Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA15_05MM_H09_IRREG_M | BGA15_05MM_H09_IRREG_M | AK8973B | IC | 1 | SSU4 |
BGA90_08MM_8X13_H1_M | BGA90_08MM_8X13_H1_M | K4M51323PE-HG75 | IC | 2 | MEU1; MEU2 |
BGA133_20_05MM_H1P2_M | BGA133_20_05MM_H1P2_M | SDIN5D2-8G_8G*8 | IC | 1 | MEU8 |
BGA133_20_16_05MM_3S_H1P2_M | BGA133_20_16_05MM_3S_H1P2_M | SDIN4C1-4G | IC | 1 | MEU7 |
BGA304_96_05MM_H1P2_M | BGA304_96_05MM_H1P2_M | S3C2450X40-YL40 | IC | 1 | CPU1 |
C0402_H07_M | C0402_H07_M | 6.8PF | DISCRETE | 9 | MEC77; MEC78; MEC79; MEC80; MEC81; MEC82; MEC101; MEC102; MEC104 |
C0402_H08_M | C0402_H08_M | 160pF-NP0 | DISCRETE | 1 | CPC8 |
C0402_H055_M | C0402_H055_M | 15PF | DISCRETE | 19 | CPC1; CPC2; CPC4; CPC5; CPC6; CPC7; LCC18; LCC20; LCC21; MCC11; MEC13; MEC22; MEC29; SPC33; SPC34; SPC35; SPC36; SSC16; SSC17 |
C0402_H055_M | C0402_H055_M | 1U | DISCRETE | 5 | CPC9; LCC3; LCC19; SPC37; SPC162 |
C0402_H055_M | C0402_H055_M | 0.1U | DISCRETE | 70 | CPC10; CPC16; CPC21; CPC22; CPC23; CPC25; CPC26; CPC30; CPC31; CPC32; CPC37; CPC38; CPC39; CPC40; CPC41; CPC43; CPC44; CPC49; CPC51; CPC53; CPC55; CPC57; CPC68; CPC104; CPC106; LCC4; LCC5; LCC9; MCC3; MCC5; MCC7; MEC9; MEC10; MEC11; MEC14; MEC17; MEC18; MEC19; MEC20; MEC24; MEC25; MEC26; MEC28; MEC30; MEC74; MEC75; OTC23; OTC24; OTC25; OTC29; SPC10; SPC12; SPC14; SPC16; SPC26; SPC38; SPC40; SPC41; SPC42; SPC44; SPC161; SSC7; SSC13; SSC15; SSC20; SSC26; SSC27; SSC29; SSC31; SSC35 |
C0402_H055_M | C0402_H055_M | 10P | DISCRETE | 8 | CPC11; CPC17; CPC18; CPC19; CPC69; LCC10; LCC11; LCC12 |
C0402_H055_M | C0402_H055_M | 47P | DISCRETE | 4 | CPC13; CPC15; CPC101; SPC4 |
C0402_H055_M | C0402_H055_M | 0.01U | DISCRETE | 24 | CPC27; CPC33; CPC34; CPC35; CPC36; CPC42; CPC45; CPC46; CPC47; CPC48; CPC52; CPC54; CPC56; LCC13; LCC14; LCC15; LCC16; MCC1; MEC12; MEC15; MEC21; MEC23; MEC27; SPC28 |
C0402_H055_M | C0402_H055_M | | DISCRETE | 1 | CPC100 |
C0402_H055_M | C0402_H055_M | 100P | DISCRETE | 1 | CPC105 |
C0402_H055_M | C0402_H055_M | 2.2UF | DISCRETE | 3 | MEC72; MEC73; MEC76 |
C0402_H055_M | C0402_H055_M | 18P | DISCRETE | 3 | MEC103; SPC48; SPC49 |
C0402_H055_M | C0402_H055_M | 0.22U | DISCRETE | 1 | MEC107 |
C0402_H055_M | C0402_H055_M | 0.033U | DISCRETE | 1 | SPC22 |
C0402_H055_M | C0402_H055_M | 22pF-NP0 | DISCRETE | 2 | SPC47; SPC50 |
C0402_H055_M | C0402_H055_M | 0.047U | DISCRETE | 1 | SPC163 |
C0402_H055_M | C0402_H055_M | 0.022U | DISCRETE | 4 | SPR21; SPR137; SPR138; SSC1 |
C0603_H1_M | C0603_H1_M | 22UF | DISCRETE | 1 | LCC6 |
