作品名:[AD 10][2层] tc1002+LM393+IRF540N+IR2101 电机驱动板 PCB
7 W! G# W' ?' t
7 C& P- W+ o! j3 ^5 k" j文件描述$ o y( s! E! u6 J1 ?' O Z
1. 作品用途:电机驱动板" B# O9 ` C! i; o2 d |, N8 s
2. 软件版本:AD 10( n6 [& ?/ x3 }4 w; a* }; z
3. 层数:2层板9 l1 v' }; i* u" g b
4. 用到的主要芯片: tc1002+LM393+IRF540N+IR2101
$ E k4 c& T7 w- k9 y5. PCB尺寸:101.4mm*70.3mm
: k0 e5 A! _- c$ L# \2 f! o* k# ~6 b- r( z% o5 H
作品截图如下:0 ~8 t. g% T$ f! ]9 d2 R
顶层截图:
/ U. v N* D/ t- J6 K+ _& d2 X
1 Y5 j1 ]# A$ G' @% V6 T% D: a
: k$ ~; g+ d; Z% @, w3 q+ R
底层截图:
) q! I$ z8 W! B+ J
9 z' }7 B4 ], c7 O* E; z* l7 F) L w4 J# o" {2 Y+ c
全层截图:. l- h5 [1 I f. e: }
8 P6 b$ u, F# B4 d/ j
7 ~$ F* U- c5 Z r3 W; I叠层信息截图如下:
" f9 {, _0 z# Y- Z6 a; \+ [0 x, s
9 }8 m7 a6 h6 F# ?) X
$ w2 s4 z& o0 s# y8 t
BOM:7 i# J: E! ?/ T3 v
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1uF | C1, C2, C3, C4, C15 | 0805 | 5 | 100nf | C5, C6, C7, C8, C18, C100, C401, C501, C506, C507, C701, C801, C900 | 0805 | 13 | 1nf | C16, C505 | 0805 | 2 | 470PF | C17 | 0805 | 1 | 25V/100UF | C19, EC1 | CAP@7 | 2 | 25V/100UF | C20, C21 | CAP@6 | 2 | 220P | C22, C23 | 0805 | 2 | 100nf | C400 | 0805C | 1 | 270PF | C502, C503 | 0805 | 2 | 470nf | C504 | 0805 | 1 | | C700, C800 | 0805 | 2 | | CON1 | CON2@5.08 | 1 | CON6 | CON2 | CON2@5.08 | 1 | 1N4148 | D1, D2, D3, D5, D6, D10, D11, D20, D21 | D4148 | 9 | 1N4148 | D4, D9, D14, D19 | 7227 | 4 | UF2D | D8, D13, D18, D23 | 7227 | 4 | 4148 | D15, D16 | D4148 | 2 | US2D | D24, D25, D26 | 7227 | 3 | | D27 | 7227 | 1 | 100V/100UF | E1, E2 | CAP1000UF | 2 | | JP1 | JP6 | 1 | LEDG | LEDG | LED2 | 1 | LEDR | LEDR | LED2 | 1 | IRF540N | Q1, Q2, Q3, Q4, Q5, Q6, Q7, Q8 | T0220 | 8 | FU220N | Q9 | MOS-1N | 1 | 270R | R1, R3, R5 | 0805 | 3 | 68k | R7 | 0805 | 1 | 36k | R8 | 0805 | 1 | 3.9k | R9, R71 | 0805 | 2 | 4.7k | R10, R26, R28, RP0, RP1, RP2 | 0805 | 6 | 1k | R11, R12, R23, R24, R30, R74 | 0805 | 6 | 10k | R13, R14, R15, R16, R17, R18, R19, R20, R39, R72 | 0805 | 10 | 47k | R21 | 0805 | 1 | 30k | R22 | 0805 | 1 | 10R | R25, R27, R36, R40 | 0805 | 4 | 3.6k | R29 | 0805 | 1 | 750R | R31, R32 | 0805 | 2 | 51R | R33 | 0805 | 1 | 22R | R34, R37 | 0805 | 2 | 20R | R35 | 0805 | 1 | 39R | R38, R73 | 0805 | 2 | 100R | R42, R45, R46, R49, R50, R53, R54 | 0805 | 7 | 0.22R/2W | R58, R59, R60, R61 | AXIAL15 | 4 | 16.9K | R62, R62A, R63, R63A, R64, R64A, R65, R65A | 1206 | 8 | 4.7k | R66, R67 | 1206 | 2 | 470K | R69 | 0805 | 1 | 15K | R70 | 0805 | 1 | 0.5R | R75 | 1206 | 1 | 2.2K | R260, R270 | 0805 | 2 | 33R | R900 | 0805 | 1 | | SW | DIP16 | 1 | | T1 | HT1 | 1 | TLP2531 | U1 | DIP8 | 1 | P521 | U2 | DIP4 | 1 | HER4093 | U3 | SOJ-14 | 1 | LM339 | U4 | SOJ-14 | 1 | tc1002 | U5 | QFP44 | 1 | LM393 | U7, U8 | SO-8 | 2 | LM317 | U9 | LM317 | 1 | LM358 | U10 | SO-8 | 1 | IR2101 | U11, U12, U13, U14 | SO-8 | 4 | 3843B | U15 | SO-8 | 1 | 78L05 | U16 | SO-8 | 1 |
* w1 e& f8 b- {3 t附件:
4 V$ c2 \* R. u1 s6 F1 V7 t" d7 jPCB源文件如下:
+ \; r, O) x. E. p# b4 n) |; B5 a7 h. I' k p$ x
5 d! j% E& Q$ m; j
