我在生成网表后,导入pads layout, 结果报告如下错误:, x. s5 p! [% H' {, `1 z
Can't find part Type item < XTAL_HC49SMT >6 w4 N! N1 x5 H0 k9 ]
Y1 XTAL_HC49SMT: ]' O2 T& S0 ^# ?
Can't find part Type item < XTAL_HC49SMT >' b' G- B+ v) f: R
Y2 XTAL_HC49SMT! v9 ]* x* K, | r6 A: A, z3 S
( L0 C% I* ?2 |: P9 b; b6 fY3 XTAL_HC49SMT! A, W1 B% `, A- t' H) s
*Part name not found U13" e3 B0 T) Q* `: w; m( E
U13.1 R9.1 C45.2 R13.2 R14.1) u% v2 X- D- @. S
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1356420) g* S K! q1 H$ [
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XT2_PHY% E. V5 S) y- Z0 z2 P
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal USB_D+27 w& ~/ x `) c' F4 M2 k
*Part name not found Y14 [2 n3 p' p* `& G% I# e/ H; B
Y1.2 U6.1 C28.1 J3.1 J4.1 J5.1' }; S& S7 Y4 `
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal OSC1
9 b9 p% x$ M1 H*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CRS_PHY
: W$ V7 D0 }) R*Part name not found Y2; Q/ _% D' n( o ]
U5.34 Y2.2 C41.2
- ?3 i) z; {0 S7 Y5 M*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal RTCK1% m' J0 z1 G8 @
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal VDD_PHY; p, ^3 U9 _. W# [. S
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal TXD1_PHY1 S* q# W6 T. k% C1 a' ~1 y
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal USB_OTG_ID
$ V5 S X2 d1 z* b# _- ~: `$ t9 S$ {除了上述报错元件不能导入,可以导入其它元件。我的部分PCB封装在自己建的pads库里,还用了些常用的自带库。请问3 @' [) f3 T) Y6 r+ ~9 P
这些错是什么原因造成的?我看了一天了也没头绪。
0 C. g! u& C+ Q( m( h; v+ R6 H: P多谢各位看完。
' z" e1 I5 h% k我会把整个设计放在附件里。$ n5 V$ W; n! W: z+ D( Z% }; N8 [
再谢。 |
