查看: 2615|回复: 0
【请教】mentor的PCB设计文件如何导入allegro查看?
发表于 2010-11-17 15:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
对方工程师把设计文件转成DXF,可是在IMPORT进allegro的时候总是报错:
' P9 h6 A+ B4 k( e7 R' g! E4 G; a4 d5 n% s
DBERROR: The coord. buffer is incomplete.
7 h) ^0 t5 Z' v9 Z5 [ERROR: Failed to add (LW)POLYLINE
' m- _" o  U; k! Y% U' U  on BOARD GEOMETRY / 4
7 v+ N6 u$ [# s/ \  LWPOLYLINE on line number 21162 U& a/ `6 V6 q5 l8 [( m6 D
WARNING: Ignoring zero length segment at (84.3846, 214.6300), I2 B6 V) }! c. {! H' [$ X
% j) U1 ~0 |7 @; m* y& ?  [6 w: uDBERROR: The coord. buffer is incomplete.6 y! }1 D) W$ d9 p/ M1 ]
ERROR: Failed to add (LW)POLYLINE( w8 C/ m+ C3 }6 S8 U
  on BOARD GEOMETRY / 48 ], B( ~: J. u# i" {& n& C
  LWPOLYLINE on line number 2188
% P- E# _- ~1 r9 [$ hWARNING: Ignoring zero length segment at (62.9253, 214.6300)
  Q3 B  U$ x. z0 y5 k1 X1 z0 a  [3 C: g" N, h: f/ y1 B7 n: O
DBERROR: The coord. buffer is incomplete.# E9 a* g- e3 Z  P  s* n
ERROR: Failed to add (LW)POLYLINE& _4 W+ T$ O7 T( v
  on BOARD GEOMETRY / 4( L4 F& V" `5 I% Q, o3 h
  LWPOLYLINE on line number 2238
2 F: ]) r* h7 x3 HWARNING: Ignoring zero length segment at (-62.9304, 214.6300)9 U( w) G" H2 x' v" c; _5 y: y& M
( \+ n) H; C" V  B2 j请教有什么办法吗?谢谢
GMT+8, 2025-7-20 20:31 , Processed in 0.109375 second(s), 24 queries , Gzip On.
