作品名:[AD 10][2层] CY3274 Programmable High Voltage Powerline Communication Development Kit原理图与PCB文件
; o* Y: X# A1 I( w8 L
; R. {9 }) Y! O文件描述
$ Y* ]" f6 U& z1. 作品用途:Programmable High Voltage Powerline Communication Development Kit E! p, g! {, z% W0 K1 v
2. 软件版本:AD 10# [- w% }7 b# X; L9 m" I- C' w0 I: y; k
3. 层数:2层板
2 Q. W+ \3 P0 o8 l4. 用到的主要芯片:CY3274
* s7 X0 ]4 T+ h- W) C7 |7 P& |% U$ f5. PCB尺寸:126.7mm*101.6mm
7 ?$ M* P$ O P k) j+ P% v5 A( e1 l- r. Q c0 n) a
作品截图如下:
3 G1 b/ f+ Z u F9 k ]4 ]顶层截图:
, u0 O& a3 X0 r, m& w' E1 o+ w: I& O
$ V. F' w' ?! j# v
: i5 B N; R4 @! H! h" h底层截图:) F7 {3 P& o* R' x3 K$ C. H
% p: x8 p' t# w6 A4 l6 `9 n/ u: d2 G* P
全层截图:
5 z9 A9 S* d. @5 L
5 q2 P/ A5 Y( G5 o- C
% s& o' B$ O, j$ T5 s; R( Y" `. q3 c叠层信息截图如下:; P# }- [- ~! _- T
% U9 c( K& ]) c d8 e
* p- _$ \5 S& [1 _% Y+ [$ J& ~BOM:
% C; ]- y+ z- B/ Z1 o6 ]5 D$ @Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Capacitor 0.1uF | C1 | CC2012-0805 | 1 | CCapacitor Ceramic 1.0nF X7R 10% 25V C0603 | C2 | 0603 | 1 | Capacitor Ceramic 0.01uF 25V X7R 0603 | C3, C4, C10, C36 | 0603 | 4 | Capacitor Ceramic 0.1uF 25V X7R 0603 | C5 | 0603 | 1 | Capacitor Ceramic 1.0uF 16V X7R 0603 | C6, C12, C13, C14, C15 | 0603 | 5 | Capacitor Ceramic 22pF 100V C0G 0603 | C7, C8 | 0603 | 2 | Capacitor Metal Poly Film 0.15uF 300VAC X1 | C9 | ECQU3A-18x8mm | 1 | Capacitor 1.0uF, 16V | C11 | CC2012-0805 | 1 | Capacitor Ceramic 0.10uF 10% 16V X7R 0603 | C16, C17, C18, C24, C27, C34 | 0603 | 6 | Capacitor Ceramic 10.0uF 10% 25V X5R 1206 | C19, C26, C33 | C1206 | 3 | Capacitor Ceramic 1000pF 1% 5V NP0 0603 | C20, C21, C22, C23 | 0603 | 4 | Capacitor 0.47uF, 16V | C25, C38, C42 | CC2012-0805 | 3 | Capacitor Ceramic 470pF 250VAC X1Y1 Radial | C28 | Radial Cap 10mm | 1 | Cpacitor Metal Poly Film 0.022uF 300VAC X1 | C29 | ECQU3A-15x5mm | 1 | Capacitor Electrolytic 4.7uF, 400V | C30, C31 | CAP POL 10mm | 2 | Capacitor Electrolytic 330uF 16V 20% | C32 | CAP Rad D8.5mm S3.5mm | 1 | Capacitor Electrolytic 10uF 50V 20% | C35 | E-Cap 5mm | 1 | Capacitor 0.1uF, 16V | C37 | CC2012-0805 | 1 | Capacitor 100pF | C40 | CC2012-0805 | 1 | Capacitor Ceramic 1500pF 10% 50V X7R 0603 | C41 | 0603 | 1 | TrTransorb Voltage Suppressor 430V 1250A ZNR | D1 | MOV 5 x 2.9mm | 1 | BAT54S | D6 | SOT23 | 1 | Full Wave Diode Bridge | D7 | DF-S 10.4mm | 1 | Schottky Diode 100V 1A SMA | D8, D9 | SMA | 2 | Transient Voltage Suppressor 400W 12V BIDIRECT SMA | D10 | SMA | 1 | LED2 | DS1 | LED0805 - duplicate | 1 | LED Red | DS2 | LED0805 - duplicate | 1 | LED Green | DS3 | LED0805 - duplicate | 1 | LED Yellow | DS4 | LED0805 - duplicate | 1 | Fuse 2A Slow Blow 250VAC | F1 | FUSE RST | 1 | BREADBOARD | H1 | BBOARD 1.8X1.4 - No holes | 1 | Header 10 | J1, J10, J12, J18 | HDR1X10 | 4 | Power Inlet 2-Pin | J7 | AC Power Conn Screw Hole | 1 | | J8 | HDR2x1 | 1 | Header 4 | J9, J13, J17, J20 | HDR1X4 | 4 | ICE_CONN_STRAIGHT | J14 | RJ45 | 1 | 5-pin ISSP Header | J15, J21 | ISPCON | 2 | | J16 | HDR1X4 | 1 | | J19 | DB9F | 1 | 12V LED Supply Connector (DNP) | J22 | PWRCON | 1 | LED DaughterCard Connector (DNP) | J23 | HDR2X13REV_rAngle | 1 | DNP | JP1, JP3, JP4, JP5 | HDR2x1 | 4 | Inductor 1500uH 0.2A 5% Radial | L3 | Radial Inductor 5mm | 1 | Inductor 22uH 20% 1210 | L4 | 3225[1210] | 1 | Inductor 1mH 10% 1007 | L5 | 1007 (2518 Metric) | 1 | LCD_MODULE | LCD1 | HDR1X14 | 1 | LED | LED1, LED2, LED3, LED4 | LED0805 | 4 | MTG HOLE | MTG1, MTG2, MTG3, MTG4 | MTG_HOLE | 4 | Transistor NPN HV 40V 1A SOT-89 | Q1 | SOT89 | 1 | Transistor PNP HV 40V 1A SOT-89 | Q2 | SOT89 | 1 | MMBT3904 | Q3 | SOT-23 | 1 | TS13003HV | Q4 | TO-92 (NPN HV) | 1 | Resistor 1.00k 1% 1/10W 0603 | R1, R3, R4, R25 | 0603 | 4 | Resistor 2.1k 1% 1/10W 0603 | R2 | 0603 | 1 | Resistor 402 1% 1/10W 0603 | R5 | 0603 | 1 | Resistor 7.50k 1% 1/10W 0603 | R6, R7, R22 | 0603 | 3 | Resistor 330 Ohm 1% 1/10W 0603 | R8 | 0603 | 1 | RResistor 20.0k 1% 1/10W 0603 | R9, R11 | 0603 | 2 | Resistor 2.0k 1% 1/10W 0603 | R10 | 0603 | 1 | ResResistor 22.1 1% 1/10W 0603 | R14 | 0603 | 1 | Resistor 10.0k 1% 1/10W 0603 | R15, R17, R18, R28, R29, R30, R31, R33 | 0603 | 8 | Resistor 4.02k 1% 1/10W 0603 | R16 | 0603 | 1 | Resistor 37.4k 1% 1/10W 0603 | R19, R20 | 0603 | 2 | Resistor 3.83k 1% 1/10W 0603 | R21 | 0603 | 1 | Resistor 4.99 1% 1/10W 0603 | R23 | 0603 | 1 | Resistor 36.5 1% 1/10W 0603 | R26 | 0603 | 1 | Resistor 41.2 1% 1/10W 0603 | R27 | 0603 | 1 | Resistor 750k 1% 1206 | R32 | 3216[1206] | 1 | Resistor 820k 1% 1206 | R34 | 3216[1206] | 1 | Resistor 3.9 Ohm 1% 0805 | R35 | 2012[0805] | 1 | Resistor 68.0k 1/8W 1% 0805 SMDD | R36 | 2012[0805] | 1 | Resistor 1.00 Ohm 1/10W 1% 0603 SMD | R37 | 0603 | 1 | Resistor 100k 1/10W 1% 0603 SMD | R38 | 0603 | 1 | Resistor 12.0k 1/10W 1% 0603 SMD | R39 | 0603 | 1 | Resistor 6.8k 1% 0603 | R40 | 0603 | 1 | Resistor 10.0 Ohm 5W 5% Wire Wound | R41 | Res-on-end-300dia | 1 | | R46, R47 | POT-3352T | 2 | Resistor 1.0K, SMT | R48, R49, R50, R51, R61, R62, R63, R64, R65 | R2012-0805 | 9 | Resistor 56 Ohm, SMT | R57, R58, R59, R60 | R2012-0805 | 4 | | S2, S4 | STDSW | 2 | SW-DIP8 | S3 | DIP-16-KEY | 1 | Coupler | T1 | Coupler | 1 | Power Trasnsformer EE-16 | T2 | XFMR EE16 | 1 | 24mH Common Mode Choke | T3 | Choke EE8.3 | 1 | Gnd | TP1, TP2, TP3, TP4 | TP64 | 4 | CY8CPLC20 OCD | U1 | 100TQFP | 1 | LMH6639MF | U2, U3, U4 | SOT-23-6 | 3 | LD1117DT50CTR | U5 | DPAK - LT1117dt50 | 1 | iW1690-07 | U6 | SOIC-8 | 1 | RS-232 tranceiver | U8 | SO-16 | 1 | 24MHz Oscillator | Y1 | SMD 5x7 - Other Silkscreen | 1 | 32.768kHz | Y2 | XTAL32K | 1 | ! K2 [/ Q3 a# y& [. Q+ S0 y
附件:
6 @! ]$ @9 _ d/ j原理图和PCB源文件如下:
5 R+ y' W+ q1 d- L9 G; c* }- g
) M0 a* A% D. ?# H) f) O. N/ K' l! h1 c Z
