自己写了一个头文件LCD.H,在其中定义了如下的全局变量:const int8 NoCheckBusy = 0; const int8 CheckBusy = 1; const int32 LCD_RS = 1<<4; const int32 LCD_RW = 1<<5; const int32 LCD_EN = 1<<6; const int32 LCD_DATA = 0xff<<7; 在c文件lcd.c和main.c中都要用到,但是在编译的时候出现如下的问题: Error: L6200E: Symbol NoCheckBusy multiply defined (by main.o and lcd.o). Error: L6200E: Symbol LCD_RS multiply defined (by main.o and lcd.o). 上网站ARM.com/help/index.jsp?topic=/com.arm.doc.dui0435a/index.html" target="_blank">/zixunimg/eepwimg/infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0435a/index.html上去查找,有如下结果: L6200E:Symbol multiply defined (by and ). There are two common examples where this occurs: 1)Symbol __semihosting_swi_guard multiply defined (by use_semi.o and use_no_semi.o). This error is reported when functions that use semihosting SWIs are linked in from the C library, in the presence of the__use_no_semihosting_swiguard. See the ADS 1.2 Compilers and Libraries Guide, section 4.2.2, "Building an application for a nonsemihosted environment" and ADS 1.2 Developer Guide, Section 6.10.1, "Linker error __semihosting_swi_guard". To resolve this, you must provide your own implementations of these C library functions. The ADS 1.2 Examplesembedded directory contains examples of how to re-implement some of the more common SWI-using functions - see the fileretarget.c. To identify which SWI-using functions are being linked-in from the C libraries: 1. Link with armlink -verbose -errors err.txt 2. Search err.txt for occurrences of __I_use_semihosting_swi For example: : Loading member sys_exit.o from c_a__un.l. reference : __I_use_semihosting_swi definition: _sys_exit : This shows that the SWI-using function _sys_exit is being linked-in from the C library. To prevent this, you will need to provide your own implementation of this function. 2)Symbol __stdout multiply defined (by retarget.o and stdio.o). This means that there are two conflicting definitions of__stdoutpresent – one inretarget.o, the other instdio.o. The one inretarget.ois your own definition. The one instdio.ois the default implementation, which was probably linked-in inadvertently. stdio.ocontains a number symbol definitions and implementations of file functions likefopen,fclose,fflush, etc.stdio.ois being linked-in because it satisfies some unresolved references. To identify why stdio.o is being linked-in, you must link with the linkers "verbose" switch, e.g.: armlink [... your normal options...] -verbose -errors err.txt Then studyerr.txt, so see exactly what the linker is linking-in, from where, and why. To move forward, the user may have to either: - Eliminate the calls likefopen,fclose,fflush, etc, or - Re-implement the_sys_xxxxfamily of functions. See the ADS 1.2 Compilers and Libraries Guide, section 4.10, "Tailoring the input/output functions". 具体是什么意思看的也不是很懂,后来看了别人的解决方法是:在头文件中仅声明变量,而把变量的定义都放到c文件中去,问题就解决了。 即把 const int8 NoCheckBusy = 0; const int8 CheckBusy = 1; const int32 LCD_RS = 1<<4; const int32 LCD_RW = 1<<5; const int32 LCD_EN = 1<<6; const int32 LCD_DATA = 0xff<<7; 都放到lcd.c中就可避免该问题,时间不多,具体原因还有待研究。 在使用ADS1.2编译程序的过程中,我们有函数如下定义:void PutStr(uint8 x, uint8 y, uint8* str); 我们在主函数中有这样的用法: PutStr(0, 0, "Hello world!"); 经编译后,有如下错误: Error: C3028E implicit cast of pointer to non-equal pointer 解决方法如下: PutStr(0, 0, (uint8*)"Hello world!"); 即将我们的字符串强制转换为我们在函数中所定义的形式。 PS: C3028E: implicit cast of pointer to non-equal pointer C3029E: implicit cast of non-0 int to pointer C3030E: implicit cast of pointer to int C3031E: implicit cast of to int Try re-writing the code to avoid the implicit cast, e.g. add an explicit cast. These errors can be suppressed with "-Ec". |
GMT+8, 2025-9-23 08:11 , Processed in 0.140625 second(s), 27 queries , Gzip On.
