9 H. e1 T6 J0 T( P6 c& I1 O0 R) h1 ?! f6 V" C; I
solution: }+ H; }5 [ N
1.Editor Control 中Route 选项卡中Vias&fanouts下面的Auto trim through vias不选。如果选上,那默认的就是打最短路径的过孔。
g S6 z/ t. T# @ c5 o
% W* N" V$ P3 m+ ?- i" ]. z" ?) }( ^9 b1 E& x7 s. B/ F7 F
0 D- Y4 u3 X" F% w% ^3 x! D, b
6 i6 _; ]4 h7 e% v& x2 b! [Auto trim through vias:Checked, converts all existing through-hole vias to the shortest via span the routing requires.Note: Clear this option to change multiple microvia spans to a through-hole via span. Otherwise, when the software applies auto trim, or when the microvia moves, the through hole span automatically reverts to a microvia span.
3 y; Z0 ?3 S4 T1 h+ Y7 K3 F8 r( B) S5 m
2.走线时还是要特别注意,打好之后check一下是不是想要的那种孔,因为后来盲孔也去掉了,只有through via 一种类型,所以规律还没有找到,但是至少手工改动之后不会自动变化。 |
