[allegro17.2][4层]采用CY7C68013A-128AXC的USB 2.0USB到ATA参考设计(SDA+SIO-1+54HC245)原理图和pcb文件 $ w$ z& j' u/ R0 @% h
文件描述: 1. 作品用途:采用CY7C68013A-128AXC的USB 2.0USB到ATA参考设计 2. 软件版本:allegro17.2 3. 层数:4层 4. 用到的主要芯片:SDA+SIO-1+54HC245 5. PCB尺寸:4875*7000 mil ; a+ i' n2 N. d, H+ O
作品截图如下:
3 R5 V4 ?: z3 W9 w/ V顶层截图:
- f, e h3 g) R8 b! ^7 A底层截图: 全层截图: 叠层阻抗信息: 4 `/ U1 }- c, a6 o. Q! @: T6 i3 o
BOM:
0 |# ^0 x9 ~, O# e0 z) m0 @Bill of Material Report (Condensed) | | | | | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | 32SOJ | 32SOJ | CY7C1019BV33-12VC | IC | 1 | U4 | 4148_SOT23 | 4148_SOT23 | 1N4148 | IC | 1 | D1 | 171826-4 | 171826_4 | EXT PWR | IC | 1 | J13 | C-CC0805 | ECJ_2YB1H104K | 0.1 uFd | IC | 27 | C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C13; C17; C18; C20; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C37 | C-CC0805 | 12PFD_0805 | 12 pFd | IC | 2 | C11; C12 | C-CC0805 | ECJ_2VB1H103K | 0.01 uFd | IC | 1 | C22 | C-CC0805 | 0P33UFD_0805 | 0.33 uFd | IC | 1 | C36 | C-CC7163 | ECK_TBC472MF | 4700 pFd 250v | IC | 1 | C16 | C-PCC3216 | 1UFD_TANT_16V | 1 uFd 16v | IC | 1 | C14 | C-PCC3216 | 2P2UFD_TANT_10V | 2.2 uFd 10v | IC | 1 | C15 | C-PCC3216 | 10UFD_TANT_16V | 10 uFd 16v | IC | 2 | C19; C21 | C-PCC7343 | 100UFD_TANT_7343 | 100 uFd 16v | IC | 1 | C35 | CR-LED1206 | LED_GREEN1206 | DRIVE RDY | IC | 3 | D2; D7; D12 | CR-LED1206 | LED_GREEN1206 | BKPT/MONITOR | IC | 1 | D3 | CR-LED1206 | LED_GREEN1206 | GPIO_0 | IC | 1 | D4 | CR-LED1206 | LED_GREEN1206 | VCC3.3 GOOD | IC | 1 | D5 | CR-LED1206 | LED_GREEN1206 | GPIO_1 | IC | 1 | D6 | CR-LED1206 | LED_GREEN1206 | GPIO_2 | IC | 1 | D8 | CR-LED1206 | LED_GREEN1206 | GPIO_3 | IC | 1 | D9 | CR-LED1206 | LED_GREEN1206 | GPIO_4 | IC | 1 | D10 | CR-LED1206 | LED_GREEN1206 | GPIO_5 | IC | 1 | D11 | DIP8_S | 24LC128_DIP8 | 24LC128-I/P | IC | 1 | U7 | FLASH50-1CM-MA2N | CF-TYPE | CF TYPE I & II | IC | 1 | J1 | HDR2 | 103185_2 | AVCC | IC | 1 | J6 | HDR2 | 103185_2 | 3.3V | IC | 1 | J7 | HDR2 | 103185_2 | MM0 | IC | 1 | J8 | HDR2 | 103185_2 | DMACK#_CF | IC | 1 | J10 | HDR2 | 103185_2 | DMARQ_CF | IC | 1 | J11 | HDR2 | 103185_2 | MM1 | IC | 2 | J12; J16 | HDR2 | 103185_2 | 3.3V IN | IC | 1 | J17 | HDR2 | 103185_2 | GPIO0 | IC | 1 | J19 | HDR2 | 103185_2 | GPIO1 | IC | 1 | J21 | HDR2 | 103185_2 | SDA | IC | 1 | J22 | HDR2 | 103185_2 | GPIO2 | IC | 1 | J24 | HDR2 | 103185_2 | GPIO3 | IC | 1 | J26 | HDR2 | 103185_2 | GPIO4 | IC | 1 | J29 | HDR2 | 103185_2 | GPIO5 | IC | 1 | J30 | HDR3 | HDR3_G | 3 PIN HDR | IC | 7 | J2; J3; J4; J5; J15; J23; J28 | HDR3 | HDR3_G | PWR SEL | IC | 1 | J14 | HDR3X2 | 103186-3 | PWR SEL | IC | 1 | J25 | HDR20 | HDR20 | LOGIC ANALYZER HDR | IC | 6 | P1; P2; P3; P4; P5; P6 | HDR_2X20_0P1 | HDR40 | ATA CONNECTOR | IC | 1 | J27 | HDR_2X22_2MM-RA | HDR44-PIN-2MM_RA | 2.5 ATA CONNECTOR | IC | 1 | J18 | MAX809 | MAX809J_SOT23 | MAX809J | IC | 1 | U1 | P-DB9F | P_DB9F | SIO-1 | IC | 1 | J20 | PLCC28_S | 22V10_PLCC28 | GAL22LV10C-7LJ | IC | 1 | U2 | R-CR0805 | 10K_0805 | 10K 5% | IC | 16 | R1; R5; R8; R9; R13; R16; R21; R35; R36; R41; R43; R47; R49; R52; R55; R60 | R-CR0805 | 100K_0805 | 100K | IC | 2 | R2; R15 | R-CR0805 | 0_0805 | zero | IC | 4 | R3; R4; R14; R18 | R-CR0805 | 1M_0805 | 1M | IC | 1 | R6 | R-CR0805 | 39K_0805 | 39K | IC | 1 | R7 | R-CR0805 | 62K_0805 | 62K | IC | 1 | R10 | R-CR0805 | 390_0805 | 390 | IC | 11 | R11; R20; R33; R34; R37; R38; R42; R46; R53; R56; R57 | R-CR0805 | 1K_0805 | 1K | IC | 6 | R12; R19; R39; R44; R50; R58 | R-CR0805 | NO_LOAD_0805_R | NO LOAD | IC | 1 | R17 | R-CR0805 | 22_0805 | 22 | IC | 8 | R22; R23; R24; R25; R26; R27; R29; R31 | R-CR0805 | 2P2K_0805 | 2.2K | IC | 2 | R28; R30 | R-CR0805 | 33_0805 | 33 | IC | 2 | R32; R48 | R-CR0805 | 22K_0805 | 22K | IC | 1 | R40 | R-CR0805 | 4P7K_0805 | 4.7K | IC | 2 | R45; R59 | R-CR0805 | 120K_0805 | 120K | IC | 1 | R51 | R-CR0805 | 5P6K_0805 | 5.6K | IC | 1 | R54 | S-EVQ-PBC07K | SW_PUSHBUTTON_TH | RESET# | IC | 1 | S1 | S-EVQ-PBC07K | SW_PUSHBUTTON_TH | GPIO0 | IC | 1 | S2 | S-EVQ-PBC07K | SW_PUSHBUTTON_TH | GPIO1 | IC | 1 | S3 | S-EVQ-PBC07K | SW_PUSHBUTTON_TH | GPIO2 | IC | 1 | S4 | S-EVQ-PBC07K | SW_PUSHBUTTON_TH | GPIO3 | IC | 1 | S5 | S-EVQ-PBC07K | SW_PUSHBUTTON_TH | GPIO4 | IC | 1 | S6 | S-EVQ-PBC07K | SW_PUSHBUTTON_TH | GPIO5 | IC | 1 | S7 | SO8 | IRF7204 | IRF7204 | IC | 1 | Q5 | SO8 | LT1763CS8-33 | LT1763CS8-3.3 | IC | 1 | U5 | SOIC-16 | LTC1386_SOIC16 | LTC1386CS | IC | 1 | U6 | SOT-23 | 2N7002_SOT23 | 2N7002 | IC | 6 | Q1; Q2; Q3; Q4; Q6; Q7 | SW_DIP4 | 3_435640_5 | 4 POS SW | IC | 1 | SW1 | TP-43R_S | TP-43R_B | GND | IC | 6 | TP1; TP2; TP3; TP4; TP5; TP6 | TP-43R_S | TP-43R_O | 3.3V | IC | 1 | TP7 | TP-43R_S | TP-43R_R | 5V | IC | 1 | TP8 | TQFP128 | CY7C68013A_128AXC | CY7C68013A-128AXC | IC | 1 | U3 | TV-20R | TV-40R | SPARE1 | IC | 1 | TV1 | TV-20R | TV-40R | SPARE8 | IC | 2 | TV2; TV8 | TV-20R | TV-40R | SPARE3 | IC | 1 | TV3 | TV-20R | TV-40R | SPARE4 | IC | 1 | TV4 | TV-20R | TV-40R | SPARE5 | IC | 1 | TV5 | TV-20R | TV-40R | SPARE6 | IC | 1 | TV6 | TV-20R | TV-40R | SPARE7 | IC | 1 | TV7 | USB_B_90 | USB_B_90 | USB B RA | IC | 1 | J9 | Y-XTAL-FX | FX2400018 | 24MHz Crystal | IC | 1 | Y1 |
附件: 原理图和pcb文件 | * \, C5 ?' i Z; s( n' i
