查看: 413|回复: 0
[AD 10][4层]飞凌iMX6Q嵌入式开发板(NLSV1T34DFT2G+GPS_RF+WM8962MODULE_NC)PCB...
发表于 2020-1-8 15:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][4层]飞凌iMX6Q嵌入式开发板(NLSV1T34DFT2G+GPS_RF+WM8962MODULE_NC)PCB源文件7 Y3 s% ^0 j, J, v
2 |2 F7 q7 I& _) @/ l0 Y* j文件描述
+ |- H3 L. F: V6 v) i4 }) M$ m* a
1. 作品用途:飞凌iMX6Q嵌入式开发板: R' t! }" x9 s6 e- V# j
$ q/ O) {9 @$ m9 S2. 软件版本:AD 10" d" V: F1 {- I, Y
, I* E! e6 `; w3 w3 q7 C4 D3. 层数:4层板
' C: i  R- ~7 a: r# K; L1 |1 k! a8 B" _( t# \8 r: @" T
4. 用到的主要芯片:NLSV1T34DFT2G+GPS_RF+WM8962MODULE_NC* B! {% I7 |4 ?7 T" r
* R9 X1 a* ?, y! O- q, V# t. a- l
5. PCB尺寸:190.2mm*130.2mm
% X+ n& }. ]. {. f$ }: a* U1 u' \% V: B/ a( l& z% L
8 l0 U; j/ J' C; ], A7 X/ v" v作品截图如下:- Z7 n" }$ D1 w# L6 X
- J) X( O* H9 _% L/ n% U顶层截图:
8 q' H* V" L( \, Z: h   ~; l+ ]7 P% `" d# W# r7 X5 H
: Y" \1 I1 p4 X8 s底层截图:
1 z" g( w0 e. N% P ) I# B) s& z% E  @
3 [( u5 k" E& d+ r! h/ w) J" w. e
全层截图:9 ?/ J1 {) i  S3 V+ x( y
' [: ?8 T" w- L
& v1 o4 x  R! p  a, u- B叠层信息截图如下:
1 {/ Q; f. F/ f1 @% m- ? ) d7 K9 k* m7 m# _
% T$ R& M( e0 V4 s2 [BOM:
5 c8 b& e; `8 P6 P7 g) q' C% i
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
CR2032BT1CR2032
0.1uFC1, C2, C4, C5, C6, C7, C9, C11, C12, C13, C14, C16, C18, C26, C27, C30, C38, C39, C41, C44, C46, C49, C52, C53, C54, C55, C56, C60, C63, C64, C65, C66, C67, C68, C70, C71, C74, C75, C76, C77, C78, C83, C89, C94, C95, C97, C98, C99, C100, C101, C102, C106, C109, C112, C113, C117, C118, C1320603C+
58
10uFC3, C10, C28, C29, C48, C510603C+
10pF_NCC8, C150603C+
1uFC17, C42, C45, C47, C50, C69, C72, C73, C84, C85, C86, C87, C88, C93, C105, C115, C116, C119, C121, C125, C130, C134, C135, C137, C1380603C+
25
0.1uFC20, C21R0402
4.7nFC22, C23, C24, C25, C31, C32, C33, C340603C+
8
56pF_NCC35, C360603C+
1nFC370603C+
22pFC40, C57, C580603C+
10uFC43, C62, C103, C133TC3216A
18pFC59, C610603C+
2.2pF_NCC79, C80, C81, C82R0402
1uF_NCC900603C+
100uFC91, C120, C123, C128, C129TC3528B
22uFC92, C104, C1240603C+
1500uFC96, C108, C110CAP_10_13
4.7uFC107, C111, C114, C126, C127, C1310603C+
1000uF 16VC122CAP_10_13
MIC_PINKCON1PHONEJACK SW
Phone_GREENCON2PHONEJACK SW
LCDCON54CON3FPC54
RClamp0502BD1, D6, D10SOT-523
GESD1005H150CR10GPTD2, D3R0402
BAT54CD4SOT23
BAT54HT1D5, D7Diode1.6*2.6
SMBJ15CAD8, D9SMB/DO-214AA
SR54D11, D15SMB/DO-214AA
MMSZ5231BD12Diode1.6*2.6
S3MD16SMB/DO-214AA
0.5AF1, F2, F3R_1210
3AF4R_1210
120OHMFB1, FB2, FB3, FB4, FB5, FB6, FB8, FB9, FB10, FB11, FB12, FB14, FB150603R+
13
120OHM/NCFB130603R+
MICRO_USBJ1microUSB
LVDS CONNECTORJ22.0MM_19X2
SDCARD_KMSD18J3TF-CARD
SDCARD_KMSD18J4SD-CARD3
LEFT_UPJ5SOCKET_80PIN_0.5MM
RIGHT_UPJ6SOCKET_80PIN_0.5MM
LEFT_DOWNJ7SOCKET_80PIN_0.5MM
RIGHT_DOWNJ8SOCKET_80PIN_0.5MM
RJ45_GigabitJ9RJ45_Gagabit
USB-VJ10, J13USB-C
CON2x10/NCJ11IDC20S
D Connector 9J12DSUB1.385-2H9-M
PWR2.5J14JACK-2.5MM_B
PWR2.5_NCJ15JACK-2.5MM_B
CON3J16POWER_SWITCH
KEYK1, K2, K3KEY6*6*6.5
KEYK4SW_6X6_SMT
4.7uHL1L_3-3
GREEN_LED0805LED1, LED2, LED3, LED5LED0805+
REDLED4, LED6LED0805+
GREENLED7LED0805+
LOGOLOGO1LOGO
MARKM1, M2, M3Mark Point_circle
MHOLE-2M4, M5, M6, M73.2mm_hole
