查看: 205|回复: 0
[allegro17.2][2层]采用桥式开关电机驱动器和Link开关TN2的300 W三相逆变器(TMPM3...
发表于 2020-1-15 17:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][2层]采用桥式开关电机驱动器和Link开关TN2的300 W三相逆变器(TMPM375FSDMG+CP2102-GMR+SS13-E3/61T原理图和pcb文件
文件描述:
1. 作品用途:采用桥式开关电机驱动器和Link开关TN2的300 W三相逆变器
2. 软件版本:allegro17.2
3. 层数:2层
4. 用到的主要芯片:TMPM375FSDMG+CP2102-GMR+SS13-E3/61T
5. PCB尺寸:91*133 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
FUSE_EFUSE_FUSE_E_FUSE HOLDERFuse HolderIC1F1
INDC2012X105NINDUCTOR_BEAD_INDC2012X105N_220220 Ohm@100MHzIC1L1
PICHOKETOKINVD345H453LS197D030INDUCTOR_PICHOKETOKINVD345H453L680 uHIC1L2
PIDV300X200X060DO15D0201ADDIODE_PIDV300X200X060DO15D0201A1N5404-E3/54IC1D4
PIMTGHOLED156POST_CRKT_BRD_6-32_HEX_PIMTGHOLPost Hex, 6-32, snap, 0.375L, NYLIC4POST-CRKT_BRD_6-32_HEX1; POST-CRKT_BRD_6-32_HEX2; POST-CRKT_BRD_6-32_HEX3; POST-CRKT_BRD_6-32_HEX4
PIPOLCAPCLYD200LS80030CAP POL_PIPOLCAPCLYD200LS80030_100 uFIC1C33
PIPOLCAPCLYD710LS300040CAP POL_PIPOLCAPCLYD710LS30004047 uFIC1C24
PIRAD400X175LS250031THERMISTOR_PIRAD400X175LS25003110IC1RT1
PISMC0603CAP NP_PISMC0603_1000 PF1000 pFIC3C4; C15; C23
PISMC0603CAP NP_PISMC0603_470 PF470 pFIC3C5; C18; C25
PISMC0603CAP NP_PISMC0603_1 NF1 nFIC3C6; C10; C13
PISMC0603CAP NP_PISMC0603_100 NF100 nFIC8C7; C11; C14; C27; C29; C31; C35; C38
PISMC0603CAP NP_PISMC0603_4.7UF4.7uFIC1C9
PISMC0603CAP NP_PISMC0603_1 UF_PISMC06031 uFIC3C16; C26; C36
PISMC0603CAP NP_PISMC0603_10 NF10 nFIC1C19
PISMC0603CAP NP_PISMC0603_1 UF1 uFIC3C28; C40; C41
PISMC0805CAP NP_PISMC0805_100 PF100 pFIC3C1; C8; C20
PISMC0805CAP NP_PISMC0805_4.7 UF4.7 uFIC4C12; C17; C37; C39
PISMC0805CAP NP_PISMC0805_10 UF10 uFIC1C30
PISMC1206CAP NP_PISMC1206_4.7 UF4.7 uFIC3C3; C22; C34
PISMC1812CAP NP_PISMC1812_220 NF220 nFIC3C2; C21; C32
PISMDDFLR120012DIODE_PISMDDFLR120012_DFLR1600-DFLR1600-7IC1D6
PISMDO214AC12DIODE SCHOTTKY_PISMDO214AC12_SSSS13-E3/61TIC3D2; D3; D5
PISMR0402R_PISMR0402_3.48 K3.48 kIC1R42
PISMR0402R_PISMR0402_2.49 K_1%2.49 kIC1R44
PISMR0603R_PISMR0603_330330IC2R1; R14
PISMR0603R_PISMR0603_1 K1 kIC17R3; R7; R11; R12; R16; R17; R20; R23; R24; R25; R26; R28; R30; R32; R37; R43; R47
