cadence orcad CAPTURE元件库介绍
EDA365欢迎您登录!您需要 登录 才可以下载或查看,没有帐号?注册  % N$ L" P  g0 u' U3 N% x" O' A3 X0 K& r; i( R; b
 IEEE       Digital_IEEE_74009 f% b2 Q/ L! p5 T- I4 j8 R5 c8 ?
 - W% u! x% t& i1 w& {$ o              BUS_Driver_Transceiver_IEEE_7400  g! h( y3 d* i5 T; Y2 z
 , _6 p. @; d- k0 H              Counter_IEEE_7400
 3 Z- e* ~5 m9 s! o* J% w( y; c  e2 {( |$ ?) g% O3 T5 }  Q) D
 Digital_Gate_IEEE_7400.olb
 * X4 I8 u1 y( L4 q  `9 \$ Z* q0 E: ?2 Z+ T  ?! N
 Digital_Latch_IEEE_7400.olb   锁存器
 0 S: Q7 P5 h9 [/ _  F; T* I3 ^
 - |: F0 }, v. R# _% {Digital_MUX_IEEE_7400.olb     MUX
 - Z& U0 Y8 p/ V) M- B$ K多路复用器(multiplexer);* k9 M& F4 L4 W/ y# ~3 D
 Digital_Shift_Register_IEEE_7400.olb) ~: O8 P  y) r( x, p
 : N$ y, y. `8 F; x" E! b* a
 Digital_Static_RAM_IEEE_7400.olb                  静态随机存储器(Static Random Access Memory)+ I6 y6 Z: E' Z4 T3 l4 t: W
 $ C: ~0 C5 E5 h+ g+ H& a! w
 $ u3 u- s- ^5 Z) j, F% b8 J
 ( {  k( S/ D5 K3 aLibrary文件夹9 m/ ]2 F$ j. _: H9 q) l% |
 AMPLIFIER.OLB     5 A, [. ^* w' B$ w, f5 d& o
 共182个零件,存放模拟放大器IC,如CA3280,TL027C,EL4093等。  Amplifier_Analog_IC.olb
 ! C, e9 s$ t! K
 : B9 e* |* v, p  K% J5 pARITHMETIC.OLB       8 G- L5 O% B" O9 _
 共182个零件,存放逻辑运算IC,如TC4032B,74LS85等。
 ( M- L8 F* |/ \1 G( d4 x1 M
 9 p( `) y* i& J4 b6 E) wDigital_Logic_Arithmetic_IC.olb
 . y* J7 I  j2 ^/ i6 i$ E3 ?/ \) {+ w; V0 V5 E5 k
 ATOD.OLB& `8 c( I3 ]: `6 c- V9 ^" S
 共618个零件,存放A/D转换IC,如ADC0804,TC7109等。
 : P( V6 s2 e$ r3 H3 W& g8 D- I9 Y! p- q' R+ J5 K
 Data_AD_Converter.olb; ?0 D, L9 \# N% s; q# w$ D
 % K- Q: x# Y6 Z& ~% w+ ?4 m; d
 BUS DRIVERTRANSCEIVER.OLB  v, e- f5 O4 N2 m5 ?7 P4 G
 共632个零件,存放汇流排驱动IC,如74LS244,74LS373等数字IC。Digital_Bus_Drive_Transceiver+ [) z0 ?% N# q3 g( e. Z* f
 4 Z3 Y/ |9 c: u& `: ]
 CAPSYM.OLB( H9 ^! U% F7 O5 a, E) X4 T0 c0 d
 共35个零件,存放电源,地,输入输出口,标题栏等。7 {2 U5 Q( l& k& l2 J: x
 6 q, K* r- L/ J9 [. t* ZCONNECTOR.OLB7 {& O/ E8 R" b( M: y: `- g- O# |
 共816个零件,存放连接器,如4 HEADER,CON AT62,RCA
 & ^, f7 X; [. i' U% h; r5 @' ]% s  ?0 q! b; B
 JACK等。 Connector& l6 L. M8 V8 k% A, i
 ) R- G; ]8 j5 {1 y
 COUNTER.OLB
 7 W' |1 B: M" u共182个零件,存放计数器IC,如74LS90,CD4040B。) w' U4 W; ^& {0 l8 [- M, h
 * j) p( y9 C2 f# t: k4 z
 Digital_Counter_IC.OLB
 w: Y9 I2 P# f  _: E: _# Z; Y" B7 M  S8 ?
