查看: 272|回复: 2
单片机矩阵键盘密码锁的仿真加源代码
发表于 2018-12-29 13:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
单片机矩阵键盘密码锁的仿真加源代码
* i. L4 Z) T' O& w, F
, r! s% G& t6 q  w0 H% ^
求大神赐教用矩阵键盘设计的密码锁的仿真+程序  ~6 {: D* L" u# `/ ]: |7 _  D: h
单片机源代码:
8 E, G9 h8 v+ G$ t# n
#include<reg52.h>
6 b3 m* n, T: A7 o) ^0 B' W/ `#define uint unsigned int
" v2 n; r  H$ o' ^#define uchar unsigned char
$ G4 n0 Y- q7 W0 A+ G; o3 g8 W; I& y5 t: G1 J* U
# U0 v& J' ~2 w4 H8 |sbit key1=P3^4;6 m5 w0 G6 n1 C, r- C- Q% x
sbit D1=P1^0;
) o3 f' L8 P2 c& q0 [sbit dula=P2^6;
8 d8 H. L% h$ ~- _+ ^- @sbit wela=P2^7;! G! r/ a) g2 L9 C
void delay(uint z);
, t7 U# F! v4 y. a3 m0 evoid display(uchar num);
5 y+ S, D1 @) M7 fuchar code table[]={- B5 W6 H3 d3 P% y4 c. U6 P
0x3f,0x06,0x5b,0x4f," E) m% R) S* @' \- B3 |8 S
0x66,0x6d,0x7d,0x07,/ Q1 N2 A1 Q# w6 j1 c$ a
0x7f,0x6f,0x77,0x7c,$ G+ S$ u9 P: p- c  F' b# j- b
0x39,0x5e,0x79,0x71};
9 h! A( k: C2 |+ Xuchar temp=0,num=1,temp1;: m+ F9 J9 P0 B! ]& q, x8 B: Y, ~% g( X
8 ~6 ^+ c$ a2 F& V* P2 C
$ Z) K4 I* k1 f1 ~; @7 J+ y4 X2 n+ x
void display(uchar temp1 );" Q' Y3 x* c# J6 @" S; {9 V
void init();2 b6 |) [) c0 M7 O
uchar keyscan();
) r; d, s" P) \/ M/ B4 Y+ Yvoid main()
' m$ w7 N' G, F/ T  ?1 g/ V  q. a' \9 }* u{& m" f0 _( U6 x
        init();
) u0 s# Q, z2 }. Q$ V  `        while(1)
* L5 j* {  B1 x& ~9 J        {
) `! ^6 O! @; c/ n) B% H                 temp1=keyscan();
6 K  [' h, i: e+ ~2 i                display(temp1);5 N6 l# I: Z; {( C
! y! R6 x6 S( Y$ P}: \) ]1 G( f* {* a% z: Q* k7 n
void delay(uint z)
1 V& h6 x1 t$ M4 t{! N( p% f5 J+ w( j0 [, G0 r
        uint x,y;
( n8 f- V- _- h% @  H* i( K% w0 L        for(x=z;x>0;x--)+ V% B9 f& K+ u
7 ]- k3 A" O& N& T                for(y=110;y>0;y--);
* z8 `; v% M4 R        }* }! p) k& I/ i  ?( J4 \
4 H" g0 L1 h5 s# {0 G}
; b; L; u& v5 I/ D9 I: j/ ?9 n" R! N6 N7 W
! X. d+ ^# j2 \4 U8 U$ V( yvoid display(uchar temp1 )
6 z: |2 f% q7 [( h{
, X5 `' P' P" K3 a* X                & ~4 H. }% y# G: g* }, y' Z
                wela=1;
# _5 W$ r# m& a* A3 L                P0=0xfe;
; {' b7 e' o) V; ]9 ?5 V3 y$ P                wela=0;
" o) J3 K' Y& _& R2 d) G$ ~                dula=1;
0 I. i+ b' o+ p, `5 F: T                P0=table[temp1-1];
* N2 \! w/ f" i/ J, T                dula=0;
7 ]$ [. S$ l: F. c* s0 F                delay(10);        : j' ~, S4 z6 ^3 d5 ?
