楼主: yulizi
Hotfix_$PB16.50.009
    2024-5-31 15:50
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    16#
    发表于 2011-10-30 10:29 | 只看该作者
    安装了不是S009的
    17#
    发表于 2011-10-30 11:51 | 只看该作者
    rx_78gp02a 发表于 2011-10-29 00:46
    - M4 p2 R8 A( u8 R5 G有不用重装的方法啊!先安装程序,不装hotfix,把spb16.5整个文件夹压缩备份,装好hotfix再破解,以后有新 ...
    ( l+ u: g( \  c{:soso_e179:} 试试这种方法稳定性如何!
    18#
    发表于 2011-10-30 11:59 | 只看该作者
    我认为这不是真正的009,大家还是不要安装了。
    2023-10-12 15:00
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    19#
    发表于 2011-10-30 13:29 | 只看该作者
    本帖最后由 flyingc381 于 2011-10-30 13:30 编辑 2 E4 e: K; q3 v8 m1 H" m% V1 ?- E
    ; [; N* U1 C0 S没有问题,,是009,,我已安装,,只不过只解决了两个bug
    8 j: O# b* ]  f' Z  E+ ZDATE: 10-26-2011   HOTFIX VERSION: 009, }/ |+ e; h8 T0 S) I. _
    ===================================================================================================================================) d  s0 V" s# m# U: O
    CCRID   PRODUCT        PRODUCTLEVEL2   TITLE( C- `' r" p. N' u: m
    ===================================================================================================================================5 {9 z" O3 w- z
    945788  CONCEPT_HDL    CORE             Some component properties on the parts are incorrectly changed after Import Sheet- c2 z. t* A  N% T- W! V
    945789  ADW            LRM              Some component instances are not updated by LRM even though cache ptf is updated from reference6 G6 `  R0 Q! _
    DATE: 10-21-2011   HOTFIX VERSION: 0088 K; J" ]6 M9 s% A2 d2 u
    5 S' J' O0 H( m6 I) LCCRID   PRODUCT        PRODUCTLEVEL2   TITLE
    6 ]7 b5 l. ~9 K/ |7 P$ r) B===================================================================================================================================
    ) a7 D1 Y2 K# ]! d+ h+ U- ~906827  ALLEGRO_EDITOR DATABASE         Logic > Parts logic does not work correctly.) k2 J) v% u- s2 L$ T
    923346  CONCEPT_HDL    CORE             Not able to move the reference designators inside hierarchal blocks after uprev to 16.5
    % G* ?& Q7 t# ]7 L926347  ADW            COMPONENT_BROWSE Usability- Libflow Part check in comment should end up in Comments attribute for UCB/Designer to see it  I; R( K% w2 b( {
    929348  F2B            BOM              Warning 007: Invalid output file path name5 r6 `3 N9 G  c( q& y
    929777  CONCEPT_HDL    OTHER            Component Revision Manager gives internal error) k9 V9 c# X' Y# ]% j, B2 Y2 \4 G
    930783  CONCEPT_HDL    CORE             Painting with groups with default colors
    ' s0 ~- [. B" d1 ^# [936748  ALLEGRO_EDITOR INTERACTIV       "Unplace Component" menu inconsistent between General Edit and Placement Edit Mode.
