查看: 285|回复: 0
[allegro16.3][6层] BeagleBoneBlack(XAM3359AZCZ100+TDA19988+TPS65217C)pcb文件
发表于 2020-1-15 17:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 bosnn 于 2020-1-15 17:35 编辑 : I: _9 v5 \9 ?
8 S. t  l+ v6 v7 W; c
: d8 U' z& m5 _
5 E8 \) ?6 q' H8 O文件描述:5 d" U6 _; h; t
! i8 b  `+ E. A1 k1. 作品用途:BeagleBoneBlack
1 k# M8 `, E  K! s) ?/ \2. 软件版本:allegro16.3; H, d. ]. W( Z/ b( T# B/ }+ f1 u
3. 层数:6层
( L2 Z/ Q. e( \1 K8 R6 k6 h4. 用到的主要芯片:XAM3359AZCZ100+TDA19988+TPS65217C
' S% ?/ Z! F- W: ]- v# A$ K6 L5. pcb尺寸:3400*2150 MIL- S& @8 s/ U& r8 t4 @! ^* U
" `1 B4 N( G2 ^% F& W* K% @0 L) W作品截图如下:
9 |/ H% v6 w+ y  \! }  X
% O5 p  o$ {# e6 G顶层截图:
% ]  K4 p6 K3 n2 z9 A . |' o, X0 o! X# ^4 F! R4 E8 C
底层截图:) L* d) ?  M; p* E1 `+ \2 _
6 @1 F( x) n6 }  S3 @! z2 H1 V
2 [& N& ^1 @3 G全层截图:' o8 v! G7 O5 C4 y
8 g) _4 i. R( z. C4 i
4 H4 F$ ~, ~- E0 g: H+ K# a/ W( p7 x3 z' y" ?% y% f
BOM:& a7 {+ ]6 O  c
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP_0.1UF_X5R_6.3V_20% 0201 _400.1uf,6.3VIC99C3; C20; C27; C28; C29; C30; C31; C33; C35; C36; C37; C38; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C56; C57; C58; C59; C60; C61; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C92; C93; C94; C97; C98; C99; C100; C101; C102; C103; C105; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C119; C120; C121; C124; C127; C128; C129; C130; C131; C132; C135; C145; C147; C149; C150; C152; C154; C155; C158; C159
402CAP_2.2UF_X5R_6.3V_10%_0402_4022.2uF,6.3VIC8C16; C17; C18; C125; C144; C146; C148; C151
402CAP_470PF_X7R_25V_10%_0402_402_470pF,6.3VIC1C19
402CAP_18PF_COG_50V_5%_0402_402_1818pF,50VIC4C21; C22; C25; C26
402CAP_1.0UF_X5R_10V_10%_0402_402_1uF,10VIC7C24; C89; C90; C91; C104; C106; C134
402CAP_0.001_X7R_50V_5%_0402_402_00.001uf,50VIC2C32; C123
402470PF/5%/50V/C0G/0603_0_0402_47470pF,6.3VIC1C136
402CAP_0402_100PF_COG_50V_402_15PF15pF,DNIIC4C137; C138; C139; C140
402CAP_0402_0.1UF_X5R_10V_402_0.020.022uF,10VIC1C141
402CAP_30PF_COG_50V_5%_0402_402_3030pF,50VIC2C142; C143
402CAP_0.1UF_X5R_6.3V_20% 0201 __147pf,6.3VIC16C156; C157; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173
402RES_100K_1/16W_1%_0402_402_100K100K,1%IC22R1; R56; R65; R66; R67; R68; R76; R77; R78; R79; R80; R82; R83; R84; R85; R86; R87; R88; R89; R94; R95; R165
402RES_1.5K_1/16W_5%_0402_402_1.5K1.5K,1%IC4R3; R4; R119; R146
402RES_4.75K_1/16W_1%_0402_402_0,10,1%IC10R5; R6; R7; R9; R50; R51; R159; R160; R161; R162
402RES_4.75K_1/16W_1%_0402_402_0,D0,DNIIC1R8
