尝试画个层次原理图,很简单,就几个电阻一连,可是画完了DRC的时候总是报错:& u3 M7 d% O- w. u% Y' C; ]* ?
Checking Misleading Tap connection
- L3 d: y+ Q! J: C1 f3 aERROR [DRC0039] Tap may not be connected with the bus Check Entire net. DD1: SCHEMATIC1, top (3.55, 2.30)) H& n- {6 |% A) ^8 f; D
ERROR [DRC0039] Tap may not be connected with the bus Check Entire net. DD2: SCHEMATIC1, top (3.55, 2.30)
1 E0 M5 ?3 A- p8 X, b1 V$ j, s8 QERROR [DRC0039] Tap may not be connected with the bus Check Entire net. DD3: SCHEMATIC1, top (3.55, 2.30)
6 M5 }, o4 p8 t; O' |: ~# kERROR [DRC0039] Tap may not be connected with the bus Check Entire net. DD4: SCHEMATIC1, top (3.55, 2.30)( M( w! A* a" ]8 Q0 W
hierarchical pin name D[1..4],
& ?! c% M, X2 tbus name DD[1..4],
1 a* o1 v3 F7 L: q$ D+ \, l5 dnet alias 分别为DD1,DD2,DD3,DD4。
. F* L- n! S( M9 }, C问题出在哪呢?如果把根图上的bus name 去掉,就又报警了,
" T/ D9 m! H V' L3 F/ ICheck Bus width mismatch2 d8 R! `" @8 [$ g
N06946 has not connected with proper width
6 H: [/ }3 |0 b! z- TWARNING [DRC0030] Bus width is not matching with the port Width block1,DD[1..4]: SCHEMATIC1, top (2.45, 2.30)
5 r/ ^. d0 I& Z1 r" x2 fN06946 has not connected with proper width
7 Z4 z+ \$ S0 @8 |/ ]WARNING [DRC0030] Bus width is not matching with the port Width block2,DD[1..4]: SCHEMATIC1, top (3.55, 2.30)
! Z' w G1 U" I7 H |