    8 d5 [$ s$ q% w: T- C938143  ALLEGRO_EDITOR CREATE_SYM       Why is this Extra Property 'ECSET_MAPPING_ERROR3 @) M$ T" Q0 [; I5 O6 V
    938281  SIP_RF         OTHER            export_chips creating bad data when symbol is split and contains V- V+ pins5 m6 ~, T* q/ \4 }# ~
    938812  ALLEGRO_EDITOR SYMBOL           Cannot create a BSM with this DRA, errors out but does not state a reason.% b4 j% C9 I) v0 p
    939075  CAPTURE        TCL_INTERFACE    Texts are getting garbled in command window% b6 Z8 S1 i4 I3 ?7 \5 Q
    939193  F2B            PACKAGERXL       ERROR(SPCODD-439): Connectivity server is unable to load the design.( m% D* r9 M. j* d' l" C! J
    939199  CONCEPT_HDL    DOC              "Retain electrical constraint on net" mismatch between schematic (YES) and design (NO)7 [! b1 s: @4 U0 h
    939346  ALLEGRO_EDITOR SHAPE            Shape disappears when updating with variable shape_rki_autoclip set.: I+ x/ ~2 a7 ^) N, K& w; L1 r
    939901  CONCEPT_HDL    INFRA            NET_SPACING_TYPE shows ??on lower hierarchy level nets after Upreving to 16.5 version.  t2 T* F0 |' i( k1 d3 n) t
    939918  PSPICE         PROBE            Print > Preview for output file causes Pspice crash.& v% I( Z4 o0 s
    940217  CONCEPT_HDL    COMP_BROWSER     UCB reports 'No Symbol found for the part'
    0 w: L- Z6 v1 T: N4 x0 v- y4 x+ S940835  CONCEPT_HDL    INFRA            Desing package different after uprev to 16.5 where comp instance  propeties are lost  lost8 `" Z  U# U, a! O
    941125  ALLEGRO_EDITOR DATABASE         Performance advisor doesn't skip non plated slot padstacks
    9 c3 D" @! Q& ?0 s4 M941876  SIG_INTEGRITY  OTHER            Illegal model name cause pxl fail in 16.3
      N9 ?4 [# ?  m! u! Z, `! N8 c1 z) g942210  SCM            OTHER            Is the Project File argument is being correctly passed?9 X# }/ {: i4 K; {5 v
    942274  CAPTURE        PROJECT_MANAGER  Crash on renaming a Design Cache part in Project Manage after doing replace cache7 U1 i9 b( b+ J6 S( l; a
    942839  ALLEGRO_EDITOR GRAPHICS         Graphics Issue- Pads are not visible: W0 x( U3 n5 \9 X( `0 B
    943055  ALLEGRO_EDITOR SKILL            axlDBCreatePropDictEntry causes application to crash# n  U5 `' w0 k, L4 ]* w" B, R
    5 R2 c3 O# A% W# t发布日期只隔了5天
    20#
    发表于 2011-10-30 14:47 | 只看该作者
    ivanyjf 发表于 2011-10-30 11:51
    - \+ A! w/ V9 e# x3 ^, ]9 `1 o试试这种方法稳定性如何!
    ' J/ s6 ~0 S# K: @* \
    没问题的,相当于重装了软件
    21#
    发表于 2011-10-30 14:55 | 只看该作者
    mengshang 发表于 2011-10-30 11:59 # k; `% i2 Q1 H) o3 u  S% Q3 A3 T3 R
    5 \5 r, J- d; n3 s& J" y: b3 K$ ?这个是真的09,只有更新了bug的插件才会显示是最新的版本,如果pcb editor没有更新,版本号会停留在最近修改的版本号上
    2025-7-23 15:00
  • 签到天数: 649 天
    [LV.9]以坛为家II
    22#
    发表于 2011-10-30 14:57 | 只看该作者
    cadence, 无语了啊!
    23#
    发表于 2011-10-30 20:58 | 只看该作者
    无更新啊
    24#
    发表于 2011-10-31 16:29 | 只看该作者
    谢谢分享
    2 U" \( ^3 ^: ?
    25#
    发表于 2011-10-31 16:40 | 只看该作者
    和008相比,改动很小
    26#
    发表于 2011-10-31 16:42 | 只看该作者
    和008相比,改动很小
    27#
    发表于 2011-10-31 16:50 | 只看该作者
    下载了,谢谢LZ.这补丁版本真是更新的够勤的。
    28#
    发表于 2011-11-1 11:06 | 只看该作者
    谢谢分享
    29#
    发表于 2011-11-1 12:31 | 只看该作者
    rx_78gp02a 发表于 2011-10-28 21:41 9 h' {1 k4 e8 I( y- b
    09竟然比08就大了1kb!
