TA的每日心情 | 开心 2023-7-3 15:02 |
签到天数: 37 天 [LV.5]常住居民I
- a6 z$ D; c. D5 h
2 G+ A) O6 q% R+ k* ~) r电气规则:等长,差分对对间线长误差
" Z% | ^1 ]! a. S' I. |. R0 e物理规则:线宽,线距0 z5 m: G3 M. f4 O' Y5 x) h Q: n
间距规则:间距相关设置
6 e+ N W! u5 z% [* t
! F7 C: i2 I: M& n% l) D7 m/ g* Z' U
Class:A Net Class constraint object lets you group net objects that share common characteristics and require a similar constraint requirement
2 \4 A4 [( ~, d5 {; ?Net group:A Net Group is a collection of various net (signal) objects. Different type of net objects, such as nets, buses, differential pairs, and XNets, can be the members of a Net Group.
1 z5 ] P8 z( L& _9 t1 |0 ]Match group:A Match Group is a collection of nets, Xnets, or pin pairs which must all match (in delay or length) or be relative to a specific target within the group
; d/ P, {, ?4 u" ` @Pin pair:Pin Pairs may not be directly connected but they must exist on the same net or Xnet
7 }( a! c/ P4 ^5 C$ IDifferential pair:差分对5 |/ F" c* q& r8 Y7 z3 f2 G
Net:网络
' p5 y1 T" v% s5 f) LX-net:) Z* C K. m. s) i: c7 g. z& T$ y3 m+ K, {
Region:区域! q$ e/ j1 t! Z; ]& h- S
Region class:A Region Class constraint object lets you constrain the members of a Net Class—within a Region—differently than the original constraints on that Region5 Q) S& O) d! h
( O+ C1 B. ^% Y, X4 q* t' O: ~4 w* t+ \" b( Y- s2 ]- D9 Z
