作品名:[AD 10][2层] 基于stm32 的数控线性实验电源 原理图和pcb& |" h l7 W1 ?" g e! M5 Q5 Q
: q# P, {: c) n$ R文件描述
1 L5 f, ^8 ?3 L' @$ }& i+ S1. 作品用途:数控线性实验电源& I! {! p3 ]# B- Y5 s# Y( {6 a: v
2. 软件版本:AD 10
4 m- ?0 ~0 k* x; \* V, S. k3. 层数:2层板" ]. ~: y' K# w$ h) [
4. 用到的主要芯片:stm32; L" ]4 ]: _6 {& P) X2 g
5. PCB尺寸:177.9mm*90mm
/ N- @) E/ Q0 k# e. ^. m
. G# }6 U' R! E" {0 ~5 _+ V作品截图如下:" \5 f- N8 ^' _6 E4 v
顶层截图:
8 k' N, C1 D, r6 p# O( m/ G8 F
, \. @! e, e- X. W& a
. s5 W: l+ M4 W# H; X: q: P! P" \底层截图:
! l( Y5 \+ B6 Z. Z' e2 _
" c( E8 L6 x, K) g% J: T3 Y* Z' n
6 p* i# j' Q4 Z( I9 V
全层截图:; } x3 W: X9 O) D6 [5 ~$ |! B2 H
4 M( ~" v6 w5 G8 E# Q
; O8 ~/ f. v* Q9 B) z0 L
叠层信息截图如下:
3 k& o0 I( |) C- a
2 h' Y3 P) K) b8 E: s' L! J; |1 x G9 `( L* l! X, U- v8 t. h. R
BOM:
" }6 m1 [- M+ b: v0 UComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | STM32103VE | *1 | LQFP100 | 1 | Bell | buzzer1 | BUZZER - duplicate | 1 | 0.1uF | C1, C3, C6, C8, C9, C11, C23, C24, C25, C26, C27, C28, C35, C41, C44, C46, C49, C50, C51, C52, C53, C54, C55 | 0603R | 23 | 2200uF/25V | C2 | CE07 | 1 | 100uF | C4, C5, C10, C12, C43 | CE07 | 5 | 470uF | C7, C45 | CE07 | 2 | 22P | C13, C20, C21, C22, C31, C32, C33, C34, C37, C38, C39 | 0603R | 11 | 2200UF | C14, C15, C16, C17, C18, C19 | CE18 | 6 | 104 | C29 | 0603R | 1 | 103 | C30 | 0603R | 1 | 2200uF | C36 | CE10 | 1 | 470uF/25V | C40, C42 | CE07 | 2 | 22pF | C47, C48 | 0603R | 2 | AC 12V*2 | CN1 | CON3/5.08 | 1 | AC 6V | CN2 | CON2/5.08 | 1 | 风扇 | CN3 | CON3/2.54 | 1 | CON8 | CN4 | SIP8/5.08 | 1 | CON5 | CN5 | BMQ | 1 | CON4 | CN6, CN8 | SIP04W | 2 | LCD12864 | CN7 | LCD-12864 - duplicate | 1 | CON2 | CN9 | CON2.54 | 1 | IN4148 | D1, D2, D4, D5, D6, D7 | D1206 | 6 | SS34 | D3 | D-1210 | 1 | GBP306 | DB1, DB2 | DB-L140 | 2 | DB | DB3 | DB-5mm | 1 | Comment | Designator6, Designator7, Designator8, Designator9 | HOLE-R1.6 | 4 | J-1D-2Z-12V | K1, K2, K3, K4 | J-1D-2Z-12V | 4 | BUTTON | K5 | KS1 | 1 | LED | LED1 | LED-0603-A | 1 | 0.05R/5W | LOAD1 | R800 | 1 | 3904 | Q1, Q5, Q8, Q9, Q10, Q11, Q12 | SOT-23 | 7 | MOS-N | Q2, Q3 | TO247 | 2 | 3906 | Q4, Q6 | SOT-23 | 2 | MOS-P | Q7 | SOT-23 | 1 | SCR | Q13 | SO-08 | 1 | Comment | R | 0603R | 2 | 220R | R1 | 0603R | 1 | 1K | R2, R6, R19 | 0603R | 3 | 4.7K | R3, R4, R7, R9, R16, R17, R18, R23, R31, R45, R46, R47, R48, R56, R57, R58, R59, R62, R63 | 0603R | 19 | 10R | R5, R8, R64 | 0603R | 3 | 0.1R/2W | R10, R11 | R800 | 2 | 1M | R12, R22, R27, R35 | 0603R | 4 | 0.1R/2W | R14 | RV400 | 1 | 10K 1% | R15, R26, R34 | 0603R | 3 | 22K 1% | R20 | 0603R | 1 | 100K 1% | R21, R24, R32 | 0603R | 3 | 24K 1% | R25, R33 | 0603R | 2 | 4.7K 1% | R28, R30 | 0603R | 2 | 1k/2W | R29 | R800 | 1 | 10K | R36, R37, R60, R61 | 0603R | 4 | 300R | R38 | 0603R | 1 | 100R | R39 | 0603R | 1 | 100R | R40, R41, R42, R43 | 0805R | 4 | 330R | R44, R53 | 0603R | 2 | 100K | R49, R50, R51, R52 | 0603R | 4 | Res Varistor | R54, R55 | SIP02 | 2 | SW-PB | S1, S2, S3, S4, S5 | K-SMD 12*12 | 5 | MC7812ACT | U1 | TO263-D2PAK | 1 | MC7805ACT | U2 | TO263-D2PAK | 1 | MC7912ACT | U3 | TO263-D2PAK | 1 | Optoisolator1 | U4, U9 | SOP4 | 2 | OP07 | U5, U6, U7, U8 | SO-08 | 4 | 1117-3.3 | U10 | SPX1117M | 1 | FLASH | U11 | SO-08 | 1 | X | X1 | X | 1 | Comment | [NoValue], led1 | LED-0603-A | 2 | ) O. G+ R+ T% V% ^
附件:6 y* G+ Z0 j* S& j) C
原理图和PCB源文件如下:' Z7 M6 h6 N" b2 r( f- d% y
# Q' ~6 i# E( v
8 H b% {7 N" k |