 DISCRETE.OLB" O( P: D* I! v5 t
 共872个零件,存放分立式元件,如电阻,电容,电感,开关,变压器等常用零件。Mixed_Discrete
 / `4 T3 D) D9 e- E% X- K& h$ U
 , o, h) U" B; ?! b3 RDRAM.OLB  动态随机存取存储器(Dynamic Random Access Memory)
 : m9 m* F' P- R共623个零件,存放动态存储器,如TMS44C256,MN41100-10等。RAM_ Dynamic _IC
 6 }/ ?" {8 H4 U/ Z# |7 V3 h, r! n$ v6 y7 `$ z3 o
 ELECTRO MECHANICAL.OLB+ ^7 L! G6 c4 e3 {4 O
 共6个零件,存放马达,断路器等电机类元件。* ]' Q3 Y; k% n8 `5 v  n1 ~
 / i- X8 n* B5 e
 Electro_ Mechanical.OLB
 6 |3 }' u/ _' E& h
 1 m% B) C! O% ~FIFO.OLB  {计} first-in first-out (FIFO)
 5 }( Q; ]$ a7 L( Z- ^4 z2 d- `共177个零件,存放先进先出资料暂存器,如40105,SN74LS232。
 - Q: p! y% w) ^/ s1 dData_Register_IC_First_in_first_out
 ) @% S7 U8 @; }' Q* w: }
 & }" Z" D5 ~0 q1 g4 z' ZFILTRE.OLB
 . e* F2 {: h( v8 b- T共80个零件,存放滤波器类元件,如MAX270,LTC1065等。. _2 j6 e9 L5 B
 - k% E' ?; B9 Y; jFilter.OLB; K; k4 Z4 P+ f1 e( ~) b
 ! T$ d+ e0 ^2 s9 k1 F' G  A6 \
 FPGA.OLB
 ; k  j2 s6 ~. ~8 D. m+ D存放可编程逻辑器件,如XC6216/LCC。
 # r: O$ I# k( m/ w- j  i
 0 R0 i) k" M" R; g# qFPGA_Programable.olb, B3 {3 E" R. \" R
 # W: X* \5 N# J  e1 }+ PGATE.OLB
 + a2 K6 U; I& J7 b: G8 w. h共691个零件,存放逻辑门(含CMOS和TLL)。/ D6 {) v* p% S0 x6 _
 ' U& m) z2 E, O: w  wDigital_Gate_IC_Misc
 8 n# z- S6 t* q" P
 0 `# p5 [& O! p: A* @, _LATCH.OLB
 6 U+ z. u; B9 R$ h! l% E共305个零件,存放锁存器,如4013,74LS73,74LS76等。
 ' P2 q; D, G: N+ c' d/ D7 i/ @1 Z3 Q" G) v, }9 v
 Latch_kinds_of.OLB8 l/ J$ }- h# }( S
 9 |8 [5 `% B9 x! r2 A
 LINE DRIVER RECEIVER.OLB$ H# t7 a% d" u7 v- b4 O2 \
 共380个零件,存放线控驱动与接收器。如SN75125,DS275等。
 & l/ G) G- l" N9 X! z4 H0 i+ d6 n
 / E) `7 O2 Y% @) y$ _* t/ G4 X0 yLine_Control_Drive_Receiver2 k8 i  Q9 I/ s4 d% S2 n" M( S
 , U* h  @* h5 s7 r" u* l, @8 g) x1 X+ V6 L$ \$ Q
 1 g2 @9 k' |4 E( F% ^& c, zMECHANICAL.OLB( v5 N) k8 v& p( ?9 m; ]
 共110个零件,存放机构图件,如M HOLE 2,PGASOC-15-F等。  Mechanical&DIPXX, Q  f! E# `& g+ ]( x, g% g4 A9 m) f4 w* ^
 ( r8 o7 R1 n* s( y  Q6 SMICROCONTROLLER.OLB
 - t3 `$ x3 {2 z3 l# W& k8 G共523个零件,存放单晶片微处理器,如68HC11,AT89C51等。5 Q& w6 b! q2 F3 Q; i
 - {! f6 d% S; |& c$ X6 @: \+ pMicrocontroller
 0 H; u/ r) E& K
 & @5 ~$ {5 x) e, o5 |1 V& pMICROPROCESSOR.OLB6 u( \" g) _$ I6 u4 |
 共288个零件,存放微处理器,如80386,Z80180等。
 i, g1 K% e1 D# g/ P& k7 v6 P! R9 Q7 A% ?/ L- b1 s( E* S; ?
