查看: 411|回复: 5
[Cadence Sigrity] Sigrity点击保存提示警告求助
发表于 2022-8-29 16:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1 B4 ], Q* Q' P. ]' H8 J
各位大佬,! B4 Z' q3 P9 q7 c5 ^) O* A# _
点击SAVE提示报警告,但没看出是哪里出问题,是不是sigrity哪里要设置规则,新手,烦请各位指点* u- V  ^' D) x3 C5 r3 i; J
0 c: h" e$ F4 i/ O  i6 f: `2 B  Y1 P) m8 I$ P
& [3 L7 \- L& Q
  ]+ {9 w: A3 C2 Q# Z9 ^- jWARNING [Node Placement]: Node206971::GND at (143.578mm, 132.688mm) on layer Signal$TOP has a placement warning, X! S/ t/ N8 D1 h- v
WARNING [Node Placement]: Node206117::GND at (95.517mm, 109.995mm) on layer Signal$BOTTOM has a placement warning* x# h! }) j0 ?+ B6 k( J
WARNING [Node Placement]: Node207005::GND at (156.575mm, 57.134mm) on layer Signal$BOTTOM has a placement warning& u9 L5 M0 \# t6 q( M
WARNING [Node Placement]: Node206160::GND at (155.173mm, 79.820mm) on layer Signal$BOTTOM has a placement warning! |% T9 P) l! K5 R' k+ t
WARNING [Node Placement]: Node206179::GND at (144.899mm, 63.703mm) on layer Signal$BOTTOM has a placement warning, I; f& N% K# C) {& |1 U/ r
WARNING [Via Placement]: Via11200::GND at (78.553mm, 122.712mm) with lower node on Signal$BOTTOM has a  placement warning
+ I5 w( V' w8 H1 H. q  r/ kWARNING [Via Placement]: Via12064::GND at (95.546mm, 122.578mm) with lower node on Signal$BOTTOM has a  placement warning* w) a/ X/ O) {- }: l6 ]8 M
WARNING [Via Placement]: Via13072::GND at (164.985mm, 70.455mm) with lower node on Signal$BOTTOM has a  placement warning
4 }4 E; C0 u( D' s; x% vWARNING [Via Placement]: Via24423::GND at (115.047mm, 10.426mm) with lower node on Signal$BOTTOM has a  placement warning3 N2 L( M: ]9 I& J! |9 a! i
WARNING [Via Placement]: Via27191::GND at (200.754mm, 52.577mm) with lower node on Signal$BOTTOM has a  placement warning" S6 s: S5 {' W7 p" q& @7 [
WARNING [Via Placement]: Via38951::GND at (152.865mm, 79.728mm) with lower node on Signal$BOTTOM has a  placement warning# Q- J$ t/ z$ W9 @6 p
WARNING [Via Placement]: Via38961::GND at (153.665mm, 79.728mm) with lower node on Signal$BOTTOM has a  placement warning7 [+ B+ L9 y* S) T" j
WARNING [Via Placement]: Via38991::GND at (154.465mm, 83.728mm) with lower node on Signal$BOTTOM has a  placement warning
5 Y7 {% q* Q$ e9 N# q9 h! AWARNING [Via Placement]: Via39041::GND at (160.065mm, 79.728mm) with lower node on Signal$BOTTOM has a  placement warning- l3 }6 e9 V" j' G% \4 B
WARNING [Via Placement]: Via39061::GND at (158.465mm, 79.728mm) with lower node on Signal$BOTTOM has a  placement warning! H' q/ Q8 @5 S2 a! Q
WARNING [Via Placement]: Via39091::GND at (156.065mm, 79.728mm) with lower node on Signal$BOTTOM has a  placement warning0 P+ H" P( e, e$ f
WARNING [Via Placement]: Via39101::GND at (159.265mm, 79.728mm) with lower node on Signal$BOTTOM has a  placement warning2 d5 u4 d# c# S" _1 q0 Q
WARNING [Via Placement]: Via39131::GND at (155.265mm, 79.728mm) with lower node on Signal$BOTTOM has a  placement warning9 X1 }$ [3 P8 I! h  e
WARNING [Via Placement]: Via39361::GND at (148.865mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning1 L9 |# [/ }. ?) ~" M/ d
WARNING [Via Placement]: Via39371::GND at (148.065mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning# ~% s" i2 G# J' v, t7 F1 a9 F
WARNING [Via Placement]: Via39471::GND at (153.665mm, 65.631mm) with lower node on Signal$BOTTOM has a  placement warning8 T9 a& \0 g& M  _' }# B
WARNING [Via Placement]: Via39481::GND at (160.065mm, 65.631mm) with lower node on Signal$BOTTOM has a  placement warning  P8 C) c4 e. D9 @4 O
WARNING [Via Placement]: Via39591::GND at (153.665mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning
+ h" G) e. A& z! Y5 Z7 {WARNING [Via Placement]: Via39611::GND at (160.065mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning0 u- y6 h- Z  i5 J
