查看: 2912|回复: 4
关于orcad出网络表带value的问题
发表于 2008-12-7 13:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(orcad 2 pads2007)的网络表时,却出现以下的问题,各位请问应该怎么解决呢?谢谢!!!% B0 m6 I  c$ j
4 S1 ~' O( Z7 z# ^6 A" bReading file --  F:\adsl.asc1 }. s+ C" r4 r7 ~0 `0 s  V8 N
*Unspecified or unsupported version of ASCII file% O. l1 C, _3 w: @+ O& Q
*PADS2000*
: H# y: B; O; C- `" [2 FBad part mirror value -1+ t( g, T$ i# G* M
C12              DIP-CAP,470PF - 5KV - Y2  @( Q( p. r. U* X% \2 u( m* {
*Bad *PART* ascii data line format+ [$ |8 @' |8 v6 W0 {1 g7 G
C24              0603,0.1UF 10%
" v$ n9 }8 K$ ]5 p( y8 O, B*Bad *PART* ascii data line format/ ~, }; \8 j  W( {6 W6 f
C25              0603,0.1UF 10%
8 b( X# P. E2 l*Bad *PART* ascii data line format! R6 r2 K$ E) K9 T: h* }7 X
C26              0603,0.1UF 10%
! f$ O# N3 H, q7 J*Bad *PART* ascii data line format7 n4 J$ X9 e" I2 _/ @" R2 |. Q
C73              0603,CAP NP
9 W, }0 e4 S; F3 z. D2 Y) {*Bad *PART* ascii data line format
0 N$ L9 M. t1 n2 |1 H: Q, u/ WC75              0603,CAP NP9 Y1 j4 J' F; Z" L3 v6 Y. ]' |
Bad part mirror value -1& Q  I: o" i* M; `  d
C9               DIP-CAP,470PF - 5KV - Y2
* @8 r3 D" S  A7 \) e* `4 l; k*Bad *PART* ascii data line format# z1 `, l; {: C- P
R39              0603,24K 5%
, U  ^2 R1 j9 i* `$ }*Bad *PART* ascii data line format
% v+ F" o; _- _% VSW1              SW-8,SW SLIDE-DP3T4 D1 T+ [1 N) _0 d- }
*Bad *PART* ascii data line format7 a, A1 T+ p" }' P/ n$ h4 P8 N
SW2              SIP-3P,SW SLIDE-SPDT
2 r; ~/ \5 F! B& w2 ?*Bad *PART* ascii data line format, a' g$ N' D8 D
SW3              SIP-3P,SW SLIDE-SPDT
& C/ B, w4 _" A+ v/ G8 }1 x+ r, T3 ]7 A*Bad *PART* ascii data line format
7 `6 w, V  O) ?. U8 cSW4              SIP-3P,SW SLIDE-SPDT
5 P4 J5 p+ ^) L) I: o5 T" Q7 A*Part name not found C26( X3 W! h5 `+ f/ `% ]
U2.4 C26.1 C23.2, ~2 z9 N+ l5 m/ i
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N253543! {: j+ f. j3 D4 ^( ?+ V& _
*Part name not found SW4
4 x& c% e0 F$ z5 DSW4.3 R113.15 Z% I; O+ s% u
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1817995% a! Q" Q% A& o. P4 i
*Part name not found SW3! {$ V+ m% ?4 k' L7 |
SW3.3 U10.3& ]8 |0 j0 O( e& \
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1842163! u0 e' p# T! ^, @
3 v4 \( N2 T; \, i9 v- ~" |1 @R112.1 SW4.12 {, L6 [4 t( C: b
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1800505- ]0 o- w% K" D: E( \& [( H4 J
*Part name not found SW1% L# Z. |; z1 L  [8 ~- g7 F
SW1.5 RV3.1 D12.19 ?4 z+ u! f7 \
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N10263+ `3 ^; C5 _( S/ {1 W' o: A
*Part name not found SW1& |6 c4 d3 e5 }: M" \9 Z$ y+ ]
SW1.6 J7.1
) H( ?- }3 w8 I! K! D2 _& m9 \! n*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N09585% _0 L; d; i: n9 x% V
*Part name not found C751 ]0 L8 N2 u# Q( E1 k6 m2 q2 E4 u
U11.8 U13.1 C75.14 z5 j5 n: A5 D9 k/ }& t) B! i
*Part name not found SW2% ]; ~  I, S$ x; ~$ L3 }% q
SW2.2 U12.13+ o! u4 `8 q8 t! `3 A0 v; i
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N31703185 |$ ?8 R" I: ?, p$ E
*Part name not found SW3, `- M% F; B+ j+ T. \. l, l
SW3.2 U12.12
8 ]/ v( e# K& D4 u7 c*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N3170741
/ F+ s' C, `. x*Part name not found C12: C: X- k5 V/ H0 |' K1 Y
C12.1 RV2.1 RV1.2 T1.9 J1.4/ @4 p9 e& N$ ]0 v8 P3 ?
