2. 软件版本:allegro17.2
3. 层数:4层
5. PCB尺寸:2700*1000 mil
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 位号 | 数量 | 位号 |
603 | 0_0.1 UFD 0603 X7R_0603_0.1 UFD | 0.1 uFd | IC | 5 | C40; C41; C45; C46; C47 |
603 | 0_0.01 UFD 0603 X7R_0603_0.01 U | 0.01 uFd | IC | 1 | C43 |
603 | 1.0 UFD 0603 X5R_0603_DISCRETE_ | 1.0 uFd | DISCRETE | 1 | C48 |
603 | 560 PFD 0603_0603_DISCRETE_560 | 560 pFd | DISCRETE | 1 | C49 |
603 | 47 NH INDUCTOR 0603 A_0_0603_47 | 47 nH | IC | 1 | L1 |
603 | 2_0.2K OHM 5% 0603_0603_2.2K | 2.2K | IC | 6 | R19; R20; R21; R38; R39; R40 |
603 | 100K OHM 1% 0603_0_0603_100K | 100K | IC | 2 | R22; R33 |
603 | 100 OHM 5% 0603_0603_DISCRETE_1 | 100 ohm | DISCRETE | 4 | R25; R26; R30; R31 |
603 | 470 OHM 5% 0603_0_0603_470 | 470 | IC | 3 | R27; R36; R37 |
603 | 24 OHM 5% 0603 _0603_DISCRETE_2 | 24 ohm | DISCRETE | 2 | R28; R29 |
603 | 10K OHM 5% 0603_0603_DISCRETE_1 | 10K | DISCRETE | 1 | R34 |
805 | 2.2 UFD 0805 X7R 10V_0805_DISCR | 2.2 uFd | DISCRETE | 1 | C44 |
805 | 10 UFD CERAMIC 16V 0805 X5R_080 | 10 uFd 16V | DISCRETE | 1 | C50 |
805 | 100K OHM 1% 0603_0_0805_100K | 100K | IC | 1 | R32 |
1206_FUSE | FUSE 350MA 1206L_0_1206_FUSE_35 | 350mA | IC | 1 | F1 |
ANT_RUFA_W32PCB-R | ANTENNA W_0_ANT_RUFA_W32PCB-R_A | Antennova Rufa | IC | 1 | ANT1 |
C0402_1MMPITCH | 27 PFD 0402 NPO_0_C0402_1MMPITC | 27 pF | IC | 4 | C1; C22; C25; C30 |
C0402_1MMPITCH | 0_0.1 UFD 0402 X5R_C0402_1MMPIT | 0.1 uFd | IC | 2 | C2; C5 |
C0402_1MMPITCH | 2_0.0 PFD 0402 A NPO_C0402_1MMP | 2.0 pFd | IC | 3 | C3; C17; C24 |
C0402_1MMPITCH | NO LOAD CAP 0402 A_0_C0402_1MMP | 1.2pF | IC | 1 | C4 |
C0402_1MMPITCH | 27 PFD 0402 NPO_0_C0402_1MMPI_3 | 0.1uF | IC | 8 | C6; C26; C27; C28; C29; C34; C35; C36 |
C0402_1MMPITCH | 0_0.047 UFD 0402 A X5R_C0402_1M | 0.047 uFd | IC | 6 | C8; C9; C10; C11; C13; C14 |
C0402_1MMPITCH | 0_0.47 UFD 0402 A X5R_C0402_1MM | 0.47 uFd | IC | 2 | C12; C39 |
C0402_1MMPITCH | 27 PFD 0402 NPO_0_C0402_1MMPI_1 | 18 pF | IC | 5 | C15; C16; C31; C32; C33 |
C0402_1MMPITCH | 27 PFD 0402 NPO_0_C0402_1MMPI_2 | 10 pF | IC | 1 | C23 |
C0402_1MMPITCH | 2_0.2NH INDUCTOR 0402_C0402_1MM | 2.2 nH | IC | 2 | L2; L4 |
C0402_1MMPITCH | 2_0.2NH INDUCTOR 0402_C0402_1_1 | 12 nH | IC | 1 | L3 |
C0402_1MMPITCH | 2_0.2NH INDUCTOR 0402_C0402_1_2 | 5.6 nH | IC | 1 | L5 |
C0402_1MMPITCH | R_C0402_1MMPITCH_140 | 140 | IC | 1 | R4 |
C0402_1MMPITCH | R_C0402_1MMPITCH_160 | 160 | IC | 1 | R5 |
C0402_1MMPITCH | NO LOAD RESISTOR 0402_0_C0402_1 | NO LOAD | DISCRETE | 1 | R9 |
C0402_1MMPITCH | 2_0.2K OHM 5% 0402_C0402_1MMPIT | 2.2K | IC | 2 | R23; R24 |
C0402_1MMPITCH | ZERO OHM 0402_0_C0402_1MMPITCH_ | ZERO | DISCRETE | 2 | R41; R42 |
CON-USB-SMRA-MOLEX48037 | USB A RIGHT ANGLE PLUG SMD_CON- | USB A RA PLUG SMD | IC | 1 | J3 |
FILT_DEA202450BT | DEA202450BT-1213C1_0_FILT_DEA20 | DEA202450BT-1213C1 | IC | 1 | FLT1 |
HEADER-8X2-RA-300 | PCB RECEPTACLE_16_RA_FTPC_HEADE | 8X2 PIN RECPT RA | IC | 1 | P1 |
HEADER_5X1 | 5 PIN HEADER _HEADER_5X1_IO_5 P | 5 PIN HDR | IO | 1 | J1 |
LEDC1608X80N | LED BLUE 0603_LEDC1608X80N_LED | LED BLUE | IC | 1 | D1 |
LEDC1608X80N | LED GREEN 0603_0_LEDC1608X80N_L | LED GREEN | IC | 1 | D2 |
LEDC1608X80N | LED RED 0603_LEDC1608X80N_LED R | LED RED | IC | 1 | D3 |
MLF_40P_05MM | CYRF6936-40LFXC_MLF_40P_05MM_CY | CYRF6936 | IC | 1 | U1 |
PSON48P150X110X55-6N | UPG2214TK_PSON48P150X110X55-6N_ | UPG2214TK | IC | 2 | U5; U6 |
QFN50P800X800X100-57N | CY8C24894 QFN56_QFN50P800X800X1 | CY8C24894 QFN56 | IC | 2 | U7; U8 |
SC70-5 | NC7SV34 SC70-5_SC70-5_NC7SV34P5 | NC7SV34P5X | IC | 2 | U10; U11 |
SOIC8 | LT1763CS8-3.3 SO8_SOIC8_LT1763C | LT1763CS8-3.3 | IC | 1 | U9 |
SW-B3FS-1052 | SWITCH TACT 6MM 150GF SPST SMD_ | SW PUSHBUTTON SMT | IC | 1 | SW1 |
TP_40_20 | TEST VIA 20 HOLE 40 PLATED_0_TP | TV-20R | IC | 13 | TV1; TV2; TV3; TV4; TV5; TV6; TV7; TV8; TV9; TV10; TV11; TV12; TV13 |
TSON_6P | UPG2250_TSON_6P_UPG2250 | UPG2250 | IC | 1 | U3 |
XTAL_SM_4P_FX065 | ECERA FF1200030 12MHZ_XTAL_SM_4 | eCera FF 12MHz | IC | 1 | Y1 |