C0603_H09_M | C0603_H09_M | 1800pF-COG | DISCRETE | 1 | CPC3 |
C0603_H09_M | C0603_H09_M | 10U | DISCRETE | 19 | CPC14; CPC24; CPC28; CPC29; CPC107; MEC105; MEC106; SPC1; SPC2; SPC7; SPC8; SPC9; SPC11; SPC13; SPC15; SPC25; SPC39; SPC160; SPC164 |
C0603_H09_M | C0603_H09_M | 0.47U | DISCRETE | 3 | LCC7; LCC8; LCC17 |
C0603_H09_M | C0603_H09_M | 1U | DISCRETE | 8 | OTC26; OTC30; SPC27; SSC12; SSC14; SSC21; SSC28; SSC30 |
C0603_H09_M | C0603_H09_M | 4.7U | DISCRETE | 1 | SPC46 |
C0603_H094_M | C0603_H094_M | 1U | DISCRETE | 3 | MCC2; MCC4; MCC6 |
C0805_H1P35_M | C0805_H1P35_M | 10U | DISCRETE | 1 | SPC21 |
C0805_H1P45_M | C0805_H1P45_M | 10U | DISCRETE | 2 | CPC102; CPC103 |
C0805_H085_M | C0805_H085_M | 10U | DISCRETE | 1 | MEC108 |
CHOKE_ELLVEG_M | CHOKE_ELLVEG_M | 10uH | IC | 1 | CPL2 |
CHOKE_WCM2012_M | CHOKE_WCM2012_M | 90Z-100M | IC | 1 | OTL1 |
CONBTB34_NAIS_AXT3-01_M | CONBTB34_NAIS_AXT3-01_M | 34_0.4mm_FM_ST_AXT334124 | IO | 1 | CAJ1 |
CONFPC04_FCI_59453-01_M | CONFPC04_FCI_59453-01_M | RA/4P/SMT | IO | 1 | LCJ3 |
CONFPC45_AT_HRS_FH23-01_M | CONFPC45_AT_HRS_FH23-01_M | FPC/FFC/45P/0.3MM | IO | 1 | LCJ1 |
CONFPC45_AT_SUNY_BL125-01_M | CONFPC45_AT_SUNY_BL125-01_M | FPC/FFC/45P/0.3MM | IO | 1 | LCJ2 |
CONMUSB05_TIC_MU05F473_M | CONMUSB05_TIC_MU05F473_M | 5P_1Slot_ST_- | IO | 1 | OTJ3 |
CONWTB03_JXT_WB253003S10P_M | CONWTB03_JXT_WB253003S10P_M | JXT-WB253-003S10P-3P | IO | 1 | SPJ1 |
D1206_H1P16_M | D1206_H1P16_M | SSCD204H | DISCRETE | 2 | SPD5; SPD6 |
FD_DOT020_M | FD_DOT020_M | FIDUCIAL-MARK | IO | 4 | FD1; FD2; FD3; FD4 |
HVQFN28_150_045MM_G_H1_M | HVQFN28_150_045MM_G_H1_M | ATMEGA48 | IC | 1 | |
ICBAROMETER_BOSCH_BMP180_M | ICBAROMETER_BOSCH_BMP180_M | BMP180-ICBAROMETER | IC | 1 | SSU3 |
ICGSENSOR_BOSCH_BMA250E_M | ICGSENSOR_BOSCH_BMA250E_M | BMA250E-ICGSENSOR | IC | 1 | SSU2 |
IND_NR3010_H1_M | IND_NR3010_H1_M | 2.2UH | IC | 1 | SPL1 |
IND_VLS3010E_M | IND_VLS3010E_M | 22uH | IO | 1 | LCL7 |
JTAG_100_TEST_7_M | JTAG_100_TEST_7_M | JTAG_100_TEST | IO | 2 | CPTP4; MCTP1 |
L0402_H055_M | L0402_H055_M | 120Z-100M | DISCRETE | 6 | CPR22; CPR25; CPR68; LCL21; LCL22; LCL24 |
L0402_H055_M | L0402_H055_M | 600OHM/100MHZ | DISCRETE | 1 | OTL5 |
L0603_H095_M | L0603_H095_M | 120Z-100MHZ | DISCRETE | 1 | SPR1 |
L0805_H1P05_M | L0805_H1P05_M | 600Z-100M | DISCRETE | 1 | OTL2 |
PAD_SCW_PASTE_M16T0P8_M | PAD_SCW_PASTE_M16T0P8_M | HOLE1.8/PAD4.0/H0.8MM | IO | 2 | MTG5; MTG6 |
QFN10_DRC_NH_M | QFN10_DRC_NH_M | TS3USB221DRCR | IC | 1 | OTU4 |