+ l$ e. Y. ~9 E
$ t7 q; V* K* z/ l' D) o0 e
2 i) z/ w% R; U; D1 h, ~9 d) U; t
void init()                  //初始化数码管,
" d4 }  x' s# b7 K$ S% x{
' t5 j. M1 h- h7 c        wela=1;$ o! q$ f* B* |
        P0=0xfe;
2 w% Y1 @' D7 `! W8 W        wela=0;; ?: E( Y: r5 A" a8 F
        dula=1;% b+ S8 P5 A8 I! Y( X4 u! |
        P0=0;
' P. [9 C$ c8 H: s2 a  u. k8 o, X! }( t        dula=0;
& G! e0 D% ]( w}% {. i1 p( N; q% x/ _
" s% ^* p1 Z& e" ^6 Q
8 S5 G  m, M, t- O7 muchar keyscan()
0 Q0 |# O  N, t5 y{
/ G- Q4 V, h- j: K' P: J                P3=0xfe;           //初始化P3口,检测键盘第一行
/ S6 m' K- K' @2 [6 |# j' y                temp=P3;            $ W* l. [# T9 H5 O+ T/ t2 u
                temp=temp&0xf0;    //检测高四位。- G- ?& w& G8 m& E
                while(temp!=0xf0)$ X4 Y) m" O% q9 b) V: z
7 p' e0 P$ S2 {- A, i                         delay(5);                       //消除抖动。1 Q# h0 j8 {* k8 I; z# Y$ Y1 r. L
                         temp=P3;4 T- I6 d; R# G, k* x
( Q& \( o1 Z6 w7 a7 x- e2 p1 J! Q1 B% X                         while(temp!=0xf0)
. s2 m' V2 ~% _% v9 ~8 @: B                         {
" R* D4 F3 f+ V                                 temp=P3;         % o) C5 h* f% x3 w9 f6 ?/ m2 b4 n+ l
                                 switch(temp)
1 f' R. T" _7 Z& E+ K6 A                                {
" G5 Z" g, q' S  o) E                                        case 0xee:num=1;break;1 Z  q! m0 N7 V, |; H9 U0 W
                                        case 0xde:num=2;break;0 d7 @" v; z, b5 w3 [& ^& `# f' T
                                        case 0xbe:num=3;break;
/ T" @4 Z' ^1 T2 y2 N8 u. U                                        case 0x7e:num=4;break;- t) Q" R9 q9 w3 N
6 D2 l& m0 h' c) T& z, ]4 x% ]6 y: O                                while(temp!=0xf0)                 //这就是还处于按住不放,1 q% x, Q& w! u$ V  g- q. J
                                {7 u2 n0 b# M, ?4 [& K- K) v
                                        temp=P3;                                //如果松开了按键,
& L  W' [, c2 f0 v8 f" i                                        temp=temp&0xf0;                        //与后的值将会和0xf0相等。从而跳出while循环
" X4 Y; k3 s& O* F- F+ T1 F/ ~- X                                }
. y; J1 a# @" H% j7 s  U2 o                         }
9 h8 D  }5 c& f6 H# A, H( p5 q                }
2 |8 E; \- U; Y
) t2 m. x+ L2 w+ N: ~: S
' C& ]& g+ z/ [" h                                P3=0xfd;        //初始化P3口,检测键盘第2行: b8 D# _9 j: S2 Y; N9 A
                                temp=P3;//程序版权:51黑电子论坛
8 N! ]5 T1 M2 I6 J8 K                                temp=temp&0xf0;  //检测高四位。
7 r! Y' ^: z# C8 u                                while(temp!=0xf0)
0 R- I% \. D- s' r                                {4 ^" O4 ?# b& {( g9 g
                                         delay(5);2 Q8 N4 q: u" S# ~6 q
                                         temp=P3;
* c. z. V" O* f/ y! h+ ?* ]                                         temp=temp&0xf0;  //检测高四位。
' V( w( j9 Z1 y- i' ?1 ^" f                                         while(temp!=0xf0)
+ \4 }- O& y& B8 p                                         {
2 c6 M* _; h" f9 q6 x                                                 temp=P3;        * W  h2 ]' l4 t% h* [9 W4 h! `
                                                 switch(temp)
9 p, ^. d/ b0 V                                                {
9 G2 }& [5 f- y0 r  t: l                                                        case 0xed:num=5;break;, E0 {7 G. }  X' V" {
                                                        case 0xdd:num=6;break;0 W" i: f0 F% w: l: a) o
                                                        case 0xbd:num=7;break;
( A; M3 M+ }' Z9 T# W" u& f                                                        case 0x7d:num=8;break;
: q* {, [- v4 `/ g' o                                                }
$ P3 b3 D1 T/ h5 R4 j1 N" U. ~  @                                                while(temp!=0xf0)                 //这就是还处于按住不放,; P, N- G, Z+ t2 K$ q( K
                                                {$ H4 e- i7 H' L5 E0 s# Q3 P