 Micro_Processor.OLB
 - \  G$ V: `+ Q$ E" y9 q( E% R8 @5 T, C8 C0 c, H" P
 MISC.OLB3 x# E; s/ l4 ?, T
 共1567个零件,存放杂项图件,如电表(METER MA),微处理器周边(Z80-DMA)等未分类的零件。Miscellaneous) \8 r; }  g* B. T
 . T) a7 }. K7 H/ h/ w: T. j- P1 U' WMISC2.OLB
 7 V5 B' w2 t& X) J+ |6 O9 ]7 K! C共772个零件,存放杂项图件,如TP3071,ZSD100等未分类零件。Miscellaneous21 {# O# [% ]6 B* Y- d0 ]% R: _3 ^
 , x3 u3 l" D( xMiscellaneous37 g  F8 N/ p: R. U6 u& j, l
 ( \7 c# `5 B  B  S8 `MISCLINEAR.OLB        Linear_Misc/ n5 P7 p2 m) B. q( M' O
 共365个零件,存放线性杂项图件(未分类),如14573,4127,VFC32等。
 1 `9 _5 o/ u, J4 |! T
 8 f! k0 D# C& q4 HLinear_Misc# }3 C/ i- |+ u8 Y  d. t5 B% {
 ) z, b; K2 e% TMISCMEMORY.OLB6 A& j+ L4 W  S, L. F
 共278个零件,存放记忆体杂项图件(未分类),如28F020,
 9 H. D# h5 a' [' c+ [! a' F& o( d. H  _9 C. q+ E$ |& a5 B
 X76F041等。 Memory_Misc
 ! P$ E- G- r9 l) L( N5 F# F: G, Z, Z9 I& d! A7 e
 MISCPOWER.OLB      Power_High_IC_Misc5 h% i) ~0 {# L% M9 v
 共222个零件,存放高功率杂项图件(未分类),如REF-01,PWR505,TPS67341等。; X6 s7 Y" s. V! q
 , N% w# }5 w; Q) ^+ ZMUXDECODER.OLB
 * b& y, s$ x0 y  s5 |$ d3 A, g" A共449个零件,存放解码器,如4511,4555,74AC157等。. `5 W& k) K- z8 l
 9 J* T3 y/ B. e  R4 h
 Decoder_MUX, O- d  j9 i! F9 K
 ' e: I; F) s2 X4 E) k* R
 OPAMP.OLB
 3 B/ J2 r) e6 o+ Y7 r* J共610个零件,存放运放,如101,1458,UA741等。Amplifier_Operal.olb
 4 w) b" ]( H  E$ Q0 w3 W  W1 L& L# H& O6 N5 V
 PASSIVEFILTER.OLB
 / w9 A% L* k% H  \. T共14个零件,存放被动式滤波器,如DIGNSFILTER,RS1517T,LINE FILTER等。Filter_Passive
 & m7 ?& C0 t; A  o% _) o
 s6 D. O5 ~+ `PLD.OLB
 ) \; L. f7 ~+ V& o+ L" T2 F4 W共355个零件,存放可编程逻辑器件,如22V10,10H8等。# {. `. L+ ?8 v  ^# K, U4 J
 ; O+ e" ~4 z. T. T3 t6 KFPGA_PLD
 6 |# c: q8 y4 q' ?
 ' a/ e! l8 f3 y1 W+ |( a$ ZPROM.OLB6 L$ A7 G% ?' Z. I) L: ^
 共811个零件,存放只读记忆体运算放大器,如18SA46,XL93C46等。ROM_ Programmable_IC
 / @/ t! P3 Q8 q; A' z- h- X, X9 h+ q* g
 REGULATOR.OLB6 y6 A4 s; A9 E* {( S# ?
 共549个零件,存放稳压IC,如78xxx,79xxx等。Voltage_ Stable &Regulator.olb$ L) b' Z; ~# t- y
 ) Y. y( ?, F+ @- L# i
 SHIFTREGISTER.OLB: j1 [7 S* J& o! D
 共610个零件,存放移位寄存器,如4006,SNLS91等。
 6 O+ [9 e2 q% F% m; @4 s! e  n+ a5 D; x  U
 Shift_Register
 5 g4 t, ~% ^! T+ w$ P/ x; w- L0 n6 Y; R: b- c
 SRAM.OLB
 * ]' M2 A3 E; i* {5 u/ X共691个零件,存放静态存储器,如MCM6164,P4C116等。$ d# e+ {) D* n3 U* t
 ) b0 \6 a: E1 b& |0 n0 K4 u
 RAM_Static
 6 t1 l9 v. F- D" o$ P/ W1 ?
 6 T( n; ]* @% k5 J0 QTRANSISTOR.OLB) c1 S6 e: u) l" x! t% l4 Z! n
 共210个零件,存放晶体管(含FET,UJT,PUT等),如2N2222A,2N2905等。. m3 S2 E6 E6 _0 n( t7 p
 ' b( {4 w) @7 Q  [$ C- U  TTransister_FET_MOS_etc& k$ B, L! ^* L" S) s  {
 3 o: p* `6 {2 k: X  |. h# |1 q  {
 . e0 ~: F) Q7 Z- n0 B  C" I5 F7 g5 W/ V5 K$ ?$ X/ J
 ! ~( h1 t2 Z  y, \) @4 D4 OIEC 文件夹(器件图形都是国际标准符号)   International Electrotechnical Commission  国际电工委员会它是世界上成立最早的国际性电工标准化机构,负责有关电气工程和电子工程领域中的国际标准化工作。
 1 u7 C7 o  b8 h/ m6 U: c2 o5 q, Z2 Z: a+ ~2 G- W- l" r
 ANALOG           Analog_Miscellaneous.olb6 v1 S* u/ U+ d/ N
 5 l! @1 v$ I3 a4 r; H$ O6 [5 s4 NCMOS1—4          Digital_CMOS_1000_4000_7400.olb
 - ~. v' f6 e; _! u1 J1 n& P9 O: H: x( p! z# H, `( ^$ b" @2 {
 & z: l' q- N4 V& ~
 2 |  Y1 N& U  {DEVICE              Miscellaneous_Device.olb
 4 ]2 q% k# S4 |7 i, q  |
 * S' w# g/ \6 T5 u+ }+ PHEADER             Header_Contact _Pin
 5 p6 j' ]9 c: W  u7 ~9 V5 j( D- z; _' K( x
 TTL1—15            Digital_TTL_7400.olb; Y& n8 M  y+ A& O: y/ W, n+ }
 5 a# d* ]$ W1 ~$ `( U- r6 g
 9 G5 x8 {( k" x
 ! \7 k/ I2 }  K3 i8 I. w' x( o) e! k4 Q& \; {- U8 K% ^, I7 @
 4 F. ~' ?4 F. C. J2 _8 |
 5 M; M% d! _- d: U# @" L
 $ G+ _  g  F" O4 E2 _. Y说明:本介绍包含了\capture\library\Pspice和capture\library\pspice\advanls目录下所有库,但由于作者水平有限,介绍得也比较简单,有些说明可能不一定对.请高手指正.谢谢!