QFN32_05MM_G_H08_M | QFN32_05MM_G_H08_M | UP6615 | IC | 1 | SPU1 |
R0402_H04_M | R0402_H04_M | 1M | DISCRETE | 4 | CPR1; CPR2; CPR209; SPR141 |
R0402_H04_M | R0402_H04_M | 4.99M | DISCRETE | 1 | CPR3 |
R0402_H04_M | R0402_H04_M | 49.9K | DISCRETE | 1 | CPR11 |
R0402_H04_M | R0402_H04_M | 15K | DISCRETE | 5 | CPR12; CPR18; CPR21; CPR23; SPR14 |
R0402_H04_M | R0402_H04_M | 10K | DISCRETE | 35 | CPR13; CPR24; CPR26; CPR27; CPR32; CPR33; CPR34; CPR40; CPR41; CPR42; CPR43; CPR207; LCR4; LCR17; MCR9; MCR15; MCR26; MCR29; MCR30; MCR33; MCR34; MER22; MER23; MER24; MER25; MER26; MER61; MER62; MER63; MER64; SSR9; SSR32; SSR33; SSR34; SSR35 |
R0402_H04_M | R0402_H04_M | 0 | DISCRETE | 73 | CPR14; CPR15; CPR16; CPR30; CPR36; CPR48; CPR51; CPR52; CPR53; CPR54; CPR55; CPR56; CPR57; CPR69; CPR76; CPR79; CPR80; CPR118; CPR210; CPR211; LCL18; LCL19; LCL20; LCL23; LCL25; LCL26; LCL27; LCR36; MCR6; MCR7; MCR8; MCR14; MCR20; MCR21; MCR22; MCR27; MCR31; MCR32; MCR35; MCR36; MCR38; MCR39; MEL1; MER11; MER13; OTR16; OTR18; OTR19; OTR50; OTR53; OTR54; OTR56; OTR58; OTR59; OTR61; SPR9; SPR61; SPR132; SPR133; SSR5; SSR6; SSR7; SSR8; SSR13; SSR14; SSR16; SSR17; SSR18; SSR19; SSR26; SSR28; SSR29; SSR37 |
R0402_H04_M | R0402_H04_M | 100K | DISCRETE | 34 | CPR19; CPR37; CPR60; CPR61; CPR62; CPR63; CPR64; CPR71; CPR206; LCR16; MCR16; MCR17; MCR18; MCR19; OTR23; OTR24; OTR25; OTR27; OTR28; OTR34; OTR44; SPR16; SPR18; SPR51; SPR62; SPR63; SPR124; SPR134; SPR135; SPR136; SPR139; SPR140; SSR11; SSR20 |
R0402_H04_M | R0402_H04_M | 470 | DISCRETE | 1 | CPR20 |
R0402_H04_M | R0402_H04_M | 10 | DISCRETE | 6 | CPR28; CPR29; LCL9; LCL11; LCL12; LCL13 |
R0402_H04_M | R0402_H04_M | 68K | DISCRETE | 2 | CPR31; MER65 |
R0402_H04_M | R0402_H04_M | 470K | DISCRETE | 2 | CPR35; CPR38 |
R0402_H04_M | R0402_H04_M | 44.2 | DISCRETE | 1 | CPR39 |
R0402_H04_M | R0402_H04_M | 100 | DISCRETE | 5 | CPR44; CPR45; CPR46; CPR47; CPR59 |
R0402_H04_M | R0402_H04_M | 169K | DISCRETE | 1 | CPR185 |
R0402_H04_M | R0402_H04_M | 120K | DISCRETE | 1 | CPR186 |
R0402_H04_M | R0402_H04_M | 24K | DISCRETE | 2 | CPR208; MCR37 |
R0402_H04_M | R0402_H04_M | 2K | DISCRETE | 5 | LCR2; SPR52; SPR53; SSR12; SSR21 |
R0402_H04_M | R0402_H04_M | 200 | DISCRETE | 1 | LCR5 |
R0402_H04_M | R0402_H04_M | 5.1K | DISCRETE | 1 | LCR14 |
R0402_H04_M | R0402_H04_M | 5.9 | DISCRETE | 1 | LCR15 |
R0402_H04_M | R0402_H04_M | 91K | DISCRETE | 1 | LCR18 |
R0402_H04_M | R0402_H04_M | 22 | DISCRETE | 1 | MER10 |
R0402_H04_M | R0402_H04_M | 33 | DISCRETE | 5 | MER27; MER28; OTL3; OTR29; OTR30 |