                                                        temp=P3;                                //如果松开了按键,
( ^' i' \* X/ J* ]# R                                                        temp=temp&0xf0;                        //与后的值将会和0xf0相等。从而跳出while循环7 M) y& b! D# Z4 e
1 T9 A8 Z7 W, ~" b: [                                         }
0 J9 ?9 C) N* @4 Q1 z, ]                                }" @% A3 q- e& P! w$ `( L0 ~; b, K
; s+ h. K& w, A* @9 j
* s5 Q. @/ p2 G& Q9 |- y& Q/ i" s
                P3=0xfb;        //初始化P3口,检测键盘第3行
) ]1 I$ i. @) y- m/ I                temp=P3;" [: P, a7 g: v* M
                temp=temp&0xf0;  //检测高四位。# q8 y7 O+ i, T
                while(temp!=0xf0)
, {7 S* \5 C; i) C7 c% d9 Q                {
0 e! G) h. G3 v! v                                delay(5);* A% O$ d3 H( ]  h; o& G+ j# c
                                temp=P3;
* g6 [- h' f! |: I9 `4 }! p2 l                                temp=temp&0xf0;  //检测高四位。
$ m; M$ B8 h8 h* J                                while(temp!=0xf0)2 U& N6 F9 u0 U! W8 b" I1 p/ I
! A' [' d) a0 e8 S# @                                        temp=P3;         //````````````% D& [8 H9 v. N, R) n: N
                                         switch(temp). O% U% K" F8 Z. h* E( J
                                        {1 }) ?; e6 W+ R! t* u! G) }- f
                                                case 0xeb:num=9;break;2 Z* f; c5 h1 O+ y/ q# ]. D+ H, J. W; V
                                                case 0xdb:num=10;break;
& T- b9 r# H* Y  Z4 b. u                                                case 0xbb:num=11;break;* b1 y, {! v4 K# j
                                                case 0x7b:num=12;break;0 ]. T3 z) N4 h" L: x9 X
2 G# L) X+ N; r7 {2 z3 C6 H                                        while(temp!=0xf0)                 //这就是还处于按住不放,
6 J& |. A3 \. n. h4 J' D* H                                                {- ~) d* o; e' `; T# G5 k
                                                        temp=P3;                                //如果松开了按键,$ I& U$ E, X0 w9 h: E+ \
& ?  j1 i' L. S! t  J5 c6 t; d                                                }$ X# w) f% v& W3 }9 T: r* e3 ?
                                }$ |: x: T. P4 h- z7 Y
0 Q8 _6 U" ~' N2 G5 G6 E                + p5 d$ ^0 v% l+ L
( ^5 f* \$ e+ N  I& H/ r                        7 |+ {( Y- u6 {$ f
        P3=0xf7;        //初始化P3口,检测键盘第4行9 n6 o3 p/ C6 b9 \3 ?3 f9 E# P
        temp=P3;% ]5 j' D! r) l  a1 m* g* v/ D$ ~
        temp=temp&0xf0;  //检测高四位。4 _, \7 o  B* H' h/ r
        while(temp!=0xf0)  W# b" ^, K/ j; W5 @# q" P
        {  Y* I& n3 g! ]! |. P$ c
                delay(5);
3 a( V/ O4 a* N                temp=P3;/ `& }  q+ e% t5 t: j
; a! {1 m/ U( |( ^5 J9 T                while(temp!=0xf0)# H, d5 z) |' `! s3 v
                {) c# j5 \& e2 T6 t- y7 g
                        temp=P3;         //````````````% @$ _# T+ i* J. K. O- V5 A1 H
                        switch(temp)
8 K( `9 I. K1 W  }: C                        {, @9 I* ]% |' |, r2 @. z, z
                                case 0xe7:num=13;break;
0 r( [: _+ h9 L( A# N                                case 0xd7:num=14;break;
& b2 J. f$ F7 E0 P+ L                                case 0xb7:num=15;break;
0 I' x4 _+ |" m" T5 _/ ^                                case 0x77:num=16;break;
* g( f! [8 ]# x: X4 |                        }7 r( ^! [4 e% W9 a
2 z3 q) S9 W" Q5 b                        {
- U+ k* g3 w( m6 {                                temp=P3;                                //如果松开了按键,% k" ?6 s$ C) l) R
                                temp=temp&0xf0;                        //按位与后的值将会和0xf0相等。从而跳出while循环  e( O6 v. [! O
. o9 \: c' e3 W6 }8 S2 [" Z9 p9 V( A1 G+ _
: s+ z6 {: r3 Z
; b& T" h$ o7 Q$ A6 q+ p…………限于本文篇幅 余下代码请从论坛下载附件…………/ l* B5 S' L, x' n9 o+ C, @
游客,如果您要查看本帖隐藏内容请回复
: Q0 k- O& c; @& f8 B
9 J1 m" M3 m8 x3 r  X
发表于 2019-1-30 15:13 | 只看该作者
看看楼主的代码
GMT+8, 2025-6-19 23:02 , Processed in 0.093750 second(s), 26 queries , Gzip On.