 " D/ n! I) E- L2 b
 - ^# X$ G5 V" ?+ F: ]* c) R4 K! z3 a$ b) y: s- Z
 ! _* o  d, f+ C1.1_SHOT              : 10个杂项器件,其中有54,74,CD的
 9 Y$ I% ?: ~. l2 O( ^4 G) p
 ! U$ S& s) Z' v2 e( o$ u' I9 x2.7400~74S            : 74系列的器件
 : A7 \5 M) _; N6 f3 ~5 H+ c! ~9 `+ h6 Y8 a) u- _
 3.AA_IGBT             : IGBT是强电流、高压应用和快速终端设备用垂直功率MOSFET( @4 _% K2 C' m
 8 D* u  q6 O9 V5 j
 4.AA_MISC             : miscellaneous杂项金属氧化物半导体场效应晶体管                     (Metal-Oxide -Semiconductor Field Effect Transistor)
 9 `1 P# ]5 z2 k
 : B0 v  L( z4 Y' `5.ABM                 : 各种数学运算单元,如cos,sin,log,hipass,lowpass等,还有E/F/H/G等元件.
 % t. l4 e; q- U8 p5 x0 [0 g$ d, t) U, _: V: C2 C
 6.ADV_LIN             : ALD系列的线性放大器linear amplifier | Linear Amp | Hdlin
 7 F  w, a. e5 e& V9 d$ e% }! N. b3 N" d8 i% W; @
 7.ANA_SWIT            : 模拟开关analogue switch: d# z$ y1 i' D9 S
 , N. q0 Y0 L0 {9 _: A$ K5 ?
 8.ANALOG和ANALOG_P    : 通用模拟器件,R,C,L
 " y: Z2 `) P# [' N
 5 ^' x6 q7 X1 ]. }" E! k3 d9.ANL_MISC            : 杂项模拟器件,如三相变压器,555,RELAY,SWITCH,VCO
 a- K! C- ?) g4 W! l4 y( u5 O8 D( m4 D# |  l
 10.ANLG_DEV           : AD公司放大器,电压参考器件,, l$ [; N2 X4 l; Z, e
 9 f# A: Y& L: y! A. |
 11.APEX               : APEX公司PA/AM 系列运放/ t* ~. L9 @6 W" r; V! q# [
 ) u% K6 e8 q% C8 b- W" j  m
 12.APEX_PWM           : APEX公司系列PWM控制器
 8 O! e! P$ c; o) I5 w) b% Z5 q
 8 B: ~2 ~, [8 D- _6 z13.ASW                : DG系列模拟开关/ Y) V; Q, \$ ]7 E: ^1 c$ }5 W& c6 B
 : B" C5 a6 z& ]% d
 14.BIPOLAR~BJPD       : 三极管bipolar:双极的 | 双极性 | 两极的) r1 h3 P! @8 l; w& s
 ~7 j, x$ ?( q9 [2 p
 15.BREAKOUT           : 用于最坏情况分析的元件。RAM,ROM,DA8/10/12,AD/8/10/12,R,SWITCH,Q,POT  (                       滑动变阻器),M,X(TRANSFORER)
 ! y0 T, m. z. n& l7 K+ R$ D
 ; l7 V  u  ^6 `& R' Y  d16.BUF & BUFF_BRN     : BUFFERS  缓冲
 " N! D  G2 L2 l: I% Z; ~
 : ^# G. y5 {  m" w$ {17.CD4000             : CD系列器件& m4 X" O' ?3 p2 V2 D
 0 @8 d6 }5 T) x6 t+ _
 18.CEL                : NE系三极管: {6 \0 Y0 q+ X5 k+ ?1 o$ K
 " G, n9 q" ?2 Z5 S% {19.COMLINR            : CLC系列BUFF,OPA. W& x1 w8 I1 @* v8 _! P
 ' _5 z' m' i2 c
 20.CONTROLLER         : 电源控制电路,DC TO DC
 6 K0 Q# v7 E7 i: v7 H
 % q$ [6 F/ {% f0 p$ z6 M21.CORES              : 磁芯
 $ D4 Y! |* g  o- J, W- C3 a: r! e9 g5 t$ x& h! K