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N150942
  W( n% Z3 ~5 r5 a; R! K*Part name not found C9
; p' ^! S% s) \8 w5 RC9.2 C12.2 J1.10 J1.9 J3.37 J3.36 J3.35 J3.34
' r0 h' X; Z) U) @*Part name not found R393 T0 [9 {; M" I. m/ N
U2.51 U2.43 R39.2 C26.2 C24.2 C29.2 C31.2 C32.2
6 ?) Y7 Y. J& L7 a! o/ x' b*Part name not found C25
6 D' F; w( F& h0 H% x4 xU1.57 U1.48 U1.21 C6.2 C13.2 C25.2 C30.2 C33.2+ n$ @" @6 ]/ w  K# O' p* E
*Part name not found C73( |; I* A  U8 {4 B( b: ]
C72.2 U11.7 C73.2 U12.7 U10.7 U13.8' j, [6 R$ E* j# {
*Part name not found C252 n( D0 [+ R; u+ w# H
U2.5 C25.1 C23.1
4 x3 e0 ?: \. D1 }*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N253227+ c) Q- {7 s6 c. G
*Part name not found C24/ M. G5 z" ~, y1 l; S- P
U2.6 C24.1
( j  f. t$ ^3 X0 b*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N252913
$ b; K; x/ R$ C+ w+ Q# r4 z& F; u: ^*Part name not found R39
7 V3 h. ]$ r) D' NU2.24 R39.1# C2 z& o. r  d* X# F! c' j) A
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N252601
4 @, e9 [  B; y$ U2 ~! r*Part name not found C9
( W8 s$ v1 J$ Q: x0 }- i' v  dT1.16 C9.1 RV1.1 RV2.2 J1.3
$ W0 `, _3 K6 ^& h5 n: m) c5 u*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N150517
: {3 x. F4 F4 t5 a3 b. `8 l*Part name not found SW2* k# y8 d6 g% y" }8 N
U1.76 D8.2 SW2.3$ \, J" \* Q0 D( P9 o$ K
4 M; N  F( B, T, C: TSW3.1 SW2.1
! G4 w2 T8 K( W  n*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1889636  ?% @) O2 h; N# a
*Part name not found C73- d5 t9 b% U% r1 [( c
U11.2 C73.1 SW4.2
& o" t" @! ]" y5 L*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N1800965
$ B# ~0 L( U8 A6 d1 \' K8 O*Part name not found C75
- `4 L$ T$ R4 u0 o4 lU11.12 U11.13 R116.2 C75.23 B0 m) h0 x: _3 K, U' v
Warning: deleting signal N2535430 D8 ]/ ]/ v' I) G$ J7 P
Warning: deleting signal N18179950 s4 f2 `2 O+ u4 h6 J' t
Warning: deleting signal N1842163! U, |$ x8 v% f" \
Warning: deleting signal N1800505
7 R1 b5 h# X, i7 U) L* Z; oWarning: deleting signal N10263
+ s. R1 t  ~, A4 M3 xWarning: deleting signal N09585
9 g* ]' I* L. M* e# T4 X$ gWarning: deleting signal N3170318
% S1 E2 b8 b, a% X4 o5 XWarning: deleting signal N31707411 ]- b8 f2 Q6 J9 r
Warning: deleting signal N150942
- W3 ~3 }& S" P  @. [Warning: deleting signal N2532273 S# a$ N; W2 d
Warning: deleting signal N252913
% K* s2 s( |% C; |5 q8 D, [1 LWarning: deleting signal N252601
5 [& v* i, F: E5 j: I( c) [0 sWarning: deleting signal N150517& L/ ^/ H0 L9 l$ _& x* k
Warning: deleting signal N1889636
% |. Q& ~8 b9 s0 c4 r$ W1 WWarning: deleting signal N1800965% k& O" V' B) d! k
**INPUT WARNINGS FOUND**  `& F- ~8 G0 n- ^; x( O
如果不带value出网络表则没有问题;出网络表的设置如图所示  M, E+ X! ~8 T! |. a$ L+ w& ^
9 `5 {4 r: p; H! ?, V[ 本帖最后由 panhaojie 于 2008-12-7 13:48 编辑 ]
发表于 2008-12-7 17:23 | 只看该作者
ORCAD不能有非法字符。请楼主改一下
 楼主| 发表于 2008-12-7 20:31 | 只看该作者
毒女,非法字符在哪
那为什么不带value出网络表则没有问题;
发表于 2008-12-8 10:12 | 只看该作者
呵呵,比如你的值有空格间距或非法字符,最好用/这样的表示
 楼主| 发表于 2008-12-12 00:04 | 只看该作者
是这么回事
谢谢上面两位
GMT+8, 2025-9-20 15:50 , Processed in 0.140625 second(s), 27 queries , Gzip On.
