查看: 249|回复: 0
[allegro16.3][6层]Altera arriagx_pcix_b开发板(EP1AGX60DF780+EPM570++QSH_060+...
发表于 2019-12-25 14:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][6层]Altera arriagx_pcix_b开发板(EP1AGX60DF780+EPM570++QSH_060+金手指)pcb文件
1 `  h0 Y# D7 @- A  p8 h( Q" F" a6 T. @2 L3 d; [3 I$ I: Z2 ?7 j
文件描述:
  s2 y- Q# [* E8 {) G( y. g
1. 作品用途:Altera arriagx_pcix_b开发板
2. 软件版本:allegro16.3
3. 层数:6层
4. 用到的主要芯片:EP1AGX60DF780+EPM570++QSH_060+金手指
5.pcb尺寸:167.64*106.65mm- y: n8 W5 ?" }: D8 j
$ K( Z2 `) E0 i9 f
作品截图如下:
1 q* l. u# D, a3 T  `, \) M. p2 N4 D8 O  ~4 S
7 u$ A8 o2 q0 a
顶层截图:
* B8 R: Y, A0 ~, `. _1 i) o5 X. L: U0 [9 X0 t6 K
底层截图:
4 e: v# e* l" b2 J! d" y& P# Y$ A
; z% u5 q$ c+ P* }! Y6 f( p% F' g$ t+ a3 m- p' y3 p
全层截图:
4 k$ f- ~: ^- B; Q4 {* E' |; Z' ~/ L3 t. M: y1 ~" @
/ F2 k6 Z8 u& J
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP_0402_1UF1uFIC6C3; C53; C54; C60; C98; C99
402CAP_0402_0.01UF0.01uFIC5C22; C31; C147; C149; C168
402CAP_0402_0.1UF0.1uFIC62C24; C25; C32; C73; C74; C77; C78; C79; C100; C101; C102; C103; C104; C107; C111; C113; C116; C119; C120; C121; C122; C123; C124; C125; C126; C129; C130; C132; C151; C152; C155; C157; C161; C162; C165; C166; C167; C169; C170; C171; C173; C181; C182; C187; C193; C195; C211; C212; C213; C214; C219; C220; C221; C222; C224; C225; C226; C227; C228; C229; C230; C231
402CAP_0402_100PF100pFIC4C26; C29; C37; C196
402CAP_0402_820PF820pFIC2C27; C30
402CAP_0402_4700PF4700pFIC5C89; C96; C114; C127; C148
402CAP_0402_470PF470pfIC14C134; C135; C136; C137; C143; C144; C145; C146; C174; C180; C189; C190; C191; C192
402CAP_0402_DNIDNIIC1C138
402CAP_0402_1000PF1000pFIC2C158; C175
402RESISTOR_0402_10K10KIC22R1; R2; R3; R4; R95; R98; R99; R100; R101; R102; R104; R106; R107; R111; R112; R113; R119; R122; R123; R125; R127; R129
402RESISTOR_0402_4.7K4.7KIC13R5; R6; R8; R13; R15; R34; R46; R48; R50; R52; R92; R109; R110
402RESISTOR_0402_100K100KIC5R7; R45; R47; R49; R65
402RESISTOR_0402_1.00K1.00kIC36R9; R12; R20; R32; R33; R35; R36; R37; R40; R42; R44; R55; R56; R57; R58; R59; R60; R61; R62; R66; R82; R83; R84; R85; R86; R87; R88; R93; R96; R103; R114; R115; R126; R128; R138; R142
402RESISTOR_0402_2.00K2.00KIC4R10; R43; R132; R135
402RESISTOR_0402_100, 1%100, 1%IC8R11; R63; R64; R80; R91; R120; R136; R137
402RESISTOR_0402_3.57K3.57KIC1R14
402RESISTOR_0402_10.2K10.2kIC1R18
402RESISTOR_0402_20.0K20.0KIC2R19; R31
402RESISTOR_0402_10.0K10.0KIC4R23; R26; R29; R53
402RESISTOR_0402_1010IC5R24; R116; R117; R130; R131
402RESISTOR_0402_00IC1R27
