查看: 3760|回复: 3
按页面添加封装,在创建网表时出错,求指导。
发表于 2014-10-22 20:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# B. j7 `9 x: t6 N
5 b& y& V3 \" A5 }5 a% _6 L( }9 ]2 U
session log:# @6 B" Q0 g8 [0 Q
INFO(ORCAP-32004): Design Name:
) d  b: _- V  b) a" q  }9 o3 ke:\cadence\myprj\prj\prj3\prj3.dsn
, a, v9 R6 ]" bNetlist Directory:
" p' Q, K/ k* S* t/ ~2 DE:\CADENCE\MYPRJ\PRJ\PRJ3- O" G1 Q2 K* u- @; ~
Configuration File:7 c/ X: m+ M/ F* W- r5 T1 l( Y
D:\allegro\tools\capture\allegro.cfg" A+ I9 }2 x) C9 ]1 M+ A4 \. b6 Y( @
+ b: _# ^9 w& K' r+ I% N- E5 y: s
Spawning... "D:\allegro\tools\capture\pstswp.exe" -pst -d "e:\cadence\myprj\prj\prj3\prj3.dsn" -n "E:\CADENCE\MYPRJ\PRJ\PRJ3" -c "D:\allegro\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"
0 G" n) K" ~* W2 E( |! e#1 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#1" as visible power pin of same name already exists in Package AUDIO_RJ , J6: SCHEMATIC1, OPA_BUF (363.22, 50.80).
8 c# B: w  ^* B#2 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#6" as visible power pin of same name already exists in Package AUDIO_RJ , J6: SCHEMATIC1, OPA_BUF (363.22, 50.80).: K' I6 e! Q4 Q: ?; j
#3 WARNING(ORCAP-36006): Part Name "SW PUSHBUTTON-DPST_RESET_DSP-RESET" is renamed to "SW PUSHBUTTON-DPST_RESET_DSP-RE".5 q$ X! @6 a+ r& y5 B4 ~  b
#4 WARNING(ORCAP-36006): Part Name "TMS320C6713GDP_BGA272DSP_TMS320C6713GDP" is renamed to "TMS320C6713GDP_BGA272DSP_TMS320".
; b  f9 Q2 q6 F% L; p* @#5 WARNING(ORCAP-36006): Part Name "MT48LC2M32B2B5-6_SDRAMTSOP86_MT48LC2M32B2B5-6" is renamed to "MT48LC2M32B2B5-6_SDRAMTSOP86_MT".+ _- y3 q8 _" [3 R
#6 WARNING(ORCAP-36006): Part Name "SST39VF800A_SST39VFTSOP48_SST39VF800A" is renamed to "SST39VF800A_SST39VFTSOP48_SST39".
0 a; g/ T  S/ B0 M7 A1 r/ gScanning netlist files ...
6 a- d0 Z9 d: b  N( N; z2 D6 M4 N$ t* Z' e: O" @5 |& {
Loading... E:\CADENCE\MYPRJ\PRJ\PRJ3/pstchip.dat9 n  I: G8 w4 S4 u8 ^! D
+ k7 F! P/ {* R
0 U- T+ {3 I2 V5 M. y' @" O
/ ~, O; {6 m- c3 d* nLoading... E:\CADENCE\MYPRJ\PRJ\PRJ3/pstxpr
* F% p$ T  U" ^9 M9 x$ It.dat
% z% ?6 t( ~$ J: z9 D
' H$ R! g' E2 B* J, }4 wLoading... E:\CADENCE\MYPRJ\PRJ\PRJ3/pstxnet.dat
( c, x2 }, r5 C3 Rpackaging the design view...
