查看: 252|回复: 0
[allegro16.6][6层]Atmel ATSAMA5D2-XULT__KitsFiles参考板(SAMA5D27+AT32UC3A425...
发表于 2020-1-11 16:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
/ Y' {9 z$ g3 t
[allegro16.6][6层]Atmel ATSAMA5D2-XULT__KitsFiles参考板(SAMA5D27+AT32UC3A4256HHB-C1UR+2片DDR)原理图和pcb文件
/ E, H! e2 J# m0 y0 x$ o- ]9 ?2 h) F$ p; A
文件描述:5 l: t9 M5 {1 b
) j& `9 `+ Y% b- H+ B1. 作品用途:Atmel ATSAMA5D2-XULT__KitsFiles参考板2 o- i6 j: h3 a) X6 A
2. 软件版本:allegro16.68 b1 A( O' E6 ?
3. 层数:6层
0 u3 |: L3 q8 r, R+ q& c4. 用到的主要芯片:SAMA5D27+AT32UC3A4256HHB-C1UR+2片DDR. t  u+ |  y( ~/ n# X
5. pcb尺寸: 3456.693*5307.087 MIL
+ `5 p* ]2 q- M1 H
9 s3 @$ C8 b( v* ~6 Y+ Q" Q作品截图如下:/ u& g" L# b: C
- R0 s+ ~4 Q, l/ G7 S
顶层截图:" q* }! l+ }% c5 s! X% z8 U0 I
0 c- V# @* }/ L1 J
底层截图:
+ b% d6 P6 i, _" `) \* e: ]' l: D& ]: I5 b7 w
2 G* Y; B( [! ^/ ^' t9 x. T7 Y' B
全层截图:
% u9 x$ U! z3 d+ t8 T! }) `* C/ ]1 @+ v
) y) `- B+ D% |, M% L0 H* C4 g& s( ?BOM:* L8 i1 G% H) N
Bill of Material Report (Condensed)
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_CLASS
QUANTITY
REFDES
名称
类型
属性
类别
数量
位号
BGA9P4
FAN48610_BGA9P4_FAN48610
FAN48610
IC
U22
BGA100F
AT32UC3A_BGA100F_AT32UC3A4256HH
AT32UC3A4256HHB-C1UR  ( AT32UC3A4256J-C1UR, Factory Programmed )
IC
U1
BGA153P5
EMMC_BGA153P5_MTFC4GLDEA-0M  WT
MTFC4GLDEA-0M WT
IC
U11
BGA289P8
SAMA5D2X_BGA289_0_BGA289P8__SAM
SAMA5D27-CN
IC
U6
BGADDR96P8B90X140
MT41K128M16JT-125_BGADDR96P8B90
MT41K128M16JT-125:K
IC
U4; U8
C117X68
CAP_PN_C117X68_0.2F/3.3V
0.2F/3.3V
IC
C42
C0402
C0402_C0402_100NF
100nF
IC
95
C1; C4; C8; C10; C15;  C21; C24; C25; C29; C31; C38; C45; C46; C51; C52; C53; C54; C55; C58; C62;  C63; C65; C66; C68; C69; C72; C76; C77; C78; C79; C80; C81; C87; C88; C89;  C90; C91; C92; C93; C94; C95; C96; C99; C100; C101; C102; C103; C104; C107;  C108; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121;  C123; C125; C126; C128; C129; C130; C131; C132; C133; C134; C135; C136; C138;  C139; C140; C143; C144; C145; C146; C149; C150; C151; C153; C155; C156; C161;  C167; C170; C172; C174; C175; C177; C178
C0402
C0402_C0402_1NF
1nF
IC
13
C5; C30; C49; C50;  C67; C74; C82; C84; C97; C105; C122; C137; C141
C0402
C0402_C0402_DNP(1NF)
