查看: 266|回复: 0
[allegro16.3][10层]AMD GizmoSphere开发板(GET40EFSB22GVE+CG2293+DDR3+金手指)...
发表于 2019-12-25 15:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][10层]AMD GizmoSphere开发板(GET40EFSB22GVE+CG2293+DDR3+金手指)pcb文件
1 `  h0 Y# D7 @- A  p8 h( Q" F" a6 T. @% o4 u9 B3 W6 D" o
文件描述:
8 C) I% l* A' k, k
1. 作品用途:AMD GizmoSphere开发板
2. 软件版本:allegro16.3
3. 层数:10层
4. 用到的主要芯片:GET40EFSB22GVE+CG2293+DDR3+金手指
5.pcb尺寸:98.83*89.53mm$ U% X; v0 U! S, W* d
; y6 i1 J- @: g9 A% K- B5 }
作品截图如下:
1 q* l. u# D, a3 T  `, \) M. p2 N4 D8 O  ~4 S6 V8 Z( \5 d6 Q! {  b
顶层截图:
* B8 R: Y, A0 ~, `. _1 i$ W+ y/ V; H7 o! E. q
底层截图:
4 e: v# e* l" b2 J+ c7 C9 y4 N1 u0 Z; d# h( L/ \; S2 P3 ~
; z% u5 q$ c+ P* }! Y6 f( p% F' g4 c/ J5 X' l4 [
全层截图:
4 k$ f- ~: ^- B; Q
1 u# x# @$ E6 ]% r* e: s( B
  g0 H  P7 H, u( f# {
叠层阻抗信息:
' ~. u5 f: `  T4 c
" f$ w/ h! Q' Z6 \# A" W- ^
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
7440530047INDUCTOR_7440530047_DISCRETE_4.4.7UH/2ADISCRETE1L2
BGA96_0P8_9P15X14P152G_DDR3_SDRAM_128MX16_96P_BGA96EDJ2116DEBGIC4U15; U16; U17; U18
BGA-413-AJ29-D8-ONTARIO_FT1_APUIC_APU-FT1_BGA413_BGA-413-AJ29-GET40EFSB22GVEIC1U1
BS-5CONN_BATT_0_BS-5_IO_COIN_HLDR_VCOIN_HLDR_VRT_2032IO1J3
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.1UF0.1uFDISCRETE122C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C14; C27; C28; C29; C30; C31; C32; C44; C45; C46; C47; C55; C66; C67; C68; C69; C70; C73; C74; C88; C89; C90; C96; C99; C105; C109; C111; C123; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C146; C147; C149; C150; C151; C152; C153; C154; C156; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C177; C178; C179; C183; C184; C185; C186; C193; C194; C201; C202; C209; C211; C212; C213; C222; C233; C234; C239; C241; C243; C247; C250; C255; C256; C257; C259; C260; C261; C263; C269; C282; C283; C284; C291; C325; C326; C327; C330; C331; C350; C353; C364; C365; C370; C371; C372; C373; C387
CC0402_25CAP_NP_CC0402_25_DISCRETE_1000P1000PF/50VDISCRETE4C13; C290; C297; C306
CC0402_25CAP_NP_CC0402_25_DISCRETE_1.0UF1.0uFDISCRETE42C23; C24; C25; C26; C33; C34; C35; C36; C43; C48; C49; C50; C51; C52; C54; C58; C61; C62; C63; C64; C65; C71; C119; C143; C173; C180; C181; C187; C188; C192; C199; C200; C203; C204; C205; C206; C215; C232; C262; C264; C272; C273
CC0402_25CAP_NP_CC0402_25_DISCRETE_180_1180pFDISCRETE18C72; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C91; C92; C93; C94
