查看: 245|回复: 0
[allegro17.2][4层]CY4532 Power Board(SBH11-PBPC-D13-ST-BK+MIC29152WD-TR)原...
发表于 2020-1-7 14:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]CY4532 Power Board(SBH11-PBPC-D13-ST-BK+MIC29152WD-TR)原理图和pcb文件
文件描述:
1. 作品用途:CY4532 Power Board
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:SBH11-PBPC-D13-ST-BK+MIC29152WD-TR
5. PCB尺寸:97.85*103.37 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
500SSP1S1M1QEASWITCH_450301014042_WURTH_0_500SWITCHIC1SW1
1935161TERMINAL_BLOCK_1935161__19351611935161IC1J5
B2B-EH-A-LF-SNCON2_0_B2B-EH-A-LF-SN__B2B-EH-AB2B-EH-A(LF)(SN)IC1J1
BATTERYSOLDERPADT POINT S_BATTERYSOLDERPAD_T POT POINT SIC4B+; B-; P+; P-
C1808CAP NP_C1808__2200PF__2200pFIC1C96
CAPC1005X56N_CYPSCAP NP_CAPC1005X56N_CYPS__0.1UF0.1uFIC14C2; C3; C20; C26; C27; C28; C36; C39; C41; C42; C57; C73; C89; C90
CAPC1005X56N_CYPSCAPACITOR 402 GENERIC SMD_CAP_147pFIC4C21; C22; C33; C34
CAPC1005X56N_CYPSCAPACITOR 402 GENERIC SMD_CAPC10.1uFIC4C24; C30; C100; C104
CAPC1005X56N_CYPSCAP NP_CAPC1005X56N_CYPS_47NF_C47nFIC1C25
CAPC1005X56N_CYPSCAP NP_CAPC1005X56N_CYPS_22NF_C22nFIC1C29
CAPC1005X56N_CYPSCAPACITOR 402 GENERIC SMD_CAP_20.01uFIC4C31; C32; C35; C37
CAPC1005X56N_CYPSCAP_1UF_25V_X5R_0402_TDK_0_CA_11uFIC9C38; C40; C48; C81; C82; C83; C84; C85; C86
CAPC1005X56N_CYPSCAP NP_CAPC1005X56N_CYPS__4.7UF4.7uFIC1C50
CAPC1005X56N_CYPSCAP NP_CAPC1005X56N_CYPS_0.1UF_0.1uFIC1C58
CAPC1005X56N_CYPSCAP NP_CAPC1005X56N_CYPS_0.1U_10.1uFIC3C59; C74; C75
CAPC1005X56N_CYPSCAPACITOR_CAPC1005X56N_CYPS_4.74.7uFIC2C88; C91
CAPC1005X56N_CYPS0_0.01 UFD 0402 X7R_CAPC1005X560.01 uFIC1C99
CAPC1608X90N_TYCAP_1UF_25V_X5R_0402_TDK_0_CAPC1uFIC3C1; C93; C103
CAPC1608X90N_TYCAP NP_CAPC1608X90N_TY__0.1UF__0.1uFIC2C23; C92
CAPC1608X90N_TY10UF-50V-10%-X5R-1206_CAPC1608X10uFIC2C43; C44
CAPC1608X90N_TYCAPACITOR NON-POL_CAPC1608X90N_22uFIC4C45; C46; C47; C49
CAPC1608X90N_TYCAPACITOR 402 GENERIC SMD_CAP_30.001uFIC8C51; C56; C63; C64; C65; C66; C67; C79
CAPC1608X90N_TYCAP-NP_0_CAPC1608X90N_TY_390PF_390pFIC2C101; C102
CAPC1608X90N_TYINDUCTOR FERRITE_CAPC1608X90N_T220Ohm@100MHzIC1L3
CAPC2012X70N_MURATACAP_22UF_0.3V_X5R_0805_MURATA_C22uFIC1C87
CAPC3216X180N_TDK10UF-50V-10%-X5R-1206_CAPC3216X22uFIC14C4; C5; C6; C8; C9; C10; C13; C14; C15; C16; C17; C18; C55; C71
CAPC3216X180N_TDK10UF-50V-10%-X5R-1206_CAPC321_110uFIC14C7; C11; C12; C19; C52; C53; C54; C60; C61; C68; C69; C70; C76; C77
CAPC3216X180N_TDKCAP NP_CAPC3216X180N_TDK_22UF_C22uFIC2C62; C78
CAPC3216X180N_TDK10UF-50V-10%-X5R-1206_CAPC321_24.7uFIC1C72
CAPC3225X280N_TDK10UF-50V-10%-X5R-1206_CAPC3225X10uFIC1C80
CAPC3225X280N_TDK10UF-50V-10%-X5R-1206_CAPC322_14.7uFIC1C94
ESD_TSLP2_0P65_0H4BZX84C18/SOT_1_ESD_TSLP2_0P65_0ESD105B102ELE6327XTMA1IC2ESD1; ESD2
