查看: 886|回复: 1
正向标注错误
发表于 2016-6-28 13:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Problem encountered while synchronizing the PCB data and schematic connectivity data in the Common Database. See PCBLogFile.txt for details. Loading of the database has failed. iCDB error (Could not copy with overwrite to snapshot [Board1_layout_temp] because is currently in use)
/ g9 B. }- ]$ o5 z1 ?8 M# s* Q
6 e( Y5 ?! f. z* a正向标注过来出现下面报错,请问是什么问题?; Q, z" J' Q: u* Y
发表于 2016-7-3 21:58 | 只看该作者
用icdb修复工具试试,在开始菜单MGC SDD目录下System tools里面的project backup 工具,里面有repair项,用一用看看
GMT+8, 2025-10-13 04:04 , Processed in 0.125000 second(s), 23 queries , Gzip On.