6 ?! q6 H8 b( l% g$ L( ]& N% K) y$ U) U1 K2 P
Exiting... "D:\allegro\tools\capture\pstswp.exe" -pst -d "e:\cadence\myprj\prj\prj3\prj3.dsn" -n "E:\CADENCE\MYPRJ\PRJ\PRJ3" -c "D:\allegro\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"0 n6 ]9 B6 h+ L# ?9 x0 G' |
INFO(ORCAP-32005): *** Done ***
0 e/ J( m- U- w6 s! C6 v" G; N# j********************************************************************************* A, E6 v* B/ G
' k% A$ f& B, e' q* Updating Allegro PCB Editor Board
( @& A  A! F) V' x7 ~& Y*
! i8 G! v# B- H! B8 y$ x% @# I********************************************************************************
: e8 x6 }2 V# h$ A% pINFO(ORCAP-32040): Updating Allegro PCB Editor Board
$ a: w5 ^$ q4 s. n, L+ M% Y8 o$ c
1 t  p. a% V+ \3 l, Z  y0 v! W, J4 _2 k3 \) `( u0 }9 v. z
Spawning... netrev.exe -5         -y 1  -u  -i "E:\CADENCE\MYPRJ\PRJ\PRJ3" "E:\cadence\myprj\prj\prj4\prj4.brd" "E:\cadence\myprj\prj\prj4\prj4.brd"% O$ y3 d4 P3 h# T9 T$ L; L9 ~
Reading File : E:/CADENCE/MYPRJ/PRJ/PRJ3/pstchip.dat        , _4 n; j. a4 ?0 M8 A. [4 x
(00:00:00.09)# n4 R3 ?% }% t) B3 `
Reading File : E:/CADENCE/MYPRJ/PRJ/PRJ3/pstxprt.dat        6 e: ]! F; @' b: ~
(00:00:00.01)9 @2 K  K" g' R2 \3 m  S: M$ g
Reading File : E:/CADENCE/MYPRJ/PRJ/PRJ3/pstxnet.dat
  Z9 F/ v% _9 q; S  N% R: W4 G( z. W(00:00:00.01)
* J. f3 c8 n# ~& H5 \
; U9 X/ b9 @; I  J0 A9 K& ]  a: P/ H0 Znetrev run on Oct 21 16:18:39 2014+ D( [% {4 Y% g8 x3 F% ?
   DESIGN NAME : 'PRJ3'3 ], {8 O0 Z. ?: i) W7 l& J
   PACKAGING ON Apr 21 2011 10:02:30
/ D5 |& w/ ?. a+ e& U% R! S
8 o, X! E$ l! C: e# ?8 r1 R
' W8 B2 ~, o1 W8 Q$ n0 ^' x: d- k  2 errors detected! I, S7 Y8 M  h1 g# S1 t7 w
No oversight detected
. M. S+ [& M3 x0 q' e0 W No warning detected
( v' k% \* ]: b7 ?" G9 x( D+ g+ X4 p/ A* u
cpu time      0:00:300 V) Q& K2 u, F% `8 u
elapsed time  0:00:00
( K' P' |; F8 V; E/ \; S0 I7 d4 p% V( ~4 `- N  T3 w) m: w+ t" C
$ d0 ]! s) }: v0 `" g% ^Exiting... netrev.exe -5         -y 1  -u  -i "E:\CADENCE\MYPRJ\PRJ\PRJ3" "E:\cadence\myprj\prj\prj4\prj4.brd" "E:\cadence\myprj\prj\prj4\prj4.brd"
6 Z1 J& k; `# q7 F8 b6 K(---------------------------------------------------------------------)
4 J  l2 {; K) F1 Y* a* R7 M  O(        )
6 B3 O5 [# R. U(    Allegro Netrev Import Logic                                      )6 A% O- ]9 T. F0 ]# ?) }0 f8 W. ~
