作品名:[AD 10][2层] 无刷电机功放(IR2132S+TLC2272+IRF540N)原理图、PCB源文件- W" \8 p/ l" ~+ Z* e* z j
7 b+ B% z8 r! a( d
文件描述
0 F5 W; v1 `: R! O) t6 I1. 作品用途:无刷电机功放/ N$ x9 @7 T& V! @
2. 软件版本:AD 10
9 y# I9 ~4 Z* U# Y; V7 L! J3. 层数:2层板. v# t3 `# f1 u8 g& w3 |, C+ o
4. 用到的主要芯片:IR2132S+TLC2272+IRF540N8 }8 G1 m7 Q3 y
5. PCB尺寸:164mm*104mm
3 U# J7 V; r$ _" ]( z
- x; t9 f& d4 C作品截图如下:
5 B0 v. T( c- S9 a3 E3 g. |" y3 r顶层截图:1 a D! |6 w6 Q( ~& n; z
( K% z& c" T) X6 e" B
底层截图:) P: F( B/ c/ F0 f0 j+ S
0 a/ h9 d( C( m/ p+ `全层截图:9 ?4 B! c" N; E/ v8 N% S
6 L2 e! M2 C3 I" D* G叠层信息截图如下:! {9 ]; H0 s4 ?# }
* u* ?! Y7 Y) E: d& x$ w6 a, _
BOM:
- Y* I$ w5 v5 |' Q- m; @( lComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | LED | 3.3V, 5V, 15V, 24V, LED | LED-0805 | 5 | 2200uF/35V | C1 | CAP | 1 | 0.1uF | C2, C4, C9, C12, C14, C15, C16, C20, C21, C22, C23, C24, C26, C29, C30 | 0805 | 15 | 10uF/35V | C3, C5, C6, C7 | 7243-S | 4 | 100uF/10V | C8 | 7243-S | 1 | 47uF/10V | C10, C13 | 3528 | 2 | 0.01uF | C17, C18, C19 | 0805 | 3 | 2200pF | C25, C27, C28 | 0805 | 3 | IN5819 | D1, D2, D3 | 1808 | 3 | BAT54 | D4, D5, D6, D7, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21 | SOT-23 | 17 | HEADER 5 | D8 | 1808 | 1 | 8A | FUSE | SF | 1 | T | HALL1, HALL2, Ibus, IVin, PWM1, PWM2, PWM3, PWM4, PWM5, PWM6, Vbias, Vref, VUin, VVin | TEST | 14 | S1C | HALL3 | TEST | 1 | | IUin | TEST | 1 | HEADER 13X2 | J1 | IDC26B | 1 | HALL IN | J2 | POWER5 | 1 | HALL OUT | J3 | IDC10B | 1 | SW-DIP4 | J4 | DIP8 | 1 | POWER | J5 | POWER4A | 1 | 4 HEADER | J6 | POWER4B | 1 | | L1 | 1210 | 1 | | L2 | 0805 | 1 | IRF540N | Q1, Q2, Q3, Q4, Q5, Q6, Q7 | TO-220AB | 7 | NPN | Q8 | SOT-23 | 1 | 10 | R1 | 0805 | 1 | 9K | R2, R16, R18, R20 | 0805 | 4 | 1K | R3, R17, R19, R21, R24, R27, R33, R34, R35, R36, R37, R38, R39, R40, R41 | 0805 | 15 | 33 | R4, R5, R6, R7, R8, R9 | 0805 | 6 | 0.1 | R10, R11, R12, R13, R14, R15 | 2200F | 6 | 10 | R22 | RES | 1 | 10k | R23, R25, R43, R44, R47, R48, R51, R52 | 0805 | 8 | 430 | R26, R55 | 0805 | 2 | 3.9K | R28 | 0805 | 1 | 6.2K | R29 | 0805 | 1 | 4.7K | R30, R31, R32 | 0805 | 3 | 5K | R42, R45, R49, R53 | 0805 | 4 | 50K | R46, R50, R54 | 0805 | 3 | IR2132S | U1 | SO-28W | 1 | 7815 | U2 | SOT-89A | 1 | LT1117 | U3 | SOT223 | 1 | TLC2272 | U4, U5, U6, U7, U8 | SO-8 | 5 | T15 | Vps | TEST | 1 | 5K | VR1, VR2, VR3, VR4 | VR7 | 4 | 5K | VR5 | VR | 1 | T16 | VWin | TEST | 1 | 附件:
" ~* [9 r+ A$ p( D原理图和PCB源文件如下:
, |: |# m9 B* s; I4 z8 E# |; j
0 O8 O' Y7 \. n% S( l# |4 w; v
9 I. C9 a$ `/ ]5 s1 K |