CC0402_25CAP_NP_CC0402_25_DISCRETE_2.2UF2.2UFDISCRETE15C101; C102; C190; C195; C196; C197; C214; C216; C217; C218; C219; C220; C221; C248; C251
CC0402_25CAP_NP_CC0402_25_DISCRETE_4.7UF4.7uFDISCRETE4C112; C142; C245; C246
CC0402_25CAP_NP_CC0402_25_DISCRETE_100PF100PFDISCRETE6C113; C117; C118; C155; C288; C390
CC0402_25CAP_NP_CC0402_25_DISCRETE_18PF_18PFDISCRETE1C124
CC0402_25CAP_NP_CC0402_25_DISCRETE_10PF_10PFDISCRETE3C140; C145; C305
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.01U0.01UFDISCRETE10C144; C148; C223; C224; C225; C226; C227; C228; C229; C230
CC0402_25CAP_NP_CC0402_25_DISCRETE_22PF_22PFDISCRETE4C171; C172; C174; C175
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.22U0.22UFDISCRETE43C285; C303; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C328; C329; C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344; C345; C346; C347; C348; C349; C366; C367; C368; C369; C374
CC0402_25CAP_NP_CC0402_25_DISCRETE_4700P4700PFDISCRETE1C289
CC0402_25CAP_NP_CC0402_25_DISCRETE_1200P1200PF/50VDISCRETE2C292; C302
CC0402_25CAP_NP_CC0402_25_DISCRETE_180PF180pF/50VDISCRETE1C296
CC0402_25CAP_NP_CC0402_25_DISCRETE_33PF_33PFDISCRETE1C304
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.47U0.47uFDISCRETE2C351; C352
CC0402_25CAP_NP_CC0402_25_DISCRETE_5PF/55pF/50VDISCRETE3C356; C359; C362
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0 U1.0 UFDISCRETE17C19; C20; C21; C56; C121; C158; C235; C236; C249; C252; C265; C266; C279; C280; C281; C298; C299
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_10U_110uFDISCRETE8C22; C41; C42; C53; C59; C60; C182; C210
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_10UF_10uFDISCRETE13C95; C98; C100; C103; C106; C139; C231; C237; C244; C355; C357; C358; C360
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_22UF_22UFDISCRETE28C15; C40; C57; C122; C125; C138; C176; C189; C191; C198; C207; C238; C253; C254; C258; C267; C268; C270; C271; C274; C275; C286; C287; C294; C307; C384; C385; C391
CC1206_OVCAP_NP_CC1206_OV_DISCRETE_100UF100UFDISCRETE19C16; C17; C18; C37; C38; C39; C276; C293; C295; C300; C301; C308; C394; C395; C396; C397; C398; C399; C400
CC1206_OVCAP_NP_CC1206_OV_DISCRETE_10UF_10UFDISCRETE2C240; C242
CC1411CAP_NP_CC1411_DISCRETE_100UF_20100UFDISCRETE5C354; C388; C389; C392; C393
