看了论坛上知道NC Route出椭圆,方形焊盘,不知道具体怎么做,哪为高手可以指点一下,网上看有人加个ncroutebits.txt文件,添加后提示以下,还有就是cutting path怎么回事?' J4 |1 |: I7 h: h/ W
0 ` v- c( [9 s4 f# m! F5 A G7 [9 ^+ w* v7 z0 r+ H' Y9 Y8 o- l
0 V7 x( A7 s4 \ Processing NC Parameters file ...
; \0 H4 |0 \7 t7 m3 k4 N6 X3 Y5 |9 g/ Q) \, p" P( }
NC PARAMETERS
% W$ W- v" ]! s5 } -------------6 F/ h4 N* h; @3 n
4 w8 V0 H$ R6 G- m4 D3 q
FORMAT 2.39 p. v b3 g3 R+ M& W+ ]
MACHINE-OFFSET x:0.000000 y:0.000000# E: m( `2 K8 M2 N' N3 j7 M: k
FEEDRATE 1# a1 U! r8 {7 ?1 J" l0 l5 }, n
COORDINATES ABSOLUTE
V2 ^ @/ w# O OUTPUT-UNITS ENGLISH
% c0 H, V9 w2 `; d' b/ ^8 ^ TOOL-ORDER INCREASING: \7 v3 m$ ^, G. V
REPEAT-CODES YES
; r1 A9 S t* b5 }2 o- q, r SUPPRESS-LEAD-ZEROES NO0 Q6 d8 o, V. S4 N7 M) g
SUPPRESS-TRAIL-ZEROES NO
5 G: N; {; G# X9 K0 k SUPPRESS-EQUAL NO
/ S7 p& w, v% q TOOL-SELECT NO/ E9 k: u" }5 g P( v5 T
HEADER none
4 P% x1 p. W! a2 N LEADER 12
* G/ K: n8 L" d% Z CODE ASCII. ]' V( q- t, d$ d& s* D! i
SEPARATE NO
! j T3 l# w( H2 g! p h. `0 U OPTIMIZE_DRILLING NO
5 B+ t9 `5 ?- z9 e& J ENHANCED_EXCELLON NO* \& j ^" Y5 X
SCALE 1.000000
0 C$ R7 |/ r6 y' R% j
+ Q4 V: y& n2 Z0 i3 C* @; r-------------------------------------------------------------
( c3 u0 p% m) _6 g' i% i
# `* s' {% r% D$ P/ b6 U; T9 }* e& N l- a Processing route path data ...
+ l2 x+ H) O# ?$ N u. v" e. `( \. y; h; G0 t: q
WARNING: No route path data was found for processing!$ W+ n7 T; }. m* r3 B# |
R ^0 l8 h4 E6 [1 K-------------------------------------------------------------9 I4 \8 H! P/ d
2 V2 |, R8 A+ g9 }1 _( g8 L( [
Processing slot hole data ...( T% |4 T' u' g, y8 {! U# _
% g7 P1 c8 Z: a6 E( [
Processing tool file (ncroutebits.txt) ...
0 b8 J3 k* B/ M8 ]/ [- W NOTE: All units are assumed to be inches.) U5 A' H; B2 k3 e$ y
/ a) J- P" ]% k
0.6 T200
: {- M X6 h7 N4 B2 ^1 U" P 0.65 T201
1 M: E' ]# X6 e 0.7 T202
* R9 J" G5 E2 g% ?5 A" {# V: V5 | 0.75 T203% j6 o; e) ^9 {, d2 f1 T/ z/ F# Z
0.8 T204
- E: T' J c1 Q 0.85 T205
# x$ { i: u" G+ V3 ^1 c 0.9 T206
/ W0 T$ h8 l' B* i ?0 A 0.9271 T207
; ~. o8 Y% F% A# U9 K/ L; J 0.95 T208& f4 b6 {5 T" } b5 ^9 m8 D3 \
1 T209" r! j1 L4 n$ X$ `: P V
1.05 T2105 o. b) W' J5 M6 @9 j
1.1 T211
5 s+ |# W+ G0 s! y5 p% H' B* v1 X 1.15 T212
+ P" a3 I- m/ w8 c+ P8 b 1.2 T2139 j7 V( Q: S4 w4 K
1.25 T2141 ] U; ]" |8 ^& [/ K: \5 N
1.3 T2151 I% e3 f( g9 D3 z; Q7 L# _
1.35 T216
" }1 E. G- J9 c" Q; j$ ` 1.4 T217
2 o* o) f2 E" {2 r( K2 a+ y 1.45 T2185 q; ~- O2 ~; }3 e" h) B
1.5 T219
2 }! }4 S+ }$ u4 M7 }: x8 C 1.55 T220
& w5 }, e2 U4 m1 W: u0 m! f 1.6 T221
: o; q8 Y% v# E) k) O 1.65 T2223 S: {8 v6 u+ l# m5 n/ K. A1 M" v' P( w# ^
1.7 T223( G& k+ C+ v- c: T8 N8 v
1.75 T224) \; Q, h) V) `+ C4 ^
1.8 T225! L8 \5 i9 I- U& @1 r# L9 t3 C/ v
1.85 T226
! n* n( l' @. t- ^- g1 ? 1.8542 T227
9 ^- E' G3 S: g+ v# h 1.9 T228
6 c2 T% O8 j$ {5 I& R3 u( V+ @ 1.95 T229
6 p8 Z7 ?) m: O- U0 J& y 2 T230
" y; K2 k' H$ D* H 2.05 T231
& U/ J5 n4 _1 E- R% w3 J 2.1 T2322 W0 l+ y( _% n4 F" l h7 Z3 p
2.15 T233
" g* A7 E! f1 k4 L 2.2 T234
5 G+ H. N, J/ B2 m% U4 ]$ |3 \! ` 2.25 T235 I+ p2 y* R; F7 |! t0 k
2.3 T236
m$ ?, d) N: ]; f5 R# E) Q 2.35 T237# S k$ t4 X; t, q' `" p) r; ?
2.4 T238
2 N8 i3 j" u& ~: P
, u3 H* s" {" h# M* [$ ]2 j4 W+ m( { No errors found.. M! j9 T8 f; n* r% Q
+ Q7 K# ^* t n, r t4 u' U
; ^6 ` \( Y) Y5 J0 F WARNING: No toolcode of a size the same as or smaller than 39 found for an OVAL slot!: z% _9 W1 c, w& O$ l! b+ H6 u
Defaulting to T01 as toolname.
, N" S+ R4 g9 ^: k3 f
2 H" ^4 A+ B# x% a9 h; ^ WARNING: No toolcode of a size the same as or smaller than 39 found for an OVAL slot!
5 ^/ y1 | Z, h# p Defaulting to T01 as toolname.
6 J6 a! \1 G5 y% _9 N& g! x
. E5 `' _ d" b7 z1 D WARNING: No toolcode of a size the same as or smaller than 39 found for an OVAL slot!, G3 s& D3 Y+ P3 g2 V2 w) ^
Defaulting to T01 as toolname.+ h' T7 j3 y b% J
8 _$ A, W8 ^3 M* J5 X8 A
OVAL slots routed: 3
7 X3 j+ j+ D; N, k8 f h! F RECTANGLE slots routed: 0
' U/ ]8 A- c& P; o1 [
7 [. K* |2 e8 T4 N8 s( e-------------------------------------------------------------8 c2 h* _4 A" Z
& M( W; A5 N0 q3 B# n1 J- h NC Route file BDPCB12.rou created WITH WARNINGS ... Program completed. |
