作品名:[AD 10][4层]物联网开发板硬件设计参考(STM32L475VGT6+LSM6DSL+HTS221)原理图和PCB源文件* b0 M9 ^+ z8 i: g
& c; b$ p6 a+ T/ H' q! J) V# O6 \
文件描述4 ^+ Z l/ A* O+ A
& d4 {8 c8 g( K5 M& r; g1. 作品用途:物联网开发板硬件设计参考
5 N. b/ J5 \! z- q! T0 p1 M4 l+ I& T( ?9 X9 a6 |, F( o" X
2. 软件版本:AD 10
% w! M4 H3 {6 p3 G- \$ A, O( b; A
- x3 D- X6 v, W3. 层数:4层板* y* U) q6 O( K& N
, \! a8 n( \! y& ?) Q. T
4. 用到的主要芯片:STM32L475VGT+LSM6DSL+HTS221: o3 G! v% j' [
- u* s4 |5 Y/ N, _( j; x& g5. PCB尺寸:90mm*62mm
" z: ?& j R, V" ?) B* W
8 K& X6 X9 U- ^" J5 M: @$ L9 j5 n7 N& l3 A7 B* |. m" [" \; g5 u2 j* e' v: p
作品截图如下:/ v' |+ w6 j/ s+ u% r
+ o2 X/ o; n7 s$ p) |顶层截图:" ]1 v1 L4 ?' v1 ?2 |9 f8 K! A
0 ^- h; H/ y* K+ V$ d
3 X) C! T( h! R6 v- O4 Z# Z3 J
底层截图:# b: \. c( A6 B, e, Y1 c7 Z& a8 l
, ?2 r* r# ?( M7 a7 L( u+ ~, V$ S3 h5 s/ Q. @& b
全层截图:
/ l, Y- N$ |0 g* q
( P$ o) Y6 g i5 t& J1 `* x) _: U) A: H; f
叠层信息截图如下:
8 t) ~: O# S, V( P" K6 R
8 ^$ O+ b7 y7 ?* ?) G! F; |$ ?" k. ?, p o7 _1 {* {% i
BOM:
) z1 u! s$ K4 z5 g/ W }Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | SW-PUSH-CMS_BLACK | B1 | SWI_WEALTHMETAL_TD-0341_4P - BACK | 1 | SW-PUSH-CMS_BLUE | B2 | SWI_WEALTHMETAL_TD-0341_4P - BLUE | 1 | 100nF | C1, C3, C5, C7, C9, C10, C11, C12, C13, C17, C19, C20, C22, C23, C25, C26, C28, C29, C31, C32, C33, C34, C36, C42, C43, C44, C45, C47, C48, C54, C55, C57, C60, C61, C62, C63, C65, C73, C74 | 0402_CAP_NPOL | 39 | Not Fitted (8.2pF) | C2, C4 | 0402_CAP_NPOL | 2 | 1uF | C6, C8, C24, C56, C59, C64, C68 | 0402_CAP_NPOL | 7 | 5.1pF | C14, C15 | 0402_CAP_NPOL | 2 | 10uF | C16, C38, C39, C40, C41, C46, C49, C50 | 0603_CAP_NPOL | 8 | 4.7uF | C18, C21, C30, C66 | 0603_CAP_NPOL | 4 | 2.2uF | C27, C75, C76 | 0603_CAP_NPOL | 3 | 10pF | C35, C37, C51, C52, C53, C71 | 0402_CAP_NPOL | 6 | 10nF | C58 | 0402_CAP_NPOL | 1 | 100pF | C67 | 0402_CAP_NPOL | 1 | Not Fitted | C69, C70, C72 | 0402_CAP_NPOL | 3 | Header 10X1_Female_SMD | CN1 | F-V50XC-1X10R-LF | 1 | Header 8X1_Female_SMD | CN2, CN3 | F-V50XC-1X08R-LF | 2 | Header 6X1_Female_SMD | CN4 | F-V50XC-1X06R-LF | 1 | TC2050-IDC-NL | CN5 | CON_TAG-C_TC2050-IDC-NL | 1 | header 2 pins 2.54mm | CN6 | CON_SAMTEC_TSW-102-07-G-S | 1 | 1050170001 | CN7 | CON_USBMICROB_MOLEX_105017-0001_H2P90 | 1 | Header 4 pins | CN8 | CON_SAMTEC_TSW-104-07-G-S | 1 | 475900001 | CN9 | CON_USBMICROAB_MOLEX_47590-0001_H3 | 1 | HEADER_2X6_PMOD | CN10 | Header F 2x6x2.54 TH H PMOD | 1 | Comment | CN26, CN27, CN28, CN29 | Spacer+Nut M3 | 4 | BAT60JFILM | D2, D3, D4, D5 | DIO_SOD323 | 4 | HEADER_2X5 | JP4 | Header M 2x5x2.54 TH V | 1 | Jumper_2.54mm | JP5, JP6, JP7, JP8 | CON_SAMTEC_TSW-102-07-G-S | 4 | FCM1608KF-601T03 | L1 | 0603L | 1 | 742792042 | L2 | 0603L | 1 | LED | LD1, LD2, LD5, LD9 | 0603_LED_GREEN | 4 | LED | LD3 | 0603_LED_Yellow | 1 | LED | LD4 | 0603_LED_Blue | 1 | LD_BICOLOR_CMS | LD6 | LED_BI-GR_HSMF-A201-A00J1 | 1 | LED | LD7, LD8 | 0603_LED_RED | 2 | Comment | Logo_ST | LOGO_ST_Size3 | 1 | BT Module | M1 | SPBTLE-RF | 1 | ISM43362-M3G-L44 | M2 | ISM43362-M3G-L44 | 1 | SPSGRF | M3 | SPSGRF | 1 | BSR14 | Q1, Q2 | SOT23-3 | 2 | 30K | R1 | 0402_RES | 1 | 0R | R2, R6, R12, R13, R42, R43 | 0402_RES | 6 | 1K | R3, R18, R19, R21, R24, R52, R56 | 0402_RES | 7 | 20K | R4 | 0402_RES | 1 | Not Fitted (0R) | R5, R7, R30 | 0402_RES | 3 | 2K2 | R8, R9, R10, R11, R53 | 0402_RES | 5 | 10K | R14, R15, R16, R31, R48, R51, R67 | 0402_RES | 7 | 330R | R20, R25, R44, R47, R55 | 0402_RES | 5 | 680R | R22 | 0402_RES | 1 | 100K | R23, R29, R49, R54, R59 | 0402_RES | 5 | 47K | R26, R57, R58, R62 | 0402_RES | 4 | 4K7 | R27, R40, R41 | 0402_RES | 3 | 2K7 | R28 | 0402_RES | 1 | 22R | R32, R33, R34, R35 | 0402_RES | 4 | Not Fitted (10K) | R36, R64, R65, R66 | 0402_RES | 4 | 200K | R38 | 0402_RES | 1 | 100R | R39, R45 | 0402_RES | 2 | 36K | R46 | 0402_RES | 1 | 1K5 | R50 | 0402_RES | 1 | 0R | R61 | 0603_RES | 1 | Close | SB1, SB2, SB3, SB4, SB5, SB6, SB7, SB8, SB10, SB13, SB14, SB15, SB17, SB18, SB21 | SB | 15 | Open | SB9, SB11, SB12, SB16, SB19, SB20 | SB | 6 | PT | TP1, TP2, TP3, TP4, TP5, TP6 | PTB | 6 | Comment | TP9 | LOGO CE | 1 | STM32L475VGTx | U1 | LQFP100 14x14x1.6 | 1 | MP34DT01-M | U2, U10 | HCLGA-4LD 3x4x1 | 2 | LSM6DSL | U3 | LGA14L-2.5X3X0.86p0.5 | 1 | VL53L0X | U4 | LGA12-optical | 1 | LIS3MDL | U5 | VFLGA12-2x2x1 | 1 | HTS221 | U6 | HLGA6L-2x2x0.9 | 1 | LPS22HB | U7 | HLGA10L-2X2X0.76 | 1 | M24SR64-Y | U8 | SOP8 | 1 | STSAFE-A100 (Not Fitted) | U9 | SOP8 | 1 | MX25R6435F | U11 | SOP8L | 1 | LT1963EST-3.3 | U12 | SOT223_SC73 | 1 | LD1117S50TR | U13 | REG_SOT223-TAB | 1 | LD1117S33TR | U14 | REG_SOT223-TAB | 1 | STM32F103CBT6 | U15 | ICC_LQFP48_7X7_P050 | 1 | LD3985M33R | U16 | REG_SOT23-5L | 1 | ST890CDR | U17 | ICC_SO8_5X4_P127 | 1 | EMIF02-USB03F2 | U18, U20 | ESD_FLIP-CHIP-BGA11_1P44X1P94_P050 | 2 | STMPS2141STR | U19 | MOS_SOT23-5L | 1 | TSV631AILT | U21 | SOT23-5 | 1 | Not Fitted (NX3225GD-8.00M) | X1 | CRY_NX3225GD_2P | 1 | NX3215SA-32.768K | X2 | CRY_NX3215SA_2P | 1 | NX3225GD-8.00M | X3 | CRY_NX3225GD_2P | 1 | ' Z$ G2 F, q" ?& f5 ^
附件:( x+ W3 Y1 c( C; A! x1 @) @. m* C' [/ M
. ?1 @2 V6 g% K原理图和PCB源文件如下:) @: T$ ]% _+ M" [/ ~" ?# r4 e! Y6 N
" a0 x4 q7 N2 N4 H W- l: P. U6 [
, E4 P$ b' {" R: c' v. d6 u* Q. t) N+ E5 T X4 V# n, a+ _8 _
* \. p& s) [! a0 Y2 }$ Z8 D8 x- h