 22.DARLNGTN           : EPITAXIAL(外延的) SILICON TRANSISTOR1 t3 m! D" g, ]) F
 ( A: ^0 H! Q9 @$ g) C1 T! j
 23.DATACONV           : AD,DA   data converter8 G) D/ o  z) T: N$ }- j. r4 L
 6 o1 Y( n3 J, O: @0 b$ U24.DI                 : DIODE: ~. |5 f+ }3 x, d+ o
 3 B) \/ N% L! U" a25.DIF                : DIODE BRIDGE* J$ X# I% Y! A& ?' C
 ( _1 m2 [& E# E) P8 a) g! r5 ]
 26.DIG_ECL            : D Flip-Flop 翻转触发器;啪嗒啪嗒的响声, V  D; {6 F+ T4 [$ \3 _# F
 - R6 i$ n+ N  r28.DIG_GAL            : Generic Array Logic 逻辑阵列 组
 4 n( c  m# c% i/ v1 S+ ]' P
 / ]7 ~2 D% F1 s: q1 D29.DIG_MISC           : miscellaneous杂项 digital device
 8 p9 l8 d& Z. K
 * ]0 H9 z2 F; e- a) W" Z6 S4 @* s4 f7 ]* `( p6 |  K2 d* r
 " s# z0 {7 C0 }" C1 M, M) ?& d' j4 b4 H2 S+ S; J2 v
 6 _2 t# b4 ^# F3 ~
 - g) l: B& Z2 M) D2 `
 5 @. ^. r1 I# E# t6 b/ u; E3 Q
 * |6 P* C& K7 J# d3 n! [) m: F& c9 e7 |8 W5 R6 L5 `! B( g) m
 30.DIG_PAL            : programable Array Logic
 * r- Z' k) }( w) ~8 @5 Y6 \( W
 4 A0 }/ z3 e6 X' }31.DIG_PRIM           : Generic digitial device: and,add,Flip_Flop1 R$ j% i, t5 m2 C
 W9 m7 j: t6 _8 a; q8 \
 32.DIH                : diode pull-up and pull-down network# U1 P) U% X* H1 k
 ' L! o( p# o4 i0 d0 X# x
 33.DIODE              : diode" e$ i0 k$ W5 _& W9 x- U9 d9 d
 : g0 Z  N6 Z. @8 ^5 q/ B* E34.DIV                : diode v   稳压二极管  S/ a9 f1 ?, b7 h" ]
 : Q6 M1 ?; T: _6 G
 35.DIZ                : diode z  zener
 ) n: x; Y  S& W8 X* x+ J( p9 C4 Q& f$ W2 r# d3 [2 h2 c
 36.DRI                : MIXED( Q# ?2 V2 b6 e
 . Y7 X, i" D; Y9 t8 o' |, Z5 M
 37.EBIPLOAR           : bipolar 有两极的,双极的" Q  \7 U+ z9 @: v4 f- ~
 7 I6 t: q' I9 ]38.EDIODE             : diode. c& `, I6 e, l( e% V
 0 `" E! X* r* t" J/ R
 39.ELANTEC            : ELANTEC半导体公司器件,运放,门电路等
 # p& h1 ^3 j! L% c9 p" f0 O9 x; U0 N& {4 \& n- [  F; _
 40.EPCOS              : EPCOS公司器件,磁珠,压每电阻,NTC等。8 `  `9 }, C( v8 k$ K& s; K' I
 6 @9 @( y/ ]( b/ k' J# y
 ( E- ?) \5 a9 p$ U, a/ V& n8 ~/ X) Z' l9 T; s. t! o
 $ f8 n5 W, [7 F2 E* [
 7 O% K* S- _; {8 T; v* Z41.EPWRBJT            : bjt) Y: j. d+ p8 `) R- c3 W6 C. w, ]
 3 \( {" P# c/ \( E% C- X
 42.FAIRCHILD         FieldEffectTransistorJunction : fairchild device (Fairchild半导体公司 飞兆- Z& E! h, `, D* e, {; |
