查看: 242|回复: 0
[allegro17.2][4层]充电器(LED_5050+CON6)原理图和pcb文件
发表于 2020-1-15 17:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
文件描述:
1. 作品用途:充电器
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:LED_5050+CON6
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C0603CAP NP_C0603_100NF100nFIC2C22; C23
C0603CAP NP_C0603_47PF47pFIC1C25
C0603CAP NP_C0603_1NF1nFIC1C26
C0603CAP NP_C0603_10NF10nFIC3C27; C30; C31
C0603CAP NP_C0603_0.1UF0.1uFIC1C28
C0603CAP NP_C0603_3.9NF3.9nFIC1C29
C0603CAP NP_C0603_10UF10uFIC4C33; C34; C35; C36
C1206CAP NP_C1206_47UF_10V47uF_10VIC1C24
CON_SMT_50_6_90DEGCON6_CON_SMT_50_6_90DEG_CON6CON6IC1J14
CON_SMT_100_2_90DEGCON2_CON_SMT_100_2_90DEG_CON2CON2IC5J9; J12; J13; J15; J16
DPAKMOSFET P_5_DPAK_AOD413AAOD413AIC1Q17
DPAKMOSFET P_6_DPAK_AOD413AAOD413AIC1Q19
ECAP_SMD_6MM3_SQ_MCAP_ECAP_SMD_6MM3_SQ_M_220UF_35220uF_35VIC2E2; E5
ECAP_SMD_6MM3_SQ_MCAP_ECAP_SMD_6MM3_SQ_M_220UF_16220uF_16VIC1E3
ECAP_SMD_6MM3_SQ_MCAP_ECAP_SMD_6MM3_SQ_M_22UF/6.322uF/6.3VIC1E4
FB0805FB_FB0805_100R_100MHZ100R_100MHzIC1FB1
INDR_PIO54FB_INDR_PIO54_22UH22uHIC1L1
INDR_PIO54FB_INDR_PIO54_10UH10uHIC1L2
LED_5050LED_1_LED_5050_LED_5050LED_5050IC12D18; D19; D26; D27; D28; D29; D30; D31; D32; D33; D34; D35
R0603RESISTOR_R0603_10K10KIC18R58; R63; R64; R67; R69; R75; R77; R79; R80; R81; R82; R83; R84; R85; R86; R88; R89; R90
R0603RESISTOR_R0603_10R10RIC2R59; R65
R0603RESISTOR_R0603_2K22K2IC2R62; R66
R0603RESISTOR_R0603_220K220KIC1R68
R0603RESISTOR_R0603_47K47KIC1R70
R0603RESISTOR_R0603_29K429K4IC1R71
R0603RESISTOR_R0603_1K91K9IC1R72
R0603RESISTOR_R0603_100K100KIC1R73
R0603RESISTOR_R0603_6.8K6.8KIC2R74; R87
R0603RESISTOR_R0603_44.2K44.2KIC1R76
R0603RESISTOR_R0603_3.4K3.4KIC1R78
SMADIODE_S_SMA_SS34SS34IC1D15
SMADIODE_S_SMA_SS110SS110IC1D17
SO08_MTPS54331D_SO08_M_TPS54331TPS54331IC1U18
SOD123DIODE_S_SOD123_SS110SS110IC1D1
SOD123DIODE_S_SOD123_NCNCIC1D14
SOP8_39MP2307_SOP8_39_MP2307MP2307IC1U1
SOT23_5_MPL2700_1_SOT23_5_M_PL2700PL2700IC2U2; U19
SOT23_MNPN_SOT23_M_MMBT4401MMBT4401IC2Q18; Q20
SOT23_MSI2302_0_SOT23_M_SI2302SI2302IC3Q21; Q22; Q23
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
9 c5 w6 G3 d! i, h& e6 x" p
GMT+8, 2025-7-19 06:48 , Processed in 0.125000 second(s), 28 queries , Gzip On.