HDR2X1CON2_0_HDR2X1__961102-6404-AR__961102-6404-ARIC2J4; J14
HDR3X1CON3_0_HDR3X1_PRPC003SAAN-RCPRPC003SAAN-RCIC3J6; J7; J9
HDR5_KEYED_MCON5_0_HDR5_KEYED_M__22232051__22232051IC1J8
INDM4440X200NINDUCTOR_INDM4440X200N_1UH 5A_71uH 5AIC1L4
IND_SRP1245AIND_WURTH_0_IND_SRP1245A_6.8UH6.8uHIC1L1
IND_SRP1245AIND_WURTH_0_IND_SRP1245A_3.3UH3.3uHIC1L2
LEDC1608X80NLED_GREEN2_0_LEDC1608X80N__GREEGREENIC1LED1
NET_TIENET TIE_NET_TIE_NET TIENet TieIC1NT1
PMEG3050EP-115BZX84C18/SOT_0_PMEG3050EP-115__PMEG3050BEP,115IC4D2; D3; D7; D9
QFN40P400X400X80-33T270X270NSC8802_2_QFN40P400X400X80-33T27SC8802QDERIC1U1
QFN40P400X400X80-33T270X270NSC8701_1_QFN40P400X400X80-33T27SC8701QDERIC1U2
QFN50P400X400X60-25T275X275NCY7C65215_7_QFN50P400X400X60-25CY7C65211-24LTXIIC1U7
QFN50P600X600X60-41T470X470NCYPD4125-40LQXIT_1_QFN50P600X60CYPD4126-40LQXIIC1U3
RAPC712CONN_JACK_PWR_2_RAPC712__6941086.94108E+11IC1J3
RECPT13X2_100CON24A_0_RECPT13X2_100__SBH11-PSBH11-PBPC-D13-ST-BKIC2J10; J11
RESC1005X40N_PEC5.49K-1/10W-1%-0603_RESC1005X_249.9KIC3R2; R30; R61
RESC1005X40N_PEC5.49K-1/10W-1%-0603_RESC1005X_3499KIC3R4; R29; R64
RESC1005X40N_PEC5.49K-1/10W-1%-0603_RESC1005X401KIC8R8; R10; R11; R12; R31; R32; R33; R34
RESC1005X40N_PECRESISTOR 402 GENERIC SMD_RESC10270KIC1R15
RESC1005X40N_PEC5.49K-1/10W-1%-0603_RESC1005X_175KIC1R16
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40N_100KDISCRETE9R17; R21; R48; R94; R96; R98; R101; R104; R108
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40_34.7KDISCRETE1R18
RESC1005X40N_PECRESISTOR 402 GENERIC SMD_RESC_168KIC2R22; R50
RESC1005X40N_PECR_RESC1005X40N_PEC_10K_RC0603JR10KIC2R24; R65
RESC1005X40N_PECR_RESC1005X40N_PEC_4.99K_RC06034.99KIC1R25
RESC1005X40N_PECRESISTOR_RESC1005X40N_PEC_2K2KIC3R26; R27; R28
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40_424KDISCRETE2R35; R39
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40_536KDISCRETE2R37; R51
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40_618KDISCRETE1R38
RESC1005X40N_PECR_RESC1005X40N_PEC_100K100KIC9R40; R43; R44; R66; R67; R89; R91; R93; R109
RESC1005X40N_PECRESISTOR 402 GENERIC SMD_RESC_20EIC3R41; R49; R53
RESC1005X40N_PEC5.49K-1/10W-1%-0603_RESC1005X_410KIC3R52; R68; R69
RESC1005X40N_PEC5.49K-1/10W-1%-0603_RESC1005X_51MIC1R57
RESC1005X40N_PECRESISTOR_RESC1005X40N_PEC_110K_110KIC1R58
RESC1005X40N_PECRESISTOR_RESC1005X40N_PEC__0E__0EIC4R59; R62; R63; R83
RESC1005X40N_PECRESISTOR_RESC1005X40N_PEC_1M_ER1MIC1R60
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40_10EDISCRETE2R85; R106
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40_710KDISCRETE1R87
RESC1005X40N_PEC5.49K-1/10W-1%-0603_RESC1005X_6200KIC1R88
