1. 作品用途:DEVKIT-MOTORGD DEVKIT平台的低成本电机控制解决方案
2. 软件版本:allegro17.2
3. 层数:2层
5. PCB尺寸:3650*2299 mil
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CASE_G_AL | CAP_POL_CASE_G_AL_DISCRETE_10.8 | 330UF | DISCRETE | 1 | C28 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 470PF | DISCRETE | 4 | C1; C2; C5; C16 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 0.1uF | DISCRETE | 16 | C4; C7; C9; C10; C13; C22; C29; C31; C32; C33; C37; C39; C41; C44; C45; C48 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.91M | 47PF | DISCRETE | 6 | C11; C14; C19; C20; C23; C25 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 82pF | DISCRETE | 5 | C15; C18; C21; C26; C27 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_2 | 220PF | DISCRETE | 1 | C24 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_3 | 1uF | DISCRETE | 2 | C43; C49 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 2.2uF | DISCRETE | 2 | C3; C6 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 2.2uF | DISCRETE | 6 | C12; C30; C38; C40; C42; C46 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | 4.7uF | DISCRETE | 3 | C34; C35; C36 |
CCE63X55 | CAP_POL_CCE63X55_DISCRETE_6.1MM | 47UF | DISCRETE | 1 | C8 |
CON2X8_2P54_TH | CONN_HDR_8X2_CON2X8_2P54_TH_IO_ | CON_2X8 | IO | 3 | J1; J3; J4 |
CON2_TB_5MM_TH | TB2_CON2_TB_5MM_TH_IO_10.2MM_21 | CON_2_TB | IO | 1 | J12 |
CON3_PWR_JACK_TH_PJ051A | DC_POWER_JACK_SHD_CON3_PWR_JACK | PJ-051AH | IO | 1 | J7 |
CON4_TB_5MM | 282836-4_CON4_TB_5MM_IO_10MM_21 | CON_4_TB | IO | 1 | J13 |
CON20_2P54_TH | CONN_HDR_10X2_CON20_2P54_TH_IO_ | CON_2X10 | IO | 3 | J2; J5; J6 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.58MM_2 | HDR 1X2 | IO | 1 | J8 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38 MM_ | HDR_1X3 | IO | 3 | J9; J10; J11 |
HDR106_100_TH | CONN_HDR_6X1_HDR106_100_TH_IO_1 | HEADER 1X6 | IO | 1 | JP1 |
HSMX-C170 | LED_HSMX-C170_IC_0.9 MM_370-300 | HSMG-C170 | IC | 1 | D2 |
LFPAK56_1P27_4P7X5P3 | NMOS_DUAL_8P_B_LFPAK56_1P27_4P7 | BUK7K52-60E | IC | 3 | Q2; Q3; Q4 |
POT3_3313J | POT_POT3_3313J_DISCRETE_2.4MM_4 | 10K | DISCRETE | 1 | R72 |
QFN56_0P5_8X8 | MC34GD3000_QFN_56P_EP_B_QFN56_0 | MC34GD3000EP | IC | 1 | U1 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 33 | DISCRETE | 4 | R1; R7; R9; R59 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | 1K | DISCRETE | 8 | R4; R5; R6; R13; R14; R20; R25; R63 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_1 | 330 | DISCRETE | 1 | R11 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 1.2K | DISCRETE | 1 | R12 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_2 | 1.50K | DISCRETE | 12 | R15; R18; R23; R28; R31; R35; R64; R65; R66; R67; R68; R69 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_3 | 24K | DISCRETE | 12 | R16; R19; R24; R29; R30; R32; R33; R36; R37; R38; R39; R40 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_2 | 120 | DISCRETE | 6 | R17; R22; R27; R34; R41; R62 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 10.0K | DISCRETE | 4 | R21; R26; R70; R73 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 3.0K | DISCRETE | 6 | R42; R43; R44; R45; R46; R61 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_3 | 100 | DISCRETE | 6 | R47; R48; R49; R53; R54; R55 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.60 MM_ | 4.7 | DISCRETE | 4 | R3; R50; R51; R52 |
RC2512_C_A | RES_RC2512_C_A_DISCRETE_0.8MM_4 | 0.01 | DISCRETE | 4 | R56; R57; R58; R60 |
SO8_1P27_4X5 | OPA2677_8P_SO8_1P27_4X5_IC_1.75 | AD8656 | IC | 2 | U2; U4 |
SOD123LF | DIODE_SCHTKY_SOD123LF_IC_1.2MM_ | PMEG3020EH | IC | 2 | D1; D3 |
SOD123LF | DIODE_SCHTKY_SOD123LF_IC_1.2M_1 | PMEG2005EH | IC | 3 | D6; D9; D10 |
SOD323 | DIODE_SOD323_IC_1.1MM_480-78885 | BAS316 | IC | 2 | D4; D5 |
SOD-128 | DIODE_SCHTKY_SOD-128_IC_1.1 MM_ | PMEG4050EP | IC | 2 | D7; D8 |
SOT23_A | NMOSFET_PMV130ENEA_SOT23_A_IC_1 | PMV130ENEA | IC | 1 | Q5 |
SOT223 | REG1117ADJ_SOT223_SOT223_IC_1.8 | LM317A | IC | 1 | U3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_210 | TEST POINT BLACK | IO | 4 | TP2; TP3; TP4; TP5 |
TP_TH_018 | TESTLOOP_TP_TH_018_IO_0.127MM_2 | TEST POINT | IO | 4 | TP1; TP7; TP8; TP9 |
