2 G0 N' ^& @/ \+ W+ O4 u3 l8 D- P' O+ ?; q7 c# [( c7 B
PART TYPE 不能分配多个原理图封装吗?
5 [0 C4 D7 q2 C; korcad导入pads出错,不可能呀,我小部分原理图都可以,整个原理图就是不行,
& Q6 P% L5 H: D8 U' k* {, \6 ]! B% R6 dReading file -- C:\Documents and Settings\-\桌面\DESIGN2.asc6 [' ^5 c$ y0 f& h7 ~# E& V
*Unspecified or unsupported version of ASCII file3 x6 }. L: z; i5 C
*PADS2000*
) B6 d" P) E+ ^6 r*Bad *PART* ascii data line format* {) c# C8 l9 Z* [! H
C1 3 47UF
* b2 {, O7 r6 r# x4 s*Bad *PART* ascii data line format* G' h5 m; j6 c" A: V' G
C10 1 1041 M" X' O! L! D6 {5 `7 L7 r$ U
- r1 \3 `3 q& E+ H* \+ F I; a' hC11 3 47UF
& U) ]6 |1 y( f, b7 i, n*Bad *PART* ascii data line format
4 n/ ?0 u( v: U* ?# O9 O& `4 {C12 1 104
3 V0 M# d% v! N# M; M* N4 f* s*Bad *PART* ascii data line format* d. v* m" D+ @. y0 |1 V* k7 o& C6 L
C13 1 104
& g1 N. U& u; M0 S q*Bad *PART* ascii data line format# A7 L! M3 A# A A7 p- l6 d
C14 1 1UF
8 g' Z7 l. L0 D5 _. @2 @*Bad *PART* ascii data line format
6 m1 s; e1 q B0 r p! E" l, vC15 1 1UF
9 }3 N# j2 D9 _, D& S4 \*Bad *PART* ascii data line format
Y! g: T, ?6 i- c% xC16 1 1UF
, k7 V; R! t2 M*Bad *PART* ascii data line format
; u6 m( q7 N- J T! tC17 1 104
* N0 C% t! a- l! n3 l3 U; s7 d; z/ L*Bad *PART* ascii data line format0 P$ h- Q( f( M/ X
C18 3 47UF, Z% J" n. Q$ A8 F, Y
*Bad *PART* ascii data line format3 o V1 t& }5 s: G4 \# A
C19 1 1UF9 E p( T8 k' `+ H* V0 V/ l2 d
- x" w( Z( m v. e3 `9 j8 w: tC2 1 104# k7 U" M" S% G$ L; Z: s
出错的提示 |
