TA的每日心情 | 开心 2024-3-29 15:04 |
签到天数: 71 天 [LV.6]常住居民II
{ Using PSTWRITER 16.6.0 d001Jul-10-2020 at 16:24:03 }
5 a: b" J6 B! U" q& c
6 [+ x& D1 d! B4 Y% J7 P' l$ ]. m* g' @+ p4 d$ t
#1 ERROR(ORCAP-36071): Illegal character "Dot(.)" found in "PCB Footprint" property for component instance U4: SCHEMATIC1, PAGE1 (238.76, 114.30) .
# H0 z9 e: f6 l0 Z0 o" _. g; _
1 Y. f6 {) y: g" y#2 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance E1: SCHEMATIC1, PAGE1 (13.46, 6.60).
1 [+ Z, ^0 @2 s, h) u
. Q# m( {0 ?- T! V; u7 h#3 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E5: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
4 w9 [. A4 @* U
; _0 V! F8 P, r P#4 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number F2: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.. m% M+ c4 T! o: `) @1 z8 `: L. t
' d. w |' k* h( a S; P% C4 Z" J#5 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number D7: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
8 f. T: H" ] }, F
2 l1 v- w$ _9 f- n! Q( B" }; t# x#6 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E7: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.* ? }8 @$ ^, H, d$ B
) v7 N# o4 S: t1 K: T#7 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number D6: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
+ K+ m; O7 K1 O
! ~* ]8 u1 T6 o6 ~& h#8 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E6: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these./ u6 n9 G0 l9 E4 P! U
5 ^1 `% r! [. O, d. [0 E( F# {& s) e#9 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , RST_N1: SCHEMATIC1, PAGE1 (40.39, 86.36). All pins should be numbered., L7 O% ^- y" u& W
- y8 d/ D% N& j$ w% V2 @#10 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , UART_RX1: SCHEMATIC1, PAGE1 (19.56, 109.22). All pins should be numbered.: q/ y/ d' b! ~9 q+ ^7 i% g0 d" N
5 K, h9 }* G. j. k0 |" C+ j8 T7 `
#11 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , BATP1: SCHEMATIC1, PAGE1 (20.07, 86.36). All pins should be numbered.4 k+ Y& l3 a# b! l; o4 [/ N
$ p) N* M' z0 u( N3 m/ B0 n
#12 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , UART_TX1: SCHEMATIC1, PAGE1 (18.03, 99.06). All pins should be numbered.
0 o9 w" h7 f% z( y$ a8 ~3 m3 Y% A) U% D( b/ a/ e
#13 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , GND1: SCHEMATIC1, PAGE1 (40.13, 109.22). All pins should be numbered.
6 I w0 S3 ^% W. o) r4 j, c$ ~/ l( j Y4 L. @
#14 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , REGEN1: SCHEMATIC1, PAGE1 (40.64, 99.31). All pins should be numbered.
( G& n5 k1 P, O, v( P$ w1 T, _4 I# X; C% X: b% P
#15 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , OD_GPIO1: SCHEMATIC1, PAGE1 (19.81, 119.38). All pins should be numbered.
# k0 h3 z2 r0 L7 c9 m: V7 ^1 W1 j3 B+ T f& T; d! m; R
#16 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package TP_1 , L-1: SCHEMATIC1, PAGE1 (241.81, 4.83). All pins should be numbered.
! f7 W+ P( U# H4 D' G4 f
2 M7 `( H9 y% O6 N#17 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , PIO1: SCHEMATIC1, PAGE1 (40.64, 119.38). All pins should be numbered.
9 b. T: J! B. g
1 e$ F( N- j) l, i; a#18 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package TP_1 , L+1: SCHEMATIC1, PAGE1 (238.51, 27.69). All pins should be numbered.
5 }6 G7 T" E9 D; C0 |0 y) @8 e, `4 i' Y. B0 g
#19 INFO(ORCAP-36107): PCB Editor does not support Dots(.), Forward Slash(/) and White space in footprint names. The supported characters include Alphabets, Numerics,
2 z- W5 g) k& V1 I
- ~, m6 `( s3 w2 I: W$ ^7 Y$ @* K' p- S) [9 u7 R
Underscore(_) and Hyphen(-).; M2 X) }2 K( G( g( J3 Z d
* A& Z# C+ m6 r; _/ C: G
+ f$ `4 a! V( y/ n: g% l
7 l" |, m" ?8 ] }$ K#20 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.5 O/ ^" t# r+ \8 k: A" @. u
9 F, a* O; v! S- Q4 B2 B请问大家这么多的错误,除了红色部分外,应该如何更改?& I. G, S# \! E3 K
第一,做元件的时候说GND告警可以忽略,这里警告改如何修改?我通过把GND加数字办法已经修改成功,请问高手还没有其他办法?
4 N9 r$ C5 }2 l4 O- f$ U# [第二,那些焊点的错误,因为是要做测试夹具,程序下载口可以随便放置,因此做的是一个焊点算是一个封装,这里是我最明白的,希望能得到大神的指导。6 \+ Z' d( F% l2 ^
希望有大神不吝赐教,谢谢了!8 l0 C0 S- Z/ V5 G! F% t
" H; o' o- R: b6 j