CC1812FUSE_RESETTABLE_CC1812_IC_1.1A/1.1A/33VIC1F2
CC1812FUSE_RESETTABLE_CC1812_IC_500MA500mA/30VIC1F5
CHOKE_WCM2012DLMUTRANSFORMER_1_CHOKE_WCM2012DLMU744231091IC3T1; T3; T4
CHOKE_WCM2012DLMUTRANSFORMER_2_CHOKE_WCM2012DLMU744231091IC1T2
CMS043A_20V_SS32_0_CMS04_IC_30V/5A30V/5AIC1D9
CON8X2_2MCONN_HDR_8X2_CON8X2_2M_IO_6200162001621121IO1J1
CONN_2X32_FINGERSCONN_PCIEX4_1_CONN_2X32_FINGERSPCI EXPRESS 64IO1J7
CON_DB_15F_29_SM_RACON_VGA_CON_DB_15F_29_SM_RA_200200-015-263R001IC1J10
CON_DCJACK_063BH_TH_RADC_POWER_JACK_063BH_CON_DCJACK_PJ-063BHIO1J8
EC_3M5_8M_9MCAP_POL_EC_3M5_8M_9M_DISCRETE_2220uF/35VDISCRETE2C277; C278
FCBGA605_AJ29_D8IC_FCH-H1_BGA605_FCBGA605_AJ29_100-CG2293IC1U6
FDMS9620SFDC6301N_5_FDMS9620S_IC_FDMS962FDMS9620SIC8Q3; Q4; Q5; Q6; Q7; Q8; Q9; Q11
FN6884IC_REG-SW-SVID_OZ8380_QFN32_0_FISL6265AHRTZIC1U14
FPF1039UCXFPF2163_1_FPF1039UCX_IC_FPF1039FPF1039UCXIC1U8
FPF1039UCXFPF2163_2_FPF1039UCX_IC_FPF1039FPF1039UCXIC1U11
FPF1039UCXFPF2163_3_FPF1039UCX_IC_FPF1039FPF1039UCXIC1U12
FUSE_1P6X0P8FUSE_RESETTABLE_FUSE_1P6X0P8_IC500mA/6VIC1F4
FUSE_2X1P4FUSE_RESETTABLE_FUSE_2X1P4_IC_00805L110SLYRIC5F1; F3; F6; F7; F8
H2191-NDCON_FAN_0_H2191-ND_DF13-2P-1.25DF13-2P-1.25DSAIC1J6
HDR205CONN_HDR_5X2_HDR205_IO_6130102161301021121IO1J9
HEADER_2P54_THCON_HDR_1X4_HEADER_2P54_TH_IO_1171825-4IO1J5
IND_0402INDUCTOR_FERRITE_IND_0402_DISCR220OHM_500mADISCRETE10B5; B8; B10; B13; B14; B15; B16; B17; B18; B20
IND_0402INDUCTOR_IND_0402_DISCRETE_16NH16nH/560mADISCRETE6L13; L14; L15; L16; L17; L18
IND_0603BEAD_IND_0603_DISCRETE_60OHM_60OHMDISCRETE1B6
IND_0805INDUCTOR_FERRITE_IND_0805_DISCR42 OHM_4ADISCRETE5B1; B4; B7; B9; B11
IND_0805INDUCTOR_FERRITE_IND_0805_DIS_1220 OHM_2ADISCRETE4B2; B3; B12; B19
LED_0603LED_LED_0603_IC_LTST-C190KSKTLTST-C190KSKTIC2D1; D7
LQFP48IC_HD_AUDIO_CODEC_ALC_48PIN_LQFALC272-GRIC1U2
LQFP48_H1M7IC_ETH-1GB_RTL8111D_LQFP48_H1M7RTL8111DL-VB-GRIC1U4
PCI_EXPRESS_36PCI EXPRESS X1_A_0_PCI_EXPRESS_PCI EXPRESS 36IO1J12
QFN32_5X5TPS51124_6_QFN32_5X5_IC_XRP7713XRP7713ILB-FIC2U9; U10
RC0402_25RES_RC0402_25_DISCRETE_1.0K_1%1.0KDISCRETE32R1; R2; R6; R7; R8; R9; R10; R15; R16; R17; R19; R21; R24; R25; R27; R28; R29; R32; R33; R34; R55; R73; R75; R84; R86; R87; R125; R129; R147; R148; R150; R152
RC0402_25RES_RC0402_25_DISCRETE_330_1%330DISCRETE3R3; R4; R26