DNP(1nF)
IC
C7
C0402
C0402_C0402_10PF
10pF
IC
C9; C127
C0402
C0402_C0402_20PF
20pF
IC
C11; C14; C57
C0402
C_GENERIC_C0402_100NF_
100nF
IC
C18; C75; C86; C160;  C162
C0402
C0402_C0402_22PF
22pF
IC
C34; C35; C40; C41;  C106; C109
C0402
C0402_C0402_27PF
27pF
IC
C47; C48
C0402
C_GENERIC_C0402_10NF_
10nF
IC
C158; C159
C0402
C_GENERIC_C0402_47NF_
47nF
IC
C166
C0603
C0603_C0603_2.2UF
2.2uF
IC
11
C6; C16; C61; C73;  C98; C124; C152; C154; C168; C171; C179
C0603
C0603_C0603_DNP(1UF)
DNP(1uF)
IC
C44
C0603
C0603_C0603_1UF
1uF
IC
C85
C0805
C0603_C0805_10UF
10uF
IC
24
C2; C3; C12; C20;  C22; C23; C26; C27; C28; C32; C33; C36; C37; C39; C59; C60; C64; C70; C71;  C157; C163; C164; C176; C180
C0805
C0603_C0805_4.7UF
4.7uF
IC
12
C13; C17; C19; C43;  C56; C83; C142; C147; C148; C165; C169; C173
C0805
C0603_C0805_22UF
22uF
IC
C181
CON4B100X60M
1X3PIN_CON4B100X60M_1X3PIN
1X3Pin
IC
J3
CON4B160X70V_A
1X4PIN_CON4B160X70V_A_1X4PIN
1X4Pin
IC
J5
DCK6FN
ADG849_DCK6FN_ADG849
ADG849
IC
U13
DFN8_1P5R
AT24C08B-PU_DFN8_1P5R_AT24MAC40
AT24MAC402-MAHM-T
IC
U18
FPCB50_2P5
XF2M_OMRON50PTS_0_FPCB50_2P5_50
50 Pin FPC Connector
IC
J2
H2M
1X2PTS_MALE_STRIGHT_2.00MM_H2M_
DNP(Header 1X2  2.54MM)
IC
J15
H2M
1X2PTS_MALE_STRIGHT_2.00MM_H2_2
Header 1X2
IC
JP3; JP4; JP5; JP6;  JP7; JP8
H2P20
1X2PTS_MALE_STRIGHT_2.00MM_H2P2
DNP(Header 1X2  2.00MM)
IC
J4
H2P20
1X2PTS_MALE_STRIGHT_2.00MM_H2_1
Header 1X2
IC
JP1; JP2; JP9
H2X2LMZ
HEADER  2X2_H2X2LMZ_DNP(HEADER 2
DNP(Header 2X2)
IC
J24
H2X3MZ
2X3PTS_MALE_STRAIGHT_2.54MM_H2X
Header 2X3
IC
J16
H2X10LMZ
2X10PTS_MALE_ANGLE_2.54MM_H2X10
DNP(Header 2X10)
IC
J25; J26
H6M
1X6PTS_MALE_STRAIGHT_2.54MM_H6M
Header 1X6
IC
J1
H8M
1X8PTS_FEMALE_STRAIGHT_2.54_H8M
Socket 1X8
IC
J7; J8; J9; J21; J22
H10M
1X10PTS_FEMALE_STRAIGHT_2.54_H1
Socket 1X10
IC
J20
HS2X5_2JZ
2X5PTS_MALE_STRAIGHT_1.27MM_HS2
DNP(Header 2X5)
IC
J10
HS2X5_2JZ
2X5PTS_MALE_STRAIGHT_1.27MM_H_1
Header 2X5
IC
J11
HS2X7_2JZ
2X7PIN_HS2X7_2JZ_DNP(HEADER  2X7
DNP(Header 2X7)
IC
J12
HS2X15_2MZ
2X15PTS_MALE_STRAIGHT_2.54_HS2X
Header 2X15
IC
J18
H_S2X18MZ
2X18PTS_FEMALE_STRAIGHT_2.54_H_
Socket 2X18
IC
J17
L0603
L_SMT_L0603_10UH_150MA
10uH_150mA
IC
L12; L14; L20; L22