WARNING [Via Placement]: Via39621::GND at (158.465mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning7 h) T- y$ \8 o: j
WARNING [Via Placement]: Via39631::GND at (157.665mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning
7 b  p% G1 ^6 X. sWARNING [Via Placement]: Via39641::GND at (155.265mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning" E6 Z9 Z6 `. ?+ _8 r
WARNING [Via Placement]: Via39651::GND at (156.065mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning! w; \: d( j# Z* ]3 k5 l
WARNING [Via Placement]: Via39661::GND at (154.465mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning, D3 G0 t! h' [6 \6 l# w: N
WARNING [Via Placement]: Via39671::GND at (159.265mm, 69.631mm) with lower node on Signal$BOTTOM has a  placement warning  n/ Y" C: K1 c5 C; w
WARNING [Via Placement]: Via40277::GND at (152.065mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning
% B& X% i* J, m. W9 }WARNING [Via Placement]: Via40552::GND at (153.665mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning7 J: X' l% H  j/ l+ l3 a4 Z7 a2 R4 U
WARNING [Via Placement]: Via40585::GND at (152.865mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning: R" y: G; {  i) ~6 ^) ?, [9 V
WARNING [Via Placement]: Via40673::GND at (159.265mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning; f( l; Y' _8 I. ?6 v
WARNING [Via Placement]: Via40684::GND at (155.265mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning* r" r& |: _) n4 K" R
WARNING [Via Placement]: Via40695::GND at (156.865mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning, U/ Y+ ~9 v: M3 m
WARNING [Via Placement]: Via40706::GND at (157.665mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning8 s; F, p8 d1 N' b
WARNING [Via Placement]: Via40717::GND at (156.065mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning
$ c# V6 `  ^' J+ x5 Y& KWARNING [Via Placement]: Via40728::GND at (158.465mm, 37.437mm) with lower node on Signal$BOTTOM has a  placement warning
3 R/ }$ m) V. a/ LWARNING [Via Placement]: Via41135::GND at (152.865mm, 23.086mm) with lower node on Signal$BOTTOM has a  placement warning/ R: Q" ?) F/ R2 L* z1 w4 |
WARNING [Via Placement]: Via41146::GND at (153.665mm, 23.086mm) with lower node on Signal$BOTTOM has a  placement warning
& X9 u0 g7 `  X' ]2 nWARNING [Via Placement]: Via41179::GND at (158.465mm, 23.086mm) with lower node on Signal$BOTTOM has a  placement warning0 S6 Z, c3 `. u5 p' S& X
WARNING [Via Placement]: Via41223::GND at (157.665mm, 23.086mm) with lower node on Signal$BOTTOM has a  placement warning$ ?' f. P: R4 s& f7 c) x8 l( @
WARNING [Via Placement]: Via41234::GND at (156.865mm, 23.086mm) with lower node on Signal$BOTTOM has a  placement warning7 J4 |; i  M* G8 r9 u* ~) ~9 S& c
WARNING [Via Placement]: Via41278::GND at (159.265mm, 23.086mm) with lower node on Signal$BOTTOM has a  placement warning& y/ m# R" O1 @3 T, f8 V" t7 Y' W
WARNING [Node Placement]: Node155676!!2::GND at (160.333mm, 86.927mm) on layer Signal$BOTTOM has a placement warning.7 |; G+ c! l/ k6 I$ g0 S, J
- a! ~( c! }' \7 {0 o5 v6 a
/ r# ?: Z  G  M& |6 V$ E/ e
发表于 2022-8-29 18:24 | 只看该作者
没设置好吧。5 p$ p7 T6 Z; ?/ Z- @9 }
这跟哪里的设置相关呢,没看到有类似PCB的设置啊  详情 回复 发表于 2022-8-30 10:19
 楼主| 发表于 2022-8-30 10:19 | 只看该作者
messed 发表于 2022-8-29 18:24" Z* o: L0 s8 M4 t# u, Q  T8 K& {
没设置好吧。
: J. V  Z* ]( C* R; i2 b$ P
这跟哪里的设置相关呢,没看到有类似PCB的设置啊. Z' O  G9 a' g+ w
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2022-8-30 12:05 | 只看该作者
    按提示的坐标检查一下过孔连接情况,警告信息而已,不一定要处理
    OK  详情 回复 发表于 2022-8-30 14:49
     楼主| 发表于 2022-8-30 14:49 | 只看该作者
    dzkcool 发表于 2022-8-30 12:05  k4 V- b- R. g9 s
    ; {( e2 S5 H' C) J  m
    OK2 k( F4 ~( I2 d4 ^- A% f
    发表于 2022-9-1 09:40 | 只看该作者
    警告,可以直接忽略
    GMT+8, 2025-11-2 14:58 , Processed in 0.234375 second(s), 28 queries , Gzip On.