RC0402_25RES_RC0402_25_DISCRETE_150_1%150DISCRETE33R5; R11; R12; R13; R52; R53; R54; R76; R105; R162; R163; R164; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191
RC0402_25RES_RC0402_25_DISCRETE_510_1%510DISCRETE3R14; R20; R82
RC0402_25RES_RC0402_25_DISCRETE_499_1%499DISCRETE1R18
RC0402_25RES_RC0402_25_DISCRETE_51_1%51DISCRETE4R22; R23; R39; R41
RC0402_25RES_RC0402_25_DISCRETE_2.0K_1%2.0KDISCRETE2R30; R78
RC0402_25RES_RC0402_25_DISCRETE_1.27K_1%1.27KDISCRETE1R31
RC0402_25RES_RC0402_25_DISCRETE_39.2_1%39.2DISCRETE1R35
RC0402_25RES_RC0402_25_DISCRETE_5.11K_1%5.11KDISCRETE1R36
RC0402_25RES_RC0402_25_DISCRETE_20K_1%20KDISCRETE6R40; R46; R94; R116; R131; R136
RC0402_25RES_RC0402_25_DISCRETE_68_1%68DISCRETE1R43
RC0402_25RES_RC0402_25_DISCRETE_4.7K_1%4.7KDISCRETE7R45; R48; R51; R64; R65; R157; R165
RC0402_25RES_RC0402_25_DISCRETE_51K_1%51KDISCRETE1R47
RC0402_25RES_RC0402_25_DISCRETE_33_1%33DISCRETE7R49; R58; R60; R62; R63; R201; R203
RC0402_25RES_RC0402_25_DISCRETE_2.49K_1%2.49KDISCRETE2R50; R126
RC0402_25RES_RC0402_25_DISCRETE_15K_1%15KDISCRETE1R56
RC0402_25RES_RC0402_25_DISCRETE_11.8K_1%11.8KDISCRETE1R57
RC0402_25RES_RC0402_25_DISCRETE_0_0DISCRETE6R59; R121; R137; R141; R142; R196
RC0402_25RES_RC0402_25_DISCRETE_10.0K_1%10.0KDISCRETE26R66; R68; R69; R70; R71; R72; R88; R89; R90; R92; R93; R95; R96; R97; R98; R99; R100; R101; R104; R108; R109; R110; R117; R195; R197; R198
RC0402_25RES_RC0402_25_DISCRETE_220_1%220DISCRETE2R74; R158
RC0402_25RES_RC0402_25_DISCRETE_590_1%590DISCRETE1R77
RC0402_25RES_RC0402_25_DISCRETE_22_1%22DISCRETE2R79; R80
RC0402_25RES_RC0402_25_DISCRETE_10M_1%10MDISCRETE1R81
RC0402_25RES_RC0402_25_DISCRETE_1M_1%1MDISCRETE1R83
RC0402_25RES_RC0402_25_DISCRETE_931_1%931DISCRETE1R85
RC0402_25RES_RC0402_25_DISCRETE_100_1%100DISCRETE5R91; R119; R123; R139; R140
RC0402_25RES_RC0402_25_DISCRETE_2.2K_1%2.2KDISCRETE4R102; R103; R199; R200
RC0402_25RES_RC0402_25_DISCRETE_10.0_1%10DISCRETE1R107
RC0402_25RES_RC0402_25_DISCRETE_4.7_1%4.7DISCRETE2R112; R114
RC0402_25RES_RC0402_25_DISCRETE_2.2_1%2.2DISCRETE5R115; R118; R120; R130; R135
RC0402_25RES_RC0402_25_DISCRETE_16.2K_1%16.2KDISCRETE1R122
RC0402_25RES_RC0402_25_DISCRETE_255_1%255DISCRETE1R124
RC0402_25RES_RC0402_25_DISCRETE_54.9K_1%54.9KDISCRETE1R127
RC0402_25RES_RC0402_25_DISCRETE_4.87K_1%4.87KDISCRETE1R128
RC0402_25RES_RC0402_25_DISCRETE_66.5K_1%66.5KDISCRETE1R132