L1008
L_10UH-150  MA_L1008_2.2UH
2.2uH
IC
L1; L5; L6
L1008
L_10UH-150  MA_L1008_0.47UH
0.47uH
IC
L27
LED4B32X28
RGB_FULL  COLOR_LED_LED4B32X28_R
RGB LED
IC
D2
LED0805
LED RED  KPG-1608_0_LED0805_RED
RED
IC
D1; D4
LED0805
LED BLUE  KPG-1608_0_LED0805_BLU
BLUE
IC
D3
MHC50D30
PTH_2_MHC50D30_PTH
PTH
IC
MH1; MH2; MH4
MHC50D30
PTH_3_MHC50D30_PTH
PTH
IC
MH3
QFN32_1P5H
KSZ8081RNB_0_QFN32_1P5H_KSZ8081
KSZ8081RNB
IC
U3
QFN40_1P4H
ACT8945A_QFN40_1P4H_ACT8945AQJ4
ACT8945AQJ405-T
IC
U2
R0402
R_GENERIC_R0402_10K_
10K
IC
33
R1; R6; R7; R31; R32;  R33; R34; R48; R60; R65; R66; R67; R68; R100; R127; R186; R187; R209; R217;  R218; R225; R226; R229; R230; R272; R301; R312; R313; R318; R319; R323; R340;  R345
R0402
R_GENERIC_R0402_200K
200K
IC
R2; R184
R0402
R_GENERIC_R0402_100K_
100K
IC
14
R3; R12; R15; R43;  R53; R74; R75; R104; R183; R242; R243; R332; R333; R346
R0402
R_GENERIC_R0402_330R_
330R
IC
15
R4; R5; R46; R76;  R77; R78; R79; R92; R93; R118; R120; R132; R133; R134; R135
R0402
R_GENERIC_R0402_68K_
68K
IC
R8; R189; R192; R241;  R245
R0402
R_GENERIC_R0402_1K_
1K
IC
12
R9; R45; R51; R52;  R54; R55; R56; R57; R58; R69; R152; R275
R0402
R_GENERIC_R0402_6.8K  1%_
6.8K 1%
IC
R10; R180; R181
R0402
R_GENERIC_R0402_DNP(11K  1%)_
DNP(11K 1%)
IC
R11
R0402
R_GENERIC_R0402_49.9K  1%
49.9K 1%
IC
R13; R14
R0402
R_GENERIC_R0402_100R  1%_
100R 1%
IC
13
R16; R17; R20; R91;  R94; R117; R119; R123; R146; R227; R261; R280; R310
R0402
R_GENERIC_R0402_11K  1%_
11K 1%
IC
R18
R0402
R_GENERIC_R0402_0R
0R
IC
32
R19; R30; R35; R40;  R42; R50; R80; R81; R136; R137; R155; R178; R194; R196; R198; R200; R202;  R203; R206; R247; R249; R252; R258; R260; R270; R271; R281; R290; R294; R302;  R316; R329
R0402
R_GENERIC_R0402_2.2M  1%_
2.2M 1%
IC
R21
R0402
R_GENERIC_R0402_1.5M  1%_
1.5M 1%
IC
R22
R0402
R_GENERIC_R0402_39R
39R
IC
16
R23; R25; R49; R140;  R161; R163; R165; R222; R239; R246; R251; R259; R278; R279; R282; R285
R0402
R_GENERIC_R0402_DNP(3.9K  1%)_
DNP(3.9K 1%)
IC
R24
R0402
R_GENERIC_R0402_DNP(8.2K  1%)_
DNP(8.2K 1%)
IC
R26
R0402
R_GENERIC_R0402_2.43K  1%_
2.43K 1%
IC
R27
R0402
R_GENERIC_R0402_DNP(330R)_
DNP(330R)
IC
11