402RESISTOR_0402_63.4K63.4KIC1R30
402RESISTOR_0402_2.74K2.74KIC1R39
402RESISTOR_0402_5.23K5.23KIC1R41
402RESISTOR_0402_5.76K5.76KIC1R54
402RESISTOR_0402_56.256.2IC13R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R133; R134
402RESISTOR_0402_2727IC5R78; R79; R143; R144; R145
402RESISTOR_0402_49.949.9IC3R81; R121; R124
402RESISTOR_0402_2222IC2R89; R90
402RESISTOR_0402_1.5K1.5KIC1R94
402RESISTOR_0402_332332IC1R97
402RESISTOR_0402_DNIDNIIC4R108; R140; R141; R146
402RESISTOR_0402_732732IC1R118
603CAP_0603_4.7UF4.7uFIC1C4
603CAP_0603_0.1UF0.1uFIC5C71; C76; C80; C87; C88
603CAP_0603_2.2UF2.2uFIC3C72; C209; C223
603CAP_0603_1UF1uFIC1C194
603BEAD_FERRITE_SM_0603_DNIDNIIC5L5; L6; L8; L9; L10
603BEAD_FERRITE_SM_0603_BLM18PG121BLM18PG121SN1IC1L7
603RESISTOR_0603_24.9K24.9KIC1R22
805CAP_0805_10UF10uFIC20C6; C7; C46; C47; C48; C55; C75; C81; C86; C106; C108; C115; C179; C185; C186; C188; C205; C215; C216; C217
805CAP_0805_2.2UF2.2uFIC1C70
1206CAP_1206_10UF10uFIC11C63; C64; C65; C66; C69; C97; C105; C139; C183; C184; C197
1206RESISTOR_1206_1.001IC1R38
1206RESISTOR_1206_DNIDNIIC2R105; R139
1210CAP_1210_10UF10uFIC12C13; C14; C17; C18; C23; C28; C33; C39; C44; C45; C57; C58
6032PPCAP_6032P_100UF100ufIC23C5; C8; C9; C10; C11; C12; C15; C16; C19; C20; C21; C36; C40; C43; C49; C50; C51; C52; C56; C59; C61; C164; C176
CAP_594D_CCAP_SMD_POL_CAP_594D_C_22UF22uFIC9C67; C68; C159; C160; C177; C178; C201; C202; C203
CAP_PACK_4_1206CAP_ARRAY_0_CAP_PACK_4_1206_0.10.1uF x 4IC5CN1; CN2; CN3; CN4; CN5
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_47UF47ufIC2C1; C2
CAP_SMD_8MMCAP_SMD_POL_CAP_SMD_8MM_330UF330uFIC1C62
COILTRONICS_HCP0703INDUCTOR_COILTRONICS_HCP0703_1.1.0uHIC1L3
COILTRONICS_HCP0703INDUCTOR_COILTRONICS_HCP0703_2.2.2uHIC1L4
COILTRONICS_SD3114INDUCTOR_COILTRONICS_SD3114_10U10uHIC1L2
CONN_39_26_7108CONN PCB 5X2-S_1_CONN_39_26_71070247-1051IC1J6
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026IC5U1; U3; U14; U15; U16
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SK1IC2S3; S6
DO-214AB_RECTRONDIODE_DO-214AB_RECTRON_FM540FM540IC1D14
EG2201ASW SLIDE-DPDT_EG2201A_EG2201AEG2201AIC1SW1
ESWITCH_EG-1218SW_SLIDE_SPDT_ESWITCH_EG-1218_SSW_SPDTIC2SW2; SW3
F64S29GLXXXN_BGA_1_F64_S29GL512NS29GL512NIC1U6
F100EPM570F100_F100_EPM570_100FBGAEPM570_100FBGAIC1U5
F780EP1AGX60DF780C6NEP1AGX60DF780IC1U7
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2IC6J3; J8; J9; J10; J11; J12
HDR3X1_100MIL1X3_HDR3X1_100MIL_1X3HEADER1x3HeaderIC1J13