7 X0 D* s% d: P" |- v3 d(    Drawing          : prj4.brd                                      )  K5 [: F8 d+ z: O# H5 ]4 i, f
(    Software Version : 16.5P002                                      )
/ J) F6 h' S* C(    Date/Time        : Tue Oct 21 16:18:39 2014                      )
; R- s/ Y9 {' i' D3 G3 E(        )
& S, A: ~1 `% X0 Z(---------------------------------------------------------------------)
, B7 C* ]& I6 [& x' C
) P4 t" Y$ r$ V# z  H" X+ w$ R' S( ]4 f6 T% T6 i  {" M  S
------ Directives ------, k' c% u$ w4 l" C' @+ f/ P
( q, S( [0 ]- ?: d( i# WRIPUP_ETCH FALSE;/ c7 |) ~' }6 F5 G; f
RIPUP_DELETE_FIRST_SEGMENT FALSE;
9 x/ C: g# e, \0 J" X. J1 E$ zRIPUP_RETAIN_BONDWIRE FALSE;2 r! g4 r- U( U9 j! ]3 u* z
RIPUP_SYMBOLS ALWAYS;
  j% A3 o, b+ A5 @6 z1 o, J; z# zMissing symbol has error FALSE;( \+ I+ _0 ~( l. i/ S3 B) e
SCHEMATIC_DIRECTORY 'E:\CADENCE\MYPRJ\PRJ\PRJ3';
2 n, q9 Y$ M+ ^4 v" k6 g. z, }; D- XBOARD_DIRECTORY 'E:/cadence/myprj/prj/prj4';
" |5 U! {$ g0 o" g- x8 Z6 D2 u- HOLD_BOARD_NAME 'E:/cadence/myprj/prj/prj4/prj4.brd';, t7 ~) f1 E9 f7 D1 O& p- K
NEW_BOARD_NAME 'E:/cadence/myprj/prj/prj4/prj4.brd';
& @( X3 j+ b, x: c
. H+ }' H8 Y  {6 X3 u# p; }CmdLine: netrev.exe -5 -y 1 -u -i E:\CADENCE\MYPRJ\PRJ\PRJ3 E:\cadence\myprj\prj\prj4\prj4.brd E:\cadence\myprj\prj\prj4\prj4.brd! K: Q0 v5 q0 S* Z
- W; p7 j8 a3 {9 Z4 y------ Preparing to read pst files ------
# L/ t4 y2 k9 M+ Y1 z0 ~. h2 h
- I+ w% c8 O: AStarting to read E:/CADENCE/MYPRJ/PRJ/PRJ3/pstchip.dat
9 B6 Y1 T( X* ^   Finished reading E:/CADENCE/MYPRJ/PRJ/PRJ3/pstchip.dat (00:00:00.09)
$ ~! M; b% A7 u4 K  Z' VStarting to read E:/CADENCE/MYPRJ/PRJ/PRJ3/pstxprt.dat
1 ^7 x% ~7 q$ `6 L4 C   Finished reading E:/CADENCE/MYPRJ/PRJ/PRJ3/pstxprt.dat (00:00:00.01)! _. Z, L" c* p# B0 O% H$ e8 `
Starting to read E:/CADENCE/MYPRJ/PRJ/PRJ3/pstxnet.dat ; w" ?( F# ]1 ~( }6 @
   Finished reading E:/CADENCE/MYPRJ/PRJ/PRJ3/pstxnet.dat (00:00:00.01)5 H8 N/ h+ B) ~$ N# [" R! U
, J6 u8 N% R& P. H7 t& D
------ Oversights/Warnings/Errors ------) {1 l  O4 V" d0 v+ s1 ^/ ~$ ]
* x% {1 y  i2 g( \6 }" _/ _( u- h7 a+ o4 Q, R, n; s, }) T5 W# u
ERROR: File "prj4.brd" was locked on date "Tue Oct 21 15:53:20 2014" by user "Administrator" on system "USER-NGJHCN468J". Resolve lock file and re-run netrev.! g) }& ^* ]! `; y
0 m8 }# _8 ]: j( ?% ?/ G2 u3 \2 F
#1   ERROR(SPMHNI-175): Netrev error detected.