R28; R193; R195;  R197; R199; R201; R204; R205; R248; R253; R257
R0402
R_GENERIC_R0402_DNP(1M)_
DNP(1M)
IC
R29; R64; R103; R138
R0402
R_GENERIC_R0402_DNP(0R)
DNP(0R)
IC
18
R36; R37; R38; R39;  R41; R99; R158; R240; R244; R268; R273; R283; R292; R299; R336; R341; R342;  R344
R0402
R_GENERIC_0_R0402_100R  1%
100R 1%
IC
R44
R0402
R_GENERIC_0_R0402_22R
22R
IC
92
R47; R61; R72; R73;  R82; R83; R84; R85; R86; R87; R88; R89; R90; R95; R97; R98; R101; R102; R106;  R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R122; R141; R143;  R145; R148; R150; R154; R156; R157; R159; R160; R162; R164; R166; R167; R168;  R169; R170; R171; R172; R173; R174; R175; R176; R177; R188; R190; R191; R207;  R208; R213; R215; R216; R219; R220; R221; R223; R224; R228; R231; R265; R266;  R267; R274; R276; R277; R286; R287; R288; R289; R291; R295; R296; R297; R298;  R304; R305; R307; R308; R311; R315; R322; R324
R0402
R_GENERIC_R0402_470R_
470R
IC
R59; R63; R314; R317;  R325; R326; R328
R0402
R0603_R0402_6.49K 1%
6.49K 1%
IC
R70
R0402
R_GENERIC_0_R0402_DNP(0R)
DNP(0R)
IC
R96; R121
R0402
R_GENERIC_R0402_47K_
47K
IC
11
R105; R142; R144;  R147; R149; R151; R232; R233; R234; R236; R237
R0402
R_GENERIC_R0402_240R  1%_
240R 1%
IC
R124; R238
R0402
R_GENERIC_0_R0402_2.2K
2.2K
IC
R125; R126; R306;  R309; R331; R334
R0402
R_GENERIC_R0402_DNP(10K)_
DNP(10K)
IC
R128; R320
R0402
R_GENERIC_0_R0402_DNP(2.2K)
DNP(2.2K)
IC
R139
R0402
R_GENERIC_R0402_DNP(100R  1%)_
DNP(100R 1%)
IC
R153
R0402
R_GENERIC_R0402_DNP(1K)_
DNP(1K)
IC
R179; R254
R0402
R_GENERIC_R0402_390R  1%_
390R 1%
IC
R185
R0402
R_GENERIC_R0402_DNP(47K)_
DNP(47K)
IC
R235; R255
R0402
R_GENERIC_R0402_23.2K  1%_
23.2K 1%
IC
R250
R0402
R_GENERIC_R0402_20K  1%_
20K 1%
IC
R256
R0402
R_GENERIC_0_R0402_DNP(22R)
DNP(22R)
IC
R262
R0402
R_GENERIC_R0402_5.62K  1%_
5.62K 1%
IC
R263
R0402
R_GENERIC_R0402_DNP(68K)
DNP(68K)
IC
R337; R343
R0402
R_GENERIC_R0402_68K
68K
IC
R338; R339
R0603
BEAD_  FERRITE_R0603_180OHM AT 1
180ohm at 100MHz
IC
19
L2; L3; L4; L7; L8;  L9; L10; L11; L13; L15; L16; L17; L18; L19; L21; L23; L24; L25; L26
R0603
R_GENERIC_R0603_2R2_
2R2
IC
R129; R293; R300
R0603
R_GENERIC_R0603_0R
0R
IC
9