Header 30X2P1IDC60S
Header 10X2P2IDC20S
Header 5X2P3, P6, P16, P17, P19, P21IDC10S
Header 2P5, P20HX2.54_2P
CON2x10P7IDC20S
SATAP8SATA_7P - A
Header 4P9IDE-4P-5.08
Header 4X2P10SWITCH_4P
Header 2P11, P12, P18DG128-2P
Header 6P13PH-2-P6
Header 3P14HDR1X3
Header 13X2P15IDC26S
AO3415Q1, Q3, Q4, Q5, Q6, Q7, Q8, Q12, Q14SOT95P245X110-3N
9
S8050Q2, Q9, Q13, Q15, Q16, Q17SOT95P245X110-3N
AO3400Q10, Q18SOT95P245X110-3N
S8550Q11SOT95P245X110-3N
4.7KR1, R2, R47, R48, R50, R66, R67, R70, R72, R73, R77, R128, R140, R143, R164, R170, R1790603R+
17
10KR3, R6, R9, R14, R23, R24, R25, R27, R28, R29, R33, R37, R38, R39, R40, R42, R43, R44, R45, R51, R54, R55, R78, R81, R82, R84, R85, R92, R93, R95, R97, R99, R106, R107, R113, R130, R141, R144, R155, R156, R163, R165, R168, R184, R185, R187, R207, R225, R2270603R+
49
0RR4, R7, R8, R10, R16, R17, R32, R34, R35, R59, R63, R86, R105, R142, R145, R146, R149, R150, R151, R152, R154, R157, R175, R178, R180, R181, R183, R188, R189, R190, R191, R192, R193, R210, R212, R214, R220, R222, R2330603R+
39
1KR5, R18, R21, R49, R159, R160, R161, R162, R167, R186, R195, R197, R199, R201, R203, R205, R208, R221, R2240603R+
19
330RR11, R60, R61, R62, R110, R111, R166, R2230603R+
8
470RR120603R+
22R/NCR130603R+
22RR15, R19, R79, R87, R88, R89, R90, R91, R94, R96, R98, R100, R101, R102, R108, R115, R116, R117, R118, R119, R121, R171, R172, R173, R1740603R+
25
0R_NCR20, R30, R36, R71, R74, R114, R134, R228, R2340603R+
9
0RR22, R31, R230, R231R0402
10K_NCR26, R41, R64, R83, R127, R129, R215, R2260603R+
8
10K/NCR46, R169, R1820603R+
49.9R1%R52, R530603R+
1.5KR56, R57, R109, R147, R1480603R+
4.7K_NCR58, R176, R1770603R+
15KR65, R2170603R+
47KR68, R690603R+
59RR75, R760603R+
27KR800603R+
1MR1030603R+
100R1040603R+
2.37K 1%R1120603R+
100KR120, R122, R123, R124, R125, R2180603R+
12K_1%R1260603R+
0R_NCR131R0603+
470_NCR132, R1330603R+
100RR135, R136, R2160603R+
470R/NCR1370603R+
0R/NCR138, R153, R158, R194, R211, R213, R2190603R+
330R/NCR1390603R+
100K_NCR196, R198, R200, R202, R204, R2090603R+
1K/NCR2060603R+
2.2KR229, R2320603R+
330R_NCR2350603R+
470R_NCR2360603R+
testT1TESTPOINT
OV5640U1FPC24
NLSV1T34DFT2GU2SN74LVC1G17
HS0038B_NCU3HS0038B
GPS_RFU4, U5RF
WM8962MODULE_NCU6WM8962MODULE
RL-UM02WBSU7RL-UM02WBS-8723BU
SIM_CARDU8SIM_CARD - SL
mini_pcieU9MINI PCIE-2
RX8010SJU10RX8010SJ
CM2020U11CM2020
10029449-001RLFU12HDMI
RT9013U13, U19, U22, U24, U25, U28SOT95P280X129-5N
TJA1040U14SOP127P600X175-8N
AR8031U15QFN48C40P600X600_AR8031
USB2514BU16QFN36(USB251x)
OV6540-MIPIU17FPC24
MAX3232IDU18SO-G16
FDS4435U20, U27FDS4435
LM1117-3.3U21, U26LM1117
TSC2007U23TSC2007
RClamp0524PU29SLP2510P8
WM8960U30WM8960
MIPI_DSIU31FPC30
3.5MM_NCU323.5mmaudio
24MHzX1Crystals_3225
25MHzX2Crystals_3225
11.2896M_NCX3SCO-700-(7050)
, H) Q( K5 B5 R; E3 P* J# a9 l4 Y附件:* j( P( y2 F7 ]. \/ \
2 Y& B3 [" N$ @
PCB源文件如下:
- `# U3 e% d0 c
游客,如果您要查看本帖隐藏内容请回复
' e' }2 H( m/ i4 ~, ^
) J2 `( e, X0 M2 g  y& M
5 [9 ?! U( T5 g, I: ~' z9 j8 `( w7 f
GMT+8, 2025-7-18 12:04 , Processed in 0.125000 second(s), 28 queries , Gzip On.