PISMR0603R_PISMR0603_22 K22 kIC1R4
PISMR0603R_PISMR0603_100100IC6R9; R10; R19; R27; R41; R58
PISMR0603R_PISMR0603_44.2 K44.2 kIC6R15; R21; R31; R39; R46; R53
PISMR0603R_PISMR0603_10 K10 kIC8R18; R29; R33; R34; R35; R45; R49; R56
PISMR0603R_PISMR0603_1010IC1R50
PISMR0603THERMISTOR_PISMR0603_100 K100 kIC1RT2
PISMR0805R_PISMR0805_4.99 K4.99 kIC1R2
PISMR0805R_PISMR0805_4.75 K4.75 kIC1R36
PISMR0805R_PISMR0805_100 K100 kIC1R38
PISMR0805R_PISMR0805_24 K24 kIC1R48
PISMR0805R_PISMR0805_22.122.1IC2R51; R55
PISMR0805R_PISMR0805_1 M1 MIC1R52
PISMR0805R_PISMR0805_56.2 K56.2 kIC1R57
PISMR1206R_PISMR1206_3 M3 MIC1R5
PISMR1206R_PISMR1206_2.00 M2.00 MIC2R8; R13
PISMR2010R_PISMR2010_0.220.22IC3R22; R40; R54
PISMSO8DNSHORT5678LNK32XX_8C_PISMSO8DNSHORT5678_LLNK3204DIC1U5
PI_20P_2X10_SHROUDEDCON20_PI_20P_2X10_SHROUDED_CON2CON20IC1J4
PI_CONN_QC_TAB_2PIN_LS200CON2_PI_CONN_QC_TAB_2PIN_LS200_CON2IC3J1; J2; J3
PI_IC_CER_RESONATORCRYSTAL_RESONATOR_PI_IC_CER_RES10.0000 MHzIC1Y1
PI_IC_INSOP_24CBRIDGESWITCH_1265C_PI_IC_INSOP_BRD1265CIC3U2; U4; U6
PI_MILLMAX030DTERM_1PIN_PI_MILLMAX030D_CON1CON1IC20+5V; AINB10; AINB11; AINB12; BPL_U; BPL_V; BPL_W; FAULT; GND; INH_U; INH_V; INH_W; INL_U; INL_V; INL_W; IPH_U; IPH_V; IPH_W; PGND; VBUS_IN
PI_SM_14LSSOPCOMPARATOR_QUAD_HETERO_PI_SM_14BA10339FV-E2IC1U7
PI_SM_14TSSOPTL084_HETERO_PI_SM_14TSSOP_AD86AD8648ARUZIC1U1
PI_SM_28-VFQFN_EPCP2102-GMR_PI_SM_28-VFQFN_EP_CPCP2102-GMRIC1U8
PI_SM_30_SSOPTMPM375FSDMG_PI_SM_30_SSOP_TMPMTMPM375FSDMGIC1U3
PI_SM_D_0603LED_PI_SM_D_0603_GREENGreenIC1D1
PI_SM_SOD-123_12DIODE_PI_SM_SOD-123_12_UFM15PL-UFM15PL-TPIC1D7
PI_SM_SOT_363SN74LVC1T45DCKR_PI_SM_SOT_363_SSN74LVC1T45DCKRIC1U9
PI_SWITCH_DPDT_SLIDE_EG2209SW SLIDE-DPDT_PI_SWITCH_DPDT_SLDPDT SLIDEIC1SW3
PI_SWITCH_SKRPABE010SW PUSHBUTTON-SPST_1-2_3-4_PI_SSPSTIC2SW1; SW2
PI_VRES_VERTADJPOT_PI_VRES_VERTADJ_10 K10 kIC1R6
TE_CONNECTIVITY_1734510-1USB_MINI_B_DIPCON5IO1P1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
" P3 u9 \0 ?  w3 O
GMT+8, 2025-7-20 05:56 , Processed in 0.140625 second(s), 28 queries , Gzip On.