    . R& Z/ s: k: r
    该贴可以封了,前几天我装了,忘记了跟大家说,就是008,根本不是什么009,楼主忽悠大家了
    30#
    发表于 2011-11-1 12:55 | 只看该作者
    08的是这样的,装了09会多出前两项,我没有忽悠大家,冤枉啊( Y* ~. \* i& f4 q: i+ w$ T, J
    ; `( z$ P9 K7 O& _, PDATE: 10-21-2011   HOTFIX VERSION: 008
    5 Y( v8 i+ w& f: ?" ~  V( C) Z===================================================================================================================================
    # ~9 q8 c5 G7 w* LCCRID   PRODUCT        PRODUCTLEVEL2   TITLE5 J5 j# O' A8 A7 N2 E# ?+ B
    ===================================================================================================================================/ \6 G, j1 n, W
    906827  ALLEGRO_EDITOR DATABASE         Logic > Parts logic does not work correctly.* w! x. z' k! i4 i
    ' @* s% r, o" L' p; X; J# J926347  ADW            COMPONENT_BROWSE Usability- Libflow Part check in comment should end up in Comments attribute for UCB/Designer to see it( N* M7 d$ E* i9 b8 X, L
    929348  F2B            BOM              Warning 007: Invalid output file path name" V4 O3 s# M' t0 d3 R
    ' P+ P8 K$ t2 Y9 S4 r: q( K4 c& k930783  CONCEPT_HDL    CORE             Painting with groups with default colors
    & o* Y% q+ p! k+ F7 L936748  ALLEGRO_EDITOR INTERACTIV       "Unplace Component" menu inconsistent between General Edit and Placement Edit Mode.* \, n. h/ B3 w) x- g$ J$ H
    938143  ALLEGRO_EDITOR CREATE_SYM       Why is this Extra Property 'ECSET_MAPPING_ERROR  a+ p) M9 B  ~8 B4 ~
    938281  SIP_RF         OTHER            export_chips creating bad data when symbol is split and contains V- V+ pins; D+ z5 k% x/ g
    ; t/ @/ m: ^. F: z5 m9 \939075  CAPTURE        TCL_INTERFACE    Texts are getting garbled in command window/ T* h8 R. P2 X2 s$ v4 |
    939193  F2B            PACKAGERXL       ERROR(SPCODD-439): Connectivity server is unable to load the design.& F6 Z0 q% w1 Z9 F7 M0 a
    939199  CONCEPT_HDL    DOC              "Retain electrical constraint on net" mismatch between schematic (YES) and design (NO)$ n7 }+ W( Z: ~/ M0 z0 D* {
    939346  ALLEGRO_EDITOR SHAPE            Shape disappears when updating with variable shape_rki_autoclip set.. s8 Y/ E; F2 G. E8 t
    # Y1 M$ M3 x. ^- X9 _. U# ~. w939918  PSPICE         PROBE            Print > Preview for output file causes Pspice crash.8 R8 Z2 J( e+ u* a' v  j
    940217  CONCEPT_HDL    COMP_BROWSER     UCB reports 'No Symbol found for the part'5 A( h0 w2 x% t, q4 w0 r1 w. q$ n
    940835  CONCEPT_HDL    INFRA            Desing package different after uprev to 16.5 where comp instance  propeties are lost  lost! ^; R. b) G% m( i4 z
    ( K  S  P6 p0 c6 h( x941876  SIG_INTEGRITY  OTHER            Illegal model name cause pxl fail in 16.3
    ) O5 D2 {% d$ `, c7 E+ ~$ i* E942210  SCM            OTHER            Is the Project File argument is being correctly passed?& D( W4 i  [* C- {8 _
      {7 D2 M3 E  z, a' E" ?% k942839  ALLEGRO_EDITOR GRAPHICS         Graphics Issue- Pads are not visible5 S2 {, ~/ Y& `) N# n
    GMT+8, 2025-7-23 22:19 , Processed in 0.140625 second(s), 22 queries , Gzip On.