R0402_H04_M | R0402_H04_M | 150K | DISCRETE | 1 | OTR26 |
R0402_H04_M | R0402_H04_M | 178K | DISCRETE | 1 | SPR2 |
R0402_H04_M | R0402_H04_M | 200K | DISCRETE | 4 | SPR3; SPR6; SPR10; SPR17 |
R0402_H04_M | R0402_H04_M | 147K | DISCRETE | 1 | SPR4 |
R0402_H04_M | R0402_H04_M | 2.87K | DISCRETE | 1 | SPR5 |
R0402_H04_M | R0402_H04_M | 47K | DISCRETE | 1 | SPR11 |
R0402_H04_M | R0402_H04_M | 160K | DISCRETE | 1 | SPR13 |
R0402_H04_M | R0402_H04_M | 80.6KOHM | DISCRETE | 2 | SPR58; SPR59 |
R0402_H04_M | R0402_H04_M | 36K | DISCRETE | 1 | SPR119 |
R0402_H04_M | R0402_H04_M | 1.5K | DISCRETE | 4 | SSR22; SSR23; SSR24; SSR25 |
R0402_H045_M | R0402_H045_M | 100K | DISCRETE | 1 | SPR15 |
R0402_H055_M | R0402_H055_M | 16Kohm | IO | 1 | CPR17 |
R0603_H055_M | R0603_H055_M | 0 | DISCRETE | 6 | CPR184; LCR12; LCR13; LCR35; SPR7; SPR8 |
R0805_H06_M | R0805_H06_M | 0 | DISCRETE | 1 | SPR130 |
RP0805_10_M | RP0805_10_M | 50pF | IC | 4 | LCL14; LCL15; LCL16; LCL17 |
RP_8P4R_0804D_H05_M | RP_8P4R_0804D_H05_M | 33X4 | DISCRETE | 2 | MERP21; MERP22 |
SHBKT_L21W12P8H1P7_M | SHBKT_L21W12P8H1P7_M | L21/W12.8/H1.7 | IO | 1 | CPBK2 |
SHBKT_L39P78W35P41H1P7_DODGE_M | SHBKT_L39P78W35P41H1P7_DODGE_M | BKT_1P | IO | 1 | CPBK1 |
SOD-123_H1P35_M | SOD-123_H1P35_M | 1N5819HW-7-F | IC | 1 | LCD1 |
SOT23_FET_M | SOT23_FET_M | IRLML6402TRPBF | IC | 5 | LCQ1; SPQ13; SPQ14; SSQ2; SSQ3 |
SOT25_H1P35_M | SOT25_H1P35_M | TPS62220DDCR | IC | 1 | CPU8 |
SOT25_H1P35_M | SOT25_H1P35_M | AME8801AEEVZ_3.3V | IC | 1 | SPU4 |
SOT26_095MM_H1P1_M | SOT26_095MM_H1P1_M | MP3204DJ-C169-LF-Z | IC | 1 | LCU1 |
SOT723_H05_M | SOT723_H05_M | WNM2030-SOT723 | IC | 8 | LCQ2; MCQ6; OTQ4; OTQ10; SPQ16; SPQ17; SPQ18; SPQ19 |
STANDOFF_M16_H15_CU_TIN_OPEN_M | STANDOFF_M16_H15_CU_TIN_OPEN_M | OD4.0/ID3.0 | IO | 4 | MTG1; MTG2; MTG3; MTG4 |
SWTAC_AT_NAIS_EVQP-03_M | SWTAC_AT_NAIS_EVQP-03_M | EVQPLHA15 | IO | 2 | OTSW1; OTSW2 |
TOUCHPAD_SQ020_M | TOUCHPAD_SQ020_M | 0.5X0.5MM | IO | 7 | CPTP2; CPTP3; CPTP5; CPTP6; LCTP1; SSTP1; SSTP11 |
TOUCHPAD_SQ050_M | TOUCHPAD_SQ050_M | 1.27X1.27MM | IO | 3 | OTTP1; SPTP1; SPTP2 |
TXC5X3_M | TXC5X3_M | 12MHZ | IC | 2 | CPX1; CPX2 |
VR0402_H06_M | VR0402_H06_M | VA-480P | DISCRETE | 7 | CPV1; CPV9; OTV11; OTV12; OTV13; OTV15; SSV1 |
VR0402_H06_M | VR0402_H06_M | VA-100P | DISCRETE | 7 | CPV8; CPV10; LCV1; LCV2; LCV3; LCV4; OTV6 |
VR0402_H06_M | VR0402_H06_M | VA-15P | DISCRETE | 3 | OTV7; OTV8; OTV9 |
XTAL_CC7V_M | XTAL_CC7V_M | 32.768K | IC | 1 | CPX3 |
附件:
