查看: 416|回复: 10
PIC Tutorial Hardware
发表于 2016-11-2 14:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The hardware required consists of a number  of small boards (built on Veroboard), which # \2 h" A4 _/ L5 x
connect together via ten pin leads using Molex connectors. The first board (Main Board) carries
" |4 U$ s$ {0 ?& gthe PIC16F628 processor and 5V regulator - the  board can be fed from a simple 9V battery.
+ s; S# {. ~; @+ f% w) Y3 LSome of the later tutorials will require two processor boards, this is the reason for the second # ]- `* c6 u' ?* e" c* s: j
connector on PortB - the two processors will communicate with each other over a standard 9600
: m9 q! A9 p6 @9 H% \6 c/ x: Lbaud serial bus, the second board can be either powered from the first (using a four wire
. u/ x/ G8 C$ s4 c" ]* M( w8 }connection lead), or powered from it's own supply (using a three wire connection lead). The lead
* `, P0 H7 X+ z. ]2 z+ Jconsists of a ground wire, RB1 to RB2, RB2 to RB1, and an optional 5V wire. RB1 and RB2
4 q9 G5 [) c8 W% V0 tcross over so we can experiment with the built-in hardware USART as well as software serial " A; }& x) L' W# {
communications.
Nigel tutorial.pdf
1.06 MB, 下载次数: 11, 下载积分: 威望 -5
发表于 2016-11-3 14:14 | 只看该作者
不错,值得一看
' r; }0 x. \$ G6 D0 x3 a) d
发表于 2016-11-4 15:26 | 只看该作者
楼主辛苦了!
" o! `) P6 ?2 O8 H% l0 Z& i
发表于 2016-11-4 15:39 | 只看该作者
不错,值得一看
发表于 2016-12-2 09:13 | 只看该作者
是关于PIC单片机硬件的吗
发表于 2017-2-14 16:16 | 只看该作者
PIC硬件仿真板,多谢
GMT+8, 2025-6-10 02:06 , Processed in 0.078125 second(s), 26 queries , Gzip On.