 / G4 @4 b5 L. ~" l. M7 o: z7 H9 `
 # d+ N$ j1 H. Q7 |% l
 # h* U' \: {3 h% e+ r- k43.FILTSUB            : Mixed_RCL_unknown
 7 X' `: J3 j9 O0 u% H  m3 B& G+ ?7 z9 `' ]4 b( G
 44.FUNCTION           : 函数器件
 ! B# B9 g; B% l' p8 W3 [' e5 ]1 c$ a- r0 K
 44.FWBELL             : FWBELL 公司的霍尔元件HallDevice_FWBELLl.olb
 E. }0 ]* ?0 n6 _0 T% X0 Q: ?
 : s* |7 U4 P' J) Z45.HARRIS             : HARRIS公司相关产品FET_Junction&Amp_HARRIS
 5 [1 x2 @7 ]$ m, O# T. N% H+ x( i- _
 46.IGBT               : IGBT管FETMOS绝缘栅门极晶体管(InsulatedGateBipolarTranslator 绝缘栅双极型晶体管(Insulated Gate Bipolar Transistor  IGBT_FETMOS_InsulatedGateBipolarTransistor7 D. s+ z; g) E! [& T
 2 a3 n6 Q8 Z9 L; A! E, [
 47.INFINEON        Diode&Var_Cap_IGBT_Transister_FET_Enhanced_INFINEON' F' O' A3 e5 }" d
 " p. \: s; I2 ~' D8 \; D: kINFINEON_BSX        FETMOS_Enhanced_INFINEON_BSX8 K9 O- d/ Y" {2 {/ g- L
 / H' A5 q9 H( G0 v6 ^; mINFINEON_BUZ        FETMOS_Enhanced_INFINEON_BUZ0 S5 \  j/ T5 k. K' i& Y# I4 U
 " f0 ]5 y* [+ K+ d$ \4 j. F/ x
 INFINEON_COOLMOS500   FETMOS_Enhanced_INFINEON_500% s$ M9 h" H) N# t2 M) _% a
 ( i" {* c3 U: ~2 ^4 D, R$ j3 B. @5 g, D                     FETMOS_Enhanced_INFINEON_600
 + W) O* C% V$ D% E% y, F5 J( ~) o1 N! n
 FETMOS_Enhanced_INFINEON_800) M5 j. n8 Y3 X. [
 ' }! v0 r( |+ K8 L( Y
 IGBT_INFINEON_IKW_T1204 ~8 Q* y8 p9 D# V
 b+ V# I% u: q! c
 INFINEON_OPTIMOS_N    FETMOS_Enhanced_INFINEON_PNP
 8 `4 f4 \! X1 D# V- G, _0 P- C' s1 c. `- t: j
 INFINEON_OPTIMOS_p     FETMOS_Enhanced_INFINEON_NPN0 `! S" \! q4 p
 & j2 ~& }$ Q; o* o1 f5 D/ Z; zINFINEON_OPTIMOS2                       FETMOS_Enhanced_INFINEON_PNP_( E2 b5 G# f! ]% M; ]
 5 N* ^) \: ?' O- S' T* k9 w! Q# f
 INFINEON_PFET_60        FETMOS_Enhanced_INFINEON_NPN_5 }2 D* B# ^  R; ~  F$ P
 7 N# `3 E+ `( d; u  L
 INFINEON_S_AFBJT         Transister_INFINEON_AFBJT
 ; L* q; ?( ]. V  o& }9 Y, p9 v7 ~! s! H% ?7 i% m6 e8 c
 INFINEON_S_DITR            Transister_INFINEON_DITR
 $ p0 S+ I  |. J
 2 ^6 b" ~' \( {. k/ T) \INFINEON_S_DITRAR            Transister_Double_INFINEON_DITRAR
 # l  c" M* K; A2 L' \* ]  i! b8 H& S) c
 INFINEON_SFET_100                             FETMOS_Enhanced_INFINEON_PNP_100/ w5 |2 L* B1 f- d
 7 n8 t! c: S8 o1 U1 v  iINFINEON_SIC_Diode            Diode_INFINEON_SIC0 D  F5 j; G) m$ H& {  `1 T
 - c( H+ m5 L4 _* Q. G- s1 MINFINEON_SIGCXXT120_L2         IGBT_INFINEON_SIGCXX
 # E1 y- S" s0 I% g2 ?: W; S- s, f5 d# ~/ D
 0 \4 x& A8 e! \% F& O
 ; I1 l% v; B' }. L" f" U: J7 _* Q
 # V1 t# [0 x3 Y3 Z# ^* b
 . L) x3 n* y1 W- B4 m, `4 C6 y, t7 A7 o- Q' L8 ^; a
 $ [2 S; E' p4 K6 e0 a* a6 W
 % k) j9 ]3 Z8 H. X
 48.IXYS            IGBT&MOSFET_Thyristor_Diode_IXYS             : IXYS公司的功率管产品
 0 n4 Z/ z6 z- {' y' l: @! D
 0 g' u& [' a9 t49.JBIPOLAR      Transistor_Japan               : 日本产品,三极管; t$ R; ]$ N$ p4 V: P
 " `  r+ o- H1 t& n8 Q50.JDIODE        Diode_Japan               : 日本产品,二极管
 8 ^# s: k/ M; n8 ]2 S1 {, ^7 W1 Y& _: z; r
 51.JFET          FET_Junction_Japan               : 日本产品,FET场效应晶体管(Field Effect Transistor
 ' i( c. B, n$ D1 l  V( |0 \" ^; v4 h/ }6 [" u
 52.JFN            FET_Junction_PNP_Japan              : 日本产品,NFET:N沟道场效应晶体管: ~& d0 {1 U  S
