D1, D2 | LEDA | 2 | DIODE | D3, D4 | DIODE0.3 | 2 | Comment | Designator46, Designator47 | SRPE | 2 | Comment | Designator48 | RAD0.2 | 1 | Comment | Designator49 | RB.2/.4 | 1 | 78XX | IC2, IC22 | TO-126A | 2 | AT89S51 | IC6 | DIP40 | 1 | CON2 | J1, J4 | SIP3.92 | 2 | CON3 | J2, J3 | SIP3 | 2 | CON9 | J5 | SIP9 | 1 | 18B20 | J6 | SIP3 | 1 | RELAY-SPDT | K1, K2 | JDQE | 2 | 1602 | LCD | LCD | 1 | SPEAKER | LS1 | FMQ | 1 | 1K | R1, R3 | AXIAL0.3 | 2 | 2K | R2, R4 | AXIAL0.4 | 2 | 4.7K | R5 | AXIAL0.3 | 1 | 10 | R7 | AXIAL0.3 | 1 | 500 | R33 | AXIAL0.3 | 1 | 10K | R44 | AXIAL0.3 | 1 | SW-PB | S1, S2, S3, S4, S6 | QCA | 5 | 74HC00 | U3 | DIP14 | 1 | 10K | W2 | VR4 | 1 | 12M | Y1 | XTAL1 | 1 | 2 n6 w+ r/ ~" S0 P6 }& y5 {
附件: 原理图和PCB源文件如下:
) Q& J$ ?: n( W0 x
- q( t8 L; A: m |
