查看: 546|回复: 2
[allegro16.6][6层] SIRF-A5 车载导航+车载移动数字电视一体板(ATLAS-V+DDR+SMS11...
发表于 2020-2-11 14:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
8 J9 A+ z/ q, c4 \
[allegro16.6][6层] SIRF-A5 车载导航+车载移动数字电视一体板(ATLAS-V+DDR+SMS1184)pcb文件6 y; R: @$ r9 h. d, U
; S, ?' d3 q) ~$ [文件描述:6 C' J+ J; P7 t$ \3 Z
" K( r* H7 O3 }3 n+ k
1. 作品用途:SIRF-A5 车载导航+车载移动数字电视一体板
7 K$ k6 \9 q+ L) ]8 o# {7 c' ]2. 软件版本:allegro16.6& K, p, }, U: G
3. 层数:6层
+ R7 x# [1 d7 S6 c5 D8 ^" m4. 用到的主要芯片:ATLAS-V+DDR+SMS1184
0 y5 f3 ^0 f: c3 `9 S  a0 E7 a5. pcb尺寸: 90*47 MM3 o* [; V: L, l9 T9 ^  U7 M: m
# R/ ?, q& y& D2 V
作品截图如下:* K" r% g- i/ _. h+ E1 |9 _
9 D: @4 l/ M( a: \2 J5 a顶层截图:
" h* R* v& `$ F5 K- Y ; p; U  D: w6 u$ b1 f( [1 m  p
底层截图:; o8 U8 q/ B: t6 F
! j! c5 c# n! M6 w' _
( B& D/ |0 B6 Z4 Z, A; N全层截图:
* l( Y: I" Z9 I
  N* S0 b* P- I; ~4 c  d) h3 a; D2 N8 `
/ v$ e- ~7 U, g! G! c3 Y$ I
; h6 r) N( U/ M3 dBOM:* s, \9 _& T7 L5 @  t* Q, s& h! F
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
ANT5_5ANT6_6_ANT5_5_ANT6_6ANT6_6IC2G_J1; J10
AVBGA-285ATLAS-V_AVBGA-285_(S1+S2+S3+S4+ATLAS-VIC1U101
BGA-86-SMS1184SMS1180_0_BGA-86-SMS1184_SMS118SMS1184IC1U28
C0402CAP-NP_C0402_100NF100nfIC32C101; C111; C201; C208; C209; C210; C211; C212; C213; C214; C215; C218; C219; C220; C221; C301; C302; C313; C702; C801; C914; C915; C929; C930; C933; C936; C944; C946; C1217; G_C601; G_C610; G_C619
C0402CAP-NP_C0402_22PF22pfIC4C103; C112; C114; G_C606
C0402CAP NP_C0402_22PF22pFIC1C104
C0402CAP-NP_C0402_33PF33pfIC2C105; C106
C0402CAP-NP_C0402_1UF1ufIC15C108; C202; C203; C901; C907; C934; C935; C937; C938; C939; C940; C941; C942; C961; C963
C0402CAP-NP_C0402_47PF47pfIC3C109; C110; C916
C0402CAP-NP_C0402_220NF220nfIC18C205; C919; C943; C945; C947; C948; C949; C950; C951; C952; C953; C955; C956; C957; C958; C959; C960; C962
C0402CAP-NP_C0402_10NF10nfIC11C206; C207; C216; C217; C964; G_C602; G_C603; G_C607; G_C611; G_C614; G_C617
C0402CAP-NP_C0402_4.7NF4.7nfIC4C513; C515; C517; C519
C0402CAP-NP_C0402_100PF100pfIC1C913
C0402CAP-NP_C0402_1NF1nfIC1C954
C0402CAP NP_C0402_100NF100nFIC11C1101; C1105; C1108; C1110; C1121; C1122; C1123; C1124; C1128; C1129; C1132
C0402CAP NP_C0402_100PF100pFIC4C1106; C1111; C1118; C1130
C0402CAP NP_C0402_1UF1uFIC3C1107; C1120; C1127
C0402CAP NP_C0402_3.9PF3.9pFIC1C1109
C0402CAP NP_C0402_4.7PF4.7pFIC1C1112
C0402CAP NP_C0402_33PF33pFIC2C1113; C1114