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1IC1L1
LUMEX_LED1206LED_LUMEX_LED1206_GREEN LEDGREEN LEDIC15D1; D2; D3; D4; D5; D6; D7; D8; D9; D10; D15; D16; D21; D22; D23
LUMEX_LED1206LED_LUMEX_LED1206_BLUE LEDBLUE LEDIC1D11
LUMEX_LED1206LED_LUMEX_LED1206_YELLOW LEDYELLOW LEDIC4D12; D13; D19; D20
MICRON_DDR2_84_12X12P5MT47H32M16CC_0_MICRON_DDR2_84_1MT47H32M16CCIC1U8
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021IC1J7
MLX_39_29_1047_RA_4P2X2_MLX_39_29_1047_RA_4P_39-29-39-29-1047IC1J5
MSOP8LM95235_MSOP8_LM95235LM95235IC1U13
MSOP10LTC4416_MSOP10_LTC4416-1LTC4416-1IC2U19; U23
PCIX-4PORTPCIE_BRACKET_X4_PCIX-4PORT_PCIEPCIE_Bracket_X4IC1J14
PSOP8LP2996_PSOP8_LP2996MRLP2996MRIC1U12
PTN78020WAZPTN78020_PTN78020WAZ_PTN78020WPTN78020WIC1U10
PUSHBUTTON_EVQEVQPAC07K_0_PUSHBUTTON_EVQ_EVQPEVQPAC07KIC4S1; S2; S4; S5
QFN32LTC3727_QFN32_LTC3728L-1LTC3728L-1IC1U9
RAPC712CONN JACK PWR_3_RAPC712_CONN JACONN JACK PWRIC1J1
RES_PACK_8RES_PACK_8_RES_PACK_8_5656IC7RN1; RN2; RN3; RN4; RN5; RN6; RN7
SAMTEC_QSHDP120CUSTOMQSH_060_SAMTEC_QSHDP120CUSTOM_QQSH_060IC1J2
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546IC1J4
SMB403A_03ZC2800E/SOT_0_SMB403A_03_MBRS13MBRS130LIC2D24; D25
SO8SI4872DY_SO8_FDS6680AFDS6680AIC4Q1; Q2; Q5; Q6
SO8PMOS_8LEAD_SO8_IRF7424PBFIRF7424PBFIC4U18; U20; U21; U22
SOD323SCHOTTKYDIODE_SOD323_CMDSH2-3CMDSH2-3IC2D17; D18
SOT23NPN_TRANS_SOT23_MMBT3904MMBT3904IC5Q7; Q8; Q11; Q12; Q13
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NIC2Q9; Q10
TO263_5LT1963A_5LEAD_TO263_5_LT1963ALT1963AIC1U17
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFIC4TP1; TP2; TP3; TP4
TSSOP8ICS83026I_TSSOP8_ICS83026ICS83026IC1U4
TSSOP20ICS8543_TSSOP20_ICS8543ICS8543IC1U2
WSL1206RESISTOR_WSL1206_0.0070.007IC2R16; R51
X2Y_0603CAP_X2Y_X2Y_0603_10NF10nFIC13C41; C90; C92; C110; C128; C133; C150; C154; C163; C200; C206; C208; C218
X2Y_0603CAP_X2Y_X2Y_0603_100NF100nFIC9C42; C93; C131; C142; C153; C172; C199; C207; C210
X2Y_0603CAP_X2Y_X2Y_0603_47NF47nFIC1C84
X2Y_0603CAP_X2Y_X2Y_0603_22NF22nFIC5C91; C94; C109; C117; C140
X2Y_1206CAP_X2Y_X2Y_1206_470NF470nFIC1C83
X2Y_1206CAP_X2Y_X2Y_1206_220NF220nFIC3C85; C112; C141
X2Y_1210CAP_X2Y_X2Y_1210_DNIDNIIC7C38; C82; C95; C118; C156; C198; C204
XTAL_PACK_D635L3C3_XTAL_PACK_D_100MHZ100MHzIC1X1
XTAL_PACK_D635L3C3_XTAL_PACK_D_125.00MHZ125.00MHzIC1X2
XTAL_PACK_D635L3C3_XTAL_PACK_D_62.50MHZ62.50MHzIC1X3
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
7 }8 k! G0 k2 v+ v
GMT+8, 2025-7-19 08:20 , Processed in 0.140625 second(s), 28 queries , Gzip On.