RESC1005X40N_PECR_RESC1005X40N_PEC__10E__10EIC1R92
RESC1005X40N_PECRESISTOR_RESC1005X40N_PEC_10K10KIC1R99
RESC1005X40N_PECR_RESC1005X40N_PEC__49.9K__49.9KIC1R100
RESC1005X40N_PEC10K-1/16W-5%-0603_RESC1005X40N_100KIC1R103
RESC1005X40N_PEC330 OHM 5% 0805_0_RESC1005X40_251KDISCRETE1R107
RESC1608X55M_ARESISTOR_RESC1608X55M_A__0E__0EIC11R1; R5; R7; R9; R14; R23; R42; R45; R46; R47; R54
RESC1608X55N_PECRESD,0402,5%,1/32W,10K_RESC1608330EIC1R3
RESC1608X55N_PECRESISTOR_RESC1608X55N_PEC__0E__0EIC11R6; R13; R19; R20; R55; R56; R75; R78; R81; R82; R86
RESC1608X55N_PECR_RESC1608X55N_PEC_4.7K_1%_RC064.7KIC1R36
RESC1608X55N_PEC330 OHM 5% 0805_0_RESC1608X55N_2R2DISCRETE4R73; R74; R76; R77
RESC1608X55N_PECR_RESC1608X55N_PEC_33K33KIC1R95
RESC1608X55N_PECR_RESC1608X55N_PEC_200K200KIC1R97
RESC3216X65N_ROHMRESISTOR 402 GENERIC SMD_RESC3210mIC4R70; R72; R79; R80
RESC3216X65N_ROHM330 OHM 5% 0805_0_RESC3216X65N_10mDISCRETE1R71
RESC3216X65N_ROHMRES_0.005R_1W_1206_RESC3216X65N0.02R,1WIC1R105
RESC6330X80NY14870R00500B9R_1_RESC6330X80N_5mIC1R84
RESC6331X64N100-16W-1%-2512_RESC6331X64N__2200EIC1R102
SIP1AAT POINT R_SIP1AA__T POINT R__T POINT RIC1VCONN_OCP
SMBJ24A-TRBZX84C18/SOT_0_SMBJ24A-TR__SMBJSMBJ24A-TRIC1D1
SMBJ24CA_3P679_2H44BZX84C18/SOT_1_SMBJ24CA_3P679_2SMBJ24CA-E3/52GICT-NDIC1D10
SMD_TEST_POINTTEST_POINT_SMD_TEST_POINT__TESTTEST_POINTIC4TP6; TP7; TP8; TP15
SOD3715X145NDIODE - SMA403D_0_SOD3715X145N_1N4148W-7-FIC4D4; D5; D6; D8
SOIC127P600X175-8N_TISI4172DY-T1-GE3_SOIC127P600X175SIR426DP-T1-GE3IC8Q4; Q5; Q6; Q7; Q8; Q9; Q10; Q11
SOP65P210X110-6L20NNCP_2_SOP65P210X110-6L20N_INA19INA199A3DCKRIC1U9
SOT23_2N7002LT1GMOSFET_N_GDS_3_SOT23_2N7002LT1GSI2371EDS-T1-GE3IC5Q1; Q2; Q3; Q13; Q15
SOT23_2N7002LT1GN-MOSFET_2N7002_SOT23_4_SOT23_2IRLML9303TRPBFIC1Q18
SOT50P160X60-6L20NUSBLC6_1_SOT50P160X60-6L20N_USBUSBLC6-2P6IC1U8
SOT95P237X112-3L20NN-MOSFET_2N7002_SOT23_3_SOT95P2SI2300DS-T1-GE3IC3Q12; Q14; Q16
SOT95P280X145-5L30NAP2822AKATR-G1_1_SOT95P280X145-AP2822AKATR-G1IC1U5
TERMINAL_BLOCK_2PINTERMINAL_BLOCK_TERMINAL_BLOCK_2OSTTC020162IC1J2
TO127P990X238-6NLI1521_5_TO127P990X238-6N_MIC29MIC29152WD-TRIC1U6
TP-43R_STEST_POINT_TP-43R_S_DISCRETE_BLBLACKDISCRETE3TP1; TP2; TP11
TP-43R_STEST_POINT_TP-43R_S__RED__REDIC7TP3; TP4; TP5; TP10; TP12; TP13; TP14
TP-43R_STEST_POINT_TP-43R_S__YELLOW__YELLOWIC2TP9; TP16
USB-MICRO-B-SMTUSB MICRO-B_2_USB-MICRO-B-SMT_I10103594-0001LFIO1J12
USB-PD_TYPE-CUSB-PD_TYPE-C_20_USB-PD_TYPE-C_DX07S024JJ2R1300IC1J13
WSON50P315X315X80_11T335X170NAOZ1050PI_3_WSON50P315X315X80_1TPS63060DSCRIC1U4
附件:
原理图和Pcb文件
游客,如果您要查看本帖隐藏内容请回复
1 ?! C1 {" F( b7 b7 s3 e! R0 ], c  f
GMT+8, 2025-7-19 09:13 , Processed in 0.156250 second(s), 28 queries , Gzip On.
