Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
ANT_AH316M | CHIP_ANTENNA_2T_ANT_AH316M_2.45 | 2.45GHz Ant | IC | 1 | E1 |
CC0402 | CAP_CC0402_10PF | 10pF | IC | 1 | C2 |
CC0402 | CAP_CC0402_6.2PF | 6.2pF | IC | 2 | C3; C4 |
CC0402 | C_CC0402_0.1UF | 0.1uF | IC | 12 | C5; C6; C7; C10; C12; C14; C16; C20; C21; C22; C23; C27 |
CC0402 | CAP_CC0402_1.0UF | 1.0uF | IC | 1 | C9 |
CC0402 | C_CC0402_4.7UF | 4.7uF | IC | 3 | C11; C13; C18 |
CC0402 | C_CC0402_10PF | 10pF | IC | 2 | C25; C26 |
CC0402 | CAP_CC0402_15PF | 15pF | IC | 1 | C29 |
CC0402 | INDUCTOR_CC0402_3.6NH | 3.6nH | IC | 1 | L1 |
CC0603 | C_CC0603_10UF | 10uF | IC | 3 | C8; C19; C24 |
CC0603 | C_CC0603_22UF | 22uF | IC | 2 | C15; C17 |
CC0805 | CAP_CC0805_10UF | 10uF | IC | 2 | C28; C31 |
CON_RF_MM8030-2600B | CONN_COAX_MURATA_4P_CON_RF_MM80 | RF SWITCH | IC | 1 | J3 |
DIO_CD0603-S0180R_CUS | DIODE_DIO_CD0603-S0180R_CUS_CD0 | CD0603-B00340 | IC | 1 | D2 |
EMERSON_128-0711-201 | CONN_UFL_3P_EMERSON_128-0711-20 | CONN_U.FL | IC | 1 | J2 |
FCI_10118194-0001 | CONN_MICRO_USB_5P_6G_FCI_101181 | CONN_MICRO_USB | IC | 1 | J7 |
FCI_20021111-00006T4LF | HEADER_3X2_FCI_20021111-00006T4 | HEADER_3X2 | IC | 1 | J4 |
FIL_DEA202450BT-1294C1 | TDK_FILTER_DEA20_FIL_DEA202450B | 2.4GHz Filter | IC | 1 | FL1 |
HDR_THVT_1X1_100_M | HEADER_1_HDR_THVT_1X1_100_M_TP_ | TP_THRU | IC | 4 | J11; J12; J13; J14 |
HDR_THVT_1X2_100_M | HEADER_1X2_HDR_THVT_1X2_100_M_H | HEADER_2 | IC | 2 | J5; J6 |
HDR_THVT_1X3_100_M | HEADER_3_HDR_THVT_1X3_100_M_HEA | HEADER_3 | IC | 1 | J8 |
HDR_THVT_2X10_100_F | CONN_RCPT_0_HDR_THVT_2X10_100_F | CONN_RCPT_10x2 | IC | 2 | J9; J10 |
INDC0805 | BEAD_FERRITE_INDC0805_BEAD_FERR | BEAD_FERRITE | IC | 2 | L7; L8 |
INDC2520X100N_MM | INDUCTOR_INDC2520X100N_MM_2.2UH | 2.2uH | IC | 2 | L3; L5 |
INDC_0402CS | CAP_INDC_0402CS_1.0PF | 1.0pF | IC | 1 | C1 |
INDC_0402CS | INDUCTOR_INDC_0402CS_5.6NH | 5.6nH | IC | 1 | L2 |
IND_CB2518_MM | INDUCTOR_IND_CB2518_MM_1UH | 1uH | IC | 1 | L4 |
LED_0603 | LED_LED_0603_LED | LED | IC | 2 | D1; D6 |
LED_0603 | LED_LED_0603_ | | IC | 1 | D5 |
PSON50P300X200X60-9N | FLASH_USON_PSON50P300X200X60-9N | 8M (1M x 8) | IC | 1 | U2 |
QFN50P900X900_64_PWP_A_EINF | CC3100_BP_V2_QFN50P900X900_64_P | CC3100 | IC | 1 | U3 |
RC0402 | RESISTOR_RC0402_10K | 10k | IC | 4 | R2; R10; R12; R19 |
RC0402 | RESISTOR_RC0402_100R | 100R | IC | 2 | R3; R48 |
RC0402 | RESISTOR_RC0402_0 R | 0 R | IC | 20 | R4; R5; R6; R7; R8; R11; R14; R16; R20; R21; R23; R24; R25; R26; R29; R33; R34; R36; R39; R41 |
RC0402 | RESISTOR_RC0402_100K | 100k | IC | 5 | R9; R17; R18; R28; R38 |
RC0402 | RESISTOR_RC0402_3.3K | 3.3K | IC | 1 | R13 |
RC0402 | RESISTOR_RC0402_1K | 1k | IC | 2 | R15; R44 |
RC0402 | R_RC0402_1K | 1k | IC | 1 | R22 |
RC0402 | RESISTOR_RC0402_DNP | DNP | IC | 5 | R27; R30; R32; R37; R40 |
RC0402 | R_RC0402_33K | 33k | IC | 2 | R31; R46 |
RC0402 | RESISTOR_RC0402_30.1K | 30.1K | IC | 1 | R43 |
RC0402 | RESISTOR_RC0402_51K | 51K | IC | 1 | R45 |
RC0603 | RESISTOR_RC0603_270 | 270 | IC | 3 | R1; R47; R49 |
RC0603 | R_RC0603_0.1 | 0.1 | IC | 2 | R35; R50 |
RC0603 | R_RC0603_DNP | DNP | IC | 1 | R51 |
RC0805 | RESISTOR_RC0805_0.1 R | 0.1 R | IC | 1 | R42 |
SOD_123FL | MBR130_SOD-123_2P_SOD_123FL_ | | IC | 2 | D3; D4 |
SOIC_8_197X157_50 | FLASH_SOIC_8_197X157_50_8M (1M | 8M (1M x 8) | IC | 1 | U1 |
SOT_23_321 | MOSFET_I_EN_GSD_SOT_23_321_BSS1 | BSS138LT3G | IC | 2 | Q1; Q2 |
SOT_223_6_TG | TPS79601_SOT-223_6P_SOT_223_6_T | TPS79601 | IC | 1 | U4 |
SW_EVQ-11A05R | SW_TACT_SPST_SW_EVQ-11A05R_SW T | SW TACT | IC | 3 | SW1; SW2; SW3 |
TANT_1206 | CAP_TANT_1206_100UF | 100uF | IC | 2 | C30; C32 |
TP_RCW1206 | TP_1206_TP_RCW1206_TP_1206 | TP_1206 | IC | 1 | TP1 |
XTAL_4_SM_104X83X20 | CRYSTAL_EPSON_FA20H_4P_XTAL_4_S | | IC | 1 | Y1 |
XTAL_4_SM_104X83X20 | SG615/SM_XTAL_4_SM_104X83X20_32 | 32.768KHz | IC | 1 | Y2 |
XTAL_ABS07 | CRYSTAL_XTAL_ABS07_CRYSTAL | Crystal | IC | 1 | Y3 |