& ^' h, g- u! l* k. Q9 \/ U
2 `+ E$ F- b! ]#2   Run stopped because errors were detected3 p0 ^4 B' T! Y! T9 G9 D+ b1 Z3 Q( ]4 O
: I* a2 J) \8 t! C1 f3 Jnetrev run on Oct 21 16:18:39 20141 s; M! ?: d, }! g7 D' A( G
   DESIGN NAME : 'PRJ3'( k( }' H4 N5 p9 O* n1 C# a
) G' \, k3 T" I5 a2 a6 f6 V1 m3 S, v
   COMPILE 'logic'
, V2 X$ ?- W, A$ ?' m' ^/ y# Y   CHECK_PIN_NAMES OFF6 `! A4 w6 Y$ w- X" ~8 @  h" l1 @
   CROSS_REFERENCE OFF
/ A6 N4 I- G3 Z- [   FEEDBACK OFF
, j, }) I& s" O# s* ?   INCREMENTAL OFF/ V$ D4 h4 I7 D( V7 H: M2 c  O
   INTERFACE_TYPE PHYSICAL' H9 ^3 h  w/ G+ c) l
   MAX_ERRORS 5004 R/ _+ i" ~* S# j. Q5 g9 g
   MERGE_MINIMUM 54 X8 o5 l+ Z( S3 ]7 W1 x1 q' ^4 X
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'  C: {) u, K1 u
   NET_NAME_LENGTH 249 O! a& N0 x4 p" P+ s1 x
   OVERSIGHTS ON& U1 B! W: Z% |$ Y) v+ y
   REPLACE_CHECK OFF/ @( P& i. k, _  S9 d6 h  r0 F
   SINGLE_NODE_NETS ON- b% A2 ]! _5 t  z* x7 ^) D; I
   SPLIT_MINIMUM 00 c. _$ a6 I# l$ T- {5 n4 z
   SUPPRESS   20, Z3 c' ~9 Y- d$ j4 V# ?4 c
   WARNINGS ON
8 N8 n7 L* P. {  q2 g) Z+ A/ b% D( c" h( B
  2 errors detected6 w8 \& W* l0 B: r
No oversight detected& |+ _$ f) m/ b2 A$ o9 c5 O/ I% ~
No warning detected
2 o* T* X* i* i8 f: r! Z, B4 b& Y9 o) Z$ ?3 s8 k
cpu time      0:00:30
+ ?* A$ I' z3 R+ Welapsed time  0:00:00
) x, A7 p" O7 ?4 J8 f7 ?
/ X' y/ n: B4 e9 aINFO(ORCAP-32005): *** Done ***
6 B, Z( Z2 o  L, k& [9 f- u2 z- p4 G4 _0 B3 _0 {7 X
6 B0 I4 g6 J3 [- x
********************************************************************************2 ?9 p/ j% O1 X" b( ^# {; M' k! D
*' Y+ R* r/ \. T1 Y8 _& f
*  Design Rules Check3 [: a$ s. W1 Y+ A: v4 g: K. t
- t7 c2 t& C- M% i1 c- ?********************************************************************************8 ]% J; a4 t1 [  L$ {4 p2 i
1 G* A; Z, H& P2 U--------------------------------------------------
4 e4 p, r3 @% L/ a& h5 \8 ]" H4 b' ]Checking Schematic: SCHEMATIC1
8 K: h- R" M& j' k! M/ t9 D--------------------------------------------------' C' _: x& D  K. Q+ e
Checking Electrical Rules % l3 p. ], t" G& Q9 X" Y* Z
WARNING(ORCAP-1831): Unconnected pin U7,DR0/AXR0[0]
1 z' N0 H4 N- k9 \WARNING(ORCAP-1831): Unconnected pin U7,CLKS0/AHCLKR0
. S/ M: f6 \7 C" d# O& BWARNING(ORCAP-1608): Net has no driving source BE3 2 r( o3 X. y* _( L, X; g
WARNING(ORCAP-1608): Net has no driving source BE1 3 e& \/ _7 v  C  Z. p
WARNING(ORCAP-1608): Net has no driving source BE2
4 Z& M+ ]5 m) K3 J, WWARNING(ORCAP-1608): Net has no driving source BE0
1 t* n; ?# t8 D  D& L' i1 S. j' n+ O( ^
Checking For Single Node Nets: g% ]3 \! N: e  L: v