C0402CAP NP_C0402_330NF330nFIC2C1115; C1117
C0402CAP NP_C0402_1NF1nFIC2C1125; C1126
C0402CAP NP_C0402_NC/100NFNC/100nFIC2C1134; C1135
C0402CAP-NP_C0402_100P100pIC1G_C604
C0402CAP-NP_C0402_10PF10pfIC1G_C615
C0603CAP-NP_C0603_2.2UF2.2ufIC2C107; G_C618
C0603CAP-NP_C0603_4.7UF4.7ufIC4C204; C904; C908; C912
C0603C-1_C0603_10UF10uFIC1C1102
C0603CAP NP_C0603_10UF10uFIC3C1103; C1116; C1119
C0603CAP NP_C0603_10UF/6.3V10uF/6.3VIC2C1104; C1131
C0805CAP-NP_C0805_22UF22ufIC3C701; C921; C922
C0805CAP-NP_C0805_10UF10ufIC5C902; C905; C920; C924; C928
CRYSTAL-3225CRYSTAL-4P-P3OUT_CRYSTAL-3225_116.367667 MHzIC1G_Y601
CRYSTAL-3225CRYSTAL-4P-13_CRYSTAL-3225_12MH12MHzIC1Y7
CRYSTAL-5032CRYSTAL-4P-13_CRYSTAL-5032_24MH24MHzIC1Y101
CRYSTAL-MC-146CRYSTAL-4P-14_CRYSTAL-MC-146_3232.768kHzIC1Y102
C_1206ACAP-POL_C_1206A_100UF/6.3V100uF/6.3VIC2C402; C403
D-2_2MMTP_2_D-2_2MM_TP_2TP_2IC4TP18; TP19; TP20; TP21
DXP18BNDXP18_DXP18BN_DXP18BN5014TDXP18BN5014TIC1BL1
FBGA-84-SAMSUNDDR2-FBGA-84P-16BIT_FBGA-84-SAMK4T51163QG-HCF7IC1U201
FB_0603FERRITE BEAD_0_FB_0603_FBM-11-1FBM-11-160808-500TIC1FB16
FPC-0D5MM-30PIN-BOT-YCX-A5COM-30P-SMT_1_FPC-0D5MM-30PIN-BCOM-30P-SMTIC1J12
F_1206RES_F_1206_0R0RIC1R518
HDR200M-1X5HEADER-5_HDR200M-1X5_CON-5PCON-5PIC1J13
HDR200M-1X35CON-35P_0_HDR200M-1X35_CON-35PCON-35PIC1J14
HOLE_AHOLE_HOLE_A_HOLEholeIC2JP9; JP11
HOLE_AHOLE_0_HOLE_A_HOLE_0hole_0IC2JP10; JP12
INDUCE-PT04X18INDUCE_INDUCE-PT04X18_2.2UH2.2uHIC2L901; L902
INDUCE-PT04X18INDUCTOR_1_INDUCE-PT04X18_4.7UH4.7uHIC1L1114
L0402CHOKE_L0402_600R600RIC2FB4; FB5
L0402INDUCE_L0402_39NH39nHIC1G_L601
L0603BEAD_L0603_60OHM60ohmIC2G_L604; G_L605
LED_0805LED_LED_0805_LEDLEDIC1LED2
MASK_IDMARK_MASK_ID_MARKMARKIC6M901; M902; M903; M904; M905; M906
PAD1_2DHDHTP_2_PAD1_2DHDH_TP_2TP_2IC4TP22; TP23; TP25; TP26
QFN_24SE4150L_QFN_24_SE4150LSE4150LIC1G_U601
R0402RES_R0402_100100IC4G_R601; G_R602; G_R603; R206
R0402RES_R0402_10K10KIC24G_R604; G_R606; R115; R203; R204; R304; R305; R306; R307; R318; R402; R403; R405; R406; R407; R408; R516; R517; R917; R933; R946; R1232; R1233; R1239
R0402RES_R0402_00IC12G_R605; G_R609; R116; R120; R122; R123; R124; R128; R918; R935; R937; R1234
R0402RES_R0402_NC/0NC/0IC2G_R607; R205
R0402RES_R0402_0R0RIC1G_R608
R0402CHOKE_R0402_6.2NH6.2nHIC1L1101
R0402CHOKE_R0402_12NH12nHIC1L1102
R0402CHOKE_R0402_24NH24nHIC2L1103; L1105
R0402CHOKE_R0402_1.5NH1.5nHIC1L1104