 - j% F. N$ a& n" v  F53.JFP             FET_Junction_NPN_Japan             : 日本产品,PFET- e0 N' L( M0 L5 w; [3 X
 # H# u& V7 O- N, H9 h
 54.JJFET           FET_Junction_Japan_             : 日本产品,JFET结晶型场效应晶体管(Junction Field-effect Tran( W+ M# r* ^7 U8 y0 Y: t
 7 b1 h% T' h- U" A8 f& v7 P55.JOPAMP         Amplifier_Operal_Japan              : 日本产品,运放
 7 Z' b: A' X, k: I9 ^: R4 V; E, B
 . b& f9 g9 N# I% j/ X" m% r56.LIN_TECH           Amplifier_Operal&Voltage_Refer_LINEAR        : AmplifierOperal 公司产品,主要是运放,也有reference
 5 ~$ D+ p+ z! t8 }* e7 ]( ^6 B2 l& w! ]
 57.LINEDRIV        Digital_Gate_IC_LINEAR             : LINEAR 公司产品,主要是门电路( R8 o( h  Q- v6 T! g' U
 5 Q( p5 L0 ]+ M8 e- o# g58.MAGNETIC      Magnetic_Core_MAGNETIC              :MAGNETIC公司磁心
 9 X+ d, Z: u( E
 $ ~4 F) S/ ?) K5 v4 g. N6 N
 + k) Q8 m7 a1 {$ @
 % C+ m# q, W2 C8 R2 r& O  ^59.MAXIM              Amplifier_Operal_MAXXX          :  MAXIM公司产品
 % ~: h( v  ]0 ~7 n; G
 ( R- E) f* I. c/ ]5 W% \! u- M; o( S60.MFN             FETMOS_PNP_Fairchild&IR             : Fairchild,IR等公司N型功率MOS% \4 b2 o( T1 v: ^, I$ l0 R
 6 r4 ]4 Z6 u7 t( H61.MFP        FETMOS_NPN_ Fairchild&IR : Fairchild,IR等公司P型功率MOS- R- b8 R. q/ j/ `; h, t3 r7 y1 `/ [
 , s4 X; S9 R: d/ g) `$ M5 ^
 62.MIX_MISC      Misc&Relay               : 4046,Relay等" `. k' i- @1 \7 t
 ' |5 V$ p  F2 n# Z63.MOTOR_RF       Transistor_RF_Freescale              : 飞思卡尔射频三极管6 \- [* R5 G/ j) n
 1 m7 h/ m( |& l64.MOTORSEN        Transducer_Press_Freescale             : 飞思卡尔压力传感器
 # \( U$ d( g7 t; V# t5 d1 f9 O0 q; T/ T4 M
 65.NAT_SEMI         Amplifier_Operal_National            : 国半产品4 a( W! _. O7 X+ ^0 [$ S9 C+ p
 , k0 t8 a9 ?, U# {0 x5 c5 q66.NEC_MOS         FETMOS_Enhanced_NEC             : NEC产品  增强型场效应管
 . I2 x. r& o! ~$ n! \4 V1 z, c
 : I0 B7 [! v* u6 m   NXP_MOSFETS     FETMOS_Enhanced*Diode_NXP/ a9 o: x! a$ o1 |; Z2 n
 4 b- B9 ]# H/ l: ]1 ^: Z
 67.ON_AMP           Amplifier_Operal_ON
 4 W1 D/ y2 O8 g8 i+ [2 S
 0 e. R7 n( ^& P% r4 zON_BJT              Transistor_ON
 / r+ U! h0 ]. |5 H9 A9 P# m  m5 D
 2 Y7 J! ^. q% v4 U$ l5 M6 OON_Diode            Diode_ON
 / Q: N% ~  m) j! h
 % f" J5 K$ c; A3 P  D9 b$ bON_MOS             FETMOS_Enhanced_ON
 0 h. h$ @) _% O4 I9 Z; y7 c1 K7 ~: s9 @) T' B1 c
 ~ON_PWM             PWM&Switching_Power_ON   : ON产品,依次是三极管,二极管,MOS管,开关电源控制芯片 (脉宽调变(Pulse-Width Modulation)MC33363,MC44608,NCP1200) X: B; Z: u* f( }0 v% x- N
 + d% s' ?, o3 E# a4 F: j3 O$ R  L! S
 68.OPA                Amplifier_Operal  x3 z, L4 t$ y; h; ]4 F( o# t# ~
 1 w% J% C+ L7 b2 t2 [& l9 v8 y; V8 pOPAMP               Amplifier_Operal&Stable_Volt_IC   : 常用运放
 . z& r1 C, P7 c
 $ S$ A" n2 ]! x; C: d- J69.OPT               Optical_Coupler |           : 光耦合器
  ptical coupler | optocoupler | Coupler6 W; d( ?% k! v$ q! a9 q 3 w5 a. I9 T/ M: @" R4 O
 70.OPTO                Optical_Coupler_         : 光耦4 o' l' @; v, V, j, u
 : g; N, z4 F/ T* h71.PHIL_BJT~           Transistor_PHIL
 $ _, t: N  t7 {) E) R0 ~; Z/ b! N* P; ]4 V5 c
 PHIL_Diode              Diode_PHIL
 4 z. X  E) p% i( c* B' d8 w' C( x8 P3 O0 _: S4 [/ J- a) S/ P' l
 PHIL_FET                FET_Junction&Enhanced_PHIL
 ; H+ v5 N5 G0 @" ?
