Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
IND_13X13_11X11 | IR_INDUCTOR_10X10MM_PAN_IND_13X | 215nH PCDC1008-R215EMO | IC | 1 | L1 |
IR3846_5X7MM | IP1837_V3_36_IR3846_5X7MM_IR384 | IR3846 | IC | 1 | U1 |
IR_C0603 | IR_C0603_IR_C0603_N/S | N/S | IC | 8 | C5; C14; C15; C16; C19; C31; C32; C33 |
IR_C0603 | IR_C0603_IR_C0603_1UF | 1uF | IC | 1 | C6 |
IR_C0603 | IR_C0603_IR_C0603_10UF | 10uF | IC | 1 | C8 |
IR_C0603 | IR_C0603_IR_C0603_8.2NF | 8.2nF | IC | 1 | C11 |
IR_C0603 | IR_C0603_IR_C0603_160PF | 160pF | IC | 1 | C12 |
IR_C0603 | IR_C0603_IR_C0603_2200PF | 2200pF | IC | 1 | C13 |
IR_C0603 | IR_C0603_IR_C0603_100PF | 100pF | IC | 1 | C17 |
IR_C0603 | IR_C1206_IR_C0603_N/S | N/S | IC | 1 | C40 |
IR_C0603 | IR_C1206_IR_C0603_0.1UF | 0.1uF | IC | 1 | C70 |
IR_C0603 | IR_C0603_IR_C0603_0.1UF | 0.1uF | IC | 2 | C100; C130 |
IR_C0805 | IR_C0603_IR_C0805_0.1UF | 0.1uF | IC | 1 | C10 |
IR_C0805 | IR_C0603_IR_C0805_N/S | N/S | IC | 1 | C30 |
IR_C0805 | IR_R0603_IR_C0805_N/S | N/S | IC | 4 | R34; R35; R36; R37 |
IR_C1206X805 | IR_C1206_IR_C1206X805_22UF | 22uF | IC | 2 | C73; C75 |
IR_C1206X805 | IR_C0603_IR_C1206X805_22UF | 22uF | IC | 1 | C74 |
IR_C1206X805 | IR_C1206_IR_C1206X805_N/S | N/S | IC | 14 | C78; C79; C80; C112; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124 |
IR_C1206X805 | IR_C1206_IR_C1206X805_47UF | 47uF | IC | 7 | C104; C105; C106; C107; C108; C113; C114 |
IR_C1210X805 | IR_C1206_IR_C1210X805_22UF | 22uF | IC | 4 | C71; C72; C76; C77 |
IR_C1210X805 | IR_C1206_IR_C1210X805_47UF | 47uF | IC | 3 | C101; C102; C103 |
IR_C1210X805 | IR_C1206_IR_C1210X805_N/S | N/S | IC | 3 | C109; C110; C111 |
IR_DIRFET_SQ | IRLMS2002_14_IR_DIRFET_SQ_IRF67 | IRF6721 N/S | IC | 1 | M1 |
IR_JUMPER_4PIN | JUMPER-4PIN_0_IR_JUMPER_4PIN_4P | 4pin jumper | IC | 1 | OCSELECT |
IR_R0402 | IR_R0603_IR_R0402_N/S | N/S | IC | 1 | R71 |
IR_R0603 | IR_R0603_IR_R0603_0 | 0 | IC | 3 | R3; R18; R70 |
IR_R0603 | IR_R0603_IR_R0603_N/S | N/S | IC | 11 | R4; R19; R30; R31; R32; R38; R39; R111; R112; R113; R114 |
IR_R0603 | IR_R0603_IR_R0603_39.2K | 39.2K | IC | 1 | R9 |
IR_R0603 | IR_R0603_IR_R0603_1.91K | 1.91K | IC | 1 | R11 |
IR_R0603 | IR_R0603_IR_R0603_127 | 127 | IC | 1 | R12 |
IR_R0603 | IR_R0603_IR_R0603_4.22K | 4.22K | IC | 4 | R13; R14; R16; R17 |
IR_R0603 | RESISTOR-0603-1/10W-1%-BIG_IR_3 | 20 | IC | 1 | R15 |
IR_R0603 | RESISTOR-0603-1/10W-1%-BIG_IR_2 | N/S | IC | 3 | R40; R41; R117 |
IR_R0603 | IR_R0603_IR_R0603_49.9K | 49.9K | IC | 1 | R100 |
IR_R0603 | IR_R0603_IR_R0603_7.5K | 7.5K | IC | 1 | R101 |
IR_R0603 | IR_R0603_IR_R0603_10K | 10K | IC | 1 | R110 |
IR_R0603 | RESISTOR-0603-1/10W-1%-BIG_IR_1 | 0 | IC | 3 | R115; R116; R118 |
IR_R0805 | RESISTOR-0603-1/10W-1%-BIG_IR_R | 0 | IC | 1 | R10 |
IR_R1206 | IR_R0603_IR_R1206_N/S | N/S | IC | 3 | R33; R48; R49 |
IR_R1206 | IR_R0603_IR_R1206_0 | 0 | IC | 2 | R46; R47 |
IR_SMD_FCASE_CAP | 330UF-8MM-FSIZE-25V-PANA_IR_SMD | 330uF | IC | 1 | C81 |
IR_SO8 | MIC4451/SO_3_IR_SO8_MIC4452/SO8 | MIC4452/SO8 N/S | IC | 1 | U2 |
IR_SOD323 | BAS316-SOD323_IR_SOD323_N/S | N/S | IC | 2 | D1; D2 |
IR_SOD523 | SSL-LX5093_IR_SOD523_N/S | N/S | IC | 2 | D3; D4 |
IR_SOT23-03 | 2N7002/FAI_0_IR_SOT23-03_N/S | N/S | IC | 1 | M2 |
IR_SW_SPDT_100_3PINS | SW_0_IR_SW_SPDT_100_3PINS_SW | SW | IC | 1 | S3 |
IR_TB_1_0 | TEST_POINT_250X300_SMT_1_IR_TB_ | Label TP | IC | 4 | VIN+; VIN-; VOUT+; VOUT- |
IR_TEST_POINT_50SQ_SMT | TEST_POINT_200X125_SMT_IR_TES_1 | 0.075" SQ_SMT_TestPoint | IC | 1 | PGND1 |
IR_TEST_POINT_75SQ | TEST_POINT_200X125_SMT_IR_TEST_ | 0.075" SQ_SMT_TestPoint | IC | 20 | AGND; ENABLE; EXTLOADCTRL; I-MONITOR; PGND; PGOOD; PG_PULLUP; SYNC; S_CTRL; VCC+; VCC-; VDDQ; VIN; VIN1; VIN2; VIN3; VOUT_ADJ; VP; VPB; VREF |
JUMPER2 | JUMPER 2_JUMPER2_JUMPER 2 | JUMPER 2 | IC | 1 | BODE1 |
JUMPER2 | JUMPER 2_JUMPER2_JUMPER 3 | JUMPER 3 | IC | 1 | BODE2 |
TPL_POSCAP | CAP_3_TPL_POSCAP_N/S | N/S | IC | 5 | C125; C126; C127; C128; C129 |