R0402RES_R0402_3333DISCRETE3R103; R111; R112
R0402RES_R0402_44.2(1%)44.2(1%)IC1R104
R0402R_R0402_3333IC7R105; R1112; R1114; R1115; R1117; R1124; R1130
R0402RES_R0402_47K47KIC3R108; R804; R930
R0402RES_R0402_510K(1%)510K(1%)IC2R109; R907
R0402RES_R0402_1M1MIC1R110
R0402RES_R0402_499(1%)499(1%)IC1R113
R0402RES_R0402_OPENopenIC3R117; R916; R934
R0402RES_R0402_2M2MIC1R118
R0402RES_R0402_200K(1%)200K(1%)IC3R119; R906; R909
R0402RES_R0402_1K1KIC3R121; R201; R202
R0402RES_R0402_30K30KIC6R309; R310; R311; R312; R313; R314
R0402R_0402_R0402_2222IC3R511; R512; R513
R0402RES_R0402_820820IC1R701
R0402RES_R0402_495K(1%)495K(1%)IC1R901
R0402RES_R0402_300K(1%)300K(1%)IC7R902; R910; R912; R914; R921; R922; R928
R0402RES_R0402_150K(1%)150K(1%)IC2R903; R929
R0402RES_R0402_5.6K(1%)5.6K(1%)IC1R904
R0402RES_R0402_100K(1%)100K(1%)IC1R905
R0402RES_R0402_130K(1%)130K(1%)IC2R913; R915
R0402RES_R0402_4.7K4.7KIC1R924
R0402R_R0402_3.9K(1%)3.9K(1%)IC1R1101
R0402R_R0402_140K(1%)140K(1%)IC1R1102
R0402R_R0402_180K(1%)180K(1%)IC1R1104
R0402R_R0402_10K10KIC5R1105; R1106; R1113; R1125; R1128
R0402R_R0402_11IC3R1107; R1109; R1110
R0402R_R0402_84.5K(1%)84.5K(1%)IC1R1108
R0402R_R0402_330K(1%)330K(1%)IC1R1111
R0402R_R0402_36K(1%)36K(1%)IC1R1116
R0402R_R0402_20K(1%)20K(1%)IC1R1118
R0402R_R0402_30K30KIC1R1120
R0402R_R0402_68.1K(1%)68.1K(1%)IC1R1122
R0402R_R0402_NC/33NC/33IC3R1126; R1127; R1129
R0402RES_R0402_2222IC4R1224; R1225; R1235; R1236
R0402RES_R0402_100K100KIC1R1245
SAW-5PIN-1_4X1_1SAW-5P_SAW-5PIN-1_4X1_1_FAR-F6KFAR-F6KA-1G5754-L4AJIC1G_F602
SO-8SN8P2501B_SO-8_SN8P2501BSN8P2501BIC1U1204
SOD-523DIODE_SOD-523_RB520S-30RB520S-30IC3D101; D102; D103
SOT23_5RT9179_SOT23_5_RT9179RT9179IC2U24; U30
SOT23_5RT8009PB_SOT23_5_RT8009PBRT8009PBIC1U29
SOT-23MMBT3904_SOT-23_MMBT3904MMBT3904IC1Q4
SOT-23LDO-3P-2_SOT-23_XC61FN2712MRXC61FN2712MRIC1U307
SOT-23-5LDO-SOT235_SOT-23-5_XC6219B332MXC6219B332MR,RT9193-33PBIC1U903
SSOP-20P5CC072_SSOP-20_P5CC072P5CC072IC1U31
TESTTEST_TEST_TESTTESTIC5TP1; TP27; TP28; TP1006; TP1008
TSLP-2-7ESD5V3U1U-2RH_TSLP-2-7_ESD5V3U1ESD5V3U1U-02LRHIC1D1
TSOP_48NAND-TSOP_TSOP_48_H27UBG8T2ATR-H27UBG8T2ATR-BCIC1U306
附件:& I) ^+ s, D7 X& b5 C
PCB文件如下:
; v" b. q4 O- ~
游客,如果您要查看本帖隐藏内容请回复
6 S! y7 i0 m( q  J7 H4 j
+ S1 g/ ]7 _. ^  _& u! Y
发表于 2023-9-18 11:57 | 只看该作者
谢谢分享
“来自电巢APP”
GMT+8, 2025-8-24 04:56 , Processed in 0.125000 second(s), 27 queries , Gzip On.