 - @$ g0 z; {  x. {, p/ @: kPHIL_RF           Transistor_RF_PHIL         : 飞利浦器件; w" v3 N% J8 q, }0 U: F
 0 w! D6 _, |  m) W5 Y; ]0 N3 k9 H/ [72.POLYFET          FETMOS_Enhanced_PNP_POLY            : POLYFET公司的MOS管
 ' O/ C# i7 o; w+ W* b* ]. J7 H1 x
 8 a$ P3 u. _2 {, w8 G3 s& w73.PSPICE_ELEM       Misc_Pspice_Model           : 用pspiceAA分析的元件,L,R,C,I,V,变压器绕线
 ' N% G' E) ?  r* B  T6 \& Z9 Z! a0 j
 74.PWRBJT           Transistor_Power            : 功率三极管- i$ r5 K1 q* h- L( m
 . T3 J/ Y+ c6 v! u  S75.PWRMOS           FETMOS_Enhanced_Power            : 功率MOS管' a4 y3 p- h' ]! x/ i# {3 c
 / o! K2 g* l. s0 _6 A8 K9 V" z: {
 76.RFBJN            Transistor_RF            : 射频三极管N5 M2 G( C5 n, A, u3 v- Q, d9 J! }; o
 # x! ^2 D" q* Y5 L
 77.RFBJP            Transistor_RF_NPN            : 射频三极管P
 ! s, a! T2 ], R" v! {: F* S: B9 O) ~5 V% ~' N7 D- _
 78.RFDIO            Doide_RF            : 射击频二极管7 k8 ]. C. T7 \) K5 g: x
 + E( J2 f& |8 b( \- j
 79.SAH   采样保持:Sampling_And_Holding    | Sample-and-Hold HA2420,HA5320,LF398H高速                                  精密采样保持放大器,
 , ]1 G8 ~0 F5 r% e% E
 ' ?6 S: S% v& }- }; g5 u% a  SAC                Inducter_Volt_Transformer; G3 m' m$ K& \# Z4 \, V6 A
 $ y! R; P' |. i
 80.SHINDNGN         Rectifier_Bridge&Diode_ SHINDNGN            : SHINDENGEN公司整流桥,二极管8 K8 t' d9 k5 T  U+ z* g0 X' s
 8 w+ y& \' k1 u81.SOURCE      Source_Signal&
  ower                 : 各种源0 _( `. x+ P( _" h
 6 [" r$ {  }9 R0 T/ u82.SOURCESTM    Signal&Controlled_Source              : 数字仿真信号源
 6 q3 c% s7 r7 p! B
 * R$ @$ D- v5 B) s2 V! z3 X. O* i% c& b6 w
 3 R& C+ h/ {+ M; k. n83.SPE            Misc_Digital&Analog$ r5 N" Q8 S3 {& T0 ~  {5 W2 _
 : P% `) @6 I* N5 ~6 H  X$ z# W
 7 @/ u" R4 i/ o0 k7 W
 9 B' H" a7 e3 y# n* o
 ~SPECIAL    Special_Unkown              : 特殊元件。print,param,IC,nodeset,VARIABLES,lib,include等很多(                                 与仿真功能、设置等相关的1 e% P0 L2 t/ N! l
 B8 @; M- D( q' c7 v- D2 \+ V. X84.SPICE_ELEM     Source_Controlled&Arithmetic              : 流控,压控,电池,微/积分,零/极点,加减乘除等
 2 I1 D2 T# R, m4 f4 x8 p/ U7 H3 l" m: z+ \: ^
 85.SWIT_RAV      Switching_Power_Model               : 开关电源仿真所用到的通用开关器件模型,分电流/电压型,CCM/DCM,(                                 大/小信号模型2 o0 W: {3 R' j& B% G% c
 ; j+ A2 j) g! ]- n9 t* r* V6 R4 N
 86.SWIT_REG       Switching_Power_Microsemi              : microsemi公司的SG系列开关电源芯片如SG1844等1 Y; z5 n$ d' D: N+ M6 }1 o0 P& w# R
 2 m# Y' O( F8 A; b0 ^
 87.TEX_INST   Amplifier_Operal&TL431_TI    : TI的系列运放和它的TL431,但不全,新运放还得从TI网站上下.
 A) V/ X  e; n2 t
 7 u$ O% q# A3 K8 d/ {1 a9 U) L88.THY1       Thyristor_ST&Freescale                  : ST,飞思卡尔等公司的可控硅,晶闸管 thyristor
 0 |* F* z5 E( L: f; ?( X$ X* s7 W0 P2 d4 U+ ]8 l% ], a" j
 SCR(silicon controlled rectifier)。4 u! ^4 r' @$ Z% r4 t
 ' Q; y' N( L7 ~7 t( V( x/ ]
 89.THYRISTR      Thyristor               : 同样是可控硅,与上面有些不同,更全一点., K- _9 t/ L% p% [: z
 4 U4 K4 |( w/ a0 v90.TLINE          Transmission_Line             : 传输线
 d6 z; q( W6 s: ]: p1 }
 " N( R/ B5 ?6 W2 B6 F91.TYCO_ELEC       Resistor_Piezo_TYCO             : Tyco公司压敏电阻
 # T$ L3 ]! y$ G
 , a- [% G4 r3 ]' n* ^92.TZB          Diode_Zener                : 单双向二极管,有常用的P6KE68A等
 1 f! s; g9 x1 R4 p# o. l
 $ {  l4 \0 D( [  u) S& {. G/ e93.VD           Voltage_Detector                : 电压检测器,MC33064,S8054ALR等
 9 u$ |2 d+ ^. b; Z) [8 D, q, G, d2 P5 A2 m
 94.VR           Voltage_Regulator&Stable                : Voltage regulator,如常用的7805,TL431等。
 9 K) t: x1 J, B4 d" @! c  ~. y# a# ?
 95.XTAL           Crystal              : 晶振
 6 N' x& m# [. E% z- C3 w0 M. F# T! m8 q+ |2 {" a7 B$ C. ~1 w
 96.ZETEX         Transister_Diode_MOSFET_ZETEX               : zetex公司三极管等.
 0 I6 w0 S  [3 }0 L) f5 H( B# O+ Y7 W0 Y$ A
 97.以osram开头的15个库          : osram公司的发光二极管等
 & h! F* x: w$ P. ^  j" E# T# T0 L# \# l* w. U
 LED_Osram_.....[/td][/tr]
 ( Q% D2 k. k/ V$ ^1 t  x[/table]& Y9 h! _* }1 m3 W* X8 F
 6 O6 |/ X8 v1 N* w7 H3 M$ |