402RES_470_1/10W_5%_0402_402_470K,470K,1%IC1R10
402RES_470_1/10W_5%_0402_402_280K,280K,1%IC1R11
402RES_470_1/10W_5%_0402_402_4.75K4.75K,5%IC5R12; R71; R72; R73; R74
402RES_10K_1/16W_1%_0402_402_10K,110K,1%IC29R14; R52; R53; R54; R96; R98; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R135; R145; R148; R150; R151; R152; R153; R154; R155; R157; R158
402RES_1M_1/16W_1%_0402_402_1M,1%1M,1%IC1R17
402RES_33_0402_0402_3333IC4R18; R21; R28; R167
402RES_0_1/16W_1%_0402_402_0,1%0,1%IC7R19; R20; R27; R29; R30; R142; R149
402RES_4.7K_0402_402_49.9,1%49.9,1%IC5R22; R120; R121; R122; R123
402RES_4.75K_1/16W_1%_0402_402_4.74.75K,1%IC6R23; R24; R25; R26; R163; R164
402RES_33_0402_0402_2222IC1R45
402RES_33_0402_0402_00IC3R46; R47; R48
402RES_100K_1/16W_1%_0402_402_0,1%0,1%IC1R49
402RES_100K_1/16W_1%_0402_402_10_1100K,1%,DNIIC16R55; R57; R58; R59; R60; R61; R62; R63; R64; R69; R70; R81; R90; R91; R92; R93
402RES_100K_1/16W_1%_0402_402_100,100,1%IC1R75
402RES_10K_1/16W_1%_0402_402_1.5K,1.5K,1%IC1R97
402RES_4.75K_1/16W_1%_0402_402_1.51.5K,1%IC3R112; R113; R114
402RES_4.75K_1/16W_1%_0402_402_10K10K,1%IC4R115; R116; R117; R118
402100-1/10W-1%-0603_4_402_10,1%,D10,1%,DNIIC1R124
402100-1/10W-1%-0603_4_402_100,1%100,1%IC5R125; R126; R129; R134; R138
402RES_100_1/10W_5%_0402_402_100,1100,1%IC5R127; R128; R131; R133; R139
402RES_470_1/10W_5%_0402_402_470,5470,5%IC2R130; R132
402RES_10K_1/16W_1%_0402_402_0,1%0,1%IC1R137
402RES_0_1/16W_1%_0402_402_0,1%,DN0,1%,DNIIC1R140
402RES_1M_1/16W_1%_0402_402_1M,1%,1M,1%,DNIIC1R141
402RES_10K_1/16W_1%_0402_402_10,1%10,1%IC1R143
402RES_12.1K_1/16W_1%_0402_402_12.12.1K,1%IC1R144
402RES_1.5K_1/16W_5%_0402_402_1._11.5K1%IC1R147
402RES_0_1/16W_1%_0402_402_10K,1%10K,1%IC1R156
402RES_22.6K_1/16W_1%_0402_402_27K27K,1%IC1R166
805CAP_10UF_Y5V_10V_10%_0805_805_110uF,10VIC24C1; C2; C4; C7; C8; C9; C10; C11; C12; C13; C14; C15; C39; C40; C55; C62; C77; C95; C96; C118; C122; C126; C133; C153
805RES_0.1_0805_805_.1,0805.1,0805IC1R136
2520IND_2.2UH_2.6A_10%_SMD_2520_LQMLQM2HPN2R2MG0LIC3L1; L2; L3
AM33XX_15X15IC_AM335X_ZCZ_AM33XX_15X15_XAM3XAM3359AZCZ100IC1U5
BGA96_T9_P8_9X14MT47H256M8_7_BGA96_T9_P8_9X14_MMT41K256M16HA -125:EIC1U12
BGA153_P14_P5_11P5X13MEM_MNAND_2GB_BGA153_P14_P5_11PMEM_MNAND_2GBIC1U13
CONN3-PWR-PJ102APOWER_JACK_CONN3-PWR-PJ102A_PJ-PJ-200AIC1P1
CONN19_HDMICONN_HDMI_TYPED_CONN19_HDMI_10110118241-001RLFIC1P6
DCK5_2P15X1P4IC_SN74LVC1G06DCK_0_DCK5_2P15X1SN74LVC1G06DCKIC1U3