RC0402_25RES_RC0402_25_DISCRETE_47K_1%47KDISCRETE1R133
RC0402_25RES_RC0402_25_DISCRETE_44.2K_1%44.2KDISCRETE1R134
RC0402_25RES_RC0402_25_DISCRETE_28K_1%28KDISCRETE1R138
RC0402_25RES_RC0402_25_DISCRETE_36_1%36DISCRETE4R143; R144; R192; R193
RC0402_25RES_RC0402_25_DISCRETE_240_1%240DISCRETE4R145; R146; R155; R156
RC0402_25RES_RC0402_25_DISCRETE_0_5%0DISCRETE3R166; R167; R194
RESONATOR_HIDRA_32KHZXTAL_RESONATOR_HIDRA_32KHZ_IC_332.768KHZIC1Y2
RNET_4_8RES_ISO4_SINGLE_RNET_4_8_DISCRE10KDISCRETE3RN1; RN2; RN3
RT9173DIC_REG-LIN_RT9173D_SOP8_RT9173DRT9173DIC1U13
SATA7P_WATM-07DBN4B2B8UWCON_SATA-INT_5_SATA7P_WATM-07DB471554001IC1J4
SHORT_0603SHORTBAR1206_SHORT_0603_IC_SHORShortingBar0603IC2BAR1; BAR2
SHORT_0603MISC_SHORT_NL_SHORT_0603_SHORT_SHORT_NLIC11S1; S2; S3; S4; S5; S6; S7; S8; S9; S10; S21
SJ-4351CON_AUDIO_PHONO_4COND_SJ-4351_HHEADSET JACKIC1J11
SMA2_4_4P6X2P9SDIODE_SMA2_4_4P6X2P9_IC_B340A-B340A-13-FIC1D10
SOD523DIODE_SCHTKY_SOD523_IC_ZHCS350TZHCS350TAIC1D2
SOIC8LW25X80V_SOIC8L_IC_W25Q16CVSSIGW25Q16CVSSIGIC1U7
SOT23DIODE_SOT23_SOT23_IC_MMBD914LT1MMBD914LT1GIC2D12; D13
SOT23NPN_SOT23_IC_MMBT3904LT1GMMBT3904LT1GIC1Q2
SOT23-6RCCLAMP_4_SOT23-6_IC_RCLAMP0504RCLAMP0504S.TCTIC1U5
SOT23-6RCCLAMP_3_SOT23-6_IC_RCLAMP0504RCLAMP0504S.TCTIC1U19
SOT23-6RCCLAMP_1_SOT23-6_IC_RCLAMP0504RCLAMP0504S.TCTIC1U20
SOT23-6RCCLAMP_2_SOT23-6_IC_RCLAMP0504RCLAMP0504S.TCTIC1U21
SOT323_3PDUALDIODE_CA_SOT23_SOT323_3P_ICBAT54AWT-TPIC4D3; D4; D5; D6
SOT353SN74LVC1G125-Q1_1_SOT353_IC_SN7SN74LVC1G125DCKTIC1U22
SOT353SN74LVC1G125-Q1_0_SOT353_IC_SN7SN74LVC1G125DCKTIC1U23
SOT-23PNP_SOT-23_IC_PMBT4403,215PMBT4403,215IC1Q1
SPM6530T-1R5M100INDUCTOR_SPM6530T-1R5M100_DISCR1.5uH/10ADISCRETE2L10; L11
SRP4020-2R2MINDUCTOR_SRP4020-2R2M_DISCRETE_2.2uH/3.9ADISCRETE3L3; L4; L5
SRP4020-2R2MINDUCTOR_SRP4020-2R2M_DISCRET_10.88uH/5.5ADISCRETE4L6; L7; L8; L9
SW2_4X3MM_SMSW2_STM151XX_2_SW2_4X3MM_SM_IC_B3U-1000PIC1SW2
TP22MISC_TESTPOINT_TP22_TESTPOINTTESTPOINTIC33TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33
USB_LAN-UDE_RU1-161ARWGFCONN_USB_DUAL_3_USB_LAN-UDE_RU1USB_TYPE_A_DUALIO1J2
XTLOSC4_2P5X2MM_SMXTAL_0_XTLOSC4_2P5X2MM_SM_IC_2525MHzIC1Y1
XTLOSC4_2P5X2MM_SMCRYSTAL1-3/SM_XTLOSC4_2P5X2MM_S25MHzIC1Y3
附件:
pcb文件如下:
游客,如果您要查看本帖隐藏内容请回复
. Y0 ?- L4 y& b3 b. {7 S* h
, Q) B& A7 e* u: @! _7 }
GMT+8, 2025-7-12 17:31 , Processed in 0.171875 second(s), 28 queries , Gzip On.