R130; R211; R214;  R264; R284; R303; R321; R327; R330
R0603
R_GENERIC_R0603_1R  1%_
1R 1%
IC
R131; R182; R269
R0603
R_GENERIC_R0603_DNP(0R)
DNP(0R)
IC
R210; R212
R0805
R_GENERIC_R0805_0R
0R
IC
R62; R71; R347
R0805
R_GENERIC_R0805_DNP(0R)
DNP(0R)
IC
R335
RJ45_13F-64GY_P12_4
J00-0061  PULSE_0_RJ45_13F-64GY_
RJ45 Connector
IC
J6
SD13_5B267X180
SD_MMCPLUS_SD13_5B267X180_SD  CA
SD Card Connector
IC
J19
SOD123
RB160M-60TR_SOD123_RB160M-60TR
RB160M-60TR
IC
D5
SOD123
LL4148_SOD123_1N4148W
1N4148W
IC
D7; D8
SOD123
RB160M-60TR_SOD123_(REPLACED  WI
(replaced with  0R-1206 -see User Guide)
IC
D9
SOIC8JA
SP2525A-SO8_SOIC8JA_SP2525A-1EN
SP2525A-1EN-L
IC
U16
SOIC8JG
AT25DF321_SU_0_SOIC8JG_AT25DF32
AT25DF321A
IC
U9
SOIC8JG
QSPI_N25Q_8PIN_SOIC8JG_DNP(N25Q
DNP(N25Q128A13ESE40F)
IC
U10
SOT23_123
SSL-LX15D-RP/SOT23_2_SOT23_123_
BAT54C
IC
D6
SOT23_123
IRLML2402_0_SOT23_123_BSS138
BSS138
IC
8
Q1; Q2; Q3; Q4; Q5;  Q6; Q8; Q9
SOT23_123
PMOS_0_SOT23_123_DNP(IRLML6402)
DNP(IRLML6402)
IC
Q7
SOT23_123
TLV431A_SOT23_123_TLV431A
TLV431A
IC
U7
SOT143B
PRTR5V0U2X_SOT143B_PRTR5V0U2X
PRTR5V0U2X
IC
U5
SOT353_5
1G126_0_SOT353_5__NL17SZ126DFT2
NL17SZ126DFT2G
IC
U14; U15; U20; U21
SOT563_6
DMC2400UV_SOT563_6_DMC2400UV
DMC2400UV
IC
U17; U19
SWS4B60S
SWITCH2_0_SWS4B60S_TACT  SWITCH
Tact Switch
IC
BP1; BP2; BP3
TP30
TP_TP30_SMD
SMD
IC
27
TP1; TP2; TP3; TP4;  TP5; TP6; TP7; TP8; TP9; TP10; TP12; TP13; TP15; TP16; TP17; TP18; TP19;  TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP30
TP80
TP_TP80_SMD
SMD
IC
TP11; TP14; TP29
TSSOP8FA
TPS2113_TSSOP8FA_TPS2113
TPS2113
IC
U12
USB4_2AL
SINGLE USB TYPE  A_USB4_2AL_SING
Single USB Type A
IC
J13
USBMICRO5_6A
USB_MICROAB_0_USBMICRO5_6A_MICR
MicroUSB AB Connector
IC
J14; J23
X4S32X25
XTAL_13Y_A_X4S32X25__12MHZ  CL=1
12MHz CL=15pF
IC
Y1; Y4
X4S32X25
12MHZ_X4S32X25_25MHZ  CL=20PF
25MHz CL=20pF
IC
Y2
X4S70X15
32_0.768K_X4S70X15_32.768KHZ  CL
32.768KHz CL=12.5pF
IC
Y3
附件:! r* Y* n* Y& r- x* E. \
原理图和PCB文件如下:, b6 P8 z. @. l6 f
游客,如果您要查看本帖隐藏内容请回复
% s2 ~) \$ J: U9 y, ^* E& m( V% V5 [( s2 b0 H; f1 P9 _$ r  }: V/ L
- J+ X" {5 e- K- r+ k4 j
GMT+8, 2025-7-18 21:44 , Processed in 0.125000 second(s), 28 queries , Gzip On.
