作品名:[AD 10][2层] STM32F103ZET6+M29W128FL70ZA6E+ST8024CDR 原厂开发板PCB和原理图
$ I5 Q' X+ o9 e% v& @% t6 S2 _: `' Y1 }
文件描述, \ q: c- Y/ s0 s3 U4 Z
1. 作品用途:原厂开发板
( s7 A( l: Q, @6 \2. 软件版本:AD 10& G% r1 C) f6 Q6 F% {
3. 层数:2层板
. x5 Z0 R& j" s4. 用到的主要芯片:STM32F103ZET6+M29W128FL70ZA6E+ST8024CDR
9 x1 \" j( K2 Q* P5. PCB尺寸:114.3mm*172.8mm( ?( H0 R: x( }* h; B
6 d m: p' h }4 V
作品截图如下:
" A9 ~+ W# D$ w0 U/ S! @顶层截图:
( y! ^% Q" p# w) C* d. _- O# n
) l8 k+ u; H9 v# U1 O; j, p) i1 R
) `" X8 a. k A$ x底层截图:
/ w8 H) v' i2 ?$ z, B. K, q
+ d* [2 }! {8 N! c& L' a* c
9 ~5 J6 r# l2 c( t全层截图:
: s z: o" Y0 R
6 H5 M$ ?+ \. e+ @( t# D+ b% ?
& R3 _, N5 }/ `) ?, h) J c9 U
叠层信息截图如下:
, R( g% G/ Z* }! R* H. h
3 M" A) l6 R' |: s, x
. z& H0 u9 a) {0 H- k
BOM:
5 N# D9 l( u- I' z8 q- y6 FComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | RESET | B1 | PB10 | 1 | WKUP | B2 | PB10 | 1 | Tamper | B3 | PB10 | 1 | USER | B4 | PB10 | 1 | | BOOT0, BOOT1, JP1, JP4, JP7, JP8, JP14, JP18 | SIP3 | 8 | CR1220 holder | BT1 | LI1220_1 | 1 | do not fit | C1, C3, C4, C5, C9, C13, C22, C51, C55, C58, C60, C91, R2, R10, R25, R50, R55, R57, R61, R74, R75, R76, R78, R105 | 0603 | 24 | 10nF | C2, C45, C46, C100 | 0603 | 4 | 100nF | C6, C7, C10, C11, C12, C14, C15, C16, C17, C18, C19, C20, C21, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C49, C52, C54, C62, C63, C64, C66, C74, C75, C83, C85, C87, C88, C89, C90, C92, C93, C94, C95, C96, C97, C98, C99 | 0603P | 56 | 1nF | C8 | 0603 | 1 | 10pF | C43, C44 | 0603 | 2 | 20pF | C47, C48 | 0603 | 2 | 10uF | C50, C65, C73, C79 | TAN-B | 4 | 2.2uF | C53 | TAN-A | 1 | 1uF | C56, C57, C59 | 0603 | 3 | 220uF | C61 | C310M | 1 | 0.22uF | C67, C76 | 0805 | 2 | 0.1uF | C68, C72 | 0603P | 2 | 47uF | C69, C70, C80, C82, C84 | TAN-B | 5 | 4.7uF | C71, C77 | TAN-B | 2 | 4.7nF | C78 | 0603 | 1 | 10uF | C81 | C160M | 1 | 330nF | C86 | 0603 | 1 | MC_connector | CN1 | IDC34S | 1 | VB334 | CN2, CN3, CN5 | VB334 | 3 | DB9-male CAN connector | CN4 | DB9/M | 1 | Header 7X2 | CN6 | IDC14S | 1 | FTSH-110-01-L-DV | CN7 | FTSH-110-01-L-DV | 1 | DB9-male USART2 | CN8 | DB9/M | 1 | JTAG | CN9 | IDC20S | 1 | Header 35X2 | CN10, CN11 | 2*35P | 2 | DB9-male USART1 | CN12 | DB9/M | 1 | PJS008-2000 | CN13 | MSD(PJS008) | 1 | USB-typeB connector | CN14 | USB-B | 1 | ST-225-02 | CN15 | ST-225-02 | 1 | Connector to Mother board | CN16 | AM240*320B | 1 | DC-10B | CN17 | DC10B | 1 | C816 | CN18 | SAM(C816) | 1 | | JP2, JP3, JP5, JP6, JP11, JP12, JP15, JP16, JP17, JP19, JP20, JP21, JP22 | SIP2 | 13 | | JP9, JP10, JP23, JP24, JP25, JP26, JP27 | JP2_SMD | 7 | | JP13 | 2*3P | 1 | BEAD | L1 | 0603 | 1 | Green | LD1 | D0603 | 1 | Orange | LD2 | D0603 | 1 | Red | LD3, LD5 | D0603 | 2 | Blue | LD4 | D0603 | 1 | 0 | R1, R3, R4, R5, R6, R8, R9, R15, R21, R22, R27, R29, R30, R31, R32, R35, R36, R37, R38, R39, R41, R44, R46, R49, R56, R60, R67, R68, R71, R77, R79, R80, R81, R82, R89, R94, R100, R101, R102, R103, R104, R106, R107, R111, R126, R128, R129, R135 | 0603 | 48 | 3.3K | R7 | 0603 | 1 | 820 | R11, R14 | 0603 | 2 | 10K | R12, R13, R16, R17, R18, R19, R20, R23, R24, R26, R34, R43, R45, R47, R48, R52, R53, R54, R58, R59, R64, R70, R72, R88, R91, R93, R108, R109, R112, R113, R114, R115, R116, R119 | 0603 | 34 | 120 | R28 | 0603 | 1 | do not fit | R33, R62 | 0603_NC | 2 | 390 | R40 | 0603 | 1 | 47 | R42, R85 | 0603 | 2 | 4K7 | R51 | RES4B | 1 | 100K | R63, R118 | 0603 | 2 | 36K | R65 | 0603 | 1 | 47K | R66, R130, R131, R132, R133, R134 | 0603 | 6 | 1.5K | R69 | 0603 | 1 | 10 | R73, R83, R86 | 0603 | 3 | 6.8 | R84, R87 | 0603 | 2 | 4K7 | R90, R121, R122 | 0603 | 3 | 5 | R92 | 0603 | 1 | 1M | R95 | 0603 | 1 | 600 | R96, R97, R98, R99 | 0603 | 4 | 330 | R110 | 0603 | 1 | 100 | R117, R120, R124, R125 | 0603 | 4 | 220K | R123 | 0603 | 1 | 300 | R127 | 0603 | 1 | 50 | R136, R137, R138 | 0603 | 3 | 10K | RV1 | ADJRH | 1 | 9013 | T1, T2 | SOT-23 | 2 | Ground | TP1, TP2, TP16 | TP | 3 | VREF | TP3 | TP | 1 | 5V | TP4 | TP | 1 | 3V3 | TP5 | TP | 1 | LIN | TP6 | TP | 1 | MCKO | TP7 | TP | 1 | HPR | TP8 | TP | 1 | RIN | TP9 | TP | 1 | HPL | TP10 | TP | 1 | MCO | TP11 | TP | 1 | SPP | TP12 | TP | 1 | SPN | TP13 | TP | 1 | AUX2 | TP14 | TP | 1 | AUX1 | TP15 | TP | 1 | IS61WV51216BLL-10MLI | U1 | FBGA48(9*11) | 1 | M29W128FL70ZA6E | U2 | TBGA64(10*13) | 1 | NAND512W3A2CN6E | U3 | TSOP48 | 1 | SN65HVD230 | U4 | SO8 | 1 | ST3232ECTR | U5, U7 | TSSOP16 | 2 | M25P64-VME6G | U6 | VDFPN8(8*6) | 1 | STM32F103ZET6 | U8 | IC149-144-045-B5 | 1 | STLM75M2E | U9 | SO8 | 1 | AK4343 | U10 | QFN32 | 1 | USBLC6-2P6 | U11 | SOT-666 | 1 | LD1086D2M33 | U12 | D2PAK/A | 1 | TFDU4300 | U13 | IR_VISHAY3 | 1 | KSS-1508 | U14 | KS1508 | 1 | ZEN056V130A24LS | U15 | polyzen | 1 | BNX002-01 | U16 | BNX001 | 1 | ST8024CDR | U17 | SO28 | 1 | HXM122032-GB1 (do not fit) | U18 | LCD12232-GB1 | 1 | MT008-A | U19 | JOY | 1 | 8MHz (with socket) | X1 | XTAL_socket | 1 | MC306-G-06Q-32.768 (manufacturer JFVNY) | X2 | SM8 | 1 | SMAJ5.0A-TR | Z1 | 1R1C | 1 | / W3 B: g& n& i1 z) ~/ j+ G# m
附件:
- K) N" ~ T3 F+ Z2 v7 q% r% M原理图和PCB源文件如下:
, S8 p( }8 ?3 n/ ], x4 X3 J8 u8 E" {( X3 ~1 F0 A3 D
0 T6 C+ r0 L7 J |