WARNING(ORCAP-1600): Net has fewer than two connections EA15
3 x2 W' t# F+ c- ~+ x2 `WARNING(ORCAP-1600): Net has fewer than two connections ED20 & ]/ A' H8 ~  e
WARNING(ORCAP-1600): Net has fewer than two connections EA19 5 ]* {& q# G# @# T6 Y% N7 r
WARNING(ORCAP-1600): Net has fewer than two connections BE3
5 ^" m) e1 V1 B6 k! ?6 bWARNING(ORCAP-1600): Net has fewer than two connections CE2 " F1 l- K" x( S) w: R$ ?& n* x6 c/ X
WARNING(ORCAP-1600): Net has fewer than two connections HOLD 0 Y3 \# q8 W  A
WARNING(ORCAP-1600): Net has fewer than two connections ED30
0 g- k1 S, p" a# K7 q) E4 E, c7 t6 yWARNING(ORCAP-1600): Net has fewer than two connections ED17
4 _4 `7 ?: Q6 e  p0 {& L. ^WARNING(ORCAP-1600): Net has fewer than two connections EA10
5 [, }2 R3 a2 {9 z2 S4 z! m, ?& iWARNING(ORCAP-1600): Net has fewer than two connections ED21
) n1 y" ?  W" G2 @& gWARNING(ORCAP-1600): Net has fewer than two connections ED18 6 ^* S/ U  V9 U7 L
WARNING(ORCAP-1600): Net has fewer than two connections EA12 * ?8 J7 u. k! b0 f' w
WARNING(ORCAP-1600): Net has fewer than two connections EA13
! }0 ]5 D2 N6 j' a* _$ l3 J( OWARNING(ORCAP-1600): Net has fewer than two connections CE3
7 Z% o0 o( f% n# ]WARNING(ORCAP-1600): Net has fewer than two connections EA20 . G: f, w* N# N3 P; ~
WARNING(ORCAP-1600): Net has fewer than two connections ED26 4 h6 m7 T/ F$ q1 h: {' n% E
WARNING(ORCAP-1600): Net has fewer than two connections ARDY
# f8 _- K. _! @* {- q% H, UWARNING(ORCAP-1600): Net has fewer than two connections ED13 6 J; t8 f. G6 d3 y
WARNING(ORCAP-1600): Net has fewer than two connections EA18 " R; ~8 `" r: w1 C5 a
WARNING(ORCAP-1600): Net has fewer than two connections EA7 ; `: Y0 [8 V3 {3 S  H
WARNING(ORCAP-1600): Net has fewer than two connections ED27 4 S$ |- d* m: p, x7 O+ V
WARNING(ORCAP-1600): Net has fewer than two connections ED22
! I6 r+ u  u4 s7 o3 J( fWARNING(ORCAP-1600): Net has fewer than two connections EA9
/ P/ W" }3 H) q; `0 RWARNING(ORCAP-1600): Net has fewer than two connections ED7
6 q/ G/ d" O" J" a- sWARNING(ORCAP-1600): Net has fewer than two connections EA17 " p  |- ]  N! s. H
WARNING(ORCAP-1600): Net has fewer than two connections ED24
+ t) R& M4 |6 m! Z: ZWARNING(ORCAP-1600): Net has fewer than two connections BE1 & G4 |# b  \8 @, Y2 e3 T4 W# \
WARNING(ORCAP-1600): Net has fewer than two connections EA4
( M& `6 b8 o! N9 M, aWARNING(ORCAP-1600): Net has fewer than two connections ED15 ( v, x" h+ B% V& q4 U1 K& ~
WARNING(ORCAP-1600): Net has fewer than two connections EA8 ( X( ~" \" R2 n+ ?