DCK5_2P15X1P4IC_SN74LVC1G07DCK_DCK5_2P15X1P4SN74LVC1G07DCKIC1U16
DGN-16X60TPS2061_1_DGN-16X60_TPS2051 (DGTPS2051 (DGN)IC1U8
HEADER10X2_SMDHDR_10X2_CJTAG_0_HEADER10X2_SMDCTI JTAG,DNIIC1P2
HEADER23X2HDR_46_F_2_0.1_0.1_HEADER23X2_FFEMALE HEADER 2x23IC2P8; P9
LED_0603LED_LTST-C150GKT_0_LED_0603_DISLTST-C191TBKTDISCRETE5D1; D2; D3; D4; D5
MTGH200C125D_PLMHOLE_MTGH200C125D_PL_MHOLEMHOLEIC4MTG1; MTG2; MTG3; MTG4
OSC4_61X65LS_79X98SMDOSC_12MHZ_1.3V_OSC4_61X65LS_79X24.576MHZIC1Y4
POLYSW200-5638-310PTC_RXEF010_POLYSW200-5638-310_PTC_RXEF010IC1RT1
QFN32_5X5MM_EP3P3MMLAN8710 QFN32_1_QFN32_5X5MM_EP3LAN8710AIC1U14
QFN64S9X9P5IC_TDA19988_HVQFN64_5_QFN64S9X9TDA19988IC1U11
RD205SMD_250DCAP_100UF_TANT_6.3V_3528-21_RD2100uF,6.3VIC1C34
RJ45-7499010211ACONN_RJ45_MAG_WE_0_RJ45-7499010LPJ0011BBNLIC1P5
SD-MICRO-SCHA5B0300MICROSD_CONN_8_SD-MICRO-SCHA5B0SCHA5B0200IC1P10
SIP6HEADER 6_SIP6_HEADER 6HEADER 6IC1J1
SM-7351-IND-0805FER_180_200_0_SM-7351-IND-0805_150OHM800mAIC5FB1; FB2; FB3; FB4; FB7
SM-7351-IND-0805FER_180_200_0805_SM-7351-IND-08150OHM800mAIC1FB5
SM-7351-IND-0805FER_180_200_0_SM-7351-IND-080_10.1 Ohm,0805IC1FB8
SM-7351-RES-0402RES_SM-7351-RES-0402_240240IC1R99
SMINI6-F3-BRN1907_SMINI6-F3-B_DMC56404DMC56404IC2Q1; Q2
SO8-25X75PWR_TLV70233DBV_0_SO8-25X75_TL5TL5209IC1U4
SOD323DIO_SR305_TH_0_SOD323_RB751V40,RB751V40,115IC1D8
SOP8_DCTIC_SN74AUC1G74_SOP8_DCT_SN74AUCSN74AUC1G74IC1U6
SOT23-5MEM_24LC32_SOT23-5_SOT23-5_24LC24LC32AIC1U7
SW4SMD_63X161LSSW_KT11P2JM_2_SW4SMD_63X161LS_DKMR231GLFSDISCRETE2S1; S3
SW4SMD_63X161LSSW_KT11P2JM_1_SW4SMD_63X161LS_DKMR231GLFSDISCRETE1S2
TP1-8040TESTPT1_TP1-8040_TESTPT1TESTPT1IC2TP1; TP4
TP60C33DTESTPT1_TP60C33D_TESTPT1TESTPT1IC5TP5; TP6; TP7; TP8; TP9
TP60C_SMDTESTPT1_TP60C_SMD_TESTPT1TESTPT1IC2TP2; TP3
TSSOP1032CTQ030/TO_1_TSSOP10_IP4283CZ1IP4283CZ10-TTIC2D6; D7
USB5MINI_4SHIELDED_SMD-5MINI-USB-AB-SOCKET_USB5MINI_4SHUSB5MINIIC1P4
USB_A_SHCONN_54819-0578_2_USB_A_SH_IO_887520-0010BLFIO1P3
U_6_DRYPROT_TPD4S012_U_6_DRY_TPD4S012TPD4S012IC2U9; U10
U_8_DCUIC_SN74LVC2G241_1_U_8_DCU_SN74LSN74LVC2G241IC1U15
U_48_RSLPWR_TPS65217_2_U_48_RSL_TPS6521TPS65217CIC1U2
XTAL4_126-216SMDCRYS_32_768KHZ_SMD32_1_XTAL4_1232.768KHz MC-306IC1Y1
XTAL150SMD_125X196CRYS_24MHZ_SCC_0_XTAL150SMD_12524MHzIC1Y2
XTAL150SMD_125X196SUNTSU ITEMP 25MHZ _0.005% 20PF25.000MHzIC1Y3
  X: H3 C* M( P& p, a9 U, ~附件:
, m% K: j3 O& u4 M) EPCB文件如下:% d* G9 N4 I. r
游客,如果您要查看本帖隐藏内容请回复
+ B1 U' ^  a1 F- d5 i
GMT+8, 2025-7-19 05:45 , Processed in 0.125000 second(s), 28 queries , Gzip On.
