仿真时报错,+ z' L; o/ d3 D% f
' [- A" o }" O4 ^! a
0 Q( R- G3 s6 H. q0 x8 e$ s# k相关报告如下
, |# ~* r: [5 A**** 04/30/20 11:06:39 ****** Pspice 17.2.0 (March 2016) ****** ID# 0 ******** ** Profile: "SCHEMATIC1-bias" [ D:\Users\Willi\AppData\Roaming\SPB_Data\l_highspeed_switch-pspicefiles\schematic1\bias.sim ] , x) M( W2 W$ Y
**** CIRCUIT DESCRIPTION& P9 v1 t$ v; C2 w) W* k |
7 m! w% E4 H6 m @+ N** Creating circuit file "bias.cir"
& [* d5 z0 _( |% c7 `% a* P** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS*Libraries:
$ C9 \# ^, Z: k1 I$ e2 t& ]* Profile Libraries :
2 Q/ t9 ~; v+ ^* b2 [* Local Libraries :
+ H! I% L- u/ h* From [PSPICE NETLIST] section of D:\cadence\SPB_Data\cdssetup\orcad_PSpice\17.2.0\PSpice.ini file:! `& I3 g8 F2 p& Y0 A( ? d
.lib "nom.lib" *Analysis directives:
9 J c) l; u# ?0 r+ b.OPTIONS ADVCONV# f! o: i5 H# a/ N( D7 ?
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*)) % r! X i8 z+ _
.INC "..\SCHEMATIC1.net" **** INCLUDING SCHEMATIC1.net ****
: D& Q3 ?5 u5 |" w; u- `3 ^ k* source L_HIGHSPEED_SWITCH
/ v$ T0 \3 h& m" Q$ D) e. B9 mR_R1 0 N14790 1k TC=0,0 3 s6 h- o& X9 M' q3 Z+ D: }% [
V_V2 N14790 0 1Vdc**** RESUMING bias.cir ****! j/ j( p! T1 t- r* a0 t( P- O( C
.END
1 V* v$ ^6 T7 y; [4 C2 o: W
t$ V. X% N2 O**** 04/30/20 11:06:39 ****** PSpice 17.2.0 (March 2016) ****** ID# 0 ******** ** Profile: "SCHEMATIC1-bias" [ D:\Users\Willi\AppData\Roaming\SPB_Data\l_highspeed_switch-pspicefiles\schematic1\bias.sim ] $ s: }& t, U" e0 ~9 @5 ~
**** SMALL SIGNAL BIAS SOLUTION TEMPERATURE = 27.000 DEG C
8 j, J5 d: c: D, p****************************************************************************** NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE- f- V$ z' z% T. D: e
(N14790) 1.0000 - P1 k1 E* t: ^0 E; t c" a1 h* f
VOLTAGE SOURCE CURRENTS- x5 J5 T* c9 C' K
NAME CURRENT V_V2 -1.000E-03 TOTAL POWER DISSIPATION 1.00E-03 WATTS JOB CONCLUDED& U; r- e! T* |. F. D E+ x
* x7 u/ O- x+ [. p9 J |2 i! ~
; K& W w& R* h" B. }**** JOB STATISTICS SUMMARY
$ P0 \2 f2 P! }& \2 @& u****************************************************************************** License check-out time = 1.73
$ @( A' `( k5 f$ v. g, g6 uTotal job time (using Solver 1) = 0.008 S% B2 H- ^: ?' Q9 Y- z