WARNING(ORCAP-1600): Net has fewer than two connections EA3 1 p0 R, y0 w. A- w
WARNING(ORCAP-1600): Net has fewer than two connections BUSRQ
; `. r# g& y9 ~& `0 u; {WARNING(ORCAP-1600): Net has fewer than two connections ED11
' y. s9 C4 P6 ?/ c  a" w8 E5 fWARNING(ORCAP-1600): Net has fewer than two connections EA6 7 h/ G% |9 z! j' X5 }; W6 q
WARNING(ORCAP-1600): Net has fewer than two connections BE2
( t' F1 [# M5 X) n" d: E; I. ~$ aWARNING(ORCAP-1600): Net has fewer than two connections EA16
* g0 q9 |! y& m3 _4 n; @WARNING(ORCAP-1600): Net has fewer than two connections ED31 " w$ e. W% g$ N4 K* Z; p
WARNING(ORCAP-1600): Net has fewer than two connections ED25
! v& a! H) ~0 {WARNING(ORCAP-1600): Net has fewer than two connections ED10 % U( @4 Z# u( t+ l: P
WARNING(ORCAP-1600): Net has fewer than two connections BE0 ! V& k$ O: T0 B' v3 D; ]( `
WARNING(ORCAP-1600): Net has fewer than two connections ED28 2 v6 }, A2 @. C* y$ q. E6 F7 N
WARNING(ORCAP-1600): Net has fewer than two connections HOLDA
2 Y( \3 q1 w: h2 w+ X6 EWARNING(ORCAP-1600): Net has fewer than two connections ED12
4 d* B. p. [4 k7 I' OWARNING(ORCAP-1600): Net has fewer than two connections EA11
1 c" S/ R. {: c" ]% h' d: HWARNING(ORCAP-1600): Net has fewer than two connections ED23
" h3 D( B9 l5 M9 f, @7 kWARNING(ORCAP-1600): Net has fewer than two connections EA14
4 p0 E" `- P4 P: O9 X% `' CWARNING(ORCAP-1600): Net has fewer than two connections ED29 " \0 [8 ^( n) E. \/ @3 Q
WARNING(ORCAP-1600): Net has fewer than two connections ED16
5 m: j/ c) e& x5 x) G+ a- @WARNING(ORCAP-1600): Net has fewer than two connections EA2
2 F6 |- ?3 |4 \( N$ E8 ?; s: VWARNING(ORCAP-1600): Net has fewer than two connections ED19 - p6 D" Y" `' _9 x5 O. \8 n
WARNING(ORCAP-1600): Net has fewer than two connections ED14 * S/ E3 v" e" V
WARNING(ORCAP-1600): Net has fewer than two connections EA5   m+ L) }6 G3 g
WARNING(ORCAP-1600): Net has fewer than two connections ECLKOUT 0 f" x: S4 d$ O! o3 ?, m
. \0 \" W& a6 l. v, x  v
Checking For Unconnected Bus Nets0 V3 K/ l& t7 G& h; J! u! |
4 Y$ m9 I. ^( V% _% f4 Q) n
% y# }; ^  ]3 c9 W2 ?6 i
发表于 2014-11-26 13:57 | 只看该作者
project 被鎖住了阿~
. h- E9 A+ t4 h. J* S* C! a  l8 _ERROR: File "prj4.brd" was locked on date "Tue Oct 21 15:53:20 2014" by user "Administrator" on system "USER-NGJHCN468J". Resolve lock file and re-run netrev.
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2014-11-26 14:29 | 只看该作者
    把打开E:\cadence\myprj\prj\prj4\prj4.brd的Allegro关掉,或者输出网表时,不要勾选Create Or Update PCB Editor Board,导出网表后再到Allegro中导入。
    GMT+8, 2025-7-14 09:44 , Processed in 0.140625 second(s), 27 queries , Gzip On.
