作品名:[AD 15][4层]一个工业级的板子(XAG49+PC16552+ATF16V8B)PCB源文件9 [- N/ u; k6 R) Z
8 ~" E/ f9 n8 t7 X
文件描述
* a. I. r$ }9 b( _
: g" H. V" ?" K( S3 u1. 作品用途:一个工业级的板子# {$ G N3 C' }0 D
* z' Z) H# F* Z
2. 软件版本:AD 15
- l q9 k9 M# h! J7 ^: l! d% P* j5 Y& i
3. 层数:4层板
$ ^9 X l: W3 N6 F( m/ J/ M; ^$ b9 q$ Q
4. 用到的主要芯片:XAG49+PC16552+ATF16V8B
: i# B0 p; S0 G& S- U& M- R; a$ p& K" K; x1 _* `9 y; X
5. PCB尺寸:212.7mm*16.3mm
$ x9 L8 T( U- @4 d$ Z* C! Z% a! e4 a2 A7 k1 \6 |
- T% D0 g- D. s1 U3 F作品截图如下:
- W1 h& G* K+ V9 o4 k
9 H# j' W K5 J& j: {! W顶层截图:
T; X( b; C& f+ P0 V
2 n6 r" Z2 J2 F) H2 H) m& P# R1 R
: G$ u3 N X. T; d
底层截图:
% L! \+ S7 O, [1 x* b" V" W
}% P4 N2 \. j" ~5 `
' Y2 N7 ~2 Z+ }% |" D全层截图:
# ~/ n6 m K$ Q. S! C* k7 Y- I
: o$ Z8 c6 T3 l6 j- I# x3 c$ l
/ m) E6 y# ~8 Z" B
叠层信息截图如下:
0 z: f3 Q8 B/ ]1 M H: S) g
2 t8 V( ]& c# }1 r1 @( U% K2 b+ T% M* s6 [$ o; \6 m
BOM:
; h2 Z$ d# Q, K' |Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | | HOLD | 3 | | | HOLE | 3 | | | place-han_zi_z | 11 | | | UT-SIGN | 1 | 220 | C6, C7, C511 | 0805 | 3 | 150 | C8, C9 | 0805 | 2 | 104 | C10, C501, C502, C503, C504, C701, C702, C703, C704, C705, C706, C707, C708, C709, C710, C711, C712, C713, C714, C715, C716, C717, C718, C719, C720, C721, C722, C723, C724, C725, C726, C727, C728, C729, C730, C734, C735, C736, C737 | 0805 | 39 | 500 | C510 | 0805 | 1 | CAP | C731, C732, C733 | 0805 | 3 | CON8 | CZ501 | CH5-8 | 1 | ZIGBEE | CZ503 | ZIGBEE | 1 | 40PIN | CZ702, CZ703 | IDC40A | 2 | | CZ705 | POW4AZ | 1 | | D1 | DS1M1A | 1 | M7 | D2, D3 | DS1M1A | 2 | 30BQ060 | D701, D702 | 30BQ060 | 2 | | DLY2, DLY3 | DLY5 | 2 | 2EHDRM-10P | DZ502, DZ704 | 10PIN | 2 | DB9M | DZ503 | DB-9/F/W | 1 | | DZXLED, ELVCC, GLVCC LED, IRDARXD, IRDATXD, PRGEN, RX501, TX501, ZBSLED, ZJSLED, ZRXD, ZTXD | LEDA | 12 | 107/16V | E1 | D6 | 1 | 477/50V | E701, E702, E703, E704, E705, E706, E707, E708, E709, E710, E711, E712 | D6 | 12 | LBV160 | FUSE1, FUSE2 | LBV160 | 2 | IDC-14 | IDC1 | FKV14SN | 1 | F1X40-2.54/M/Z | JMP3, JMP4, JMP5, JMP6 | SIP3 | 4 | AQV252G | K2 | DIP6 | 1 | | L701, L702, L703, L704 | L300 | 4 | 1511-101K | L705, L706 | L200 | 2 | 472 | R1, R3, R4, R5, R6, R7, R8, R9, R10, R27, R29, R39, R50, R51, R52, R53, R54, R55, R56, R57, R58, R59, R501, R502, R503, R504, R505, R506, R507, R508, R509, R523, R524, R538, R539, R544, R545, R701, R702 | 0805 | 39 | 103 | R2, R510, R521, R522, R530 | 0805 | 5 | 511J0805 | R14, R19, R20, R21 | 0805 | 4 | 104J0805 | R28 | 0805 | 1 | 121 | R34, R542 | 0805 | 2 | 100/10W | R36, R37, R38 | R10W | 3 | 102 | R41, R525, R526, R527, R528, R529, R531 | 0805 | 7 | 820 | R42 | 0805 | 1 | 391 | R511, R512, R513, R514, R515, R516, R517, R518, R519, R520 | 0805 | 10 | 273J0805 | R532 | 0805 | 1 | 8R2 | R536, R537 | 0805 | 2 | 152 | R540 | 0805 | 1 | 105 | R541 | 0805 | 1 | 680 | R543 | 0805 | 1 | | RF501, RF502, RF503, RF504 | ZFS | 4 | A09-472J | RP2, RP3, RP4 | RF9 | 3 | | RP9 | RF5 | 1 | SW-8 | S1 | BMKG-16 | 1 | P6KE 6.8CA | TVS501, TVS502, TVS503, TVS504, TVS704 | TVS-SMBJ | 5 | P6KE 5.6CA | TVS701, TVS702 | TVS-SMBJ | 2 | P6KE5.6CA | TVS703 | TVS-SMBJ | 1 | P6KE 26CA | TVS705 | TVS-SMBJ | 1 | 102 | TVS706 | TVS-SMBJ | 1 | ATF16V8B | U5 | DIP20 | 1 | 74HC573 | U7, U13, U18, U30, U501 | SOP20 | 5 | XAG49 | U8 | PLCC44 | 1 | 29F080B-90SC | U16 | SOP44 | 1 | SJA1000T | U20 | SOP28B | 1 | TPIC6B259 | U21 | DIP20 | 1 | GAL22V10D25LP | U22 | DIP24P | 1 | AT28C64B | U23 | SOP28A | 1 | HY628400 | U24 | SOP32 | 1 | MAX1232 | U26 | SOP8 | 1 | 74H14 | U27 | SOP14 | 1 | PS2501 | U29 | DIP4 | 1 | HCPL2631 | U502, U503, U504, U514 | DIP-8 | 4 | 6N137 | U509, U515 | DIP-8 | 2 | PC16552 | U510 | PLCC44/Z | 1 | 82C250 | U511 | DIP8 | 1 | MAX202 | U513 | SO-16 | 1 | 75LB184 | U516 | DIP-8 | 1 | LM2576-5 | U701, U702 | LM2576AA | 2 | MAU124 | U703 | DCP0505 | 1 | 22MHZ | XTAL3 | XTALL | 1 | 11.0592 | XTAL4 | XTALL | 1 | 3.6864 | XTAL501 | XTALL | 1 | ' D, f3 G, p5 D2 v, m
附件:
/ W& N7 H c# x6 v% w; O
% N) v2 [+ y3 h6 F3 b2 ?PCB源文件如下:
$ ]* K( m; B5 L9 ^4 `3 D! Q, i( u& s: \
9 j0 G ]- w1 f# _+ ~
0 {( p9 L- R* Y9 e9 G9 P
$ u! i/ z) I0 x4 T4 r8 g |
